The patch moves the common part of EEH core into arch/powerpc/kernel
directory so that we needn't PPC_PSERIES while compiling POWERNV
platform:
* Move the EEH common part into arch/powerpc/kernel
* Move the functions for PCI hotplug from pSeries platform to
arch/powerpc/kernel/pci-hotplug.c
* Move CONFIG_EEH from arch/powerpc/platforms/pseries/Kconfig to
arch/powerpc/platforms/Kconfig
* Adjust makefile accordingly
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
Cleanup on EEH core to remove unnecessary whitespaces.
The EEH core is talking with the PCI device driver to determine the
action (purely reset, or PCI device removal). During the period, the
driver might be unloaded and in turn causes kernel crash as follows:
EEH: Detected PCI bus error on PHB#4-PE#10000
EEH: This PCI device has failed 3 times in the last hour
lpfc 0004:01:00.0: 0:2710 PCI channel disable preparing for reset
Unable to handle kernel paging request for data at address 0x00000490
Faulting instruction address: 0xd00000000e682c90
cpu 0x1: Vector: 300 (Data Access) at [c000000fc75ffa20]
pc: d00000000e682c90: .lpfc_io_error_detected+0x30/0x240 [lpfc]
lr: d00000000e682c8c: .lpfc_io_error_detected+0x2c/0x240 [lpfc]
sp: c000000fc75ffca0
msr: 8000000000009032
dar: 490
dsisr: 40000000
current = 0xc000000fc79b88b0
paca = 0xc00000000edb0380 softe: 0 irq_happened: 0x00
pid = 3386, comm = eehd
enter ? for help
[c000000fc75ffca0] c000000fc75ffd30 (unreliable)
[c000000fc75ffd30] c00000000004fd3c .eeh_report_error+0x7c/0xf0
[c000000fc75ffdc0] c00000000004ee00 .eeh_pe_dev_traverse+0xa0/0x180
[c000000fc75ffe70] c00000000004ffd8 .eeh_handle_event+0x68/0x300
[c000000fc75fff00] c0000000000503a0 .eeh_event_handler+0x130/0x1a0
[c000000fc75fff90] c000000000020138 .kernel_thread+0x54/0x70
1:mon>
The patch increases the reference of the corresponding driver modules
while EEH core does the negotiation with PCI device driver so that the
corresponding driver modules can't be unloaded during the period and
we're safe to refer the callbacks.
Cc: stable@vger.kernel.org
Reported-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Function eeh_rmv_from_parent_pe() could be called by the path of
either normal PCI hotplug, or EEH recovery. For the former case,
we need purge the corresponding PE on removal of the associated
PE bus.
The patch tries to cover that by passing more information to function
pcibios_remove_pci_devices() so that we know if the corresponding PE
needs to be purged or be marked as "invalid".
The patch removes the eeh related statistics for eeh device since
they have been maintained by the corresponding eeh PE. Also, the
flags used to trace the state of eeh device and PE have been reworked
for a little bit.
The patch reworks the current implementation so that the eeh errors
will be handled basing on PE instead of eeh device.
The original EEH implementation is heavily depending on struct pci_dn.
We have to put EEH related information to pci_dn. Actually, we could
split struct pci_dn so that the EEH sensitive information to form an
individual struct, then EEH looks more independent.
The patch replaces pci_dn with eeh_dev for EEH aux components like
event and driver. Also, the eeh_event struct has been adjusted for
a little bit since eeh_dev has linked the associated FDT (Flat Device
Tree) node and PCI device. It's not necessary for eeh_event struct to
trace FDT node and PCI device. We can just simply to trace eeh_dev in
eeh_event.
The patch also renames function pcid_name() to eeh_pcid_name(), which
should be missed in the previous patch where the EEH aux components
have been cleaned up.
There're several EEH aux components and the patch does some cleanup
for them so that they look more clean.
* Duplicated comments have been removed from the header file.
* Comments have been reorganized so that it looks more clean.
* The leading comments of functions are adjusted for a little
bit so that the result of "make pdfdocs" would be more
unified.
* Function calls "xxx ()" has been replaced by "xxx()".
In order to enable particular PCI device, which has been included
in the parent PE. The involved PCI bridges should be enabled explicitly
if there has. On pSeries platform, there're dedicated RTAS calls
to fulfil the purpose.
