path: root/arch/powerpc/platforms
2006-03-16[PATCH] powerpc: properly configure DDR/P5IOC children devsJohn Rose
The dynamic add path for PCI Host Bridges can fail to configure children adapters under P5IOC controllers. It fails to properly fixup bus/device resources, and it fails to properly enable EEH. Both of these steps need to occur before any children devices are enabled in pci_bus_add_devices(). Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-16[PATCH] powerpc: enable NAP only on cpus who support it to avoid memory ↵Benjamin Herrenschmidt
corruption This patch fixes incorrect setting of powersave_nap to 1 on all PowerMacs, potentially causing memory corruption on some models. This bug was introuced by me during the 32/64 bits merge. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-14powerpc: Disallow lparcfg being a modulePaul Mackerras
The lparcfg code needs several things which are pretty arcane internal details and which we don't want to export, which means that lparcfg doesn't work when built as a module. This makes it a bool instead of a tristate in the Kconfig so that users can't try to build it as a module. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-03powerpc32: Fix timebase synchronization on 32-bit powermacsPaul Mackerras
The variable `timebase' used to transfer the current timebase value from one cpu to the other in smp_core99_give/take_timebase was only an unsigned long, i.e. 32 bits on 32-bit machines. It needs to be 64 bits. This makes it a u64, and fixes the issue reported by Kyle Moffett, that the two cpus see wildly different values for the time of day. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-03powerpc: Turn off verbose debug output in powermac platform functionsPaul Mackerras
This is along the lines suggested by Chris Lumens but goes further in that it leaves the DEBUG symbol undefined, making the DBG macro empty. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-28[PATCH] powerpc: fix NULL pointer in handle_eeh_eventsOlaf Hering
This patch fixes a crash in handle_eeh_events, but ethtool -t still doesnt work right. ... pepino:~ # cpu 0x3: Vector: 300 (Data Access) at [c00000005192bbe0] pc: c00000000004a380: .handle_eeh_events+0xe0/0x23c lr: c00000000004a374: .handle_eeh_events+0xd4/0x23c sp: c00000005192be60 msr: 9000000000009032 dar: 268 dsisr: 40000000 current = 0xc0000001fe7bf1a0 paca = 0xc00000000048b280 pid = 16322, comm = eehd enter ? for help [c00000005192bf00] c00000000004a808 .eeh_event_handler+0xcc/0x130 [c00000005192bf90] c000000000025e00 .kernel_thread+0x4c/0x68 ... (none):/# /usr/sbin/ethtool -i eth0 driver: e100 version: 3.5.10-k2-NAPI firmware-version: N/A bus-info: 0000:21:01.0 (none):/# /usr/sbin/ethtool -t eth0 Call Trace: [C00000000F8DEFF0] [C00000000000F270] .show_stack+0x74/0x1b4 (unreliable) [C00000000F8DF0A0] [C000000000049D04] .eeh_dn_check_failure+0x290/0x2d8 [C00000000F8DF150] [C000000000049E58] .eeh_check_failure+0x10c/0x138 [C00000000F8DF1E0] [C0000000002DFDB0] .e100_hw_reset+0x70/0xf4 [C00000000F8DF270] [C0000000002E1BBC] .e100_hw_init+0x2c/0x260 [C00000000F8DF310] [C0000000002E2464] .e100_loopback_test+0x8c/0x220 [C00000000F8DF3C0] [C0000000002E28DC] .e100_diag_test+0xdc/0x16c [C00000000F8DF490] [C000000000420BE0] .dev_ethtool+0xf24/0x14f8 [C00000000F8DF8F0] [C00000000041F4A8] .dev_ioctl+0x5cc/0x740 [C00000000F8DFA20] [C00000000040FEFC] .sock_ioctl+0x3d0/0x404 [C00000000F8DFAC0] [C0000000000D513C] .do_ioctl+0x68/0x108 [C00000000F8DFB50] [C0000000000D56B0] .vfs_ioctl+0x4d4/0x510 [C00000000F8DFC10] [C0000000000D5740] .sys_ioctl+0x54/0x94 [C00000000F8DFCC0] [C0000000000FB6EC] .ethtool_ioctl+0x11c/0x150 [C00000000F8DFD60] [C0000000000F7E40] .compat_sys_ioctl+0x338/0x3bc [C00000000F8DFE30] [C00000000000871C] syscall_exit+0x0/0x40 EEH: Detected PCI bus error on device 0000:21:01.0 EEH: This PCI device has failed 1 times since last reboot: <NULL> - modprobe: FATAL: Could not load /lib/modules/2.6.16-rc4-git7/modules.dep: No such file or directory Cannot get strings: No such device (none):/# (none):/# EEH: Unable to configure device bridge (-3) for /pci@400000000110/pci@2,2 (none):/# Call Trace: [C00000000FA17940] [C00000000000F270] .show_stack+0x74/0x1b4 (unreliable) [C00000000FA179F0] [C000000000049D04] .eeh_dn_check_failure+0x290/0x2d8 [C00000000FA17AA0] [C00000000001E114] .rtas_read_config+0x120/0x154 [C00000000FA17B40] [C000000000049664] .early_enable_eeh+0x274/0x2bc [C00000000FA17C00] [C000000000049708] .eeh_add_device_early+0x5c/0x6c [C00000000FA17C90] [C000000000049748] .eeh_add_device_tree_early+0x30/0x5c [C00000000FA17D20] [C000000000046568] .pcibios_add_pci_devices+0x8c/0x1f8 [C00000000FA17DD0] [C00000000004A528] .eeh_reset_device+0xe0/0x110 [C00000000FA17E60] [C00000000004A698] .handle_eeh_events+0x140/0x250 [C00000000FA17F00] [C00000000004AC7C] .eeh_event_handler+0xe8/0x140 [C00000000FA17F90] [C000000000025784] .kernel_thread+0x4c/0x68 EEH: Detected PCI bus error on device <NULL> EEH: This PCI device has failed 1 times since last reboot: <NULL> - EEH: Unable to configure device bridge (-3) for /pci@400000000110/pci@2,2 Call Trace: [C00000000FA17940] [C00000000000F270] .show_stack+0x74/0x1b4 (unreliable) [C00000000FA179F0] [C000000000049D04] .eeh_dn_check_failure+0x290/0x2d8 [C00000000FA17AA0] [C00000000001E114] .rtas_read_config+0x120/0x154 [C00000000FA17B40] [C000000000049664] .early_enable_eeh+0x274/0x2bc [C00000000FA17C00] [C000000000049708] .eeh_add_device_early+0x5c/0x6c [C00000000FA17C90] [C000000000049748] .eeh_add_device_tree_early+0x30/0x5c [C00000000FA17D20] [C000000000046568] .pcibios_add_pci_devices+0x8c/0x1f8 [C00000000FA17DD0] [C00000000004A528] .eeh_reset_device+0xe0/0x110 [C00000000FA17E60] [C00000000004A698] .handle_eeh_events+0x140/0x250 [C00000000FA17F00] [C00000000004AC7C] .eeh_event_handler+0xe8/0x140 [C00000000FA17F90] [C000000000025784] .kernel_thread+0x4c/0x68 EEH: Detected PCI bus error on device <NULL> EEH: This PCI device has failed 1 times since last reboot: <NULL> - EEH: Unable to configure device bridge (-3) for /pci@400000000110/pci@2,2 Call Trace: [C00000000FA17940] [C00000000000F270] .show_stack+0x74/0x1b4 (unreliable) [C00000000FA179F0] [C000000000049D04] .eeh_dn_check_failure+0x290/0x2d8 [C00000000FA17AA0] [C00000000001E114] .rtas_read_config+0x120/0x154 [C00000000FA17B40] [C000000000049664] .early_enable_eeh+0x274/0x2bc [C00000000FA17C00] [C000000000049708] .eeh_add_device_early+0x5c/0x6c [C00000000FA17C90] [C000000000049748] .eeh_add_device_tree_early+0x30/0x5c [C00000000FA17D20] [C000000000046568] .pcibios_add_pci_devices+0x8c/0x1f8 [C00000000FA17DD0] [C00000000004A528] .eeh_reset_device+0xe0/0x110 [C00000000FA17E60] [C00000000004A698] .handle_eeh_events+0x140/0x250 [C00000000FA17F00] [C00000000004AC7C] .eeh_event_handler+0xe8/0x140 [C00000000FA17F90] [C000000000025784] .kernel_thread+0x4c/0x68 EEH: Detected PCI bus error on device <NULL> and so on Signed-off-by: Olaf Hering <olh@suse.de> Acked-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-28[PATCH] powerpc: fix dynamic PCI probe regressionJohn Rose
Some hotplug driver functions were migrated to the kernel for use by EEH in commit 2bf6a8fa21570f37fd1789610da30f70a05ac5e3. Previously, the PCI Hotplug module had been changed to use the new OFDT-based PCI probe when appropriate: 5fa80fcdca9d20d30c9ecec30d4dbff4ed93a5c6 When rpaphp_pci_config_slot() was moved from the rpaphp driver to the new kernel function pcibios_add_pci_devices(), the OFDT-based probe stuff was dropped. This patch restores it. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-24[PATCH] powerpc: Don't re-assign PCI resources on MapleSegher Boessenkool
Maple firmware does not need PCI resource allocation, and in fact, it can cause problems in some strange cases. Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-24[PATCH] powerpc64: remove broken/bitrotted HMT supportAnton Blanchard
HMT support is currently broken and needs to be reworked to play nicely with the SMT scheduler. Remove the bit rotten bits for the time being. I also updated an incorrect comment, we enter __secondary_hold with the physical cpu id in r3. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-24[PATCH] powerpc: Fix runlatch performance issuesAnton Blanchard
The runlatch SPR can take a lot of time to write. My original runlatch code would set it on every exception entry even though most of the time this was not required. It would also continually set it in the idle loop, which is an issue on an SMT capable processor. Now we cache the runlatch value in a threadinfo bit, and only check for it in decrementer and hardware interrupt exceptions as well as the idle loop. Boot on POWER3, POWER5 and iseries, and compile tested on pmac32. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-23[PATCH] powerpc: Initialise hvlpevent_queue.lock correctlyMichael Ellerman
