Parsing and registration of fixed PHY devices was needed with the use of
of_phy_connect_fixed_link() because this function was using the
designated PHY address identifier (first cell of the property) as the
address to bind the PHY on the emulated bus.
Since commit 3be2a49e5c08d268f8af0dd4fe89a24ea8cdc339 ("of: provide a
binding for fixed link PHYs") a new pair of functions has been
introduced which allows for dynamic address allocation of these fixed
PHY devices, but also parses the old 'fixed-link' 5-digit property.
Registration of fixed PHY early in platform code was needed because we
could not issue a fixed MDIO bus re-scan within network drivers. The
fixed PHYs had to be registered before the network drivers would call
of_phy_connect_fixed_link(). All of these caveats are solved now, such
that we can safely remove of_add_fixed_phys() now.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
arch/powerpc/sysdev/fsl_soc.c:70:67: warning: incorrect type in argument 2 (different base types)
arch/powerpc/sysdev/fsl_soc.c:70:67: expected restricted __be32 const [usertype] *addr
arch/powerpc/sysdev/fsl_soc.c:70:67: got unsigned int const [usertype] *
Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com>
Disintegrate asm/system.h for PowerPC.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
cc: linuxppc-dev@lists.ozlabs.org
All these files were including module.h just for the basic
EXPORT_SYMBOL infrastructure. We can shift them off to the
export.h header which is a way smaller footprint and thus
realize some compile time gains.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Add functions to restart and halt the current partition when running under
the Freescale hypervisor. These functions should be assigned to various
function pointers of the ppc_md structure during the .probe() function for
the board:
ppc_md.restart = fsl_hv_restart;
ppc_md.power_off = fsl_hv_halt;
ppc_md.halt = fsl_hv_halt;
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (141 commits)
USB: mct_u232: fix broken close
USB: gadget: amd5536udc.c: fix error path
USB: imx21-hcd - fix off by one resource size calculation
usb: gadget: fix Kconfig warning
usb: r8a66597-udc: Add processing when USB was removed.
mxc_udc: add workaround for ENGcm09152 for i.MX35
USB: ftdi_sio: add device ids for ScienceScope
USB: musb: AM35x: Workaround for fifo read issue
USB: musb: add musb support for AM35x
USB: AM35x: Add musb support
usb: Fix linker errors with CONFIG_PM=n
USB: ohci-sh - use resource_size instead of defining its own resource_len macro
USB: isp1362-hcd - use resource_size instead of defining its own resource_len macro
USB: isp116x-hcd - use resource_size instead of defining its own resource_len macro
USB: xhci: Fix compile error when CONFIG_PM=n
USB: accept some invalid ep0-maxpacket values
USB: xHCI: PCI power management implementation
USB: xHCI: bus power management implementation
USB: xHCI: port remote wakeup implementation
USB: xHCI: port power management implementation
Manually fix up (non-data) conflict: the SCSI merge gad renamed the
'hw_sector_size' member to 'physical_block_size', and the USB tree
brought a new use of it.
Replace FSL USB platform code by simple platform driver for
creation of FSL USB platform devices.
The driver creates platform devices based on the information
from USB nodes in the flat device tree. This is the replacement
for old arch fsl_soc usb code removed by this patch. The driver
uses usual of-style binding, available EHCI-HCD and UDC
drivers can be bound to the created devices. The new of-style
driver additionaly instantiates USB OTG platform device, as the
appropriate USB OTG driver will be added soon.
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
The first global-utilities node might not contain the rstcr
property, so we should search all the nodes
Signed-off-by: Matthew McClintock <msm@freescale.com>
Acked-by: Timur Tabi <timur@freescale.com>
Introduce new FSL_SOC_BOOKE Kconfig to handle both 85xx and QorIQ
based chips.
Some CPU, like the MPC8560 don't have a RSTCR in the Global
Utilities Block. These boards will implement their own reboot
call, and not use this code, so we should only warn about the
absence of the GUTS RSTCR when the default reboot code is used.
The rstcr register mapping code was written sometime ago before
of_iomap() existed. We can use it and clean up the code a bit
and get rid of one user of get_immrbase() in the process.
commit b31a1d8b41513b96e9c7ec2f68c5734cef0b26a4 ("gianfar: Convert
gianfar to an of_platform_driver"), possibly due merge issues,
reintroduced completely unneded mpc83xx_wdt_init call, which
I removed some time ago in commit 20d38e01d48019c578ab0ec1464454c0
("powerpc/fsl_soc: remove mpc83xx_wdt code").
Remove it once again.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
The advantages of this:
- Don't encourage legacy support;
- Less external symbols, less code to compile-in for !MPC832x_RDB
platforms.
Cc: David Brownell <david-b@pacbell.net>
Cc: Kumar Gala <galak@gate.crashing.org>
The main purpose of this patch is to pass 'struct spi_device' to the chip
select handling routines. This is needed so that we could implement
full-fledged OpenFirmware support for this driver.
While at it, also:
- Replace two {de,activate}_cs routines by single cs_contol().
- Don't duplicate platform data callbacks in mpc83xx_spi struct.
