commit af81d7878c641629f2693ae3fdaf74b4af14dfca upstream.
Now we use ESID_BITS of kernel address to build proto vsid. So rename
USER_ESIT_BITS to ESID_BITS
Acked-by: Paul Mackerras <paulus@samba.org>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit c60ac5693c47df32a2b4b18af97fca5635def015 upstream.
This patch change the kernel VSID range so that we limit VSID_BITS to 37.
This enables us to support 64TB with 65 bit VA (37+28). Without this patch
we have boot hangs on platforms that only support 65 bit VA.
With this patch we now have proto vsid generated as below:
We first generate a 37-bit "proto-VSID". Proto-VSIDs are generated
from mmu context id and effective segment id of the address.
For user processes max context id is limited to ((1ul << 19) - 5)
for kernel space, we use the top 4 context ids to map address as below
0x7fffc - [ 0xc000000000000000 - 0xc0003fffffffffff ]
0x7fffd - [ 0xd000000000000000 - 0xd0003fffffffffff ]
0x7fffe - [ 0xe000000000000000 - 0xe0003fffffffffff ]
0x7ffff - [ 0xf000000000000000 - 0xf0003fffffffffff ]
Tested-by: Geoff Levand <geoff@infradead.org>
commit e39d1a471484662620651cd9520250d33843f235 upstream.
VSID_BITS and VSID_BITS_1T depends on the context bits and user esid
bits. Make the dependency explicit
commit d63ac5f6cf31c8a83170a9509b350c1489a7262b upstream.
Commit 44ae3ab3358e962039c36ad4ae461ae9fb29596c forgot to update
the entry for the 970MP rev 1.0 processor when moving some CPU
features bits to the MMU feature bit mask. This breaks booting
on some rare G5 models using that chip revision.
Reported-by: Phileas Fogg <phileas-fogg@mail.ru>
commit 13938117a57f88a22f0df9722a5db7271fda85cd upstream.
Commit f5339277eb8d3aed37f12a27988366f68ab68930 accidentally removed
more than just iSeries bits and took out the call to stab_initialize()
thus breaking support for POWER3 processors.
Put it back. (Yes, nobody noticed until now ...)
commit 25e138149c19fa0680147b825be475f5fd57f155 upstream.
In commit 466921c we added a hack to set the paca data_offset to zero so
that per-cpu accesses would work on the boot cpu prior to per-cpu areas
being setup. This fixed a problem with lockdep touching per-cpu areas
very early in boot.
However if we combine CONFIG_LOCK_STAT=y with any of the PPC_EARLY_DEBUG
options, we can hit the same problem in udbg_early_init(). To avoid that
we need to set the data_offset of the boot_paca also. So factor out the
fixup logic and call it for both the boot_paca, and "the paca of the
boot cpu".
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
commit 6a040ce72598159a74969a2d01ab0ba5ee6536b3 upstream.
The DDW code uses a eeh_dev struct from the pci_dev. However, this is
not set until eeh_add_device_late is called.
Since pci_bus_add_devices is called before eeh_add_device_late, the PCI
devices are added to the bus, making drivers' probe hooks to be called.
These will call set_dma_mask, which will call the DDW code, which will
require the eeh_dev struct from pci_dev. This would result in a crash,
due to a NULL dereference.
Calling eeh_add_device_late after pci_bus_add_devices would make the
system BUG, because device files shouldn't be added to devices there
were not added to the system. So, a new function is needed to add such
files only after pci_bus_add_devices have been called.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Acked-by: Gavin Shan <shangw@linux.vnet.ibm.com>
commit 5e249d4528528c9a77da051a89ec7f99d31b83eb upstream.
Uprobes uses emulate_step in sstep.c, but we haven't explicitly specified
the dependency. On pseries HAVE_HW_BREAKPOINT protects us, but 44x has no
such luxury.
Consolidate other users that depend on sstep and create a new config option.