When I changed the hvlpevent_queue code to use a spinlock instead of a custom atomic (719d1cd86780c156f954fc34f34481adac197aec) I didn't initialise the lock anywhere, oops. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
2006-02-20[PATCH] powermac: Fix loss of ethernet PHY on sleepBenjamin Herrenschmidt
Some recent PowerBook models tend to lose the ethernet PHY on suspend/resume. It -seems- that they use a combo ethernet-firewire PHY chip and the firewire PHY seems to die the same way when that happens. Not trying to toggle the firewire cable power appears to fix it. So this patch disables changes to the firewire cable power control GPIO on those models. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] powerpc: Fix bug in spinup of renumbered secondary threadsMichael Ellerman
If the logical and physical cpu ids of a secondary thread don't match, we will fail to spin the thread up on pSeries machines due to a bug in pseries/smp.c We call the RTAS "start-cpu" method with the physical cpu id, the address of pSeries_secondary_smp_init and the value to pass that function in r3. Currently we pass "lcpu", the logical cpu id, but pSeries_secondary_smp_init expects the physical cpu id in r3. We should be passing pcpu instead. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-08[PATCH] powermac pci iomem annotationsAl Viro
2006-02-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
2006-02-07[PATCH] bogus extern in low_i2c.cAl Viro
extern in function definition is an odd thing.. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-07[PATCH] eeh_driver NULL noise removalAl Viro
2006-02-07[PATCH] drive_info removal outside of arch/i386Al Viro
drive_info is used only by hd.c and that happens under #ifdef __i386__. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-07[PATCH] powerpc: hypervisor check in pseries_kexec_cpu_downMichael Neuling
We call unregister_vpa but we don't check to see if the hypervisor supports this. Signed-off-by: Michael Neuling <mikey@neuling.org> Acked-by: Anton Blanchard <anton@samba.org> -- arch/powerpc/platforms/pseries/setup.c | 2 +- 1 files changed, 1 insertion(+), 1 deletion(-) Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] powerpc: add refcounting to setup_peg2 and of_get_pci_addressOlaf Hering
setup_peg2 must do some refcounting. of_get_pci_address may need to drop the node Pegasos l2cr : L2 cache was not active, activating PCI bus 0 controlled by pci at 80000000 Badness in kref_get at /home/olaf/kernel/olh/ppc64/linux-2.6.16-rc2-olh/lib/kref.c:32 Call Trace: [C037BD00] [C0007934] show_stack+0x5c/0x184 (unreliable) [C037BD30] [C000E068] program_check_exception+0x184/0x584 [C037BD90] [C000F5F0] ret_from_except_full+0x0/0x4c --- Exception: 700 at kref_get+0xc/0x24 LR = of_node_get+0x24/0x3c [C037BE50] [C004FD94] __pte_alloc_kernel+0x64/0x80 (unreliable) [C037BE70] [C000CA18] of_get_parent+0x34/0x58 [C037BE90] [C0009B18] of_get_address+0x24/0x174 [C037BED0] [C000A108] of_address_to_resource+0x24/0x68 [C037BF00] [C038B128] chrp_find_bridges+0x114/0x470 [C037BF90] [C038AE48] chrp_setup_arch+0x1fc/0x32c [C037BFB0] [C03849B0] setup_arch+0x144/0x188 [C037BFD0] [C037C45C] start_kernel+0x34/0x1a8 [C037BFF0] [000037A0] 0x37a0 Badness in kref_get at /home/olaf/kernel/olh/ppc64/linux-2.6.16-rc2-olh/lib/kref.c:32 Call Trace: [C037BC90] [C0007934] show_stack+0x5c/0x184 (unreliable) [C037BCC0] [C000E068] program_check_exception+0x184/0x584 [C037BD20] [C000F5F0] ret_from_except_full+0x0/0x4c --- Exception: 700 at kref_get+0xc/0x24 LR = of_node_get+0x24/0x3c [C037BDE0] [00000000] 0x0 (unreliable) [C037BE00] [C000CA18] of_get_parent+0x34/0x58 [C037BE20] [C0009CE8] of_translate_address+0x2c/0x2fc [C037BEA0] [C0009FE8] __of_address_to_resource+0x30/0xc4 [C037BED0] [C000A130] of_address_to_resource+0x4c/0x68 [C037BF00] [C038B128] chrp_find_bridges+0x114/0x470 [C037BF90] [C038AE48] chrp_setup_arch+0x1fc/0x32c [C037BFB0] [C03849B0] setup_arch+0x144/0x188 [C037BFD0] [C037C45C] start_kernel+0x34/0x1a8 [C037BFF0] [000037A0] 0x37a0 PCI bus 0 controlled by pci at c0000000 Top of RAM: 0x10000000, Total RAM: 0x10000000 Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] powerpc: restore clock speed in /proc/cpuinfoOlaf Hering