On MPC837X CPUs Dual-Role USB isn't always available (for example DR
USB pins can be muxed away to eSDHC).
U-Boot adds status = "disabled" property into the DR USB nodes to
indicate that we must not try to configure or probe Dual-Role USB,
otherwise we'll break eSDHC support on targets with MPC837X CPUs.
Does the same for the accompanying MDIO driver, and then modifies the TBI
configuration method. The old way used fields in einfo, which no longer
exists. The new way is to create an MDIO device-tree node for each instance
of gianfar, and create a tbi-handle property to associate ethernet controllers
with the TBI PHYs they are connected to.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The init_phy() function attaches to the PHY, then configures the
SerDes<->TBI link (in SGMII mode). The TBI is on the MDIO bus with the PHY
(sort of) and is accessed via the gianfar's MDIO registers, using the
functions gfar_local_mdio_read/write(), which don't do any locking.
The previously attached PHY will start a work-queue on a timer, and
probably an irq handler as well, which will talk to the PHY and thus use
the MDIO bus. This uses phy_read/write(), which have locking, but not
against the gfar_local_mdio versions.
The result is that PHY code will try to use the MDIO bus at the same time
as the SerDes setup code, corrupting the transfers.
Setting up the SerDes before attaching to the PHY will insure that there is
no race between the SerDes code and *our* PHY, but doesn't fix everything.
Typically the PHYs for all gianfar devices are on the same MDIO bus, which
is associated with the first gianfar device. This means that the first
gianfar's SerDes code could corrupt the MDIO transfers for a different
gianfar's PHY.
The lock used by phy_read/write() is contained in the mii_bus structure,
which is pointed to by the PHY. This is difficult to access from the
gianfar drivers, as there is no link between a gianfar device and the
mii_bus which shares the same MDIO registers. As far as the device layer
and drivers are concerned they are two unrelated devices (which happen to
share registers).
Generally all gianfar devices' PHYs will be on the bus associated with the
first gianfar. But this might not be the case, so simply locking the
gianfar's PHY's mii bus might not lock the mii bus that the SerDes setup
code is going to use.
We solve this by having the code that creates the gianfar platform device
look in the device tree for an mdio device that shares the gianfar's
registers. If one is found the ID of its platform device is saved in the
gianfar's platform data.
A new function in the gianfar mii code, gfar_get_miibus(), can use the bus
ID to search through the platform devices for a gianfar_mdio device with
the right ID. The platform device's driver data is the mii_bus structure,
which the SerDes setup code can use to lock the current bus.
Signed-off-by: Trent Piepho <tpiepho@freescale.com>
CC: Andy Fleming <afleming@freescale.com>
Early versions of the Freescale DIU framebuffer driver depended on a bootmem
allocation of memory for the video buffer. The need for this feature was
removed in commit 6b51d51a, so now we can remove the platform-specific code
that allocated that memory.
mpc83xx_wdt is the OF driver now, so we don't need fsl_soc constructor.
The old code assumed there was only one, but the 8572 actually has 3.
Also, our usual id, 0xe0024520, gets resolved to -1 somewhere, and this was
preventing the multiple buses from having different ids. So we only keep
the low 20 bits, which have the interesting info, anyway.
Freescale ships MPC8315E-RDB boards in two variants:
1. With TSEC1 ethernet support and USB UTMI PHY;
2. Without TSEC1 support, but with USB ULPI PHY in addition.
For the second case U-Boot will add status = "disabled"; property
into the TSEC1 node, so Linux should not try to probe it.
Convert i2c-mpc to an of_platform driver. Utilize the code in
drivers/of-i2c.c to make i2c modules dynamically loadable by the
device tree.
Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
Change the name of the device from "rtc-ds1374" to just "ds1374", to match
what all other RTC drivers do. I seem to remember that this name was
chosen to avoid possible confusion with an older ds1374 driver, but that
driver was removed 3 months ago.
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Currently, fsl_i2c_of_init() uses the order of the I2C adapter nodes in the
device tree to enumerate the I2C adapters. Instead, let's check for the
cell-index property and use it if it exists.
This is handy for device drivers that need to identify the I2C adapters by
specific numbers. The Freescale MPC8610 ASoC V2 sound drivers are an example.
The i2c_devices[] array in fsl_soc.c lists all the I2C nodes that are supported
on Freescale boards. Add an entry for the Cirrus Logic CS4270 so that a
new-style CS4270 driver will work.
Update of_find_i2c_driver in fsl_soc.c to display a warning message if an
I2C node in the device tree isn't found in the i2c_devices[] array.
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Bolt in SLB entry for kernel stack on secondary cpus
[POWERPC] PS3: Update ps3_defconfig
[POWERPC] PS3: Remove unsupported wakeup sources
[POWERPC] PS3: Make ps3_virq_setup and ps3_virq_destroy static
[POWERPC] PS3: Add time include to lpm
[POWERPC] Fix slb.c compile warnings
[POWERPC] Xilinx: Fix compile warnings
[POWERPC] Squash build warning for print of resource_size_t in fsl_soc.c
[RAPIDIO] fix current kernel-doc notation
[POWERPC] 86xx: mpc8610_hpcd: add support for PCI Express x8 slot
Fix a potential issue in mpc52xx uart driver
[POWERPC] mpc5200: Allow for fixed speed MII configurations
[POWERPC] 86xx: Fix the wrong serial1 interrupt for 8610 board
When resource_size_t is larger than an int, the current code
generates a build warning. Kill it.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Based on earlier work by Jon Smirl and Jochen Friedrich.