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Signed-off-by: Suzuki K. Poulose <suzuki@in.ibm.com>
Cc: linuxppc-dev@ozlabs.org
commit 8520e443aa56cc157b015205ea53e7b9fc831291 upstream.
Disable hard IRQ before kexec a new kernel image.
Not doing it can result in corrupted data in the memory segments
reserved for the new kernel.
Signed-off-by: Phileas Fogg <phileas-fogg@mail.ru>
The ASM version of hash computation function was truncating the upper bit.
Make the ASM version similar to hpt_hash function. Remove masking vsid bits.
Without this patch, we observed hang during bootup due to not satisfying page
fault request correctly. The fault handler used wrong hash values to update
the HPTE. Hence we kept looping with page fault.
hash_page(ea=000001003e260008, access=203, trap=300 ip=3fff91787134 dsisr 42000000
The computed value of hash 000000000f22f390
update: avpnv=4003e46054003e00, hash=000000000722f390, f=80000006, psize: 2 ...
BenH: The over-masking has been there for ever but only hurts with the
new 64T support introduced in 3.7
Reported-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Tested-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
CC: <stable@vger.kernel.org> [v3.7]
With lazy interrupt, we always call __check_irq_replaysome with
decrementers_next_tb to check if we need to replay timer interrupt.
So in hotplug case we also need to set decrementers_next_tb as MAX
to make sure __check_irq_replay don't replay timer interrupt
when return as we expect, otherwise we'll trap here infinitely.
Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com>
the variable backup_current_thread_info isn't freed before existing the
function.
Signed-off-by: Cong Ding <dinggnu@gmail.com>
In preempt case current arch_local_irq_restore() from
preempt_schedule_irq() may enable hard interrupt but we really
should disable interrupts when we return from the interrupt,
and so that we don't get interrupted after loading SRR0/1.
The calculation for the left shift of the mask OPROFILE_PM_PMCSEL_MSK has an
error. The calculation is should be to shift left by (max_cntrs - cntr) times
the width of the pmsel field width. However, the #define OPROFILE_MAX_PMC_NUM
was used instead of OPROFILE_PMSEL_FIELD_WIDTH. This patch fixes the
calculation.
Signed-off-by: Carl Love <cel@us.ibm.com>
commit f96972f2dc "kernel/sys.c: call disable_nonboot_cpus() in
kernel_restart()"
added a call to disable_nonboot_cpus() on kernel_restart(), which tries
to shutdown all the CPUs except the first one. The issue with the PA
Semi, is that it does not support CPU hotplug.
When the call is made to __cpu_down(), it calls the notifiers
CPU_DOWN_PREPARE, and then tries to take the CPU down.
One of the notifiers to the CPU hotplug code, is the cpufreq. The
DOWN_PREPARE will call __cpufreq_remove_dev() which calls
cpufreq_driver->exit. The PA Semi exit handler unmaps regions of I/O
that is used by an interrupt that goes off constantly
(system_reset_common, but it goes off during normal system operations
too). I'm not sure exactly what this interrupt does.
Running a simple function trace, you can see it goes off quite a bit:
# tracer: function
# TASK-PID CPU# TIMESTAMP FUNCTION
<idle>-0 [001] 1558.859363: .pasemi_system_reset_exception <-.system_reset_exception
<idle>-0 [000] 1558.860112: .pasemi_system_reset_exception <-.system_reset_exception
<idle>-0 [000] 1558.861109: .pasemi_system_reset_exception <-.system_reset_exception
<idle>-0 [001] 1558.861361: .pasemi_system_reset_exception <-.system_reset_exception
<idle>-0 [000] 1558.861437: .pasemi_system_reset_exception <-.system_reset_exception
When the region is unmapped, the system crashes with:
Disabling non-boot CPUs ...
