__attribute__ ((unused))
WSP is the last user of CONFIG_PPC_A2, so we remove that as well.
Although CONFIG_PPC_ICSWX still exists, it's no longer selectable for
any Book3E platform, so we can remove the code in mmu-book3e.h that
depended on it.
arch/powerpc/platforms/wsp/wsp.c: In function ‘wsp_probe_devices’:
arch/powerpc/platforms/wsp/wsp.c:76:3: error: implicit declaration of function ‘of_address_to_resource’ [-Werror=implicit-function-declaration]
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
This patch converts a number of the powerpc drivers to use the common library
of irq_domain xlate functions, dropping a bunch of lines in the process.
v5: - Remove tsi108 changes from patch
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Milton Miller <miltonm@bga.com>
Tested-by: Olof Johansson <olof@lixom.net>
Make all the irq_domain_ops structures in powerpc 'static const'
Each revmap type has different arguments for setting up the revmap.
This patch splits up the generator functions so that each revmap type
can do its own setup and the user doesn't need to keep track of how
each revmap type handles the arguments.
This patch also adds a host_data argument to the generators. There are
cases where the host_data pointer will be needed before the function returns.
ie. the legacy map calls the .map callback for each irq before returning.
v2: - Add void *host_data argument to irq_domain_add_*() functions
- fixed failure to compile
- Moved IRQ_DOMAIN_MAP_* defines into irqdomain.c
This patch drops the powerpc-specific irq_host structures and uses the common
irq_domain strucutres defined in linux/irqdomain.h. It also fixes all
the users to use the new structure names.
Renaming irq_host to irq_domain has been discussed for a long time, and this
patch is a step in the process of generalizing the powerpc virq code to be
usable by all architecture.
An astute reader will notice that this patch actually removes the irq_host
structure instead of renaming it. This is because the irq_domain structure
already exists in include/linux/irqdomain.h and has the needed data members.
Cascade handlers must run in hard interrupt context.
Add a platform for the Wire Speed Processor, based on the PPC A2.
This includes code for the ICS & OPB interrupt controllers, as well
as a SCOM backend, and SCOM based cpu bringup.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Jack Miller <jack@codezen.org>
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
