path: root/arch/powerpc/platforms
2012-01-12powerpc: Fix unpaired probe_hcall_entry and probe_hcall_exitLi Zhong
commit e4f387d8db3ba3c2dae4d8bdfe7bb5f4fe1bcb0d upstream. Unpaired calling of probe_hcall_entry and probe_hcall_exit might happen as following, which could cause incorrect preempt count. __trace_hcall_entry => trace_hcall_entry -> probe_hcall_entry => get_cpu_var => preempt_disable __trace_hcall_exit => trace_hcall_exit -> probe_hcall_exit => put_cpu_var => preempt_enable where: A => B and A -> B means A calls B, but => means A will call B through function name, and B will definitely be called. -> means A will call B through function pointer, so B might not be called if the function pointer is not set. So error happens when only one of probe_hcall_entry and probe_hcall_exit get called during a hcall. This patch tries to move the preempt count operations from probe_hcall_entry and probe_hcall_exit to its callers. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-21powerpc/ps3: Fix lost SMP IPIsGeoff Levand
commit 72f3bea075287785ed32b777b6dd2636aa7002e8 upstream. Fixes the PS3 bootup hang introduced in 3.0-rc1 by: commit 317f394160e9beb97d19a84c39b7e5eb3d7815a sched: Move the second half of ttwu() to the remote cpu Move the PS3's LV1 EOI call lv1_end_of_interrupt_ext() from ps3_chip_eoi() to ps3_get_irq() for IPI messages. If lv1_send_event_locally() is called between a previous call to lv1_send_event_locally() and the coresponding call to lv1_end_of_interrupt_ext() the second event will not be delivered to the target cpu. The PS3's SMP IPIs are implemented using lv1_send_event_locally(), so if two IPI messages of the same type are sent to the same target in a relatively short period of time the second IPI event can become lost when lv1_end_of_interrupt_ext() is called from ps3_chip_eoi(). Signed-off-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11powerpc/eeh: Fix /proc/ppc64/eeh creationThadeu Lima de Souza Cascardo
commit 8feaa43494cee5e938fd5a57b9e9bf1c827e6ccd upstream. Since commit 188917e183cf9ad0374b571006d0fc6d48a7f447, /proc/ppc64 is a symlink to /proc/powerpc/. That means that creating /proc/ppc64/eeh will end up with a unaccessible file, that is not listed under /proc/powerpc/ and, then, not listed under /proc/ppc64/. Creating /proc/powerpc/eeh fixes that problem and maintain the compatibility intended with the ppc64 symlink. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11powerpc/pseries: Avoid spurious error during hotplug CPU addAnton Blanchard
commit 9c740025c51a26ab00192cfc464064d4ccbfe3fc upstream. During hotplug CPU add we get the following error: Unexpected Error (0) returned from configure-connector ibm,configure-connector returns 0 for configuration complete, so catch this and avoid the error. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-29powerpc: Fix device-tree matching for Apple U4 bridgeBenjamin Herrenschmidt
Apple Quad G5 has some oddity in it's device-tree which causes the new generic matching code to fail to relate nodes for PCI-E devices below U4 with their respective struct pci_dev. This breaks graphics on those machines among others. This fixes it using a quirk which copies the node pointer from the host bridge for the root complex, which makes the generic code work for the children afterward. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-05powerpc/pseries: Simplify vpa deregistration functionsAnton Blanchard
The VPA, SLB shadow and DTL degistration functions do not need an address, so simplify things and remove it. Also cleanup pseries_kexec_cpu_down a bit by storing the cpu IDs in local variables. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-08-05powerpc/pseries: Cleanup VPA registration and deregistration errorsAnton Blanchard