Error taking CPU1 down: -38
Unable to handle kernel paging request for data at address 0xd0000800903a0100
Faulting instruction address: 0xc000000000055fcc
Oops: Kernel access of bad area, sig: 11 [#1]
PREEMPT SMP NR_CPUS=64 NUMA PA Semi PWRficient
Modules linked in: shpchp
NIP: c000000000055fcc LR: c000000000055fb4 CTR: c0000000000df1fc
REGS: c0000000012175d0 TRAP: 0300 Not tainted (3.8.0-rc4-test-dirty)
MSR: 9000000000009032 <SF,HV,EE,ME,IR,DR,RI> CR: 24000088 XER: 00000000
SOFTE: 0
DAR: d0000800903a0100, DSISR: 42000000
TASK = c0000000010e9008[0] 'swapper/0' THREAD: c000000001214000 CPU: 0
GPR00: d0000800903a0000 c000000001217850 c0000000012167e0 0000000000000000
GPR04: 0000000000000000 0000000000000724 0000000000000724 0000000000000000
GPR08: 0000000000000000 0000000000000000 0000000000000001 0000000000a70000
GPR12: 0000000024000080 c00000000fff0000 ffffffffffffffff 000000003ffffae0
GPR16: ffffffffffffffff 0000000000a21198 0000000000000060 0000000000000000
GPR20: 00000000008fdd35 0000000000a21258 000000003ffffaf0 0000000000000417
GPR24: 0000000000a226d0 c000000000000000 0000000000000000 0000000000000000
GPR28: c00000000138b358 0000000000000000 c000000001144818 d0000800903a0100
NIP [c000000000055fcc] .set_astate+0x5c/0xa4
LR [c000000000055fb4] .set_astate+0x44/0xa4
Call Trace:
[c000000001217850] [c000000000055fb4] .set_astate+0x44/0xa4 (unreliable)
[c0000000012178f0] [c00000000005647c] .restore_astate+0x2c/0x34
[c000000001217980] [c000000000054668] .pasemi_system_reset_exception+0x6c/0x88
[c000000001217a00] [c000000000019ef0] .system_reset_exception+0x48/0x84
[c000000001217a80] [c000000000001e40] system_reset_common+0x140/0x180
This patch fixes MAX_STACK_TRACE_ENTRIES too low warning for ppc32,
which is similar to commit 12660b17.
Reported-by: Christian Kujau <lists@nerdbynature.de>
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
Tested-by: Christian Kujau <lists@nerdbynature.de>
Guests can trigger MMIO exits using dcbf. Since we don't emulate cache
incoherent MMIO, just do nothing and move on.
Reported-by: Ben Collins <ben.c@servergy.com>
Tested-by: Ben Collins <ben.c@servergy.com>
CC: stable@vger.kernel.org
Pull KVM bugfixes from Marcelo Tosatti.
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: x86: use dynamic percpu allocations for shared msrs area
KVM: PPC: Book3S HV: Fix compilation without CONFIG_PPC_POWERNV
powerpc: Corrected include header path in kvm_para.h
Add rcu user eqs exception hooks for async page fault
Fixes this build breakage:
arch/powerpc/kvm/book3s_hv_ras.c: In function ‘kvmppc_realmode_mc_power7’:
arch/powerpc/kvm/book3s_hv_ras.c:126:23: error: ‘struct paca_struct’ has no member named ‘opal_mc_evt’
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core __dev* removal patches - take 3 - from Greg Kroah-Hartman:
"Here are the remaining __dev* removal patches against the 3.8-rc2
tree. All of these patches were previously sent to the subsystem
maintainers, most of them were picked up and pushed to you, but there
were a number that fell through the cracks, and new drivers were added
during the merge window, so this series cleans up the rest of the
instances of these markings.
Third time's the charm...
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed up trivial conflict with the pinctrl pull in pinctrl-sirf.c.
* tag 'driver-core-3.8-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (54 commits)
misc: remove __dev* attributes.
include: remove __dev* attributes.
Documentation: remove __dev* attributes.
Drivers: misc: remove __dev* attributes.
Drivers: block: remove __dev* attributes.
Drivers: bcma: remove __dev* attributes.
Drivers: char: remove __dev* attributes.
Drivers: clocksource: remove __dev* attributes.
Drivers: ssb: remove __dev* attributes.
