path: root/arch/powerpc/platforms/pasemi
2008-05-18i2c: Switch pasemi to the new device/driver matching schemeJean Delvare
The old device/driver matching scheme is going away so stop using it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Olof Johansson <olof@lixom.net>
2008-04-21Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits) [POWERPC] Fix compile breakage for 64-bit UP configs [POWERPC] Define copy_siginfo_from_user32 [POWERPC] Add compat handler for PTRACE_GETSIGINFO [POWERPC] i2c: Fix build breakage introduced by OF helpers [POWERPC] Optimize fls64() on 64-bit processors [POWERPC] irqtrace support for 64-bit powerpc [POWERPC] Stacktrace support for lockdep [POWERPC] Move stackframe definitions to common header [POWERPC] Fix device-tree locking vs. interrupts [POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const [POWERPC] Remove unused __max_memory variable [POWERPC] Simplify xics direct/lpar irq_host setup [POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ() [POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade() [POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c [POWERPC] Use asm-generic/bitops/find.h in bitops.h [POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup [POWERPC] 85xx: Fix the size of qe muram for MPC8568E [POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier. [POWERPC] 86xx: mark functions static, other minor cleanups ...
2008-04-16phy: Change mii_bus id field to a stringAndy Fleming
Having the id field be an int was making more complex bus topologies excessively difficult. For now, just convert it to a string, and change all instances of "bus->id = val" to snprintf(id, MII_BUS_ID_LEN, "%x", val). Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-07[POWERPC] pasemi: Minor iommu cleanupOlof Johansson
Clean up the pwrficient iommu code a bit. It was using u32 *-based offsets for registers, which can be a bit confusing when comparing to the manual. Generated binaries from the code is unchanged from before. Signed-off-by: Olof Johansson <olof@lixom.net>
2008-03-05[POWERPC] pasemi: Add function engine management functions to dma_libOlof Johansson
Used to allocate functions for crypto/checksum offload. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2008-03-05[POWERPC] pasemi: Add flag management functions to dma_libOlof Johansson
Add functions to manage the channel syncronization flags to dma_lib Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2008-03-05pasemi_mac: Move RX/TX section enablement to dma_libOlof Johansson
Also stop both rx and tx sections before changing the configuration of the dma device during init. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2008-02-21[POWERPC] pasemi: Register i2c devices at bootOlof Johansson
Setup i2c_board_info based on device tree contents. This has to be a device_initcall since we need PCI to be probed by the time we run it, but before the actual driver is initialized. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-01pasemi: Fix thinko in dma_direct_ops setupOlof Johansson
[POWERPC] pasemi: Fix thinko in dma_direct_ops setup The first patch will just fall through and still set dma_data to a bad value, make it return directly instead. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31POWERPC: Set dma_data correctly for direct_ops on pasemiOlof Johansson
More late-caught fallout from the mainline merge. Commit 35e4a6e26d0c6bc7f32087db61f0fb3666531183 ("[POWERPC] Use archdata.dma_data in dma_direct_ops and add the offset") claimed "Now that all platforms using dma_direct_offset setup the archdata.dma_data correctly, ..." ..but nope -- the pasemi iommu setup code that disables translation on the DMA pci device didn't set dma_data correctly. This fixes it. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31Merge branch 'linux-2.6'Paul Mackerras
2008-01-28pasemi: export pasemi_dma_init()Olof Johansson
Forgot to export this one. Needed when pasemi_mac is compiled as a module. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28pasemi: DMA engine management libraryOlof Johansson
pasemi: DMA engine management library Introduce a DMA management library to manage the various DMA resources on the PA Semi SoCs. Since several drivers need to allocate these shared resources, provide some abstractions as well as allocation/free functions for channels, etc. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-15[POWERPC] pasemi: Move electra-ide to pata_of_platformOlof Johansson
Move electra-ide glue over to the new pata_of_platform framework, and add the quirks needed to that driver. Signed-off-by: Olof Johansson <olof@lixom.net>
