path: root/arch/powerpc/sysdev/cpm2_pic.h
2007-02-07[POWERPC] cpm2: CPM2 interrupt controller fixVitaly Bordug
This contains important fixes for the CPM2 PIC code. Eliminated CPM_IRQ_OFFSET, pulling the respective interrupt numbers from the interrupt mapping. Updated devicetree files to reflect that. Changed direct IC-related IO accesses to the IO accessors. Fixed all the sense values to keep coherency with ipic. In the current code, CPM2 stuff will have no IRQs and hence could be hardly usable. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-07[POWERPC] Fix up after irq changesOlaf Hering
Remove struct pt_regs * from all handlers. Also remove the regs argument from get_irq() functions. Compile tested with arch/powerpc/config/* and arch/ppc/configs/prep_defconfig Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-03POWERPC: 8272ads merge to powerpc: common stuffVitaly Bordug
This has modules of common directories related to the mpc8272ADS board, mainly common cpm2 changes and fsl_soc.c portions related to the bitbang MDIO and other mechanisms specific for this family. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
2006-09-21POWERPC: Get rid of remapping the whole immrVitaly Bordug
The stuff below cleans up the code attempting to remap the whole cpm2_immr early, as well as places happily assuming that fact. This is more like the 2.4 legacy stuff, and is at least confusing and unclear now. To keep the world comfortable, a new mechanism is introduced: before accessing specific immr register/register set, one needs to map it, using cpm2_map(<reg>), for instance, access to CPM command register will look like volatile cpm_cpm2_t *cp = cpm2_map(im_cpm); keeping the code clear, yet without "already defined somewhere" cpm2_immr. So far, unmapping code is not implemented, but it's not a big deal to add it, if the whole idea makes sense. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
2006-09-21POWERPC: Move generic cpm2 stuff to powerpcVitaly Bordug
This moves the cpm2 common code and PIC stuff to the powerpc. Most of the files were just copied from ppc/, with minor tuning to make it compile, and, subsequently, work. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
