path: root/arch/powerpc/platforms/fsl_uli1575.c
2007-08-17[POWERPC] Fix interrupt routing and setup of ULI M1575 on FSL boardsKumar Gala
The interrupt routing in the device trees for the ULI M1575 was inproperly using the interrupt line field as pci function. Fixed up the device tree's to actual conform for to specification and changed the interrupt mapping code so it just uses a static mapping setup as follows: PIRQA - IRQ9 PIRQB - IRQ10 PIRQC - IRQ11 PIRQD - IRQ12 USB 1.1 OCHI (1c.0) - IRQ12 USB 1.1 OCHI (1c.1) - IRQ9 USB 1.1 OCHI (1c.2) - IRQ10 USB 1.1 ECHI (1c.3) - IRQ11 LAN (1b.0) - IRQ6 AC97 (1d.0) - IRQ6 Modem (1d.1) - IRQ6 HD Audio (1d.2) - IRQ6 SATA (1f.1) - IRQ5 SMB (1e.1) - IRQ7 PMU (1e.2) - IRQ7 PATA (1f.0) - IRQ14/15 Took the oppurtunity to refactor the code into a single file so we don't have to duplicate these fixes on the two current boards in the tree and several forth coming boards that will also need the code. Fixed RTC support that requires a dummy memory read on the P2P bridge to unlock the RTC and setup the default of the RTC alarm registers to match with a basic x86 style CMOS RTC. Moved code that poked ISA registers to a FIXUP_FINAL quirk to ensure the PCI IO space has been setup properly before we start poking ISA registers at random locations. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
