[ Upstream commit 3ab3a0689e74e6aa5b41360bc18861040ddef5b1 ]
When testing out gpio-keys with a button, a spurious
interrupt (and therefore a key press or release event)
gets triggered as soon as the driver enables the irq
line for the first time.
This patch clears any potential bogus generated interrupt
that was caused by the switching of the associated irq's
type and polarity.
Signed-off-by: Christian Lamparter <chunkeey@gmail.com>
[ Upstream commit c42d3be0c06f0c1c416054022aa535c08a1f9b39 ]
The problem is the the calculation should be "end - start + 1" but the
plus one is missing in this calculation.
Fixes: 8626816e905e ("powerpc: add support for MPIC message register API")
Reviewed-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
[ Upstream commit 0834d627fbea00c1444075eb3e448e1974da452d ]
In mpic_physmask() we loop over all CPUs up to 32, then get the hard
SMP processor id of that CPU.
Currently that's possibly walking off the end of the paca array, but
in a future patch we will change the paca array to be an array of
pointers, and in that case we will get a NULL for missing CPUs and
oops. eg:
Unable to handle kernel paging request for data at address 0x88888888888888b8
Faulting instruction address: 0xc00000000004e380
Oops: Kernel access of bad area, sig: 11 [#1]
NIP .mpic_set_affinity+0x60/0x1a0
LR .irq_do_set_affinity+0x48/0x100
Fix it by checking the CPU is possible, this also fixes the code if
there are gaps in the CPU numbering which probably never happens on
mpic systems but who knows.
Debugged-by: Nicholas Piggin <npiggin@gmail.com>
[ Upstream commit 3c29b6038828c1f4c9ecbfec14d4fc5e25f1c947 ]
IRQ 0 is a valid HW interrupt. So get_irq() shall return 0 when
there is no irq, instead of returning irq_linear_revmap(... ,0)
Fixes: f2a0bd3753dad ("[POWERPC] 8xx: powerpc port of core CPM PIC")
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
[ Upstream commit 6b148a7ce72a7f87c81cbcde48af014abc0516a9 ]
IPIC Status is provided by register IPIC_SERSR and not by IPIC_SERMR
which is the mask register.
[ Upstream commit 672a2c87c83649fb0167202342ce85af9a3b4f1c ]
It is invalid to call del_gendisk() when disk->queue is NULL. Fix error
handling in axon_ram_probe() to avoid doing that.
Also del_gendisk() does not drop a reference to gendisk allocated by
alloc_disk(). That has to be done by put_disk(). Add that call where
needed.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit f83e6862047e1e371bdc5d512dd6cabe8a3965b8 ]
Otherwise KVM will fail to pass them through to the host
commit 6f553912eedafae13ff20b322a65e471fe7f5236 upstream.
of_mm_gpiochip_add_data() generates an oops for NULL pointer dereference.
of_mm_gpiochip_add_data() calls mm_gc->save_regs() before
setting the data, therefore ->save_regs() cannot use gpiochip_get_data()
Fixes: 937daafca774 ("powerpc: simple-gpio: use gpiochip data pointer")
commit a69e2fb70350a66f91175cd2625f1e8215c5b6e9 upstream.
The CPPR (Current Processor Priority Register) of a XICS interrupt
presentation controller contains a value N, such that only interrupts
with a priority "more favoured" than N will be received by the CPU,
where "more favoured" means "less than". So if the CPPR has the value 5
then only interrupts with a priority of 0-4 inclusive will be received.
In theory the CPPR can support a value of 0 to 255 inclusive.
In practice Linux only uses values of 0, 4, 5 and 0xff. Setting the CPPR
to 0 rejects all interrupts, setting it to 0xff allows all interrupts.
The values 4 and 5 are used to differentiate IPIs from external
interrupts. Setting the CPPR to 5 allows IPIs to be received but not
external interrupts.
The CPPR emulation in the OPAL XICS implementation only directly
supports priorities 0 and 0xff. All other priorities are considered
equivalent, and mapped to a single priority value internally. This means
when using icp-opal we can not allow IPIs but not externals.
This breaks Linux's use of priority values when a CPU is hot unplugged.
After migrating IRQs away from the CPU that is being offlined, we set
the priority to 5, meaning we still want the offline CPU to receive
IPIs. But the effect of the OPAL XICS emulation's use of a single
priority value is that all interrupts are rejected by the CPU. With the
CPU offline, and not receiving IPIs, we may not be able to wake it up to
bring it back online.
The first part of the fix is in icp_opal_set_cpu_priority(). CPPR values
of 0 to 4 inclusive will correctly cause all interrupts to be rejected,
so we pass those CPPR values through to OPAL. However if we are called
with a CPPR of 5 or greater, the caller is expecting to be able to allow
IPIs but not external interrupts. We know this doesn't work, so instead
of rejecting all interrupts we choose the opposite which is to allow all
interrupts. This is still not correct behaviour, but we know for the
only existing caller (xics_migrate_irqs_away()), that it is the better
option.
The other part of the fix is in xics_migrate_irqs_away(). Instead of
setting priority (CPPR) to 0, and then back to 5 before migrating IRQs,
we migrate the IRQs before setting the priority back to 5. This should
have no effect on an ICP backend with a working set_priority(), and on
icp-opal it means we will keep all interrupts blocked until after we've
finished doing the IRQ migration. Additionally we wait for 5ms after
doing the migration to make sure there are no IRQs in flight.
Fixes: d74361881f0d ("powerpc/xics: Add ICP OPAL backend")
Suggested-by: Michael Ellerman <mpe@ellerman.id.au>
Reported-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Tested-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Signed-off-by: Balbir Singh <bsingharora@gmail.com>
[mpe: Rewrote comments and change log, change delay to 5ms]
commit 9b256714979fad61ae11d90b53cf67dd5e6484eb upstream.
The IPIs come in as HVI not EE, so we need to test the appropriate
SRR1 bits. The encoding is such that it won't have false positives
on P7 and P8 so we can just test it like that. We also need to handle
the icp-opal variant of the flush.
commit 9728a7c8ab2f7a1c8d5c95278d2e4f4ac1285385 upstream.
The icp-opal call is missing the code from icp-native to recover
interrupts snatched by KVM. Without that, when running KVM, we can
get into a situation where an interrupt is lost and the CPU stuck
with an elevated CPPR.
Also harden replay by always checking the return from opal_int_eoi().
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
- EXPORT_SYMBOL for asm source by Al Viro.
This does bring a regression, because genksyms no longer generates
checksums for these symbols (CONFIG_MODVERSIONS). Nick Piggin is
working on a patch to fix this.
Plus, we are talking about functions like strcpy(), which rarely
change prototypes.