Make the VPA, SLB shadow and DTL registration and deregistration functions print consistent messages on error. I needed the firmware error code while chasing a kexec bug but we weren't printing it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-08-05powerpc/pseries: Fix kexec on recent firmware versionsAnton Blanchard
Recent versions of firmware will fail to unmap the virtual processor area if we have a dispatch trace log registered. This causes kexec to fail. If a trace log is registered this patch unregisters it before the SLB shadow and virtual processor areas, fixing the problem. The address argument is ignored by firmware on unregister so we may as well remove it. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-08-05powerpc: Make KVM_GUEST default to nAnton Blanchard
KVM_GUEST adds a 1 MB array to the kernel (kvm_tmp) which grew my kernel enough to cause it to fail to boot. Dynamically allocating or reducing the size of this array is a good idea, but in the meantime I think it makes sense to make KVM_GUEST default to n in order to minimise surprises. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-08-05powerpc: Lack of ibm,io-events not that important!Anton Blanchard
The ibm,io-events code is a bit verbose with its error messages. Reverse the reporting so we only print when we successfully enable I/O event interrupts. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-08-05powerpc: pseries: Fix kexec on machines with more than 4TB of RAMAnton Blanchard
On a box with 8TB of RAM the MMU hashtable is 64GB in size. That means we have 4G PTEs. pSeries_lpar_hptab_clear was using a signed int to store the index which will overflow at 2G. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> Acked-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits) drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c powerpc/85xx: fix mpic configuration in CAMP mode powerpc: Copy back TIF flags on return from softirq stack powerpc/64: Make server perfmon only built on ppc64 server devices powerpc/pseries: Fix hvc_vio.c build due to recent changes powerpc: Exporting boot_cpuid_phys powerpc: Add CFAR to oops output hvc_console: Add kdb support powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon powerpc/irq: Quieten irq mapping printks powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs powerpc: Add mpt2sas driver to pseries and ppc64 defconfig powerpc: Disable IRQs off tracer in ppc64 defconfig powerpc: Sync pseries and ppc64 defconfigs powerpc/pseries/hvconsole: Fix dropped console output hvc_console: Improve tty/console put_chars handling powerpc/kdump: Fix timeout in crash_kexec_wait_realmode powerpc/mm: Fix output of total_ram. powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards powerpc: Correct annotations of pmu registration functions ... Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and drivers/cpufreq
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24Merge branch 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (143 commits) KVM: IOMMU: Disable device assignment without interrupt remapping KVM: MMU: trace mmio page fault KVM: MMU: mmio page fault support KVM: MMU: reorganize struct kvm_shadow_walk_iterator KVM: MMU: lockless walking shadow page table KVM: MMU: do not need atomicly to set/clear spte KVM: MMU: introduce the rules to modify shadow page table KVM: MMU: abstract some functions to handle fault pfn KVM: MMU: filter out the mmio pfn from the fault pfn KVM: MMU: remove bypass_guest_pf KVM: MMU: split kvm_mmu_free_page KVM: MMU: count used shadow pages on prepareing path KVM: MMU: rename 'pt_write' to 'emulate' KVM: MMU: cleanup for FNAME(fetch) KVM: MMU: optimize to handle dirty bit KVM: MMU: cache mmio info on page fault path KVM: x86: introduce vcpu_mmio_gva_to_gpa to cleanup the code KVM: MMU: do not update slot bitmap if spte is nonpresent KVM: MMU: fix walking shadow page table KVM guest: KVM Steal time registration ...
