path: root/arch/powerpc/sysdev/fsl_85xx_cache_sram.c
2011-05-19powerpc: Remove ioremap_flagsAnton Blanchard
We have a confusing number of ioremap functions. Make things just a bit simpler by merging ioremap_flags and ioremap_prot. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-10-14powerpc/85xx: add cache-sram supportHarninder Rai
It adds cache-sram support in P1/P2 QorIQ platforms as under: * A small abstraction over powerpc's remote heap allocator * Exports mpc85xx_cache_sram_alloc()/free() APIs * Supports only one contiguous SRAM window * Drivers can do the following in Kconfig to use these APIs "select FSL_85XX_CACHE_SRAM if MPC85xx" * Required SRAM size and the offset where SRAM should be mapped must be provided at kernel command line as : cache-sram-size=<value> cache-sram-offset=<offset> Signed-off-by: Harninder Rai <harninder.rai@freescale.com> Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