- Fixes for PPC fallout of the above by Stephen Rothwell and Nick
Piggin
- fixdep speedup by Alexey Dobriyan.
- preparatory work by Nick Piggin to allow architectures to build with
-ffunction-sections, -fdata-sections and --gc-sections
- CONFIG_THIN_ARCHIVES support by Stephen Rothwell
- fix for filenames with colons in the initramfs source by me.
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (22 commits)
initramfs: Escape colons in depfile
ppc: there is no clear_pages to export
powerpc/64: whitelist unresolved modversions CRCs
kbuild: -ffunction-sections fix for archs with conflicting sections
kbuild: add arch specific post-link Makefile
kbuild: allow archs to select link dead code/data elimination
kbuild: allow architectures to use thin archives instead of ld -r
kbuild: Regenerate genksyms lexer
kbuild: genksyms fix for typeof handling
fixdep: faster CONFIG_ search
ia64: move exports to definitions
sparc32: debride memcpy.S a bit
[sparc] unify 32bit and 64bit string.h
sparc: move exports to definitions
ppc: move exports to definitions
arm: move exports to definitions
s390: move exports to definitions
m68k: move exports to definitions
alpha: move exports to actual definitions
x86: move exports to actual definitions
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull more powerpc updates from Michael Ellerman:
"Some more powerpc updates for 4.9:
Freescale updates from Scott Wood:
- qbman support (a prerequisite for datapath drivers such as ethernet)
- a PCI DMA fix+improvement
- reset handler changes
- more 8xx optimizations
- some cleanups and fixes.'
Fixes:
- selftests/powerpc: Add missing binaries to .gitignores (Michael Ellerman)
- selftests/powerpc: Fix build break caused by EXPORT_SYMBOL changes (Michael Ellerman)
- powerpc/pseries: Fix stack corruption in htpe code (Laurent Dufour)
- powerpc/64s: Fix power4_fixup_nap placement (Nicholas Piggin)
- powerpc/64: Fix incorrect return value from __copy_tofrom_user (Paul Mackerras)
- powerpc/mm/hash64: Fix might_have_hea() check (Michael Ellerman)
Other:
- MAINTAINERS: Remove myself from PA Semi entries (Olof Johansson)
- MAINTAINERS: Drop separate pseries entry (Michael Ellerman)
- MAINTAINERS: Update powerpc website & add selftests (Michael Ellerman):
* tag 'powerpc-4.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (35 commits)
arch/powerpc: Add CONFIG_FSL_DPAA to corenetXX_smp_defconfig
soc/qman: Add self-test for QMan driver
soc/bman: Add self-test for BMan driver
soc/fsl: Introduce DPAA 1.x QMan device driver
soc/fsl: Introduce DPAA 1.x BMan device driver
powerpc/8xx: make user addr DTLB miss the short path
powerpc/8xx: Move additional DTLBMiss handlers out of exception area
powerpc/8xx: use r3 to scratch CR in ITLBmiss
soc/fsl/qe: fix gpio save_regs functions
powerpc/8xx: add dedicated machine check handler
powerpc/8xx: add system_reset_exception
Pull powerpc updates from Michael Ellerman:
"Highlights:
- Major rework of Book3S 64-bit exception vectors (Nicholas Piggin)
- Use gas sections for arranging exception vectors et. al.
- Large set of TM cleanups and selftests (Cyril Bur)
- Enable transactional memory (TM) lazily for userspace (Cyril Bur)
- Support for XZ compression in the zImage wrapper (Oliver
O'Halloran)
- Add support for bpf constant blinding (Naveen N. Rao)
- Beginnings of upstream support for PA Semi Nemo motherboards
(Darren Stevens)
Fixes:
- Ensure .mem(init|exit).text are within _stext/_etext (Michael
Ellerman)
- xmon: Don't use ld on 32-bit (Michael Ellerman)
- vdso64: Use double word compare on pointers (Anton Blanchard)
- powerpc/nvram: Fix an incorrect partition merge (Pan Xinhui)
- powerpc: Fix usage of _PAGE_RO in hugepage (Christophe Leroy)
- powerpc/mm: Update FORCE_MAX_ZONEORDER range to allow hugetlb w/4K
(Aneesh Kumar K.V)
- Fix memory leak in queue_hotplug_event() error path (Andrew
Donnellan)
- Replay hypervisor maintenance interrupt first (Nicholas Piggin)
Various performance optimisations (Anton Blanchard):
- Align hot loops of memset() and backwards_memcpy()
- During context switch, check before setting mm_cpumask
- Remove static branch prediction in atomic{, 64}_add_unless
- Only disable HAVE_EFFICIENT_UNALIGNED_ACCESS on POWER7 little
endian
- Set default CPU type to POWER8 for little endian builds
Cleanups & features:
- Sparse fixes/cleanups (Daniel Axtens)
- Preserve CFAR value on SLB miss caused by access to bogus address
(Paul Mackerras)
- Radix MMU fixups for POWER9 (Aneesh Kumar K.V)
- Support for setting used_(vsr|vr|spe) in sigreturn path (for CRIU)
(Simon Guo)
- Optimise syscall entry for virtual, relocatable case (Nicholas
Piggin)
- Optimise MSR handling in exception handling (Nicholas Piggin)
- Support for kexec with Radix MMU (Benjamin Herrenschmidt)
- powernv EEH fixes (Russell Currey)
- Suprise PCI hotplug support for powernv (Gavin Shan)
- Endian/sparse fixes for powernv PCI (Gavin Shan)
- Defconfig updates (Anton Blanchard)
- KVM: PPC: Book3S HV: Migrate pinned pages out of CMA (Balbir Singh)
- cxl: Flush PSL cache before resetting the adapter (Frederic Barrat)
- cxl: replace loop with for_each_child_of_node(), remove unneeded
of_node_put() (Andrew Donnellan)
- Fix HV facility unavailable to use correct handler (Nicholas
Piggin)
- Remove unnecessary syscall trampoline (Nicholas Piggin)
- fadump: Fix build break when CONFIG_PROC_VMCORE=n (Michael
Ellerman)
- Quieten EEH message when no adapters are found (Anton Blanchard)
- powernv: Add PHB register dump debugfs handle (Russell Currey)
- Use kprobe blacklist for exception handlers & asm functions
(Nicholas Piggin)
- Document the syscall ABI (Nicholas Piggin)
- MAINTAINERS: Update cxl maintainers (Michael Neuling)
- powerpc: Remove all usages of NO_IRQ (Michael Ellerman)
Minor cleanups:
- Andrew Donnellan, Christophe Leroy, Colin Ian King, Cyril Bur,
Frederic Barrat, Pan Xinhui, PrasannaKumar Muralidharan, Rui Teng,
Simon Guo"
* tag 'powerpc-4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (156 commits)
powerpc/bpf: Add support for bpf constant blinding
powerpc/bpf: Implement support for tail calls
powerpc/bpf: Introduce accessors for using the tmp local stack space
powerpc/fadump: Fix build break when CONFIG_PROC_VMCORE=n
powerpc: tm: Enable transactional memory (TM) lazily for userspace
powerpc/tm: Add TM Unavailable Exception
powerpc: Remove do_load_up_transact_{fpu,altivec}
powerpc: tm: Rename transct_(*) to ck(\1)_state
powerpc: tm: Always use fp_state and vr_state to store live registers
selftests/powerpc: Add checks for transactional VSXs in signal contexts
selftests/powerpc: Add checks for transactional VMXs in signal contexts
selftests/powerpc: Add checks for transactional FPUs in signal contexts
selftests/powerpc: Add checks for transactional GPRs in signal contexts
selftests/powerpc: Check that signals always get delivered
selftests/powerpc: Add TM tcheck helpers in C
selftests/powerpc: Allow tests to extend their kill timeout
selftests/powerpc: Introduce GPR asm helper header file
selftests/powerpc: Move VMX stack frame macros to header file
selftests/powerpc: Rework FPU stack placement macros and move to header file
selftests/powerpc: Check for VSX preservation across userspace preemption
This allows PCI devices that can only address (e.g.) 36 or 40 bit DMA to
use direct DMA, at the cost of not being able to DMA to non-RAM addresses
(this doesn't affect MSIs as there is a separate dedicated window for
that) which we wouldn't have been able to do anyway if the RAM size didn't
trigger the creation of the second inbound window.