Use generic_calibrate_decr to restore missing clock: speed in /proc/cpuinfo Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] powerpc: Fix spufs initialization sequence.Geoff Levand
This is a small fix to get the spufs init sequence right. init_spu_base() in spu_base.c should be called (via module_init(init_spu_base)) before spufs_init() (via module_init(spufs_init)) in spufs/inode.c gets called. Signed-off-by: Masato Noguchi <Masato.Noguchi@jp.sony.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-01[PATCH] PowerPC/PCI Hotplug build breakLinas Vepstas
Build break: Building PCI hotplug on PowerPC results in a build break, due to failure to export symbols. Reported today by Dave Jones <davej@redhat.com>: drivers/pci/hotplug/rpaphp.ko needs unknown symbol pcibios_add_pci_devices This patch fixes the break in the arch/powerpc tree. Next patch fixes same problem in drivers/pci tree Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] powerpc: enable irq's for platform functions.Ben Collins
Make the platform function interrupt functions actually work. Calls irq_enable() for the first in the list, and irq_disable() for the last. Added *func to struct irq_client so the the user can pass just that to pmf_unregister_irq_client(). Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31[SUNGEM]: Unbreak Sun GEM chips.David S. Miller
Revert: 40727198bfb2ce5842a6e8c7f89cf8a40ff7bf14 These PHY changes hang the sungem driver on startup with Sun chips on sparc64. Hopefully we can redo these changes in a way that doesn't break non-Apple systems. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-23[SUNGEM]: Make PM of PHYs more reliable (#2)Benjamin Herrenschmidt
On my latest laptop, I've had occasional PHY dead on wakeup from sleep... the PHY would be totally unresponsive even to toggling the hard reset line until the machine is powered down... Looking closely at the code, I found some possible issues in the way we setup the MDIO lines during suspend along with slight divergences from what Darwin does when resetting it that may explain the problem. That patch change these and the problem appear to be gone for me at least... I also fixed an mdelay -> msleep while I was at it to the pmac feature code that is called when toggling the PHY reset line since sungem doesn't call it in an atomic context anymore. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>b Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-15[PATCH] powerpc: Fix Maple buildBenjamin Herrenschmidt
The changes to the device node structure broke Maple build. This fixes it. Unfortunately I coudn't test as my Maple board appears to be dead. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-14[PATCH] powerpc: Make CHRP build againDavid Woodhouse
This makes CHRP build again, although it's untested because my Pegasos is currently in pieces. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-14[PATCH] powerpc: Add MPC834x SYS board to arch/powerpcKumar Gala
Add the first MPC83xx board that uses a flat device tree to arch/powerpc. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-13[PATCH] powerpc: Remove lppaca structure from the PACADavid Gibson
At present the lppaca - the structure shared with the iSeries hypervisor and phyp - is contained within the PACA, our own low-level per-cpu structure. This doesn't have to be so, the patch below removes it, making a separate array of lppaca structures. This saves approximately 500*NR_CPUS bytes of image size and kernel memory, because we don't need aligning gap between the Linux and hypervisor portions of every PACA. On the other hand it means an extra level of dereference in many accesses to the lppaca. The patch also gets rid of several places where we assign the paca address to a local variable for no particular reason. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-13[PATCH] powerpc: Add support for changing properties from userspaceDave C Boutcher
Add support to reconfigure the device tree through the existing proc filesystem interface. Add "add_property", "remove_property", and "update_property" commands to the existing interface. Signed-off-by: Dave Boutcher <sleddog@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