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-22Merge branch 'timers-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mips: Fix i8253 clockevent fallout i8253: Cleanup outb/inb magic arm: Footbridge: Use common i8253 clockevent mips: Use common i8253 clockevent x86: Use common i8253 clockevent i8253: Create common clockevent implementation i8253: Export i8253_lock unconditionally pcpskr: MIPS: Make config dependencies finer grained pcspkr: Cleanup Kconfig dependencies i8253: Move remaining content and delete asm/i8253.h i8253: Consolidate definitions of PIT_LATCH x86: i8253: Consolidate definitions of global_clock_event i8253: Alpha, PowerPC: Remove unused asm/8253pit.h alpha: i8253: Cleanup remaining users of i8253pit.h i8253: Remove I8253_LOCK config i8253: Make pcsp sound driver use the shared i8253_lock i8253: Make pcspkr input driver use the shared i8253_lock i8253: Consolidate all kernel definitions of i8253_lock i8253: Unify all kernel declarations of i8253_lock i8253: Create linux/i8253.h and use it in all 8253 related files
2011-07-22Merge branch 'of-pci' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'of-pci' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: pci/of: Consolidate pci_bus_to_OF_node() pci/of: Consolidate pci_device_to_OF_node() x86/devicetree: Use generic PCI <-> OF matching microblaze/pci: Move the remains of pci_32.c to pci-common.c microblaze/pci: Remove powermac originated cruft pci/of: Match PCI devices to OF nodes dynamically
2011-07-22Merge branch 'gpio/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: (61 commits) gpio/mxc/mxs: fix build error introduced by the irq_gc_ack() renaming mcp23s08: add i2c support mcp23s08: isolate spi specific parts mcp23s08: get rid of setup/teardown callbacks gpio/tegra: dt: add binding for gpio polarity mcp23s08: remove unused work queue gpio/da9052: remove a redundant assignment for gpio->da9052 gpio/mxc: add device tree probe support ARM: mxc: use ARCH_NR_GPIOS to define gpio number gpio/mxc: get rid of the uses of cpu_is_mx() gpio/mxc: add missing initialization of basic_mmio_gpio shadow variables gpio: Move mpc5200 gpio driver to drivers/gpio GPIO: DA9052 GPIO module v3 gpio/tegra: Use engineering names in DT compatible property of/gpio: Add new method for getting gpios under different property names gpio/dt: Refine GPIO device tree binding gpio/ml-ioh: fix off-by-one for displaying variable i in dev_err gpio/pca953x: Deprecate meaningless device-tree bindings gpio/pca953x: Remove dynamic platform data pointer gpio/pca953x: Fix IRQ support. ...
2011-07-22powerpc/85xx: fix mpic configuration in CAMP modeFabio Baltieri
Change the string to check for CAMP mode boot on MPC85xx (eg. P2020) to match the one in the corresponding dts files (p2020rdb_camp_core{0,1}.dts). Without this fix the mpic is configured as in the SMP boot mode, which causes the first core to report a protected source interrupt error for devices of the other core and lock up. Also add MPIC_SINGLE_DEST_CPU on both P2020 based architectures in CAMP mode as suggested by Scott Wood. Thanks. Cc: Scott Wood <scottwood@freescale.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-22powerpc/64: Make server perfmon only built on ppc64 server devicesKumar Gala
The 64-bit Book-E parts (to date) dont utilize the 'server' class perfmon. So building or depending on it makes no sense (and does break FSL Book-E 64-bit support). Move the selection of PPC_HAVE_PMU_SUPPORT to be based on PPC_BOOK3S_64. Based on a patch from Scott Wood. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20switch do_spufs_create() to user_path_create(), fix double-unlockAl Viro
2011-07-19powerpc/pseries/hvconsole: Fix dropped console outputAnton Blanchard
Return -EAGAIN when we get H_BUSY back from the hypervisor. This makes the hvc console driver retry, avoiding dropped printks. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-12powerpc: rename ppc_pci_*_flags to pci_*_flagsRob Herring
This renames pci flags functions and enums in preparation for creating generic version in asm-generic/pci-bridge.h. The following search and replace is done: s/ppc_pci_/pci_/ s/PPC_PCI_/PCI_/ Direct accesses to ppc_pci_flag variable are replaced with helper functions. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org>
2011-07-12powerpc, KVM: Rework KVM checks in first-level interrupt handlersPaul Mackerras