Drivers: dma: remove __dev* attributes.
Drivers: gpu: remove __dev* attributes.
Drivers: infinband: remove __dev* attributes.
Drivers: memory: remove __dev* attributes.
Drivers: mmc: remove __dev* attributes.
Drivers: iommu: remove __dev* attributes.
Drivers: power: remove __dev* attributes.
Drivers: message: remove __dev* attributes.
Drivers: macintosh: remove __dev* attributes.
Drivers: mfd: remove __dev* attributes.
pstore: remove __dev* attributes.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
The missing NULL terminator can cause a panic on
PPC405 boards during boot:
Linux/PowerPC load: console=ttyS0,115200 root=/dev/mtdblock1 rootfstype=squashfs,jffs2 noinitrd init=/etc/preinit
Finalizing device tree... flat tree at 0x6a5160
bootconsole [udbg0] enabled
Page fault in user mode with in_atomic() = 1 mm = (null)
NIP = c0275f50 MSR = fffffffe
Oops: Weird page fault, sig: 11 [#1]
PowerPC 40x Platform
Modules linked in:
NIP: c0275f50 LR: c0275f60 CTR: c0280000
REGS: c0275eb0 TRAP: 636f7265 Not tainted (3.7.1)
MSR: fffffffe <VEC,VSX,EE,PR,FP,ME,SE,BE,IR,DR,PMM,RI> CR: c06a6190 XER: 00000001
TASK = c02662a8[0] 'swapper' THREAD: c0274000
GPR00: c0275ec0 c000c658 c027c4bf 00000000 c0275ee0 c000a0ec c020a1a8 c020a1f0
GPR08: c020f631 c020f404 c025f078 c025f080 c0275f10
Call Trace:
---[ end trace 31fd0ba7d8756001 ]---
Kernel panic - not syncing: Attempted to kill the idle task!
The panic happens since commit 9597abe00c1bab2aedce6b49866bf6d1e81c9eed
(sections: fix section conflicts in arch/powerpc), however the root
cause of this is that the NULL terminator were not added in commit
a4f740cf33f7f6c164bbde3c0cdbcc77b0c4997c (of/flattree: Add of_flat_dt_match()
helper function).
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: <stable@vger.kernel.org>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
The locking in update_vsyscall_tz() is not only unnecessary because the vdso
code copies the data unproteced in __kernel_gettimeofday() but also
introduces a hard to reproduce race condition between update_vsyscall()
and update_vsyscall_tz(), which causes user space process to loop
forever in vdso code.
The following patch removes the locking from update_vsyscall_tz().
Locking is not only unnecessary because the vdso code copies the data
unprotected in __kernel_gettimeofday() but also erroneous because updating
the tb_update_count is not atomic and introduces a hard to reproduce race
condition between update_vsyscall() and update_vsyscall_tz(), which further
causes user space process to loop forever in vdso code.
The below scenario describes the race condition,
x==0 Boot CPU other CPU
proc_P: x==0
timer interrupt
update_vsyscall
x==1 x++;sync settimeofday
update_vsyscall_tz
x==2 x++;sync
x==3 sync;x++
sync;x++
proc_P: x==3 (loops until x becomes even)
Because the ++ operator would be implemented as three instructions and not
atomic on powerpc.