2008-01-02[POWERPC] pasemi: Use machine_*_initcall() hooks in platform codeGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Olof Johansson <olof@lixom.net>
2008-01-02[POWERPC] pasemi: Fix NMI handling checkOlof Johansson
The logic that checks to see if a machine check is caused by an NMI will always match when NMI hasn't been initialized, since the mpic routine will return NO_IRQ (and that's what the nmi_virq value is as well). Signed-off-by: Olof Johansson <olof@lixom.net>
2007-12-28[POWERPC] pasemi: Distribute interrupts evenly across cpusOlof Johansson
By default the OpenPIC on PWRficient will bias to one core (since that will improve changes of the other core being able to stay idle/powered down). However, this conflicts with most irq load balancing schemes, since setting an interrupt to be delivered to either core doesn't really result in the load being shared. It also doesn't work well with the soft irq disable feature of PPC, since EE will stay on until the first interrupt is taken while soft disabled. Set the gconf0 config bit that enables even distribution of interrupts among the two cores. Signed-off-by: Olof Johansson <olof@lixom.net>
2007-12-28[POWERPC] pasemi: Implement NMI supportOlof Johansson
Some PWRficient-based boards have a NMI button that's wired up to a GPIO as interrupt source. By configuring the openpic accordingly, these get delivered as a machine check with high priority, instead of as an external interrupt. The device tree contains a property "nmi-source" in the openpic node for these systems, and it's the (hwirq) source for the input. Also, for these interrupts, the IACK is read from another register than the regular (MCACK instead), but they are EOI'd as usual. So implement said function for the mpic driver. Finally, move a couple of external function defines to include/ instead of local under sysdev. Being able to mask/unmask and eoi directly saves us from setting up a dummy irq handler that will never be called. Signed-off-by: Olof Johansson <olof@lixom.net>
2007-12-21[POWERPC] Make non-PCI build work againStephen Rothwell
Maple and pasemi both require PCI as does CONFIG_OF_PLATFORM_PCI. The default setting of CONFIG_ISA_DMA_API is set to match the protection around the relevant routines in asm/dma.h. I also had to remove the PMAC platform from the combined build. The precis is that to build a 64 bit kernel with no PCI, you can only include pSeries and iSeries. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] pasemi: Implement MSI supportOlof Johansson
Implement MSI support for PA Semi PWRficient platforms. MSI is done through a special range of sources on the openpic controller, and they're unfortunately breaking the usual concepts of how sources are programmed: * The source is calculated as 512 + the value written into the MSI register * The vector for this source is added to the source and reported through IACK This means that for simplicity, it makes much more sense to just set the vector to 0 for the source, since that's really the vector we expect to see from IACK. Also, the affinity/priority registers will affect 16 sources at a time. To avoid most (simple) users from being limited by this, allocate 16 sources per device but use only one. This means that there's a total of 32 sources. If we get usage scenarions that need more sources, the allocator should probably be revised to take an alignment argument and size, not just do natural alignment. Finally, since I'm already touching the MPIC names on pasemi, rename the base one from the somewhat odd " PAS-OPIC " to "PASEMI-OPIC". Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-11[POWERPC] Use SLB size from the device treeMichael Neuling
Currently we hardwire the number of SLBs to 64, but PAPR says we should use the ibm,slb-size property to obtain the number of SLB entries. This uses this property instead of assuming 64. If no property is found, we assume 64 entries as before. This soft patches the SLB handler, so it shouldn't change performance at all. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-06[POWERPC] Clean out asm/of_{platform, device}.hJon Loeliger
Convert #include of asm/of_{platform, device}.h into linux/of_{platform,device}.h for a few scattered platforms. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-03[POWERPC] pasemi: Fix module information for gpio-mdioOlof Johansson
Fix up the module information for gpio-mdio, it wouldn't load because of lacking license, and wouldn't auto-load because of missing MODULE_DEVICE_TABLE. Signed-off-by: Olof Johansson <olof@lixom.net>