Fix up delete/modify conflict of arch/ppc/kernel/process.c by hand (it's gone, gone, gone). Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] powerpc: task_thread_info()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] powerpc: cell namespace cleanupArnd Bergmann
These symbols are only used in the file that they are defined in, so they should not be in the global namespace. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-12[PATCH] powerpc: pmac namespace cleanupArnd Bergmann
pmac_setup_arch is only used in the file that it is defined in, so it should not be in the global namespace. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-12[PATCH] powerpc: pseries namespace cleanupArnd Bergmann
2006-01-12[PATCH] powerpc: clean up iommu.h a bitStephen Rothwell
There was a function declared for CONFIG_PSERIES which no longer exists and the two function declarations for CONFIG_ISERIES have been moved into an include file in platforms/iseries since they are defined and used only there. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-12[PATCH] powerpc: iSeries fixes for build with no PCIStephen Rothwell
This reverts part of "ppc64 iSeries: allow build with no PCI" (145d01e4287b8cbf50f87c3283e33bf5c84e8468) which affected generic code and applies a fix in the arch specific code. Commit "partly merge iseries do_IRQ" (5fee9b3b39eb55c7e3619a3b36ceeabffeb8f144) introduced iSeries_get_irq which was only available if CONFIG_PCI is set. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-12[PATCH] powerpc: eliminate bitfields from ItLpNacaStephen Rothwell
2006-01-12[PATCH] powerpc: remove bitfields from HvLpEventStephen Rothwell
2006-01-12[PATCH] powerpc: remove warning in EEH codeOlof Johansson
Remove warning in eeh code about mixed variables and code. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-11[PATCH] powerpc: Remove redundant setting of htab_addressMichael Ellerman
iSeries doesn't need to set the htab_address explicitly, htab_initialize() will do it for us later. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-11[PATCH] powerpc: Add ibm,pft-size to iSeries device treeMichael Ellerman
To make iSeries just a teensy bit less special, create ibm,pft-size properties in the iSeries device tree. We can then rely on htab_dt_scan_pftsize() to set ppc64_pft_size for us. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-11[PATCH] powerpc: Updated Kconfig and Makefiles for 83xx supportKumar Gala
Updated Kconfig & Makefiles in prep for adding support for the Freescale MPC83xx family of processors to arch/powerpc. Moved around some config options that are more globally applicable to other PowerPC processors. Added a temporary config option (83xx) to match existing arch/ppc support for the MPC83xx line. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-11[PATCH] spufs: Suspend/restore MFC DMA operations at SPU context switch.Geoff Levand
The SPE Book IV indicates that MFC DMA operations must be suspended and restored on SPU context switch (in Step 8). This patch adds that operation, which is missing from the current spufs implementation. Signed-off-by: Masato Noguchi <Masato.Noguchi@jp.sony.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-11[PATCH] powerpc: Make early debugging configurable via KconfigMichael Ellerman
This patch adds Kconfig entries to control the early debugging options, currently in setup_64.c. Doing this via Kconfig rather than #defines means you can have one source tree, which is buildable for multiple platforms - and you can enable the correct early debug option for each platform via .config. I made udbg_early_init() a static inline because otherwise GCC is to daft to optimise it away when debugging is off. Now that we have udbg_init_rtas() we can make call_rtas_display_status* static. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-11[PATCH] powerpc: Early debugging support for iSeriesMichael Ellerman
Connect iSeries up to the standard early debugging infrastructure. To actually use this you need to enable the iSeries early debugging in setup_64.c. Then after the messages are logged hit Ctrl-x Ctrl-x on your console to dump the Hypervisor console buffer. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
2006-01-10[PATCH] spufs: fix for recent "shrink dentry_struct" patchAndrew Morton
Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