A similar change was made for x86 in commit 6c260d58634
("x86: vdso: Remove bogus locking in update_vsyscall_tz")
Signed-off-by: Shan Hai <shan.hai@windriver.com>
Pull VFS update from Al Viro:
"fscache fixes, ESTALE patchset, vmtruncate removal series, assorted
misc stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (79 commits)
vfs: make lremovexattr retry once on ESTALE error
vfs: make removexattr retry once on ESTALE
vfs: make llistxattr retry once on ESTALE error
vfs: make listxattr retry once on ESTALE error
vfs: make lgetxattr retry once on ESTALE
vfs: make getxattr retry once on an ESTALE error
vfs: allow lsetxattr() to retry once on ESTALE errors
vfs: allow setxattr to retry once on ESTALE errors
vfs: allow utimensat() calls to retry once on an ESTALE error
vfs: fix user_statfs to retry once on ESTALE errors
vfs: make fchownat retry once on ESTALE errors
vfs: make fchmodat retry once on ESTALE errors
vfs: have chroot retry once on ESTALE error
vfs: have chdir retry lookup and call once on ESTALE error
vfs: have faccessat retry once on an ESTALE error
vfs: have do_sys_truncate retry once on an ESTALE error
vfs: fix renameat to retry on ESTALE errors
vfs: make do_unlinkat retry once on ESTALE errors
vfs: make do_rmdir retry once on ESTALE errors
vfs: add a flags argument to user_path_parent
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull signal handling cleanups from Al Viro:
"sigaltstack infrastructure + conversion for x86, alpha and um,
COMPAT_SYSCALL_DEFINE infrastructure.
Note that there are several conflicts between "unify
SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline;
resolution is trivial - just remove definitions of SS_ONSTACK and
SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and
include/uapi/linux/signal.h contains the unified variant."
Fixed up conflicts as per Al.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
alpha: switch to generic sigaltstack
new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those
generic compat_sys_sigaltstack()
introduce generic sys_sigaltstack(), switch x86 and um to it
new helper: compat_user_stack_pointer()
new helper: restore_altstack()
unify SS_ONSTACK/SS_DISABLE definitions
new helper: current_user_stack_pointer()
missing user_stack_pointer() instances
Bury the conditionals from kernel_thread/kernel_execve series
COMPAT_SYSCALL_DEFINE: infrastructure
Where we can pass in LOOKUP_DIRECTORY or LOOKUP_REVAL. Any other flags
passed in here are currently ignored.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"A few new features this merge-window. The most important one is
probably, that dma-debug now warns if a dma-handle is not checked with
dma_mapping_error by the device driver. This requires minor changes
to some architectures which make use of dma-debug. Most of these
changes have the respective Acks by the Arch-Maintainers.
Besides that there are updates to the AMD IOMMU driver for refactor
the IOMMU-Groups support and to make sure it does not trigger a
hardware erratum.
The OMAP changes (for which I pulled in a branch from Tony Lindgren's
tree) have a conflict in linux-next with the arm-soc tree. The
conflict is in the file arch/arm/mach-omap2/clock44xx_data.c which is
deleted in the arm-soc tree. It is safe to delete the file too so
solve the conflict. Similar changes are done in the arm-soc tree in
the common clock framework migration. A missing hunk from the patch
in the IOMMU tree will be submitted as a seperate patch when the
merge-window is closed."
* tag 'iommu-updates-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (29 commits)
ARM: dma-mapping: support debug_dma_mapping_error
ARM: OMAP4: hwmod data: ipu and dsp to use parent clocks instead of leaf clocks
iommu/omap: Adapt to runtime pm
iommu/omap: Migrate to hwmod framework
iommu/omap: Keep mmu enabled when requested
iommu/omap: Remove redundant clock handling on ISR
iommu/amd: Remove obsolete comment
iommu/amd: Don't use 512GB pages
iommu/tegra: smmu: Move bus_set_iommu after probe for multi arch
iommu/tegra: gart: Move bus_set_iommu after probe for multi arch
iommu/tegra: smmu: Remove unnecessary PTC/TLB flush all
tile: dma_debug: add debug_dma_mapping_error support
sh: dma_debug: add debug_dma_mapping_error support
powerpc: dma_debug: add debug_dma_mapping_error support
mips: dma_debug: add debug_dma_mapping_error support
microblaze: dma-mapping: support debug_dma_mapping_error
ia64: dma_debug: add debug_dma_mapping_error support
c6x: dma_debug: add debug_dma_mapping_error support
ARM64: dma_debug: add debug_dma_mapping_error support
intel-iommu: Prevent devices with RMRRs from being placed into SI Domain
The include/uapi/asm/kvm_para.h includes
<include/uapi/asm/epapr_hcalls.h> but the correct reference
should be <include/asm/epapr_hcalls.h> as this is the place
where make install_header installs the header files for
userspace.
Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com>
All architectures have
CONFIG_GENERIC_KERNEL_THREAD
CONFIG_GENERIC_KERNEL_EXECVE
__ARCH_WANT_SYS_EXECVE
None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers
of kernel_execve() (which is a trivial wrapper for do_execve() now) left.
Kill the conditionals and make both callers use do_execve().
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"Nothing all that exciting; a new module-from-fd syscall for those who
want to verify the source of the module (ChromeOS) and/or use standard
IMA on it or other security hooks."
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
MODSIGN: Fix kbuild output when using default extra_certificates
MODSIGN: Avoid using .incbin in C source
modules: don't hand 0 to vmalloc.
module: Remove a extra null character at the top of module->strtab.
ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants
ASN.1: Define indefinite length marker constant
moduleparam: use __UNIQUE_ID()
__UNIQUE_ID()
MODSIGN: Add modules_sign make target
powerpc: add finit_module syscall.
ima: support new kernel module syscall
add finit_module syscall to asm-generic
ARM: add finit_module syscall to ARM
security: introduce kernel_module_from_file hook
module: add flags arg to sys_finit_module()
module: add syscall to load module from fd
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc update from Benjamin Herrenschmidt:
"The main highlight is probably some base POWER8 support. There's more
to come such as transactional memory support but that will wait for
the next one.
Overall it's pretty quiet, or rather I've been pretty poor at picking
things up from patchwork and reviewing them this time around and Kumar
no better on the FSL side it seems..."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (73 commits)
powerpc+of: Rename and fix OF reconfig notifier error inject module
powerpc: mpc5200: Add a3m071 board support
powerpc/512x: don't compile any platform DIU code if the DIU is not enabled
powerpc/mpc52xx: use module_platform_driver macro
powerpc+of: Export of_reconfig_notifier_[register,unregister]
powerpc/dma/raidengine: add raidengine device
powerpc/iommu/fsl: Add PAMU bypass enable register to ccsr_guts struct
powerpc/mpc85xx: Change spin table to cached memory
powerpc/fsl-pci: Add PCI controller ATMU PM support
powerpc/86xx: fsl_pcibios_fixup_bus requires CONFIG_PCI
drivers/virt: the Freescale hypervisor driver doesn't need to check MSR[GS]
powerpc/85xx: p1022ds: Use NULL instead of 0 for pointers
powerpc: Disable relocation on exceptions when kexecing
powerpc: Enable relocation on during exceptions at boot
powerpc: Move get_longbusy_msecs into hvcall.h and remove duplicate function
powerpc: Add wrappers to enable/disable relocation on exceptions
powerpc: Add set_mode hcall
powerpc: Setup relocation on exceptions for bare metal systems
powerpc: Move initial mfspr LPCR out of __init_LPCR
powerpc: Add relocation on exception vector handlers
Merge misc patches from Andrew Morton:
"Incoming:
- lots of misc stuff
- backlight tree updates
- lib/ updates
- Oleg's percpu-rwsem changes
- checkpatch
- rtc
- aoe
- more checkpoint/restart support
I still have a pile of MM stuff pending - Pekka should be merging
later today after which that is good to go. A number of other things
are twiddling thumbs awaiting maintainer merges."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (180 commits)
scatterlist: don't BUG when we can trivially return a proper error.
docs: update documentation about /proc/<pid>/fdinfo/<fd> fanotify output
fs, fanotify: add @mflags field to fanotify output
docs: add documentation about /proc/<pid>/fdinfo/<fd> output
fs, notify: add procfs fdinfo helper
fs, exportfs: add exportfs_encode_inode_fh() helper
fs, exportfs: escape nil dereference if no s_export_op present
fs, epoll: add procfs fdinfo helper
fs, eventfd: add procfs fdinfo helper
procfs: add ability to plug in auxiliary fdinfo providers
tools/testing/selftests/kcmp/kcmp_test.c: print reason for failure in kcmp_test
breakpoint selftests: print failure status instead of cause make error
kcmp selftests: print fail status instead of cause make error
kcmp selftests: make run_tests fix
mem-hotplug selftests: print failure status instead of cause make error
cpu-hotplug selftests: print failure status instead of cause make error
mqueue selftests: print failure status instead of cause make error
vm selftests: print failure status instead of cause make error
ubifs: use prandom_bytes
mtd: nandsim: use prandom_bytes
This function is used by sparc, powerpc tile and arm64 for compat support.