2007-12-01[POWERPC] pasemi: Move cpus to hold loop before restartOlof Johansson
Use smp_send_stop() to move all cpus besides the one executing reboot into a hold loop, to keep them from being in powersavings mode at the time of reboot. Signed-off-by: Olof Johansson <olof@lixom.net>
2007-12-01[POWERPC] pasemi: Don't enter powersaving states from elevated astatesOlof Johansson
When the PWRficient cpus are entered into powersavings states, the astate is automatically dropped down to 0. While we still restore it when we come out of idle, it can still cause some weird effects with respect to performance (especially since it takes a while to ramp up to higher astates). So, to avoid this, don't enter power savings when the cpufreq driver (or user) has set higher astates than 0. The restore is still required, since there's a chance the astate has been raised from the other cpu while the idling one was asleep. Signed-off-by: Olof Johansson <olof@lixom.net>
2007-11-29[POWERPC] pasemi: Broaden specific references to 1682MOlof Johansson
There will be more product numbers in the future than just PA6T-1682M, but they will share much of the features. Remove some of the explicit references and compatibility checks with 1682M, and replace most of them with the more generic term "PWRficient". Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Michael Buesch <mb@bu3sch.de> Acked-by: Doug Thompson <dougthompson@xmission.com>
2007-11-29[POWERPC] pasemi: clean up mdio_gpio a bitOlof Johansson
Misc cleanups of mdio_gpio: * Better error handling/unrolling in case of init/alloc failures * Go through child nodes and get their interrupts instead of using hardcoded values * Remap the GPIO registers at module load/driver init instead of during probe * Coding style and other misc cleanups Signed-off-by: Olof Johansson <olof@lixom.net>
2007-11-19[POWERPC] pasemi: Don't reset mpic at bootOlof Johansson
Due to an erratum, we don't want to reset the mpic at boot time. It can sometimes cause problems with lost interrupts later on while running. Signed-off-by: Olof Johansson <olof@lixom.net>
2007-10-17pcmcia: CompactFlash driver for PA Semi Electra boardsOlof Johansson
Driver for the CompactFlash slot on the PA Semi Electra eval board. It's a simple device sitting on localbus, with interrupts and detect/voltage control over GPIO. The driver is implemented as an of_platform driver, and adds localbus as a bus being probed by the of_platform framework. [akpm@linux-foundation.org: cleanups] [olof@lixom.net: fix build] Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Christoph Hellwig <hch@infradead.org> Cc: Milton Miller <miltonm@bga.com> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Don't take semaphore in cpufreq_quick_get() [CPUFREQ] Support different families in fid/did to frequency conversion [CPUFREQ] cpufreq_stats: misc cpuinit section annotations [CPUFREQ] implement !CONFIG_CPU_FREQ stub for cpufreq_unregister_notifier() [CPUFREQ] mark hotplug notifier callback as __cpuinit [CPUFREQ] Only check for transition latency on problematic governors (kconfig fix) [CPUFREQ] allow ondemand and conservative cpufreq governors to be used as default [CPUFREQ] move policy's governor initialisation out of low-level drivers into cpufreq core [CPUFREQ] Longhaul - Add support for PM133 northbridge [CPUFREQ] x86: use num_online_nodes to get physical cpus numbers for
2007-10-11Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (408 commits) [POWERPC] Add memchr() to the bootwrapper [POWERPC] Implement logging of unhandled signals [POWERPC] Add legacy serial support for OPB with flattened device tree [POWERPC] Use 1TB segments [POWERPC] XilinxFB: Allow fixed framebuffer base address [POWERPC] XilinxFB: Add support for custom screen resolution [POWERPC] XilinxFB: Use pdata to pass around framebuffer parameters [POWERPC] PCI: Add 64-bit physical address support to setup_indirect_pci [POWERPC] 4xx: Kilauea defconfig file [POWERPC] 4xx: Kilauea DTS [POWERPC] 4xx: Add AMCC Kilauea eval board support to platforms/40x [POWERPC] 4xx: Add AMCC 405EX support to cputable.c [POWERPC] Adjust TASK_SIZE on ppc32 systems to 3GB that are capable [POWERPC] Use PAGE_OFFSET to tell if an address is user/kernel in SW TLB handlers [POWERPC] 85xx: Enable FP emulation in MPC8560 ADS defconfig [POWERPC] 85xx: Killed <asm/mpc85xx.h> [POWERPC] 85xx: Add cpm nodes for 8541/8555 CDS [POWERPC] 85xx: Convert mpc8560ads to the new CPM binding. [POWERPC] mpc8272ads: Remove muram from the CPM reg property. [POWERPC] Make clockevents work on PPC601 processors ... Fixed up conflict in Documentation/powerpc/booting-without-of.txt manually.
