path: root/arch/powerpc/sysdev/fsl_soc.c
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (141 commits) USB: mct_u232: fix broken close USB: gadget: amd5536udc.c: fix error path USB: imx21-hcd - fix off by one resource size calculation usb: gadget: fix Kconfig warning usb: r8a66597-udc: Add processing when USB was removed. mxc_udc: add workaround for ENGcm09152 for i.MX35 USB: ftdi_sio: add device ids for ScienceScope USB: musb: AM35x: Workaround for fifo read issue USB: musb: add musb support for AM35x USB: AM35x: Add musb support usb: Fix linker errors with CONFIG_PM=n USB: ohci-sh - use resource_size instead of defining its own resource_len macro USB: isp1362-hcd - use resource_size instead of defining its own resource_len macro USB: isp116x-hcd - use resource_size instead of defining its own resource_len macro USB: xhci: Fix compile error when CONFIG_PM=n USB: accept some invalid ep0-maxpacket values USB: xHCI: PCI power management implementation USB: xHCI: bus power management implementation USB: xHCI: port remote wakeup implementation USB: xHCI: port power management implementation ... Manually fix up (non-data) conflict: the SCSI merge gad renamed the 'hw_sector_size' member to 'physical_block_size', and the USB tree brought a new use of it.
2010-10-22USB: add platform glue driver for FSL USB DR controllerAnatolij Gustschin
Replace FSL USB platform code by simple platform driver for creation of FSL USB platform devices. The driver creates platform devices based on the information from USB nodes in the flat device tree. This is the replacement for old arch fsl_soc usb code removed by this patch. The driver uses usual of-style binding, available EHCI-HCD and UDC drivers can be bound to the created devices. The new of-style driver additionaly instantiates USB OTG platform device, as the appropriate USB OTG driver will be added soon. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-14powerpc/fsl_soc: Search all global-utilities nodes for rstccrMatthew McClintock
The first global-utilities node might not contain the rstcr property, so we should search all the nodes Signed-off-by: Matthew McClintock <msm@freescale.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-11-20powerpc/85xx: Kconfig cleanupKumar Gala
Introduce new FSL_SOC_BOOKE Kconfig to handle both 85xx and QorIQ based chips. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-24powerpc/85xx: issue fsl_soc reboot warning only when applicablePaul Gortmaker
Some CPU, like the MPC8560 don't have a RSTCR in the Global Utilities Block. These boards will implement their own reboot call, and not use this code, so we should only warn about the absence of the GUTS RSTCR when the default reboot code is used. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-05-19powerpc/fsl: use of_iomap() for rstcr mappingKumar Gala
The rstcr register mapping code was written sometime ago before of_iomap() existed. We can use it and clean up the code a bit and get rid of one user of get_immrbase() in the process. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-05-08powerpc/fsl_soc: Remove mpc83xx_wdt_init, againAnton Vorontsov
commit b31a1d8b41513b96e9c7ec2f68c5734cef0b26a4 ("gianfar: Convert gianfar to an of_platform_driver"), possibly due merge issues, reintroduced completely unneded mpc83xx_wdt_init call, which I removed some time ago in commit 20d38e01d48019c578ab0ec1464454c0 ("powerpc/fsl_soc: remove mpc83xx_wdt code"). Remove it once again. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-01powerpc/fsl_soc: isolate legacy fsl_spi support to mpc832x_rdb boardsAnton Vorontsov
The advantages of this: - Don't encourage legacy support; - Less external symbols, less code to compile-in for !MPC832x_RDB platforms. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <david-b@pacbell.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01spi_mpc83xx: rework chip selects handlingAnton Vorontsov
The main purpose of this patch is to pass 'struct spi_device' to the chip select handling routines. This is needed so that we could implement full-fledged OpenFirmware support for this driver. While at it, also: - Replace two {de,activate}_cs routines by single cs_contol(). - Don't duplicate platform data callbacks in mpc83xx_spi struct. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <david-b@pacbell.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-09powerpc/83xx: Do not configure or probe disabled FSL DR USB controllersAnton Vorontsov
On MPC837X CPUs Dual-Role USB isn't always available (for example DR USB pins can be muxed away to eSDHC). U-Boot adds status = "disabled" property into the DR USB nodes to indicate that we must not try to configure or probe Dual-Role USB, otherwise we'll break eSDHC support on targets with MPC837X CPUs. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-16gianfar: Convert gianfar to an of_platform_driverAndy Fleming
Does the same for the accompanying MDIO driver, and then modifies the TBI configuration method. The old way used fields in einfo, which no longer exists. The new way is to create an MDIO device-tree node for each instance of gianfar, and create a tbi-handle property to associate ethernet controllers with the TBI PHYs they are connected to. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31gianfar: Fix race in TBI/SerDes configurationTrent Piepho
