This patch adds basic endpoint support to the 4xx PCIe driver.
This is done by checking the device_type property of the PCIe
device node ("pci" for root-complex and "pci-endpoint" for endpoint
configuration).
Note: Currently we map a fixed 64MByte window to PLB address 0 (SDRAM).
This should probably be configurable via a dts property.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
The patch fixes a bug, where the PESDRn_UTLSET1 register was setup
wrongly resulting in a non working PCIe port 1. With this fix both
PCIe ports work fine again.
Since the arch/powerpc PCI subsystem now does a complete re-assignment of
the resources, we can move from the unconditional PCIe PHY reset to the
conditional version. Now the PHY is only reset, if no link is established yet.
An additional PHY reset (one is already done in U-Boot) leads to problems
with some Atheros PCIe boards and some HP FPGA PCIe designs.
Use dcri_clrset() for PCIe SDR0 read/modify/write access.
Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com>
All this code is needed to properly initialize the 460EX PCIe host
bridge(s). We re-initialize all ports again, even though this has been done
in the bootloader (U-Boot) before. This way we make sure, that we always
run the latest init code in Linux and don't depend on code versions from
U-Boot.
Unfortunately all IBM/AMCC chips currently supported in this PCIe driver need
a different reset-/init-sequence.
Tested on AMCC Canyonlands eval board.
Because of how big mapping the config space is (1M per bus), we limit how
many busses we support for now. In the long run, we could replace that
with something akin to kmap_atomic instead.
This patch changes the limit from currently 16 to 64.
This patch sets the ibpre flag (Inbound Presence) for the 405EX
in the 4xx PCIe driver.
This patch adds runtime detection of the 440SPe revision A chips. These
chips are equipped with a slighly different PCIe core and need special/
different initialization. The compatible node is changed to
"plb-pciex-440spe" ("A" and "B" dropped). This is needed for boards that
can be equipped with both PPC revisions like the AMCC Yucca.
This improves the way the 4xx PCI-E code handles checking for a link
and adds explicit testing of CRS result codes on config space accesses.
This should make it more reliable.
Also, bridges with no link are now still created, though config space
accesses beyond the root complex are filtered. This is one step toward
eventually supporting hotplug.
This adds to the previous 2 patches the support for the 4xx PCI Express
cells as found in the 440SPe revA, revB and 405EX.
Unfortunately, due to significant differences between these, and other
interesting "features" of those pieces of HW, the code isn't as simple
as it is for PCI and PCI-X and some of the functions differ significantly
between the 3 implementations. Thus, not only this code can only support
those 3 implementations for now and will refuse to operate on any other,
but there are added ifdef's to avoid the bloat of building a fairly large
amount of code on platforms that don't need it.
Also, this code currently only supports fully initializing root complex
nodes, not endpoint. Some more code will have to be lifted from the
arch/ppc implementation to add the endpoint support, though it's mostly
differences in memory mapping, and the question on how to represent
endpoint mode PCI in the device-tree is thus open.
Many thanks to Stefan Roese for testing & fixing up the 405EX bits !
This adds to the previous patch the support for the 4xx PCI 2.x
bridges.
This adds base support code for the 4xx PCI-X bridge. It also provides
placeholders for the PCI and PCI-E version but they aren't supported
with this patch.
The bridges are configured based on device-tree properties.
