Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data
be setup before gluing PDE to main tree.
Add correct ->owner to proc_fops to fix reading/module unloading race.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Of_get_parent and of_find_compatible_node do an of_node_get, and thus a
corresponding of_code_put is needed in the error case.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
type T,T1,T2;
identifier E;
statement S;
expression x1,x2,x3;
int ret;
T E;
* E = \(of_get_parent\|of_find_compatible_node\)(...);
if (E == NULL) S
... when != of_node_put(...,(T1)E,...)
when != if (E != NULL) { ... of_node_put(...,(T1)E,...); ...}
when != x1 = (T1)E
when != E = x3;
when any
if (...) {
... when != of_node_put(...,(T2)E,...)
when != if (E != NULL) { ... of_node_put(...,(T2)E,...); ...}
when != x2 = (T2)E
* return;
* return ret;
// </smpl>
Cc: Kumar Gala <galak@gate.crashing.org>
The struct device_node currently has a _flags variable, although
it's only used for one flag - OF_DYNAMIC. Generalise the flag
accessors so we can use them with other flags in future.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
[akpm@osdl.org: sparc64 fix]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Bug: pnx8550 code creates directory but resets ->nlink to 1.
create_proc_entry() et al will correctly set ->nlink for you.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Corey Minyard <minyard@acm.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Greg KH <greg@kroah.com>
Replace kmalloc+memset with kzalloc.
Signed-off-by: Yan Burman <burman.yan@gmail.com>
This removes statically assigned platform numbers and reworks the
powerpc platform probe code to use a better mechanism. With this,
board support files can simply declare a new machine type with a
macro, and implement a probe() function that uses the flattened
device-tree to detect if they apply for a given machine.
We now have a machine_is() macro that replaces the comparisons of
_machine with the various PLATFORM_* constants. This commit also
changes various drivers to use the new macro instead of looking at
_machine.
The kernel's implementation of notifier chains is unsafe. There is no
protection against entries being added to or removed from a chain while the
chain is in use. The issues were discussed in this thread:
http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2
We noticed that notifier chains in the kernel fall into two basic usage
classes:
"Blocking" chains are always called from a process context
and the callout routines are allowed to sleep;
"Atomic" chains can be called from an atomic context and
the callout routines are not allowed to sleep.
We decided to codify this distinction and make it part of the API. Therefore
this set of patches introduces three new, parallel APIs: one for blocking
notifiers, one for atomic notifiers, and one for "raw" notifiers (which is
really just the old API under a new name). New kinds of data structures are
used for the heads of the chains, and new routines are defined for
registration, unregistration, and calling a chain. The three APIs are
explained in include/linux/notifier.h and their implementation is in
kernel/sys.c.
With atomic and blocking chains, the implementation guarantees that the chain
links will not be corrupted and that chain callers will not get messed up by
entries being added or removed. For raw chains the implementation provides no
guarantees at all; users of this API must provide their own protections. (The
idea was that situations may come up where the assumptions of the atomic and
blocking APIs are not appropriate, so it should be possible for users to
handle these things in their own way.)
There are some limitations, which should not be too hard to live with. For
atomic/blocking chains, registration and unregistration must always be done in
a process context since the chain is protected by a mutex/rwsem. Also, a
callout routine for a non-raw chain must not try to register or unregister
entries on its own chain. (This did happen in a couple of places and the code
had to be changed to avoid it.)
Since atomic chains may be called from within an NMI handler, they cannot use
spinlocks for synchronization. Instead we use RCU. The overhead falls almost
entirely in the unregister routine, which is okay since unregistration is much
less frequent that calling a chain.
Here is the list of chains that we adjusted and their classifications. None
of them use the raw API, so for the moment it is only a placeholder.
ATOMIC CHAINS
arch/i386/kernel/traps.c: i386die_chain
arch/ia64/kernel/traps.c: ia64die_chain
arch/powerpc/kernel/traps.c: powerpc_die_chain
arch/sparc64/kernel/traps.c: sparc64die_chain
arch/x86_64/kernel/traps.c: die_chain
drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list
kernel/panic.c: panic_notifier_list
kernel/profile.c: task_free_notifier
net/bluetooth/hci_core.c: hci_notifier
net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain
net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain
net/ipv6/addrconf.c: inet6addr_chain
net/netfilter/nf_conntrack_core.c: nf_conntrack_chain
net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain
net/netlink/af_netlink.c: netlink_chain
BLOCKING CHAINS
arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain
arch/s390/kernel/process.c: idle_chain
arch/x86_64/kernel/process.c idle_notifier
drivers/base/memory.c: memory_chain
drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list
drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list
drivers/macintosh/adb.c: adb_client_list
drivers/macintosh/via-pmu.c sleep_notifier_list
drivers/macintosh/via-pmu68k.c sleep_notifier_list
drivers/macintosh/windfarm_core.c wf_client_list
drivers/usb/core/notify.c usb_notifier_list
drivers/video/fbmem.c fb_notifier_list
kernel/cpu.c cpu_chain
kernel/module.c module_notify_list
kernel/profile.c munmap_notifier
kernel/profile.c task_exit_notifier
kernel/sys.c reboot_notifier_list
net/core/dev.c netdev_chain
net/decnet/dn_dev.c: dnaddr_chain
net/ipv4/devinet.c: inetaddr_chain
It's possible that some of these classifications are wrong. If they are,
please let us know or submit a patch to fix them. Note that any chain that
gets called very frequently should be atomic, because the rwsem read-locking
used for blocking chains is very likely to incur cache misses on SMP systems.
(However, if the chain's callout routines may sleep then the chain cannot be
atomic.)
The patch set was written by Alan Stern and Chandra Seetharaman, incorporating
material written by Keith Owens and suggestions from Paul McKenney and Andrew
Morton.
[jes@sgi.com: restructure the notifier chain initialization macros]
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Signed-off-by: Jes Sorensen <jes@sgi.com>
Add support to reconfigure the device tree through the existing
proc filesystem interface. Add "add_property", "remove_property",
and "update_property" commands to the existing interface.
Signed-off-by: Dave Boutcher <sleddog@us.ibm.com>
This patch merges platform codes. systemcfg->platform is no longer used,
systemcfg use in general is deprecated as much as possible (and renamed
_systemcfg before it gets completely moved elsewhere in a future patch),
_machine is now used on ppc64 along as ppc32. Platform codes aren't gone
yet but we are getting a step closer. A bunch of asm code in head[_64].S
is also turned into C code.
This is the arch/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in arch/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Grant Grundler <grundler@parisc-linux.org>