The patch implements the function of configuring PCI bridges through
the dedicated RTAS calls. Besides, the function has been abstracted
by struct eeh_ops::configure_bridge so that the EEH core components
could support multiple platforms in future.
On RTAS compliant pSeries platform, one dedicated RTAS call has
been introduced to retrieve EEH temporary or permanent error log.
The patch implements the function of retriving EEH error log through
RTAS call. Besides, it has been abstracted by struct eeh_ops::get_log
so that EEH core components could support multiple platforms in future.
On pSeries platform, the PE state might be temporarily unavailable.
In that case, the firmware will return the corresponding wait time.
That means the kernel has to wait for appropriate time in order to
get the PE state.
The patch does the implementation for that. Besides, the function
has been abstracted through struct eeh_ops::wait_state so that EEH core
On pSeries platform, there're 2 dedicated RTAS calls introduced to
retrieve the corresponding PE's state: ibm,read-slot-reset-state and
ibm,read-slot-reset-state2.
The patch implements the retrieval of PE's state according to the
given PE address. Besides, the implementation has been abstracted by
struct eeh_ops::get_state so that EEH core components could support
There're 4 EEH operations that are covered by the dedicated RTAS
call <ibm,set-eeh-option>: enable or disable EEH, enable MMIO and
enable DMA. At early stage of system boot, the EEH would be tried
to enable on PCI device related device node. MMIO and DMA for
particular PE should be enabled when doing recovery on EEH errors
so that the PE could function properly again.
The patch implements it and abstract that through struct
eeh_ops::set_eeh. It would be help for EEH to support multiple
The EEH has been implemented on pSeries platform. The original
code looks a little bit nasty. The patch does cleanup on the
current EEH implementation so that it looks more clean.
* Try adding prefix "eeh" for functions.
* Some function names have been adjusted so that they looks
shorter and meaningful.
For adapters which have devices under a PCIe switch/bridge it is informative
to display information for both the PCIe switch/bridge and the device on
which the bus error was detected.
rebased to powerpc-next
Signed-off-by: Richard A Lary <rlary@linux.vnet.ibm.com>
During a EEH recover, the pci_dev structure can be null, mainly if an
eeh event is detected during cpi config operation. In this case, the
pci_dev will not be known (and will be null) the kernel will crash
with the following message:
Unable to handle kernel paging request for data at address 0x000000a0
Faulting instruction address: 0xc00000000006b8b4
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c00000000006b8b4] .eeh_event_handler+0x10c/0x1a0
LR [c00000000006b8a8] .eeh_event_handler+0x100/0x1a0
Call Trace:
[c0000003a80dff00] [c00000000006b8a8] .eeh_event_handler+0x100/0x1a0
[c0000003a80dff90] [c000000000031f1c] .kernel_thread+0x54/0x70
The bug occurs because pci_name() tries to access a null pointer.
This patch just guarantee that pci_name() is not called on Null pointers.
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
Signed-off-by: Linas Vepstas <linasvepstas@gmail.com>
Signed-off-by: Frans Pop <elendil@planet.nl>
Cc: linuxppc-dev@ozlabs.org
Rather than open-coding our own check, use irq_has_action()
to check if an irq has an action - ie. is "in use".
irq_has_action() doesn't take the descriptor lock, but it
shouldn't matter - we're just using it as an indicator
that the irq is in use. disable_irq_nosync() will take
the descriptor lock before doing anything also.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Based on PCI Express AER specs, a root port might receive multiple
TLP errors while it could only save a correctable error source id
and an uncorrectable error source id at the same time. In addition,
some root port hardware might be unable to provide a correct source
id, i.e., the source id, or the bus id part of the source id provided
by root port might be equal to 0.
The patchset implements the support in kernel by searching the device
tree under the root port.
Patch 1 changes parameter cb of function pci_walk_bus to return a value.
When cb return non-zero, pci_walk_bus stops more searching on the
device tree.
Reviewed-by: Andrew Patterson <andrew.patterson@hp.com>
Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
While adding native EEH support to Emulex and Qlogic drivers, it was
discovered that dev->error_state was set to pci_io_channel_normal too
late in the recovery process. These drivers rely on error_state to
determine if they can access the device in their slot_reset callback,
thus error_state needs to be set to pci_io_channel_normal in
eeh_report_reset(). Below is a detailed explanation (courtesy of Richard
Lary) as to why this is necessary.