Instead of branching out-of-line with the DO_KVM macro to check if we are in a KVM guest at the time of an interrupt, this moves the KVM check inline in the first-level interrupt handlers. This speeds up the non-KVM case and makes sure that none of the interrupt handlers are missing the check. Because the first-level interrupt handlers are now larger, some things had to be move out of line in exceptions-64s.S. This all necessitated some minor changes to the interrupt entry code in KVM. This also streamlines the book3s_32 KVM test. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12powerpc/mm: Fix memory_block_size_bytes() for non-pseriesBenjamin Herrenschmidt
Just compiling pseries in the kernel causes it to override memory_block_size_bytes() regardless of what is the runtime platform. This cleans up the implementation of that function, fixing a bug or two while at it, so that it's harmless (and potentially useful) for other platforms. Without this, bugs in that code would trigger a WARN_ON() in drivers/base/memory.c when booting some different platforms. If/when we have another platform supporting memory hotplug we might want to either move that out to a generic place or make it a ppc_md. callback. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-08powerpc/85xx: Remove stale BUG_ON in mpc85xx_smp_initLaurentiu TUDOR
Under the FSL Hypervisor we triggered a BUG_ON in mpc85xx_smp_init that expected smp_ops.message_pass to be explicity set. However recent changes allows smp_ops.message_pass to be NULL and handled by default code. Thus the BUG_ON isn't relevant anymore. Signed-off-by: Laurentiu TUDOR <Laurentiu.Tudor@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-08powerpc/85xx: Add p2040 RDB board supportMingkai Hu
P2040RDB Specification: ----------------------- 2Gbyte unbuffered DDR3 SDRAM SO-DIMM(64bit bus) 128 Mbyte NOR flash single-chip memory 256 Kbit M24256 I2C EEPROM 16 Mbyte SPI memory SD connector to interface with the SD memory card dTSEC1: connected to the Vitesse SGMII PHY (VSC8221) dTSEC2: connected to the Vitesse SGMII PHY (VSC8221) dTSEC3: connected to the Vitesse SGMII PHY (VSC8221) dTSEC4: connected to the Vitesse RGMII PHY (VSC8641) dTSEC5: connected to the Vitesse RGMII PHY (VSC8641) I2C1: Real time clock, Temperature sensor I2C2: Vcore Regulator, 256Kbit I2C Bus EEPROM SATA: Lanes C and Land D of Bank2 are connected to two SATA connectors UART: supports two UARTs up to 115200 bps for console USB 2.0: connected via a internal UTMI PHY to two TYPE-A interfaces PCIe: - Lanes E, F, G and H of Bank1 are connected to one x4 PCIe SLOT1 - Lanes C and Land D of Bank2 are connected to one x4 PCIe SLOT2 Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-06gpio: Move mpc5200 gpio driver to drivers/gpioGrant Likely
GPIO drivers are getting consolidated into drivers/gpio. While at it, change the driver name to mpc5200-gpio* to avoid collisions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-30powerpc: Move free_initmem to common codeDave Carroll
The free_initmem function is basically duplicated in mm/init_32, and init_64, and is moved to the common 32/64-bit mm/mem.c. All other sections except init were removed in v2.6.15 by 6c45ab992e4299c869fb26427944a8f8ea177024 (powerpc: Remove section free() and linker script bits), and therefore the bulk of the executed code is identical. This patch also removes updating ppc_md.progress to NULL in the powermac late_initcall. Suggested-by: Milton Miller <miltonm@bga.com> Suggested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Dave Carroll <dcarroll@astekcorp.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-06-29powerpc/pseries: Re-implement HVSI as part of hvc_vioBenjamin Herrenschmidt
On pseries machines, consoles are provided by the hypervisor using a low level get_chars/put_chars type interface. However, this is really just a transport to the service processor which implements them either as "raw" console (networked consoles, HMC, ...) or as "hvsi" serial ports. The later is a simple packet protocol on top of the raw character interface that is supposed to convey additional "serial port" style semantics. In practice however, all it does is provide a way to read the CD line and set/clear our DTR line, that's it. We currently implement the "raw" protocol as an hvc console backend (/dev/hvcN) and the "hvsi" protocol using a separate tty driver (/dev/hvsi0). However this is quite impractical. The arbitrary