It also fixes an off-by-one error that set dma_direct_ops on PCI devices
whose dma mask could address all the space below the DMA offset
(previously 40 bits), but not the window that starts at the DMA offset.
Signed-off-by: Scott Wood <oss@buserror.net>
Cc: Tillmann Heidsieck <theidsieck@leenox.de>
Tested-by: Tillmann Heidsieck <theidsieck@leenox.de>
Commit 0e6e01ff694ee ("CPM/QE: use genalloc to manage CPM/QE muram")
has changed the way muram is managed.
genalloc uses kmalloc(), hence requires the SLAB to be up and running.
On powerpc 8xx, cpm_reset() is called early during startup.
cpm_reset() then calls cpm_muram_init() before SLAB is available,
hence the following Oops.
cpm_reset() cannot be called during initcalls because the CPM is
needed for console.
This patch removes the call to cpm_muram_init() from cpm_reset().
cpm_muram_init() will be called from a new function called cpm_init()
which is declared as subsys_initcall, unless cpm_muram_alloc() is
called earlier for the serial console in which case cpm_muram_init()
will be called from there.
The reason for calling it from two places is that some drivers
(e.g. i2c-cpm) need some of the initialisations done by
cpm_muram_init() but don't call cpm_muram_alloc(). The console
driver calls cpm_muram_alloc() but some platforms might not use
the CPM serial ports for console.
[ 0.000000] Unable to handle kernel paging request for data at address 0x00000008
[ 0.000000] Faulting instruction address: 0xc01acce0
[ 0.000000] Oops: Kernel access of bad area, sig: 11 [#1]
[ 0.000000] PREEMPT CMPC885
[ 0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 4.4.14-g0886ed8 #5
[ 0.000000] task: c05183e0 ti: c0536000 task.ti: c0536000
[ 0.000000] NIP: c01acce0 LR: c0011068 CTR: 00000000
[ 0.000000] REGS: c0537e50 TRAP: 0300 Not tainted (4.4.14-s3k-dev-g0886ed8-svn)
[ 0.000000] MSR: 00001032 <ME,IR,DR,RI> CR: 28044428 XER: 00000000
[ 0.000000] DAR: 00000008 DSISR: c0000000
GPR00: c0011068 c0537f00 c05183e0 00000000 00009000 ffffffff 00000bc0 ffffffff
GPR08: ff003000 ff00b000 ff003bbf 00000000 22044422 100d43a8 00000000 07ff94e8
GPR16: 00000000 07bb5d70 00000000 07ff81f4 07ff81f4 07ff81f4 00000000 00000000
GPR24: 07ffb3a0 07fe7628 c0550000 c7ffa190 c0540000 ff003bbf 00000000 00000001
[ 0.000000] NIP [c01acce0] gen_pool_add_virt+0x14/0xdc
[ 0.000000] LR [c0011068] cpm_muram_init+0xd4/0x18c
[ 0.000000] Call Trace:
[ 0.000000] [c0537f00] [00000200] 0x200 (unreliable)
[ 0.000000] [c0537f20] [c0011068] cpm_muram_init+0xd4/0x18c
[ 0.000000] [c0537f70] [c0494684] cpm_reset+0xb4/0xc8
[ 0.000000] [c0537f90] [c0494c64] cmpc885_setup_arch+0x10/0x30
[ 0.000000] [c0537fa0] [c0493cd4] setup_arch+0x130/0x168
[ 0.000000] [c0537fb0] [c04906bc] start_kernel+0x88/0x380
[ 0.000000] [c0537ff0] [c0002224] start_here+0x38/0x98
[ 0.000000] Instruction dump:
[ 0.000000] 91430010 91430014 80010014 83e1000c 7c0803a6 38210010 4e800020 7c0802a6
[ 0.000000] 9421ffe0 bf61000c 90010024 7c7e1b78 <80630008> 7c9c2378 7cc31c30 3863001f
[ 0.000000] ---[ end trace dc8fa200cb88537f ]---
fixes: 0e6e01ff694ee ("CPM/QE: use genalloc to manage CPM/QE muram")
Cc: stable@vger.linux.org
[scottwood: Removed some string changes unrelated to bugfix]
Use of_property_read_bool to check for the existence of a property.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression e1,e2;
statement S2,S1;
- if (of_get_property(e1,e2,NULL))
+ if (of_property_read_bool(e1,e2))
S1 else S2
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Convert fsl_rstcr_restart into a function to be registered with
register_reset_handler().
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
[scottwood: Converted mvme7100 as well]
NO_IRQ has been == 0 on powerpc for just over ten years (since commit
0ebfff1491ef ("[POWERPC] Add new interrupt mapping core and change
platforms to use it")). It's also 0 on most other arches.
Although it's fairly harmless, every now and then it causes confusion
when a driver is built on powerpc and another arch which doesn't define
NO_IRQ. There's at least 6 definitions of NO_IRQ in drivers/, at least
some of which are to work around that problem.
So we'd like to remove it. This is fairly trivial in the arch code, we
just convert:
if (irq == NO_IRQ) to if (!irq)
if (irq != NO_IRQ) to if (irq)
irq = NO_IRQ; to irq = 0;
return NO_IRQ; to return 0;
And a few other odd cases as well.