The patch adds a generic implementation with a wrapper for PowerPC to do
the u32->int sign extension.
The reason for a single patch covering powerpc, tile, sparc and arm64 is
to keep it bisectable, otherwise kernel building may fail with mismatched
function declarations.
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [for tile]
Currently the __define_initcall() macro takes three arguments, fn, id and
level. The level argument is exactly the same as the id argument but
wrapped in quotes. To overcome this need to specify three arguments to
the __define_initcall macro, where one argument is the stringification of
another, we can just use the stringification macro instead.
Signed-off-by: Matthew Leach <matthew@mattleach.net>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"While small this set of changes is very significant with respect to
containers in general and user namespaces in particular. The user
space interface is now complete.
This set of changes adds support for unprivileged users to create user
namespaces and as a user namespace root to create other namespaces.
The tyranny of supporting suid root preventing unprivileged users from
using cool new kernel features is broken.
This set of changes completes the work on setns, adding support for
the pid, user, mount namespaces.
This set of changes includes a bunch of basic pid namespace
cleanups/simplifications. Of particular significance is the rework of
the pid namespace cleanup so it no longer requires sending out
tendrils into all kinds of unexpected cleanup paths for operation. At
least one case of broken error handling is fixed by this cleanup.
The files under /proc/<pid>/ns/ have been converted from regular files
to magic symlinks which prevents incorrect caching by the VFS,
ensuring the files always refer to the namespace the process is
currently using and ensuring that the ptrace_mayaccess permission
checks are always applied.
The files under /proc/<pid>/ns/ have been given stable inode numbers
so it is now possible to see if different processes share the same
namespaces.
Through the David Miller's net tree are changes to relax many of the
permission checks in the networking stack to allowing the user
namespace root to usefully use the networking stack. Similar changes
for the mount namespace and the pid namespace are coming through my
tree.
Two small changes to add user namespace support were commited here adn
in David Miller's -net tree so that I could complete the work on the
/proc/<pid>/ns/ files in this tree.
Work remains to make it safe to build user namespaces and 9p, afs,
ceph, cifs, coda, gfs2, ncpfs, nfs, nfsd, ocfs2, and xfs so the
Kconfig guard remains in place preventing that user namespaces from
being built when any of those filesystems are enabled.
Future design work remains to allow root users outside of the initial
user namespace to mount more than just /proc and /sys."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (38 commits)
proc: Usable inode numbers for the namespace file descriptors.
proc: Fix the namespace inode permission checks.
proc: Generalize proc inode allocation
userns: Allow unprivilged mounts of proc and sysfs
userns: For /proc/self/{uid,gid}_map derive the lower userns from the struct file
procfs: Print task uids and gids in the userns that opened the proc file
userns: Implement unshare of the user namespace
userns: Implent proc namespace operations
userns: Kill task_user_ns
userns: Make create_new_namespaces take a user_ns parameter
userns: Allow unprivileged use of setns.
userns: Allow unprivileged users to create new namespaces
userns: Allow setting a userns mapping to your current uid.
userns: Allow chown and setgid preservation
userns: Allow unprivileged users to create user namespaces.
userns: Ignore suid and sgid on binaries if the uid or gid can not be mapped
userns: fix return value on mntns_install() failure
vfs: Allow unprivileged manipulation of the mount namespace.
vfs: Only support slave subtrees across different user namespaces
vfs: Add a user namespace reference from struct mnt_namespace
Brings some 52xx updates. Also manually merged tools/perf/perf.h.