Background:
PCI MMIO or DMA accesses to a frozen slot generate additional EEH
errors. If the number of additional EEH errors exceeds EEH_MAX_FAILS the
adapter will be shutdown. To avoid triggering excessive EEH errors and
an undesirable adapter shutdown, some drivers use the
pci_channel_offline(dev) wrapper function to return a Boolean value
based on the value of pci_dev->error_state to determine if PCI MMIO or
DMA accesses are safe. If the wrapper returns TRUE, drivers must not
make PCI MMIO or DMA access to their hardware.
The pci_dev structure member error_state reflects one of three values,
1) pci_channel_io_normal, 2) pci_channel_io_frozen, 3)
pci_channel_io_perm_failure. Function pci_channel_offline(dev) returns
TRUE if error_state is pci_channel_io_frozen or pci_channel_io_perm_failure.
The EEH driver sets pci_dev->error_state to pci_channel_io_frozen at the
point where the PCI slot is frozen. Currently, the EEH driver restores
dev->error_state to pci_channel_io_normal in eeh_report_resume() before
calling the driver's resume callback. However, when the EEH driver calls
the driver's slot_reset callback() from eeh_report_reset(), it
incorrectly indicates the error state is still pci_channel_io_frozen.
Waiting until eeh_report_resume() to restore dev->error_state to
pci_channel_io_normal is too late for Emulex and QLogic FC drivers and
any other drivers which are designed to use common code paths in these
two cases: i) those called after the driver's slot_reset callback() and
ii) those called after the PCI slot is frozen but before the driver's
slot_reset callback is called. Case i) all driver paths executed to
reinitialize the hardware after a reset and case ii) all code paths
executed by driver kernel threads that run asynchronous to the main
driver thread, such as interrupt handlers and worker threads to process
driver work queues.
Emulex and QLogic FC drivers are designed with common code paths which
require that pci_channel_offline(dev) reflect the true state of the
hardware. The state transitions that the hardware takes from Normal
Operations to Slot Frozen to Reset to Normal Operations are documented
in the Power Architectureâ„¢ Platform Requirements+ (PAPR+) in Table 75.
PE State Control.
PAPR defines the following 3 states:
0 -- Not reset, Not EEH stopped, MMIO load/store allowed, DMA allowed
(Normal Operations)
1 -- Reset, Not EEH stopped, MMIO load/store disabled, DMA disabled
2 -- Not reset, EEH stopped, MMIO load/store disabled, DMA disabled
(Slot Frozen)
An EEH error places the slot in state 2 (Frozen) and the adapter driver
is notified that an EEH error was detected. If the adapter driver
returns PCI_ERS_RESULT_NEED_RESET, the EEH driver calls
eeh_reset_device() to place the slot into state 1 (Reset) and
eeh_reset_device completes by placing the slot into State 0 (Normal
Operations). Upon return from eeh_reset_device(), the EEH driver calls
eeh_report_reset, which then calls the adapter's slot_reset callback. At
the time the adapter's slot_reset callback is called, the true state of
the hardware is Normal Operations and should be accurately reflected by
setting dev->error_state to pci_channel_io_normal.
The current implementation of EEH driver does not do so and requires
this change to correct this deficiency.
Signed-off-by: Mike Mason <mmlnx@us.ibm.com>
Acked-by: Linas Vepstas <linasvepstas@gmail.com>
The EEH code disables and enables interrupts during the
device recovery process. This is unnecessary for MSI
and MSI-X interrupts because they are effectively disabled
by the DMA Stopped state when an EEH error occurs. The
current code is also incorrect for MSI-X interrupts. It
doesn't take into account that MSI-X interrupts are tracked
in a different way than LSI/MSI interrupts. This patch
ensures only LSI interrupts are disabled/enabled.
Currently print_device_node_tree() isn't called but it can be useful for
debugging. Leave the function there but hide it behind '#if 0' to save
it being rewritten. If you want to call it you're already editing this
file anyway. ;P
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
Fix this:
/usr/src/devel/arch/powerpc/platforms/pseries/eeh_driver.c: In function 'print_device_node_tree':
/usr/src/devel/arch/powerpc/platforms/pseries/eeh_driver.c:55: warning: ISO C90 forbids mixed declarations and code
also make that function look like it's part of Linux.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Do not wait for the pci slot status before reporting an error
to the device driver. Some systems may take many seconds to
report the slot status, and this can confuse unsuspecting
device drivers.