At least for now we keep the #define NO_IRQ, because there is driver
code that uses NO_IRQ and the fixes to remove those will go via other
trees.
Note we also change some occurrences in PPC sound drivers, drivers/ps3,
and drivers/macintosh.
Squash a bunch of sparse warnings by making things static.
Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
Signed-off-by: Daniel Axtens <dja@axtens.net>
When using the OPAL ICP backend we incorrectly pass Linux CPU numbers
rather than HW CPU numbers to OPAL.
setting the data. Therefore ->save_regs() cannot use
gpiochip_get_data()
[ 0.275940] Unable to handle kernel paging request for data at address 0x00000130
[ 0.283120] Faulting instruction address: 0xc01b44cc
[ 0.288175] Oops: Kernel access of bad area, sig: 11 [#1]
[ 0.293343] PREEMPT CMPC885
[ 0.296141] CPU: 0 PID: 1 Comm: swapper Not tainted 4.7.0-g65124df-dirty #68
[ 0.304131] task: c6074000 ti: c6080000 task.ti: c6080000
[ 0.309459] NIP: c01b44cc LR: c0011720 CTR: c0011708
[ 0.314372] REGS: c6081d90 TRAP: 0300 Not tainted (4.7.0-g65124df-dirty)
[ 0.322267] MSR: 00009032 <EE,ME,IR,DR,RI> CR: 24000028 XER: 20000000
[ 0.328813] DAR: 00000130 DSISR: c0000000
GPR00: c01b6d0c c6081e40 c6074000 c6017000 c9028000 c601d028 c6081dd8 00000000
GPR08: c601d028 00000000 ffffffff 00000001 24000044 00000000 c0002790 00000000
GPR16: 00000000 00000000 00000000 00000000 00000000 00000000 c05643b0 00000083
GPR24: c04a1a6c c0560000 c04a8308 c04c6480 c0012498 c6017000 c7ffcc78 c6017000
[ 0.360806] NIP [c01b44cc] gpiochip_get_data+0x4/0xc
[ 0.365684] LR [c0011720] cpm1_gpio16_save_regs+0x18/0x44
[ 0.370972] Call Trace:
[ 0.373451] [c6081e50] [c01b6d0c] of_mm_gpiochip_add_data+0x70/0xdc
[ 0.379624] [c6081e70] [c00124c0] cpm_init_par_io+0x28/0x118
[ 0.385238] [c6081e80] [c04a8ac0] do_one_initcall+0xb0/0x17c
[ 0.390819] [c6081ef0] [c04a8cbc] kernel_init_freeable+0x130/0x1dc
[ 0.396924] [c6081f30] [c00027a4] kernel_init+0x14/0x110
[ 0.402177] [c6081f40] [c000b424] ret_from_kernel_thread+0x5c/0x64
[ 0.408233] Instruction dump:
[ 0.411168] 4182fafc 3f80c040 48234c6d 3bc0fff0 3b9c5ed0 4bfffaf4 81290020 712a0004
[ 0.418825] 4182fb34 48234c51 4bfffb2c 81230004 <80690130> 4e800020 7c0802a6 9421ffe0
[ 0.426763] ---[ end trace fe4113ee21d72ffa ]---
fixes: e65078f1f3490 ("powerpc: sysdev: cpm1: use gpiochip data pointer")
fixes: a14a2d484b386 ("powerpc: cpm_common: use gpiochip data pointer")
Cc: stable@vger.kernel.org
These files were only including module.h for exception table
related functions. We've now separated that content out into its
own file "extable.h" so now move over to that and avoid all the
extra header content in module.h that we don't really need to compile
these files.
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
This sets the type of the interrupt appropriately. We set it as follow:
- If not mapped from the device-tree, we use edge. This is the case
of the virtual interrupts and PCI MSIs for example.
- If mapped from the device-tree and #interrupt-cells is 2 (PAPR
compliant), we use the second cell to set the appropriate type
- If mapped from the device-tree and #interrupt-cells is 1 (current
OPAL on P8 does that), we assume level sensitive since those are
typically going to be the PSI LSIs which are level sensitive.
Additionally, we mark the interrupts requested via the opal_interrupts
property all level. This is a bit fishy but the best we can do until we
fix OPAL to properly expose them with a complete descriptor. It is also
correct for the current HW anyway as OPAL interrupts are currently PCI
error and PSI interrupts which are level.
Finally now that edge interrupts are properly identified, we can enable
CONFIG_HARDIRQS_SW_RESEND which will make the core re-send them if
they occur while masked, which some drivers rely upon.
This fixes issues with lost interrupts on some Mellanox adapters.
We should set the error code here rather than incorrectly returning 0.
Otherwise static checkers complain.
Link: http://lkml.kernel.org/r/20160804053525.GM775@mwanda
Cc: Alexandre Bounine <alexandre.bounine@idt.com>
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
- Remove check for parallel PHY
- Set LP-Serial Register Map type
[akpm@linux-foundation.org: fix build]
[alexandre.bounine@idt.com: fix build fix]
Link: http://lkml.kernel.org/r/20160802184932.2755-1-alexandre.bounine@idt.com
Link: http://lkml.kernel.org/r/1469125134-16523-13-git-send-email-alexandre.bounine@idt.com
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com>
Cc: Barry Wood <barry.wood@idt.com>
Current definition of map_inb() mport operations callback uses u32 type
to specify required inbound window (IBW) size. This is limiting factor
because existing hardware - tsi721 and fsl_rio, both support IBW size up
to 16GB.
Changing type of size parameter to u64 to allow IBW size configurations
larger than 4GB.
[alexandre.bounine@idt.com: remove compiler warning about size of constant]
Link: http://lkml.kernel.org/r/20160802184856.2566-1-alexandre.bounine@idt.com
Link: http://lkml.kernel.org/r/1469125134-16523-11-git-send-email-alexandre.bounine@idt.com
There was only one use of __initdata_refok and __exit_refok
__init_refok was used 46 times against 82 for __ref.
Those definitions are obsolete since commit 312b1485fb50 ("Introduce new
section reference annotations tags: __ref, __refdata, __refconst")
This patch removes the following compatibility definitions and replaces
them treewide.
/* compatibility defines */
#define __init_refok __ref
#define __initdata_refok __refdata
#define __exit_refok __ref
I can also provide separate patches if necessary.
(One patch per tree and check in 1 month or 2 to remove old definitions)
Link: http://lkml.kernel.org/r/1466796271-3043-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
"Highlights:
- PowerNV PCI hotplug support.
- Lots more Power9 support.
- eBPF JIT support on ppc64le.
