via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The non-debug case in ps3/mm.c uses pr_debug(), so that the compiler
still does type checks etc. and doesn't complain about unused
variables in the non-debug case.
However with DEBUG=n and CONFIG_DYNAMIC_DEBUG=y there's still code
generated for those pr_debugs().
size before:
17553 4112 88 21753 54f9 arch/powerpc/platforms/ps3/mm.o
size after:
7377 776 88 8241 2031 arch/powerpc/platforms/ps3/mm.o
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Acked-by: Geoff Levand <geoffrey.levand@am.sony.com>
As <asm/iommu.h> doesn't contain any other hardware specific definitions
but only interfaces.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
It reports the failure of a call to lv1_put_iopte(), not
lv1_map_device_dma_region().
Cc: Geoff Levand <geoffrey.levand@am.sony.com>
Both arch/powerpc/platforms/cell/iommu.c and arch/powerpc/platforms/ps3/mm.c
contain the same Cell IOMMU page table entry definitions. Extract them and move
them to <asm/iommu.h>, while adding a CBE_ prefix.
This also allows them to be used by drivers.
To help users diagnose hotpug memory problems, change the
printing of memory hotplug errors from DBG() to pr_err().
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Change the PS3 hotplug memory routine ps3_mm_add_memory() from
a core_initcall to a device_initcall.
core_initcall routines run before the powerpc topology_init()
startup routine, which is a subsys_initcall, resulting in
failure of ps3_mm_add_memory() when CONFIG_NUMA=y. When
ps3_mm_add_memory() fails the system will boot with just the
128 MiB of boot memory
Fixes compiler warnings:
arch/powerpc/platforms/ps3/mm.c:1205: warning: passing argument 2 of 'ps3_repository_read_mm_info' from incompatible pointer type
arch/powerpc/platforms/ps3/mm.c:1205: warning: passing argument 3 of 'ps3_repository_read_mm_info' from incompatible pointer type
We just fix up the reference parameters as the others are dealt with by
arithmetic promotion rules and don't cause warnings.
This removes warnings like this:
arch/powerpc/platforms/ps3/interrupt.c:327: warning: passing argument 1 of 'lv1_construct_event_receive_port' from incompatible pointer type
Also, these:
drivers/ps3/ps3-vuart.c:462: warning: passing argument 4 of 'ps3_vuart_raw_read' from incompatible pointer type
drivers/ps3/ps3-vuart.c:592: warning: passing argument 4 of 'ps3_vuart_raw_read' from incompatible pointer type
Push the dma_addr_t type usage all the way down to where the actual
values are manipulated.
Now that u64 is "unsigned long long", this removes warnings like:
arch/powerpc/platforms/ps3/system-bus.c:532: warning: passing argument 4 of 'ps3_dma_map' from incompatible pointer type
arch/powerpc/platforms/ps3/system-bus.c:649: warning: passing argument 4 of 'ps3_dma_map' from incompatible pointer type
Change the debug message in dma_sb_region_create() from
pr_info() to DBG() to quiet the dmesg output.
A change was made to walk_memory_resource() in commit
4b119e21d0c66c22e8ca03df05d9de623d0eb50f that added a
check of find_lmb(). Add the coresponding lmb_add()
call to ps3_mm_add_memory() so that that check will
succeed.
This fixes the condition where the PS3 boots up with
only the 128 MiB of boot memory, and doesn't see the
other 128MiB that is available.
Remove the PS3 workaround needed to support sparsemem SPU mappings.
The SPU mappings no longer use sparsemem, so this workaround is no
longer needed.
Change the PS3 bus_id and dev_id from type unsigned int to u64. These
IDs are 64-bit in the repository, and the special storage notification
device has a device ID of ULONG_MAX.
Add support to build the PS3 flash rom image and remove some unneeded
lmb calls.
The PS3's lv1 loader supports loading gzipped binary images from flash
rom to addr zero. The loader enters the image at addr 0x100.
In this implementation a bootwrapper overlay is use to arrange for the
kernel to be loaded to addr zero and to have a suitable bootwrapper
entry at 0x100. To construct the rom image, 0x100 bytes from offset
0x100 in the kernel is copied to the bootwrapper symbol
__system_reset_kernel. The 0x100 bytes at the bootwrapper symbol
__system_reset_overlay is then copied to offset 0x100. At runtime the
bootwrapper program copies the 0x100 bytes at __system_reset_kernel to
addr 0x100.
zImage.ps3 is a wrapped image that contains a flat device tree, an lv1
compatible entry point, and an optional initrd. otheros.bld is the gzip
compresed rom image built from zImage.ps3. otheros.bld is suitable for
programming into the PS3 boot flash memory.
Fix some PS3 build warnings reported by `make C=1'.
Rework the PS3 system bus to unify device support.
- DMA region sizes must be a power of two
- storage bus DMA updates:
- Small fixes for the PS3 DMA core:
o fix alignment bug
o kill superfluous test
o indentation
o spelling
o export ps3_dma_region_{create,free}()
- ps3_dma_region_init():
o Add `addr' and `len' parameters, so you can create a DMA region that
does not cover all memory (use `NULL' and `0' to cover all memory).
This is needed because there are not sufficient IOMMU resources to have
all DMA regions cover all memory.
o Uninline
- Added remove and shutdown routines to all drivers.
- Added loadable module support to all drivers.
- Added HV calls for iopte management (needed by sound driver).
Signed-off-by: MOKUNO Masakazu <mokuno@sm.sony.co.jp>
Simplify the PS3 definition of DBG.
A minor change to remove a duplicate variable assignement in ps3_mm_shutdown();
Add missing checks to PS3 specific drivers ps3av and sys-manager to verify that
we are actually running on a PS3 (pointed out by Arnd).
Correct existing checks in other subsystems/drivers to return -ENODEV instead
of zero.
Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
Move the PS3 system bus routines from drivers/ps3 to
arch/powerpc/platforms/ps3.
Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
A few code paths need to check whether or not they are running
on the PS3's LV1 hypervisor before making hcalls. This introduces
a new firmware feature bit for this, FW_FEATURE_PS3_LV1.
Now when both PS3 and IBM_CELL_BLADE are enabled, but not PSERIES,
FW_FEATURE_PS3_LV1 and FW_FEATURE_LPAR get enabled at compile time,
which is a bug. The same problem can also happen for (PPC_ISERIES &&
!PPC_PSERIES && PPC_SOMETHING_ELSE). In order to solve this, I
introduce a new CONFIG_PPC_NATIVE option that is set when at least
one platform is selected that can run without a hypervisor and then
turns the firmware feature check into a run-time option.
The new cell oprofile support that was recently merged does not
work on hypervisor based platforms like the PS3, therefore make
it depend on PPC_CELL_NATIVE instead of PPC_CELL. This may change
if we get oprofile support for PS3.
Adds the core platform support for the PS3 game console and other devices
using the PS3 hypervisor.