Update most new-style i2c drivers to use standard module aliasing
instead of the old driver_name/type driver matching scheme. I've
left the video drivers apart (except for SoC camera drivers) as
they're a bit more diffcult to deal with, they'll have their own
patch later.
Cc: Jon Smirl <jonsmirl@gmail.com>
Cc: Jochen Friedrich <jochen@scram.de>
Add platform code to support Freescale DIU. The platform code includes
framebuffer memory allocation, pixel format, monitor port, etc.
Signed-off-by: York Sun <yorksun@freescale.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits)
[POWERPC] Fix compile breakage for 64-bit UP configs
[POWERPC] Define copy_siginfo_from_user32
[POWERPC] Add compat handler for PTRACE_GETSIGINFO
[POWERPC] i2c: Fix build breakage introduced by OF helpers
[POWERPC] Optimize fls64() on 64-bit processors
[POWERPC] irqtrace support for 64-bit powerpc
[POWERPC] Stacktrace support for lockdep
[POWERPC] Move stackframe definitions to common header
[POWERPC] Fix device-tree locking vs. interrupts
[POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const
[POWERPC] Remove unused __max_memory variable
[POWERPC] Simplify xics direct/lpar irq_host setup
[POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ()
[POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade()
[POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c
[POWERPC] Use asm-generic/bitops/find.h in bitops.h
[POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup
[POWERPC] 85xx: Fix the size of qe muram for MPC8568E
[POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier.
[POWERPC] 86xx: mark functions static, other minor cleanups
The kconfig entry can go away once arch/ppc and references to the config in
drivers are removed.
Having the id field be an int was making more complex bus topologies
excessively difficult. For now, just convert it to a string, and
change all instances of "bus->id = val" to
snprintf(id, MII_BUS_ID_LEN, "%x", val).
calling platform_device_register after platform_device_alloc causes
this:
kobject (c3841a70): tried to init an initialized object, something is seriously wrong.
Call Trace:
[c381fe20] [c0007bb8] show_stack+0x3c/0x194 (unreliable)
[c381fe50] [c01322a8] kobject_init+0xb8/0xbc
[c381fe60] [c01591cc] device_initialize+0x30/0x9c
[c381fe80] [c015ee34] platform_device_register+0x1c/0x34
[c381fea0] [c02f1fe0] of_fsl_spi_probe+0x21c/0x22c
[c381ff30] [c02f2044] fsl_spi_init+0x54/0x160
[c381ff60] [c02f3924] __machine_initcall_mpc832x_rdb_mpc832x_spi_init+0x120/0x138
[c381ff70] [c02e61b4] kernel_init+0x98/0x284
[c381fff0] [c000f740] kernel_thread+0x44/0x60
fixed by calling platform_device_add (second half of
platform_device_register) instead.
Also:
- rename "fsl_spi" to "fsl,spi";
- add and use cell-index property, if found;
- split probing code out of fsl_spi_init, thus we can call
it for legacy device_type probing and new "compatible" probing.
In case of QE we can use brg-frequency (which is qeclk/2).
Thus no need to divide sysclk in the spi_mpc83xx.
This patch also adds code to use get_brgfreq() on QE chips.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Now we're searching for "fsl,qe", "fsl,qe-muram", "fsl,qe-muram-data"
and "fsl,qe-ic".
Unfortunately it's still impossible to remove device_type = "qe"
from the existing device trees because older u-boots are looking for it.
Don't depend on the reg property as a way to determine the base
of the immr space. The reg property might be defined differently for
different SoC families.
fixed-link says: register new "Fixed/emulated PHY", i.e. PHY that
not connected to the real MDIO bus.
Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org>
Remove device_type = "usb" for 83xx SoC USB controller
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
* Removed address fields in ethernet nodes
* Removed #address-cells, #size-cells from gianfar nodes
* Added cell-index to gianfar and ucc ethernet nodes
* Added enet[0..3] labels
* Renamed compatible node for gianfar mdio to "fsl,gianfar-mdio"
* Removed device_type = "mdio"
The matching for gianfar mdio still supports the old "mdio"/"gianfar" combo
but it is now considered deprecated.
* Removed device_type = "i2c"
* Added missing second I2C controller on MPC8548 CDS, MPC8544 DS
* Added #address-cells, #size-cells, and cell-index where missing
On non-QE processors (mpc831x/mpc834x) the SPI clock is the SoC clock.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
On the majority of 85xx & 86xx we have a register that's ability to
assert HRESET_REQ to reset the board. We refactored that code so it
can be shared between both platforms into fsl_soc.c and removed all
the duplication in each platform directory.