- Lots of cxl updates.
- Boot code consolidation.
Bug fixes:
- Fix spin_unlock_wait() from Boqun Feng
- Fix stack pointer corruption in __tm_recheckpoint() from Michael
Neuling
- Fix multiple bugs in memory_hotplug_max() from Bharata B Rao
- mm: Ensure "special" zones are empty from Oliver O'Halloran
- ftrace: Separate the heuristics for checking call sites from
Michael Ellerman
- modules: Never restore r2 for a mprofile-kernel style mcount() call
- Fix endianness when reading TCEs from Alexey Kardashevskiy
- start rtasd before PCI probing from Greg Kurz
- PCI: rpaphp: Fix slot registration for multiple slots under a PHB
from Tyrel Datwyler
- powerpc/mm: Add memory barrier in __hugepte_alloc() from Sukadev
Bhattiprolu
Cleanups & fixes:
- Drop support for MPIC in pseries from Rashmica Gupta
- Define and use PPC64_ELF_ABI_v2/v1 from Michael Ellerman
- Remove unused symbols in asm-offsets.c from Rashmica Gupta
- Fix SRIOV not building without EEH enabled from Russell Currey
- Remove kretprobe_trampoline_holder from Thiago Jung Bauermann
- Reduce log level of PCI I/O space warning from Benjamin
Herrenschmidt
- Add array bounds checking to crash_shutdown_handlers from Suraj
Jitindar Singh
- Avoid -maltivec when using clang integrated assembler from Anton
Blanchard
- Fix array overrun in ppc_rtas() syscall from Andrew Donnellan
- Fix error return value in cmm_mem_going_offline() from Rasmus
Villemoes
- export cpu_to_core_id() from Mauricio Faria de Oliveira
- Remove old symbols from defconfigs from Andrew Donnellan
- Update obsolete comments in setup_32.c about entry conditions from
- Add comment explaining the purpose of setup_kdump_trampoline() from
- Merge the RELOCATABLE config entries for ppc32 and ppc64 from Kevin
Hao
- Remove RELOCATABLE_PPC32 from Kevin Hao
- Fix .long's in tlb-radix.c to more meaningful from Balbir Singh
Minor cleanups & fixes:
- Andrew Donnellan, Anna-Maria Gleixner, Anton Blanchard, Benjamin
Herrenschmidt, Bharata B Rao, Christophe Leroy, Colin Ian King,
Geliang Tang, Greg Kurz, Madhavan Srinivasan, Michael Ellerman,
Michael Ellerman, Stephen Rothwell, Stewart Smith.
Freescale updates from Scott:
- "Highlights include more 8xx optimizations, device tree updates,
and MVME7100 support."
PowerNV PCI hotplug from Gavin Shan:
- PCI: Add pcibios_setup_bridge()
- Override pcibios_setup_bridge()
- Remove PCI_RESET_DELAY_US
- Move pnv_pci_ioda_setup_opal_tce_kill() around
- Increase PE# capacity
- Allocate PE# in reverse order
- Create PEs in pcibios_setup_bridge()
- Setup PE for root bus
- Extend PCI bridge resources
- Make pnv_ioda_deconfigure_pe() visible
- Dynamically release PE
- Update bridge windows on PCI plug
- Delay populating pdn
- Support PCI slot ID
- Use PCI slot reset infrastructure
- Introduce pnv_pci_get_slot_id()
- Functions to get/set PCI slot state
- PCI/hotplug: PowerPC PowerNV PCI hotplug driver
- Print correct PHB type names
Power9 idle support from Shreyas B. Prabhu:
- set power_save func after the idle states are initialized
- Use PNV_THREAD_WINKLE macro while requesting for winkle
- make hypervisor state restore a function
- Rename idle_power7.S to idle_book3s.S
- Rename reusable idle functions to hardware agnostic names
- Make pnv_powersave_common more generic
- abstraction for saving SPRs before entering deep idle states
- Add platform support for stop instruction
- cpuidle/powernv: Use CPUIDLE_STATE_MAX instead of MAX_POWERNV_IDLE_STATES
- cpuidle/powernv: cleanup cpuidle-powernv.c
- cpuidle/powernv: Add support for POWER ISA v3 idle states
- Use deepest stop state when cpu is offlined
Power9 PMU from Madhavan Srinivasan:
- factor out power8 pmu macros and defines
- factor out power8 pmu functions
- factor out power8 __init_pmu code
- Add power9 event list macros for generic and cache events
- Power9 PMU support
- Export Power9 generic and cache events to sysfs
Power9 preliminary interrupt & PCI support from Benjamin Herrenschmidt:
- Add XICS emulation APIs
- Move a few exception common handlers to make room
- Add support for HV virtualization interrupts
- Add mechanism to force a replay of interrupts
- Add ICP OPAL backend
- Discover IODA3 PHBs
- pci: Remove obsolete SW invalidate
- opal: Add real mode call wrappers
- Rename TCE invalidation calls
- Remove SWINV constants and obsolete TCE code
- Rework accessing the TCE invalidate register
- Fallback to OPAL for TCE invalidations
- Use the device-tree to get available range of M64's
- Check status of a PHB before using it
- pci: Don't try to allocate resources that will be reassigned
Other Power9:
- Send SIGBUS on unaligned copy and paste from Chris Smart
- Large Decrementer support from Oliver O'Halloran
- Load Monitor Register Support from Jack Miller
Performance improvements from Anton Blanchard:
- Avoid load hit store in __giveup_fpu() and __giveup_altivec()
- Avoid load hit store in setup_sigcontext()
- Remove assembly versions of strcpy, strcat, strlen and strcmp
- Align hot loops of some string functions
eBPF JIT from Naveen N. Rao:
- Fix/enhance 32-bit Load Immediate implementation
- Optimize 64-bit Immediate loads
- Introduce rotate immediate instructions
- A few cleanups
- Isolate classic BPF JIT specifics into a separate header
- Implement JIT compiler for extended BPF
Operator Panel driver from Suraj Jitindar Singh:
- devicetree/bindings: Add binding for operator panel on FSP machines
- Add inline function to get rc from an ASYNC_COMP opal_msg
- Add driver for operator panel on FSP machines
Sparse fixes from Daniel Axtens:
- make some things static
- Introduce asm-prototypes.h
- Include headers containing prototypes
- Use #ifdef __BIG_ENDIAN__ #else for REG_BYTE
- kvm: Clarify __user annotations
- Pass endianness to sparse
- Make ppc_md.{halt, restart} __noreturn
MM fixes & cleanups from Aneesh Kumar K.V:
- radix: Update LPCR HR bit as per ISA
- use _raw variant of page table accessors
- Compile out radix related functions if RADIX_MMU is disabled
- Clear top 16 bits of va only on older cpus
- Print formation regarding the the MMU mode
- hash: Update SDR1 size encoding as documented in ISA 3.0
- radix: Update PID switch sequence
- radix: Update machine call back to support new HCALL.