Signed-off-by: Linas Vepstas <linas@austin.ibm.com>
Bugfix: if a driver controlling one part of a multi-function PCI card
has asked for a reset, honor that request above all others.
Clean up commentary, remove dead code.
Signed-off-by Linas Vepstas <linas@austin.ibm.com>
Twiddle the copyright notices. Per current guidelines, the use
of the (C) or (c) in source code is deprecated.
arch/powerpc/platforms/pseries/eeh.c | 6 +++++-
arch/powerpc/platforms/pseries/eeh_cache.c | 3 ++-
arch/powerpc/platforms/pseries/eeh_driver.c | 6 +++---
3 files changed, 10 insertions(+), 5 deletions(-)
Assorted minor cleanups to EEH code; -- use literals, use
kerneldoc format.
arch/powerpc/platforms/pseries/eeh.c | 13 ++++++++++---
arch/powerpc/platforms/pseries/eeh_driver.c | 7 ++++---
include/asm-powerpc/ppc-pci.h | 18 +++++++++++++++---
3 files changed, 29 insertions(+), 9 deletions(-)
Make some minor adjustments to the EEH error messages.
It turns out many/most versions of firmware enable MMIO when
the slto-error-detail rtas call is made (in violation of the
architecture). Thus, it would be best to call slot-error-detail
only after notifying device drivers of a freeze, as otherwise,
a variety of strange and unexpected things may happen.
Rework how multi-function PCI devices are identified and traversed.
This fixes a bug with multi-function recovery on Power4 that was
introduced by a recent Power4 EEH patch.
After requesting a state change, verify that the state change
actually ocurred, and the system ends up in the expected state.
The EEH event notification system passes around data that is
not needed or at least, not used properly. Stop passing this
data; get it in a more reliable fashion.
If the second or higher function of a multi-function device fails
to recover, this failure is not reported upwards. Fix this.
If a device driver does not have native PCI error recovery,
a hotplug error recovery will be attemped. In this case,
the device driver will not report back whether its healthy
or not; simply assume that it is.
There are multiple code patchs tht resuls in a "permanent
failure"; when examining rare events, it can be hard to see
which was taken. This patch adds printk's to assist.
Clarify error message re EEH permanent failure.
If one attempts to create a device driver recovery sequence that
does not depend on a hard reset of the device, but simply just
attempts to resume processing, then one discovers that the
recovery sequence implemented on powerpc is not quite right.
This patch fixes this up.
Update to the PowerPC PCI error recovery code.
Add code to enable MMIO if a device driver reports that it is capable
of recovering on its own. One anticipated use of this having a device
driver enable MMIO so that it can take a register dump, which might
then be followed by the device driver requesting a full reset.
Clean up subroutine documentation; mostly formatting changes, with
some new content.
Now that get_property() returns a void *, there's no need to cast its
return value. Also, treat the return value as const, so we can
constify get_property later.
pseries platform changes.
Built for pseries_defconfig
Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
The PCI error recovery code will printk diagnostic info when
a PCI error event occurs. Change the messages to include the slot
location code, which is how most sysadmins will know the device.
When a PCI device driver does not support PCI error recovery,
the powerpc/pseries code takes a walk through a branch of code
that resets the failure counter. Because of this, if a broken
PCI card is present, the kernel will attempt to reset it an
infinite number of times. (This is annoying but mostly harmless:
each reset takes about 10-20 seconds, and uses almost no CPU time).
This patch preserves the failure count across resets.
The current PCI error recovery system keeps track of the number of PCI card
resets, and refuses to bring a card back up if this number is too large.
The goal of doing this was to avoid an infinite loop of resets if a card is
obviously dead. However, if the failures are rare, but the machine has a
high uptime, this mechanism might still be triggered; this is too harsh.
This patch will avoids this problem by decrementing the fail count after an
hour. Thus, as long as a pci card BSOD's less than 6 times an hour, it
will continue to be reset indefinitely. If it's failure rate is greater
than that, it will be taken off-line permanently.
This patch is larger than it might otherwise be because it changes
indentation by removing a pointless while-loop. The while loop is not
needed, as the handler is invoked once fo each event (by schedule_work());
the loop is leftover cruft from an earlier implementation.
The recent patch to print device names in EEH reset messages
was lacking ... this patch works better.
Signed-off-by: Linas Vepstas <linas@linas.org>
The current code prints an ambiguous message if the recovery
of a failed PCI device fails. Give this special case its own
unique message.
This avoids printk'ing a NULL string.