2007-10-11[POWERPC] Move of_platform_driver initialisations: arch/powerpcStephen Rothwell
We no longer initialise the name and owner fields of the of_platform_driver, but use the fields of the embedded device_driver's name field instead. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-10pasemi_mac: enable iommu supportOlof Johansson
pasemi_mac: enable iommu support Enable IOMMU support for pasemi_mac, but avoid using it on non-partitioned systems for performance reasons. The user can override this by selecting the PPC_PASEMI_IOMMU_DMA_FORCE configuration option. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-04[CPUFREQ] move policy's governor initialisation out of low-level drivers ↵Thomas Renninger
into cpufreq core Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2007-09-14[POWERPC] Add workaround for MPICs with broken register readsOlof Johansson
Some versions of PWRficient 1682M have an interrupt controller in which the first register in each pair for interrupt sources doesn't always read with the right polarity/sense values. To work around this, keep a software copy of the register instead. Since it's not modified from the mpic itself, it's a feasible solution. Still, keep it under a config option to avoid wasting memory on other platforms. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-09-14[POWERPC] pasemi: Move pasemi_idle_init() to late_initcall()Olof Johansson
Move pasemi_idle_init() to be a late_initcall instead of being called from setup_arch(). This way the cpufreq driver has a chance to initialize and save away the boot time astate before we go to idle for the first time. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-09-14[POWERPC] pasemi: Print more information at machine checkOlof Johansson
Add printout of some SoC error status registers, and dump the SLB contents for those machine check events where it makes sense. Since we can't go about and ioremap registers at machine check time, and we generally want to do as little as possible to print out the information, pre-build a table of the registers to dump and their address in the common PCI config space range. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-09-14[POWERPC] pasemi: Add workaround for erratum 5945Olof Johansson
Erratum 5945 causes some of the registers on the PCIe root ports to not read correctly. Do a small dance to avoid this: Write an unused register, read the value and write it back. Thankfully this is not in a hot code path. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-09-14[POWERPC] pasemi: Add pasemi_pci_getcfgaddr()Olof Johansson
Add pasemi_pci_getcfgaddr(), to get the remapped address of a specific config register for a PCI device. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-28Merge branch 'linux-2.6' into for-2.6.24Paul Mackerras
2007-08-25[POWERPC] pasemi: Another IOMMU bugfix for 64K PAGE_SIZEOlof Johansson
More fallout from the switch from PAGE_SIZE based IOMMU to the native page size for the driver. By pure luck it happened to work most of the time, since we end up invalidating the wrong entries in the TLB. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-22[POWERPC] Rework SMP timebase handoff for pasemiOlof Johansson
Rework timebase handoff to play nice with configurations with more than 2 cores, as well as with CPU hotplug. Previous scheme just pushed out the current timebase from the giving core to all cores without caring if they wanted it or not, nor checking if they'd taken it. The taking side didn't make sure the giving side had provided a value yet either. In other words, it was completely broken. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-17[POWERPC] Fix section mismatch in pasemi/iommu.cStephen Rothwell
These functions are only called by __init functions. WARNING: vmlinux.o(.text+0x56aa0): Section mismatch: reference to .init.text:.lmb_alloc (between '.iob_init' and '.iommu_init_early_pasemi') Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-17[POWERPC] Remove gratuitous reads from pasemi pci config space methodsNathan Lynch