The init_phy() function attaches to the PHY, then configures the SerDes<->TBI link (in SGMII mode). The TBI is on the MDIO bus with the PHY (sort of) and is accessed via the gianfar's MDIO registers, using the functions gfar_local_mdio_read/write(), which don't do any locking. The previously attached PHY will start a work-queue on a timer, and probably an irq handler as well, which will talk to the PHY and thus use the MDIO bus. This uses phy_read/write(), which have locking, but not against the gfar_local_mdio versions. The result is that PHY code will try to use the MDIO bus at the same time as the SerDes setup code, corrupting the transfers. Setting up the SerDes before attaching to the PHY will insure that there is no race between the SerDes code and *our* PHY, but doesn't fix everything. Typically the PHYs for all gianfar devices are on the same MDIO bus, which is associated with the first gianfar device. This means that the first gianfar's SerDes code could corrupt the MDIO transfers for a different gianfar's PHY. The lock used by phy_read/write() is contained in the mii_bus structure, which is pointed to by the PHY. This is difficult to access from the gianfar drivers, as there is no link between a gianfar device and the mii_bus which shares the same MDIO registers. As far as the device layer and drivers are concerned they are two unrelated devices (which happen to share registers). Generally all gianfar devices' PHYs will be on the bus associated with the first gianfar. But this might not be the case, so simply locking the gianfar's PHY's mii bus might not lock the mii bus that the SerDes setup code is going to use. We solve this by having the code that creates the gianfar platform device look in the device tree for an mdio device that shares the gianfar's registers. If one is found the ID of its platform device is saved in the gianfar's platform data. A new function in the gianfar mii code, gfar_get_miibus(), can use the bus ID to search through the platform devices for a gianfar_mdio device with the right ID. The platform device's driver data is the mii_bus structure, which the SerDes setup code can use to lock the current bus. Signed-off-by: Trent Piepho <tpiepho@freescale.com> CC: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-13powerpc: remove support for bootmem-allocated memory for the DIU driverTimur Tabi
Early versions of the Freescale DIU framebuffer driver depended on a bootmem allocation of memory for the video buffer. The need for this feature was removed in commit 6b51d51a, so now we can remove the platform-specific code that allocated that memory. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-29powerpc/fsl_soc: remove mpc83xx_wdt codeAnton Vorontsov
mpc83xx_wdt is the OF driver now, so we don't need fsl_soc constructor. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-16gianfar: Add magic packet and suspend/resume support.Scott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-16powerpc: Add support for multiple gfar mdio interfacesAndy Fleming
The old code assumed there was only one, but the 8572 actually has 3. Also, our usual id, 0xe0024520, gets resolved to -1 somewhere, and this was preventing the multiple buses from having different ids. So we only keep the low 20 bits, which have the interesting info, anyway. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-16powerpc/fsl_soc: gianfar: don't probe disabled devicesAnton Vorontsov
Freescale ships MPC8315E-RDB boards in two variants: 1. With TSEC1 ethernet support and USB UTMI PHY; 2. Without TSEC1 support, but with USB ULPI PHY in addition. For the second case U-Boot will add status = "disabled"; property into the TSEC1 node, so Linux should not try to probe it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-12powerpc/i2c: Convert i2c-mpc into an of_platform driverJon Smirl
Convert i2c-mpc to an of_platform driver. Utilize the code in drivers/of-i2c.c to make i2c modules dynamically loadable by the device tree. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-06-09Merge branch 'merge'Paul Mackerras
Conflicts: arch/powerpc/sysdev/fsl_soc.c
2008-06-06rtc-ds1374: rename device to just "ds1374"Jean Delvare
Change the name of the device from "rtc-ds1374" to just "ds1374", to match what all other RTC drivers do. I seem to remember that this name was chosen to avoid possible confusion with an older ds1374 driver, but that driver was removed 3 months ago. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Kumar Gala <galak@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-02[POWERPC] fsl: Update fsl_soc to use cell-index property of I2C nodesTimur Tabi
Currently, fsl_i2c_of_init() uses the order of the I2C adapter nodes in the device tree to enumerate the I2C adapters. Instead, let's check for the cell-index property and use it if it exists. This is handy for device drivers that need to identify the I2C adapters by specific numbers. The Freescale MPC8610 ASoC V2 sound drivers are an example. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-02[POWERPC] fsl: Add CS4270 i2c data to fsl_soc.cTimur Tabi