- radix: Add LPID based tlb flush helpers
- radix: Add a kernel command line to disable radix
- Cleanup LPCR defines
Boot code consolidation from Benjamin Herrenschmidt:
- Move epapr_paravirt_early_init() to early_init_devtree()
- cell: Don't use flat device-tree after boot
- ge_imp3a: Don't use the flat device-tree after boot
- mpc85xx_ds: Don't use the flat device-tree after boot
- mpc85xx_rdb: Don't use the flat device-tree after boot
- Don't test for machine type in rtas_initialize()
- Don't test for machine type in smp_setup_cpu_maps()
- dt: Add of_device_compatible_match()
- Factor do_feature_fixup calls
- Move 64-bit feature fixup earlier
- Move 64-bit memory reserves to setup_arch()
- Use a cachable DART
- Move FW feature probing out of pseries probe()
- Put exception configuration in a common place
- Remove early allocation of the SMU command buffer
- Move MMU backend selection out of platform code
- pasemi: Remove IOBMAP allocation from platform probe()
- mm/hash: Don't use machine_is() early during boot
- Don't test for machine type to detect HEA special case
- pmac: Remove spurrious machine type test
- Move hash table ops to a separate structure
- Ensure that ppc_md is empty before probing for machine type
- Move 64-bit probe_machine() to later in the boot process
- Move 32-bit probe() machine to later in the boot process
- Get rid of ppc_md.init_early()
- Move the boot time info banner to a separate function
- Move setting of {i,d}cache_bsize to initialize_cache_info()
- Move the content of setup_system() to setup_arch()
- Move cache info inits to a separate function
- Re-order the call to smp_setup_cpu_maps()
- Re-order setup_panic()
- Make a few boot functions __init
- Merge 32-bit and 64-bit setup_arch()
Other new features:
- tty/hvc: Use IRQF_SHARED for OPAL hvc consoles from Sam Mendoza-Jonas
- tty/hvc: Use opal irqchip interface if available from Sam Mendoza-Jonas
- powerpc: Add module autoloading based on CPU features from Alastair D'Silva
- crypto: vmx - Convert to CPU feature based module autoloading from Alastair D'Silva
- Wake up kopald polling thread before waiting for events from Benjamin Herrenschmidt
- xmon: Dump ISA 2.06 SPRs from Michael Ellerman
- xmon: Dump ISA 2.07 SPRs from Michael Ellerman
- Add a parameter to disable 1TB segs from Oliver O'Halloran
- powerpc/boot: Add OPAL console to epapr wrappers from Oliver O'Halloran
- Assign fixed PHB number based on device-tree properties from Guilherme G. Piccoli
- pseries: Add pseries hotplug workqueue from John Allen
- pseries: Add support for hotplug interrupt source from John Allen
- pseries: Use kernel hotplug queue for PowerVM hotplug events from John Allen
- pseries: Move property cloning into its own routine from Nathan Fontenot
- pseries: Dynamic add entires to associativity lookup array from Nathan Fontenot
- pseries: Auto-online hotplugged memory from Nathan Fontenot
- pseries: Remove call to memblock_add() from Nathan Fontenot
cxl:
- Add set and get private data to context struct from Michael Neuling
- make base more explicitly non-modular from Paul Gortmaker
- Use for_each_compatible_node() macro from Wei Yongjun
- Frederic Barrat
- Abstract the differences between the PSL and XSL
- Make vPHB device node match adapter's
- Philippe Bergheaud
- Add mechanism for delivering AFU driver specific events
- Ignore CAPI adapters misplaced in switched slots
- Refine slice error debug messages
- Andrew Donnellan
- static-ify variables to fix sparse warnings
- PCI/hotplug: pnv_php: export symbols and move struct types needed by cxl
- PCI/hotplug: pnv_php: handle OPAL_PCI_SLOT_OFFLINE power state
- Add cxl_check_and_switch_mode() API to switch bi-modal cards
- remove dead Kconfig options
- fix potential NULL dereference in free_adapter()
- Ian Munsie
- Update process element after allocating interrupts
- Add support for CAPP DMA mode
- Fix allowing bogus AFU descriptors with 0 maximum processes
- Fix allocating a minimum of 2 pages for the SPA
- Fix bug where AFU disable operation had no effect
- Workaround XSL bug that does not clear the RA bit after a reset
- Fix NULL pointer dereference on kernel contexts with no AFU interrupts
- powerpc/powernv: Split cxl code out into a separate file
- Add cxl_slot_is_supported API
- Enable bus mastering for devices using CAPP DMA mode
- Move cxl_afu_get / cxl_afu_put to base
- Allow a default context to be associated with an external pci_dev
- Do not create vPHB if there are no AFU configuration records
- powerpc/powernv: Add support for the cxl kernel api on the real phb
- Add support for using the kernel API with a real PHB
- Add kernel APIs to get & set the max irqs per context
- Add preliminary workaround for CX4 interrupt limitation
- Add support for interrupts on the Mellanox CX4
- Workaround PE=0 hardware limitation in Mellanox CX4
- powerpc/powernv: Fix pci-cxl.c build when CONFIG_MODULES=n
selftests:
- Test unaligned copy and paste from Chris Smart
- Load Monitor Register Tests from Jack Miller
- Cyril Bur
- exec() with suspended transaction
- Use signed long to read perf_event_paranoid
- Fix usage message in context_switch
- Fix generation of vector instructions/types in context_switch
- Michael Ellerman
- Use "Delta" rather than "Error" in normal output
- Import Anton's mmap & futex micro benchmarks
- Add a test for PROT_SAO"
* tag 'powerpc-4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (263 commits)
powerpc/mm: Parenthesise IS_ENABLED() in if condition
selftests/powerpc: exec() with suspended transaction
powerpc: Improve comment explaining why we modify VRSAVE
powerpc/mm: Drop unused externs for hpte_init_beat[_v3]()
powerpc/mm: Rename hpte_init_lpar() and move the fallback to a header
powerpc/mm: Fix build break when PPC_NATIVE=n
powerpc/powernv/ioda: Fix endianness when reading TCEs
powerpc/modules: Never restore r2 for a mprofile-kernel style mcount() call
powerpc/ftrace: Separate the heuristics for checking call sites
powerpc: Merge 32-bit and 64-bit setup_arch()
powerpc/64: Make a few boot functions __init
powerpc: Re-order setup_panic()
powerpc: Re-order the call to smp_setup_cpu_maps()
powerpc/32: Move cache info inits to a separate function
powerpc/64: Move the content of setup_system() to setup_arch()
git://git.kernel.org/pub/scm/linux/kernel/git/scottwood/linux into next
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm updates from Dan Williams:
- Replace pcommit with ADR / directed-flushing.