The pasemi pci configuration space write method reads the written location immediately after the write is performed, presumably in order to flush the write. However, configuration space writes are not allowed to be posted, making these reads gratuitous. Furthermore, this behavior potentially causes us to violate the PCI PM spec when changing between e.g. D0 and D3 states, because a delay of up to 10ms may be required before the OS accesses configuration space after the write which initiates the transition. Remove the unnecessary reads from pa_pxp_write_config. Signed-off-by: Nathan Lynch <ntl@pobox.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-17[POWERPC] pa_pxp_ops: Use named structure member initializersNathan Lynch
2007-07-10[POWERPC] pasemi: Don't auto-select CONFIG_EMBEDDEDOlof Johansson
Disable auto-select of CONFIG_EMBEDDED. ELECTRA_IDE selects PATA_PLATFORM which should be sufficient. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-10[POWERPC] pasemi: Rename platformOlof Johansson
Rename the pasemi platform to "pasemi" to be in line with the platform's directory name. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-29[POWERPC] rename add_bridge to avoid namespace clashesArnd Bergmann
Many platforms currently define their own add_bridge function, some of them globally. This breaks some multiplatform configurations. Prefixing each of these functions with the platform name avoids this problem. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2007-06-25[POWERPC] pasemi: Electra IDE/pata_platform glueOlof Johansson
Glue code to hook up the pata_platform on the PA Semi Electra eval board. CFE sets up device tree entries for the IDE interface, with device type 'ide' and compatible field 'electra-ide'. We unfortunately need to modify the resources before calling the generic platform driver, since the device tree only has one register window in it and the driver expects two. Adding this as an of_platform driver instead doesn't give us any benefit, it just adds one more layer of register/probe functions. Since CONFIG_PATA_PLATFORM depends on CONFIG_EMBEDDED, add that as a default for PPC_PASEMI. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-14[POWERPC] Rewrite IO allocation & mapping on powerpc64Benjamin Herrenschmidt
This rewrites pretty much from scratch the handling of MMIO and PIO space allocations on powerpc64. The main goals are: - Get rid of imalloc and use more common code where possible - Simplify the current mess so that PIO space is allocated and mapped in a single place for PCI bridges - Handle allocation constraints of PIO for all bridges including hot plugged ones within the 2GB space reserved for IO ports, so that devices on hotplugged busses will now work with drivers that assume IO ports fit in an int. - Cleanup and separate tracking of the ISA space in the reserved low 64K of IO space. No ISA -> Nothing mapped there. I booted a cell blade with IDE on PIO and MMIO and a dual G5 so far, that's it :-) With this patch, all allocations are done using the code in mm/vmalloc.c, though we use the low level __get_vm_area with explicit start/stop constraints in order to manage separate areas for vmalloc/vmap, ioremap, and PCI IOs. This greatly simplifies a lot of things, as you can see in the diffstat of that patch :-) A new pair of functions pcibios_map/unmap_io_space() now replace all of the previous code that used to manipulate PCI IOs space. The allocation is done at mapping time, which is now called from scan_phb's, just before the devices are probed (instead of after, which is by itself a bug fix). The only other caller is the PCI hotplug code for hot adding PCI-PCI bridges (slots). imalloc is gone, as is the "sub-allocation" thing, but I do beleive that hotplug should still work in the sense that the space allocation is always done by the PHB, but if you unmap a child bus of this PHB (which seems to be possible), then the code should properly tear down all the HPTE mappings for that area of the PHB allocated IO space. I now always reserve the first 64K of IO space for the bridge with the ISA bus on it. I have moved the code for tracking ISA in a separate file which should also make it smarter if we ever are capable of hot unplugging or re-plugging an ISA bridge. This should have a side effect on platforms like powermac where VGA IOs will no longer work. This is done on purpose though as they would have worked semi-randomly before. The idea at this point is to isolate drivers that might need to access those and fix them by providing a proper function to obtain an offset to the legacy IOs of a given bus. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