difference between the two type of devices has been a major source of user (and distro) confusion. Additionally, there's an additional mini -hvsi implementation in the pseries platform code for our low level debug console and early boot kernel messages, which means code duplication, though that low level variant is impractical as it's incapable of doing the initial protocol negociation to establish the link to the FSP. This essentially replaces the dedicated hvsi driver and the platform udbg code completely by extending the existing hvc_vio backend used in "raw" mode so that: - It now supports HVSI as well - We add support for hvc backend providing tiocm{get,set} - It also provides a udbg interface for early debug and boot console This is overall less code, though this will only be obvious once we remove the old "hvsi" driver, which is still available for now. When the old driver is enabled, the new code still kicks in for the low level udbg console, replacing the old mini implementation in the platform code, it just doesn't provide the higher level "hvc" interface. In addition to producing generally simler code, this has several benefits over our current situation: - The user/distro only has to deal with /dev/hvcN for the hypervisor console, avoiding all sort of confusion that has plagued us in the past - The tty, kernel and low level debug console all use the same code base which supports the full protocol establishment process, thus the console is now available much earlier than it used to be with the old HVSI driver. The kernel console works much earlier and udbg is available much earlier too. Hackers can enable a hard coded very-early debug console as well that works with HVSI (previously that was only supported for the "raw" mode). I've tried to keep the same semantics as hvsi relative to how I react to things like CD changes, with some subtle differences though: - I clear DTR on close if HUPCL is set - Current hvsi triggers a hangup if it detects a up->down transition on CD (you can still open a console with CD down). My new implementation triggers a hangup if the link to the FSP is severed, and severs it upon detecting a up->down transition on CD. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-06-29powerpc/udbg: Register udbg console genericallyBenjamin Herrenschmidt
When CONFIG_PPC_EARLY_DEBUG is set, call register_early_udbg_console() early from generic code. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-06-29powerpc/maple: Register CPC925 EDAC device on all boards with CPC925Dmitry Eremin-Solenikov
Currently Maple setup code creates cpc925_edac device only on Motorola ATCA-6101 blade. Make setup code check bridge revision and enable EDAC on all U3H bridges. Verified on Momentum MapleD (ppc970fx kit) board. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-06-29powerpc/pseries: Improve error code on reconfiguration notifier failureAkinobu Mita
Reconfiguration notifier call for device node may fail by several reasons, but it always assumes kmalloc failures. This enables reconfiguration notifier call chain to get the actual error code rather than -ENOMEM by converting all reconfiguration notifier calls to return encapsulate error code with notifier_from_errno(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-06-29powerpc/pseries: Introduce pSeries_reconfig_notify()Akinobu Mita
This introduces pSeries_reconfig_notify() as a just wrapper of blocking_notifier_call_chain() for pSeries_reconfig_chain. This is a preparation to improvement of error code on reconfiguration notifier failure. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-06-27powerpc/85xx: disable timebase synchronization under the hypervisorTimur Tabi
The Freescale hypervisor does not allow guests to write to the timebase registers (virtualizing the timebase register was deemed too complicated), so don't try to synchronize the timebase registers when we're running under the hypervisor. This typically happens when kexec support is enabled. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-27powerpc/85xx: Add P1010RDB board supportPrabhakar Kushwaha