The pcommit instruction, which has not shipped on any product, is
deprecated. Instead, the requirement is that platforms implement
either ADR, or provide one or more flush addresses per nvdimm.
ADR (Asynchronous DRAM Refresh) flushes data in posted write buffers
to the memory controller on a power-fail event.
Flush addresses are defined in ACPI 6.x as an NVDIMM Firmware
Interface Table (NFIT) sub-structure: "Flush Hint Address Structure".
A flush hint is an mmio address that when written and fenced assures
that all previous posted writes targeting a given dimm have been
flushed to media.
- On-demand ARS (address range scrub).
Linux uses the results of the ACPI ARS commands to track bad blocks
in pmem devices. When latent errors are detected we re-scrub the
media to refresh the bad block list, userspace can also request a
re-scrub at any time.
- Support for the Microsoft DSM (device specific method) command
format.
- Support for EDK2/OVMF virtual disk device memory ranges.
- Various fixes and cleanups across the subsystem.
* tag 'libnvdimm-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (41 commits)
libnvdimm-btt: Delete an unnecessary check before the function call "__nd_device_register"
nfit: do an ARS scrub on hitting a latent media error
nfit: move to nfit/ sub-directory
nfit, libnvdimm: allow an ARS scrub to be triggered on demand
libnvdimm: register nvdimm_bus devices with an nd_bus driver
pmem: clarify a debug print in pmem_clear_poison
x86/insn: remove pcommit
Revert "KVM: x86: add pcommit support"
nfit, tools/testing/nvdimm/: unify shutdown paths
libnvdimm: move ->module to struct nvdimm_bus_descriptor
nfit: cleanup acpi_nfit_init calling convention
nfit: fix _FIT evaluation memory leak + use after free
tools/testing/nvdimm: add manufacturing_{date|location} dimm properties
tools/testing/nvdimm: add virtual ramdisk range
acpi, nfit: treat virtual ramdisk SPA as pmem region
pmem: kill __pmem address space
pmem: kill wmb_pmem()
libnvdimm, pmem: use nvdimm_flush() for namespace I/O writes
fs/dax: remove wmb_pmem()
libnvdimm, pmem: flush posted-write queues on shutdown
Instead of punching a hole in the linear mapping, just use normal
cachable memory, and apply the flush sequence documented in the
CPC625 (aka U3) user manual.
This allows us to remove quite a bit of code related to the early
allocation of the DART and the hole in the linear mapping. We can
also get rid of the copy of the DART for suspend/resume as the
original memory can just be saved/restored now, as long as we
properly sync the caches.
[mpe: Integrate dart_init() fix to return ENODEV when DART disabled]
This adds a new XICS backend that uses OPAL calls, which can be
used when we don't have native support for the platform interrupt
controller.
powernv marks it's halt and restart calls as __noreturn. However,
ppc_md does not have this annotation. Add the annotation to ppc_md,
and then to every halt/restart function that is missing it.
Additionally, I have verified that all of these functions do not
return. Occasionally I have added a spin loop to be sure.
The __pmem address space was meant to annotate codepaths that touch
persistent memory and need to coordinate a call to wmb_pmem(). Now that
wmb_pmem() is gone, there is little need to keep this annotation.
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Memory: 124428K/131072K available (3748K kernel code, 188K rwdata,
648K rodata, 508K init, 290K bss, 6644K reserved)
Kernel virtual memory layout:
* 0xfffdf000..0xfffff000 : fixmap
* 0xfde00000..0xfe000000 : consistent mem
* 0xfddf6000..0xfde00000 : early ioremap
* 0xc9000000..0xfddf6000 : vmalloc & ioremap
SLUB: HWalign=16, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Today, IMMR is mapped 1:1 at startup
Mapping IMMR 1:1 is just wrong because it may overlap with another
area. On most mpc8xx boards it is OK as IMMR is set to 0xff000000
but for instance on EP88xC board, IMMR is at 0xfa200000 which
overlaps with VM ioremap area
This patch fixes the virtual address for remapping IMMR with the fixmap
regardless of the value of IMMR.
The size of IMMR area is 256kbytes (CPM at offset 0, security engine
at offset 128k) so a 512k page is enough
If the SRAM region parameters are missing the SRAM driver
probing exits and the L2 region is configured as L2 cache
entirely. This is the expected default behaviour, so it
makes no sense to report it as an error.
Signed-off-by: Claudiu Manoil <claudiu.manoil@nxp.com>
For block drivers that specify a parent device, convert them to use
device_add_disk().
This conversion was done with the following semantic patch:
struct gendisk *disk;
expression E;
- disk->driverfs_dev = E;
- add_disk(disk);
+ device_add_disk(E, disk);
expression E1, E2;
- disk->driverfs_dev = E1;
E2 = disk;
- add_disk(E2);
+ device_add_disk(E1, E2);
...plus some manual fixups for a few missed conversions.
Cc: Jens Axboe <axboe@fb.com>
Cc: Keith Busch <keith.busch@intel.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: James Bottomley <James.Bottomley@hansenpartnership.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Pull misc DAX updates from Vishal Verma:
"DAX error handling for 4.7
- Until now, dax has been disabled if media errors were found on any
device. This enables the use of DAX in the presence of these
errors by making all sector-aligned zeroing go through the driver.
- The driver (already) has the ability to clear errors on writes that
are sent through the block layer using 'DSMs' defined in ACPI 6.1.
Other misc changes:
- When mounting DAX filesystems, check to make sure the partition is
page aligned. This is a requirement for DAX, and previously, we
allowed such unaligned mounts to succeed, but subsequent
reads/writes would fail.