The i2c_devices[] array in fsl_soc.c lists all the I2C nodes that are supported on Freescale boards. Add an entry for the Cirrus Logic CS4270 so that a new-style CS4270 driver will work. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-02[POWERPC] fsl: Add warning for unrecognized I2C nodes in the device treeTimur Tabi
Update of_find_i2c_driver in fsl_soc.c to display a warning message if an I2C node in the device tree isn't found in the i2c_devices[] array. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-05-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Bolt in SLB entry for kernel stack on secondary cpus [POWERPC] PS3: Update ps3_defconfig [POWERPC] PS3: Remove unsupported wakeup sources [POWERPC] PS3: Make ps3_virq_setup and ps3_virq_destroy static [POWERPC] PS3: Add time include to lpm [POWERPC] Fix slb.c compile warnings [POWERPC] Xilinx: Fix compile warnings [POWERPC] Squash build warning for print of resource_size_t in fsl_soc.c [RAPIDIO] fix current kernel-doc notation [POWERPC] 86xx: mpc8610_hpcd: add support for PCI Express x8 slot Fix a potential issue in mpc52xx uart driver [POWERPC] mpc5200: Allow for fixed speed MII configurations [POWERPC] 86xx: Fix the wrong serial1 interrupt for 8610 board
2008-05-01[POWERPC] Squash build warning for print of resource_size_t in fsl_soc.cBecky Bruce
When resource_size_t is larger than an int, the current code generates a build warning. Kill it. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-29i2c: Convert most new-style drivers to use module aliasingJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. Update most new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. I've left the video drivers apart (except for SoC camera drivers) as they're a bit more diffcult to deal with, they'll have their own patch later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Jochen Friedrich <jochen@scram.de>
2008-04-28powerpc: Add DIU platform code for MPC8610HPCDYork Sun
Add platform code to support Freescale DIU. The platform code includes framebuffer memory allocation, pixel format, monitor port, etc. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits) [POWERPC] Fix compile breakage for 64-bit UP configs [POWERPC] Define copy_siginfo_from_user32 [POWERPC] Add compat handler for PTRACE_GETSIGINFO [POWERPC] i2c: Fix build breakage introduced by OF helpers [POWERPC] Optimize fls64() on 64-bit processors [POWERPC] irqtrace support for 64-bit powerpc [POWERPC] Stacktrace support for lockdep [POWERPC] Move stackframe definitions to common header [POWERPC] Fix device-tree locking vs. interrupts [POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const [POWERPC] Remove unused __max_memory variable [POWERPC] Simplify xics direct/lpar irq_host setup [POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ() [POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade() [POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c [POWERPC] Use asm-generic/bitops/find.h in bitops.h [POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup [POWERPC] 85xx: Fix the size of qe muram for MPC8568E [POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier. [POWERPC] 86xx: mark functions static, other minor cleanups ...
2008-04-17[POWERPC] fsl_soc: Factor fsl_get_sys_freq() out of the wdt and spi inits.Scott Wood
2008-04-17[POWERPC] CPM: Always use new binding.Scott Wood
The kconfig entry can go away once arch/ppc and references to the config in drivers are removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-16phy: Change mii_bus id field to a stringAndy Fleming
Having the id field be an int was making more complex bus topologies excessively difficult. For now, just convert it to a string, and change all instances of "bus->id = val" to snprintf(id, MII_BUS_ID_LEN, "%x", val). Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-05[POWERPC] FSL: fix mpc83xx_spi device registrationKim Phillips
calling platform_device_register after platform_device_alloc causes this: kobject (c3841a70): tried to init an initialized object, something is seriously wrong. Call Trace: [c381fe20] [c0007bb8] show_stack+0x3c/0x194 (unreliable) [c381fe50] [c01322a8] kobject_init+0xb8/0xbc [c381fe60] [c01591cc] device_initialize+0x30/0x9c [c381fe80] [c015ee34] platform_device_register+0x1c/0x34 [c381fea0] [c02f1fe0] of_fsl_spi_probe+0x21c/0x22c [c381ff30] [c02f2044] fsl_spi_init+0x54/0x160 [c381ff60] [c02f3924] __machine_initcall_mpc832x_rdb_mpc832x_spi_init+0x120/0x138 [c381ff70] [c02e61b4] kernel_init+0x98/0x284 [c381fff0] [c000f740] kernel_thread+0x44/0x60 fixed by calling platform_device_add (second half of platform_device_register) instead. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] fsl_spi: stop using device_type = "spi"Anton Vorontsov
Also: - rename "fsl_spi" to "fsl,spi"; - add and use cell-index property, if found; - split probing code out of fsl_spi_init, thus we can call it for legacy device_type probing and new "compatible" probing. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28spi_mpc83xx: use brg-frequency for SPI in QEAnton Vorontsov