P1010RDB Overview ----------------- 1Gbyte DDR3 (on board DDR) 32Mbyte 16bit NOR flash 32Mbyte SLC NAND Flash 256 Kbit M24256 I2C EEPROM 128 Mbit SPI Flash memory I2C Board 128x8 bit memory SD/MMC connector to interface with the SD memory card 2 SATA interface 1 internal SATA connect to 2.5. 160G SATA2 HDD 1 eSATA connector to rear panel USB 2.0 x1 USB 2.0 port: connected via a UTMI PHY to Mini-AB interface. x1 USB 2.0 port: directly connected to Mini-AB interface Ethernet eTSEC1: Connected to RGMII PHY VSC8641XKO eTSEC2: Connected to SGMII PHY VSC8221 eTSEC3: Connected to SGMII PHY VSC8221 eCAN Two DB-9 female connectors for Field bus interface UART DUART interface: supports two UARTs up to 115200 bps for console display Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-27powerpc/86xx: improve calculation of DIU pixel clock on the MPC8610 HPCDTimur Tabi
mpc8610hpcd_set_pixel_clock() calculates the correct value of the PXCLK bits in the CLKDVDR register for a given pixel clock rate. The code which performs this calculation is overly complicated and includes an error estimation routine that doesn't work most of the time anyway. Replace the code with the simpler routine that's currently used on the P1022DS. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-27powerpc/85xx: clamp the P1022DS DIU pixel clock to allowed valuesTimur Tabi
To ensure that the DIU pixel clock will not be set to an invalid value, clamp the PXCLK divider to the allowed range (2-255). This also acts as a limiter for the pixel clock. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-27powerpc/e500mc: Add support for the wait instruction in e500_idleScott Wood
e500mc cannot doze or nap due to an erratum (as well as having a different mechanism than previous e500), but it has a "wait" instruction that is similar to doze. On 64-bit, due to the soft-irq-disable mechanism, the existing book3e_idle should be used instead. Signed-off-by: Vakul Garg <vakul@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-27powerpc/p1022ds: add missing iounmap calls to platform fileTimur Tabi
The platform file for the Freecale P1022DS reference board is not freeing the ioremap() mapping of the PIXIS and global utilities nodes it creates. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-27powerpc/85xx: add board support for the Freescale hypervisorTimur Tabi
Add support for the ePAPR-compliant Freescale hypervisor (aka "Topaz") on the Freescale P3041DS, P4080DS, and P5020DS reference boards. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-27powerpc: introduce the ePAPR embedded hypervisor vmpic driverAshish Kalra
The Freescale ePAPR reference hypervisor provides interrupt controller services via a hypercall interface, instead of emulating the MPIC controller. This is called the VMPIC. The ePAPR "virtual interrupt controller" provides interrupt controller services for external interrupts. External interrupts received by a partition can come from two sources: - Hardware interrupts - hardware interrupts come from external interrupt lines or on-chip I/O devices. - Virtual interrupts - virtual interrupts are generated by the hypervisor as part of some hypervisor service or hypervisor-created virtual device. Both types of interrupts are processed using the same programming model and same set of hypercalls. Signed-off-by: Ashish Kalra <ashish.kalra@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-22powerpc/qe: Limit QE support to ppc32Kumar Gala
Only 32-bit SoCs have a QUICC Engine so limit the config option to PPC32. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-22powerpc/85xx: Add PCI support in 64-bit mode on P5020DSKumar Gala
2011-06-22powerpc/85xx: Add basic P1023RDS board supportRoy Zang
The P1023 processor is an e500v2 based SoC that utilizes the DPAA networking architecture. This adds basic board support for non-DPAA functionality (device tree, board file, etc). Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-22powerpc/85xx: Set up doorbells even with no mpicScott Wood
In cases like when the platform is used under hypervisor we will NOT have an MPIC controller but still want doorbells setup. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-22powerpc/85xx: Cleanup PCIe support on corenet_ds boardsKumar Gala
Several changes on PCIe support on P3041DS/P4080DS/P5020DS boards: * Add support for "fsl,qoriq-pcie-v2.2" needed by P3041 & P5020 * Removed support for setting primary_phb_addr as we have no ISA need * Add PCI controller to of_platform_bus_probe (for EDAC) * Cleanup building w/SWIOTLB off on P4080DS (not stricly PCIe related) Signed-off-by: Kai.Jiang <Kai.Jiang@freescale.com> Signed-off-by: Laurentiu TUDOR <Laurentiu.Tudor@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