- Misc/cleanup fixes from Jan that remove unused code from DAX
related to zeroing, writeback, and some size checks"
* tag 'dax-misc-for-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
dax: fix a comment in dax_zero_page_range and dax_truncate_page
dax: for truncate/hole-punch, do zeroing through the driver if possible
dax: export a low-level __dax_zero_page_range helper
dax: use sb_issue_zerout instead of calling dax_clear_sectors
dax: enable dax in the presence of known media errors (badblocks)
dax: fallback from pmd to pte on error
block: Update blkdev_dax_capable() for consistency
xfs: Add alignment check for DAX mount
ext2: Add alignment check for DAX mount
ext4: Add alignment check for DAX mount
block: Add bdev_dax_supported() for dax mount checks
block: Add vfs_msg() interface
dax: Remove redundant inode size checks
dax: Remove pointless writeback from dax_do_io()
dax: Remove zeroing from dax_io()
dax: Remove dead zeroing code from fault handlers
ext2: Avoid DAX zeroing to corrupt data
ext2: Fix block zeroing in ext2_get_blocks() for DAX
dax: Remove complete_unwritten argument
DAX: move RADIX_DAX_ definitions to dax.c
"Highlights:
- Support for Power ISA 3.0 (Power9) Radix Tree MMU from Aneesh Kumar K.V
- Live patching support for ppc64le (also merged via livepatching.git)
Various cleanups & minor fixes from:
- Aaro Koskinen, Alexey Kardashevskiy, Andrew Donnellan, Aneesh Kumar K.V,
Chris Smart, Daniel Axtens, Frederic Barrat, Gavin Shan, Ian Munsie,
Lennart Sorensen, Madhavan Srinivasan, Mahesh Salgaonkar, Markus Elfring,
Michael Ellerman, Oliver O'Halloran, Paul Gortmaker, Paul Mackerras,
Rashmica Gupta, Russell Currey, Suraj Jitindar Singh, Thiago Jung
Bauermann, Valentin Rothberg, Vipin K Parashar.
General:
- Update LMB associativity index during DLPAR add/remove from Nathan
Fontenot
- Fix branching to OOL handlers in relocatable kernel from Hari Bathini
- Add support for userspace Power9 copy/paste from Chris Smart
- Always use STRICT_MM_TYPECHECKS from Michael Ellerman
- Add mask of possible MMU features from Michael Ellerman
PCI:
- Enable pass through of NVLink to guests from Alexey Kardashevskiy
- Cleanups in preparation for powernv PCI hotplug from Gavin Shan
- Don't report error in eeh_pe_reset_and_recover() from Gavin Shan
- Restore initial state in eeh_pe_reset_and_recover() from Gavin Shan
- Revert "powerpc/eeh: Fix crash in eeh_add_device_early() on Cell"
from Guilherme G Piccoli
- Remove the dependency on EEH struct in DDW mechanism from Guilherme
G Piccoli
selftests:
- Test cp_abort during context switch from Chris Smart
- Add several tests for transactional memory support from Rashmica
Gupta
perf:
- Add support for sampling interrupt register state from Anju T
- Add support for unwinding perf-stackdump from Chandan Kumar
cxl:
- Configure the PSL for two CAPI ports on POWER8NVL from Philippe
Bergheaud
- Allow initialization on timebase sync failures from Frederic Barrat
- Increase timeout for detection of AFU mmio hang from Frederic
Barrat
- Handle num_of_processes larger than can fit in the SPA from Ian
Munsie
- Ensure PSL interrupt is configured for contexts with no AFU IRQs
from Ian Munsie
- Add kernel API to allow a context to operate with relocate disabled
from Ian Munsie
- Check periodically the coherent platform function's state from
Christophe Lombard
Freescale:
- Updates from Scott: "Contains 86xx fixes, minor device tree fixes,
an erratum workaround, and a kconfig dependency fix."
* tag 'powerpc-4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (192 commits)
powerpc/86xx: Fix PCI interrupt map definition
powerpc/86xx: Move pci1 definition to the include file
powerpc/fsl: Fix build of the dtb embedded kernel images
powerpc/fsl: Fix rcpm compatible string
powerpc/fsl: Remove FSL_SOC dependency from FSL_LBC
powerpc/fsl-pci: Add a workaround for PCI 5 errata
powerpc/fsl: Fix SPI compatible on t208xrdb and t1040rdb
powerpc/powernv/npu: Add PE to PHB's list
powerpc/powernv: Fix insufficient memory allocation
powerpc/iommu: Remove the dependency on EEH struct in DDW mechanism
powerpc/eeh: Drop unnecessary label in eeh_pe_change_owner()
powerpc/eeh: Ignore handlers in eeh_pe_reset_and_recover()
powerpc/eeh: Restore initial state in eeh_pe_reset_and_recover()
powerpc/eeh: Don't report error in eeh_pe_reset_and_recover()
Revert "powerpc/powernv: Exclude root bus in pnv_pci_reset_secondary_bus()"
powerpc/powernv/npu: Enable NVLink pass through
powerpc/powernv/npu: Rework TCE Kill handling
powerpc/powernv/npu: Add set/unset window helpers
powerpc/powernv/ioda2: Export debug helper pe_level_printk()
1/ If a mapping overlaps a bad sector fail the request.
2/ Do not opportunistically report more dax-capable capacity than is
requested when errors present.
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
[vishal: fix a conflict with system RAM collision patches]
[vishal: add a 'size' parameter to ->direct_access]
[vishal: fix a conflict with DAX alignment check patches]
Signed-off-by: Vishal Verma <vishal.l.verma@intel.com>
Issue:
As a master, the PCI IP block can combine a memory write to the last PCI
double word (4 bytes) of a cacheline with a 4 byte memory write to the
first PCI double word of the subsequent cacheline. This affects 32-bit
PCI target devices that blindly assert STOP on memory-write transactions,
without detecting that the data beat being transferred is the last data
beat of the transaction. It can cause a hang. PCI-X operation is not
affected by this erratum.
Workaround:
Setting the bit MDS in the PCI Bus Function Register will disable the
combining of crossing cacheline boundary requests into one burst
transaction. Therefore, it can prevent the errata scenario from
occurring.
This errata exists in MPC8543, MPC8543E, MPC8545, MPC8545E, MPC8547,
MPC8547E, MPC8548 and MPC8548E. Refer to PCI 5 in MPC8548 errata
document.
Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com>
Signed-off-by: Zhiqiang Hou <Zhiqiang.Hou@freescale.com>
[scottwood: whitespace fix]
mpic_init_sys() currently doesn't check whether
subsys_system_register() succeeded or not. Check the return code of
subsys_system_register() and clean up if there's an error.
Signed-off-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
commit 0d36fe65f58391712e11a6621075f373216e5f00
"powerpc: ppc4xx: use gpiochip data pointer"
made the mm_gc local variable in ppc4xx_gpio_set()
redundant, and when GCC treats warnings as errors this
happens:
arch/powerpc/sysdev/ppc4xx_gpio.c: In function 'ppc4xx_gpio_set':
arch/powerpc/sysdev/ppc4xx_gpio.c:93:26: error:
unused variable 'mm_gc' [-Werror=unused-variable]
struct of_mm_gpio_chip *mm_gc = to_of_mm_gpio_chip(gc);
cc1: all warnings being treated as errors
Reported-by: kbuild test robot <fengguang.wu@intel.com>
This makes the driver use the data pointer added to the gpio_chip
to store a pointer to the state container instead of relying on
container_of().
Cc: Anton Vorontsov <anton@enomsg.org>
container_of().
container_of().
container_of().