In case of QE we can use brg-frequency (which is qeclk/2). Thus no need to divide sysclk in the spi_mpc83xx. This patch also adds code to use get_brgfreq() on QE chips. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] QE: get rid of most device_types and modelAnton Vorontsov
Now we're searching for "fsl,qe", "fsl,qe-muram", "fsl,qe-muram-data" and "fsl,qe-ic". Unfortunately it's still impossible to remove device_type = "qe" from the existing device trees because older u-boots are looking for it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-23[POWERPC] fsl_soc: Fix get_immrbase() to use ranges, rather than reg.Scott Wood
Don't depend on the reg property as a way to determine the base of the immr space. The reg property might be defined differently for different SoC families. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-23[POWERPC] fsl_soc: add support to gianfar for fixed-link propertyVitaly Bordug
fixed-link says: register new "Fixed/emulated PHY", i.e. PHY that not connected to the real MDIO bus. Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-23[POWERPC] 83xx: USB device tree cleanupsLi Yang
Remove device_type = "usb" for 83xx SoC USB controller Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-17[POWERPC] Use for_each macros in arch/powerpc/sysdevCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-12[POWERPC] FSL: enet device tree cleanupsKumar Gala
* Removed address fields in ethernet nodes * Removed #address-cells, #size-cells from gianfar nodes * Added cell-index to gianfar and ucc ethernet nodes * Added enet[0..3] labels * Renamed compatible node for gianfar mdio to "fsl,gianfar-mdio" * Removed device_type = "mdio" The matching for gianfar mdio still supports the old "mdio"/"gianfar" combo but it is now considered deprecated. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11[POWERPC] FSL: I2C device tree cleanupsKumar Gala
* Removed device_type = "i2c" * Added missing second I2C controller on MPC8548 CDS, MPC8544 DS * Added #address-cells, #size-cells, and cell-index where missing Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-08[POWERPC] spi: Support non-QE processorsPeter Korsgaard
On non-QE processors (mpc831x/mpc834x) the SPI clock is the SoC clock. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-08[POWERPC] 85xx/86xx: refactor RSTCR reset codeKumar Gala
On the majority of 85xx & 86xx we have a register that's ability to assert HRESET_REQ to reset the board. We refactored that code so it can be shared between both platforms into fsl_soc.c and removed all the duplication in each platform directory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-04[POWERPC] MPC8568E-MDS: add support for ds1374 rtcAnton Vorontsov
MPC8568E-MDS have DS1374 chip on the I2C bus, thus let's use it. This patch also adds #address-cells and #size-cells to the I2C controllers nodes. p.s. DS1374 rtc class driver is in the -mm tree, its name is rtc-rtc-class-driver-for-the-ds1374.patch. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-04[POWERPC] fsl_soc: fix uninitialized i2c_board_info structureAnton Vorontsov
i2c_board_info used semi-initialized, causing garbage in the info->flags, and that, in turn, causes various symptoms of i2c malfunctioning, like PEC mismatches. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-04[POWERPC] fsl_soc: rtc-ds1307 supportPeter Korsgaard
Add support for the I2C devices handled by the rtc-ds1307 driver to of_register_i2c_devices. Cc: G. Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-04[POWERPC] fsl_soc: Fix trivial printk typo.Peter Korsgaard
Fix a trivial printk typo in fsl_soc. Cc: G. Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-03[POWERPC] Introduce new CPM device bindings.Scott Wood
This introduces a new device binding for the CPM and other devices on these boards. Some of the changes include: 1. Proper namespace scoping for Freescale compatibles and properties. 2. Use compatible rather than things like device_type and model to determine which particular variant of a device is present. 3. Give the drivers the relevant CPM command word directly, rather than requiring it to have a lookup table based on device-id, SCC v. SMC, and CPM version. 4. Specify the CPCR and the usable DPRAM region in the CPM's reg property. Boards that do not require the legacy bindings should select CONFIG_PPC_CPM_NEW_BINDING to enable the of_platform CPM devices. Once all existing boards are converted and tested, the config option can become default y to prevent new boards from using the old model. Once arch/ppc is gone, the config option can be removed altogether. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-03[POWERPC] CPM: Change from fsl,brg-frequency to brg/clock-frequencyScott Wood
As suggested by David Gibson, now that we have a separate node for the baud rate generators, it's better to use the standard clock-frequency property than a cpm-node-level fsl,brg-frequency property. This patch updates existing places where fsl,brg-frequency is used. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-14[POWERPC] fsl_soc: add support for fsl_spiAnton Vorontsov
Add helper function to setup SPI bus/device information Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
