path: root/arch/powerpc/platforms/pseries/dlpar.c
2010-09-02powerpc/pseries: Correct rtas_data_buf locking in dlpar codeNathan Fontenot
The dlpar code can cause a deadlock to occur when making the RTAS configure-connector call. This occurs because we make kmalloc calls, which can block, while parsing the rtas_data_buf and holding the rtas_data_buf_lock. This an cause issues if someone else attempts to grab the rtas_data_bug_lock. This patch alleviates this issue by copying the contents of the rtas_data_buf to a local buffer before parsing. This allows us to only hold the rtas_data_buf_lock around the RTAS configure-connector calls. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-31powerpc: ONLINE to OFFLINE CPU state transition during removalRobert Jennings
If a CPU remove is attempted using the 'release' interface on hardware which supports extended cede, the CPU will be put in the INACTIVE state rather than the OFFLINE state due to the default preferred_offline_state in that situation. In the INACTIVE state it will fail to be removed. This patch changes the preferred offline state to OFFLINE when an CPU is in the ONLINE state. After cpu_down() is called in dlpar_offline_cpu() the CPU will be OFFLINE and CPU removal can continue. Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-04-07powerpc/pseries/dlpar: Use kasprintfJulia Lawall
kasprintf combines kmalloc and sprintf, and takes care of the size calculation itself. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression a,flag; expression list args; statement S; @@ a = - \(kmalloc\|kzalloc\)(...,flag) + kasprintf(flag,args) <... when != a if (a == NULL || ...) S ...> - sprintf(a,args); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-04-07powerpc/pseries/dlpar: Eliminate use after freeJulia Lawall
dlpar_free_cc_nodes frees its argument, so dlpar_online_cpu should not be called on the same value. Skip over the call to dlpar_online_cpu by jumping directly to out. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E,E2; @@ dlpar_free_cc_nodes(E) ... ( E = E2 | * E ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-15powerpc: Move cpu hotplug driver lock from pseries to powerpcNathan Fontenot
Move the defintion and lock helper routines for the cpu hotplug driver lock from pseries to powerpc code to avoid build breaks for platforms other than pseries that use cpu hotplug. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Acked-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-01-15powerpc/pseries: Fix dlpar compile warning without CONFIG_PROC_DEVICETREEFUJITA Tomonori
cc1: warnings being treated as errors arch/powerpc/platforms/pseries/dlpar.c: In function 'dlpar_attach_node': arch/powerpc/platforms/pseries/dlpar.c:239: error: unused variable 'ent' arch/powerpc/platforms/pseries/dlpar.c: In function 'dlpar_detach_node': arch/powerpc/platforms/pseries/dlpar.c:271: error: unused variable 'prop' arch/powerpc/platforms/pseries/dlpar.c:270: error: unused variable 'parent' make[3]: *** [arch/powerpc/platforms/pseries/dlpar.o] Error 1 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-18powerpc/pseries: Make declarations of cpu_hotplug_driver_lock() ANSI compatible.Gautham R Shenoy
And add the __acquires() and __releases() annotations, while at it. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-09powerpc/pseries: Correct pseries/dlpar.c build break without CONFIG_SMPNathan Fontenot
The recent patch to add cpu offline/online as part of the DLPAR process for pseries causes a build break if CONFIG_SMP is not defined. Original patch here; http://lists.ozlabs.org/pipermail/linuxppc-dev/2009-November/078299.html This corrects the build break by moving the online_node_cpus and offline_node_cpus under the #ifdef CONFIG_ARCH_CPU_PROBE_RELEASE portions of dlpar.c. This patch also slightly modifies the online_node_cpus and offline_node_cpus routines to prepend dlpar_ to the them and make them static. These two routine are only used in the dlpar add/remove of cpus and these changes should help clarify that. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-09powerpc/pseries: Serialize cpu hotplug operations during deactivate Vs ↵Gautham R Shenoy
deallocate Currently the cpu-allocation/deallocation process comprises of two steps: - Set the indicators and to update the device tree with DLPAR node information. - Online/offline the allocated/deallocated CPU. This is achieved by writing to the sysfs tunables "probe" during allocation and "release" during deallocation. At the sametime, the userspace can independently online/offline the CPUs of the system using the sysfs tunable "online". It is quite possible that when a userspace tool offlines a CPU for the purpose of deallocation and is in the process of updating the device tree, some other userspace tool could bring the CPU back online by writing to the "online" sysfs tunable thereby causing the deallocate process to fail. The solution to this is to serialize writes to the "probe/release" sysfs tunable with the writes to the "online" sysfs tunable. This patch employs a mutex to provide this serialization, which is a no-op on all architectures except PPC_PSERIES Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Acked-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-09pseries/pseries: Add code to online/offline CPUs of a DLPAR nodeGautham R Shenoy
Currently the cpu-allocation/deallocation on pSeries is a two step process from the Userspace. - Set the indicators and update the device tree by writing to the sysfs tunable "probe" during allocation and "release" during deallocation. - Online / Offline the CPUs of the allocated/would_be_deallocated node by writing to the sysfs tunable "online". This patch adds kernel code to online/offline the CPUs soon_after/just_before they have been allocated/would_be_deallocated. This way, the userspace tool that performs DLPAR operations would only have to deal with one set of sysfs tunables namely "probe" and release". Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Acked-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-09powerpc/pseries: Add kernel based CPU DLPAR handlingNathan Fontenot
This patch adds the specific routines to probe and release (add and remove) cpu resource for the powerpc pseries platform and registers these handlers with the ppc_md callout structure. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-09powerpc/pseries: Kernel DLPAR InfrastructureNathan Fontenot
The Dynamic Logical Partitioning capabilities of the powerpc pseries platform allows for the addition and removal of resources (i.e. CPU's, memory, and PCI devices) from a partition. The removal of a resource involves removing the resource's node from the device tree and then returning the resource to firmware via the rtas set-indicator call. To add a resource, it is first obtained from firmware via the rtas set-indicator call and then a new device tree node is created using the ibm,configure-coinnector rtas call and added to the device tree. This patch provides the kernel DLPAR infrastructure in a new filed named dlpar.c. The functionality provided is for acquiring and releasing a resource from firmware and the parsing of information returned from the ibm,configure-connector rtas call. Additionally this exports the pSeries reconfiguration notifier chain so that it can be invoked when device tree updates are made. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