'arm/tegra' and 'arm/omap' into next
(This is just for Acks: this won't work without the actual syscall patches,
sitting in my tree for -next at the moment).
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Pull KVM updates from Marcelo Tosatti:
"Considerable KVM/PPC work, x86 kvmclock vsyscall support,
IA32_TSC_ADJUST MSR emulation, amongst others."
Fix up trivial conflict in kernel/sched/core.c due to cross-cpu
migration notifier added next to rq migration call-back.
* tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (156 commits)
KVM: emulator: fix real mode segment checks in address linearization
VMX: remove unneeded enable_unrestricted_guest check
KVM: VMX: fix DPL during entry to protected mode
x86/kexec: crash_vmclear_local_vmcss needs __rcu
kvm: Fix irqfd resampler list walk
KVM: VMX: provide the vmclear function and a bitmap to support VMCLEAR in kdump
x86/kexec: VMCLEAR VMCSs loaded on all cpus if necessary
KVM: MMU: optimize for set_spte
KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface
KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation
KVM: PPC: bookehv: Add guest computation mode for irq delivery
KVM: PPC: Make EPCR a valid field for booke64 and bookehv
KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit
KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation
KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation
KVM: PPC: e500: Add emulation helper for getting instruction ea
KVM: PPC: bookehv64: Add support for interrupt handling
KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler
KVM: PPC: booke: Fix get_tb() compile error on 64-bit
KVM: PPC: e500: Silence bogus GCC warning in tlb code
Merge misc VM changes from Andrew Morton:
"The rest of most-of-MM. The other MM bits await a slab merge.
This patch includes the addition of a huge zero_page. Not a
performance boost but it an save large amounts of physical memory in
some situations.
Also a bunch of Fujitsu engineers are working on memory hotplug.
Which, as it turns out, was badly broken. About half of their patches
are included here; the remainder are 3.8 material."
However, this merge disables CONFIG_MOVABLE_NODE, which was totally
broken. We don't add new features with "default y", nor do we add
Kconfig questions that are incomprehensible to most people without any
help text. Does the feature even make sense without compaction or
memory hotplug?
* akpm: (54 commits)
mm/bootmem.c: remove unused wrapper function reserve_bootmem_generic()
mm/memory.c: remove unused code from do_wp_page()
asm-generic, mm: pgtable: consolidate zero page helpers
mm/hugetlb.c: fix warning on freeing hwpoisoned hugepage
hwpoison, hugetlbfs: fix RSS-counter warning
hwpoison, hugetlbfs: fix "bad pmd" warning in unmapping hwpoisoned hugepage
mm: protect against concurrent vma expansion
memcg: do not check for mm in __mem_cgroup_count_vm_event
tmpfs: support SEEK_DATA and SEEK_HOLE (reprise)
mm: provide more accurate estimation of pages occupied by memmap
fs/buffer.c: remove redundant initialization in alloc_page_buffers()
fs/buffer.c: do not inline exported function
writeback: fix a typo in comment
mm: introduce new field "managed_pages" to struct zone
mm, oom: remove statically defined arch functions of same name
mm, oom: remove redundant sleep in pagefault oom handler
mm, oom: cleanup pagefault oom handler
memory_hotplug: allow online/offline memory to result movable node
numa: add CONFIG_MOVABLE_NODE for movable-dedicated node
mm, memcg: avoid unnecessary function call when memcg is disabled
Pull trivial branch from Jiri Kosina:
"Usual stuff -- comment/printk typo fixes, documentation updates, dead
code elimination."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
HOWTO: fix double words typo
x86 mtrr: fix comment typo in mtrr_bp_init
propagate name change to comments in kernel source
doc: Update the name of profiling based on sysfs
treewide: Fix typos in various drivers
treewide: Fix typos in various Kconfig
wireless: mwifiex: Fix typo in wireless/mwifiex driver
messages: i2o: Fix typo in messages/i2o
scripts/kernel-doc: check that non-void fcts describe their return value
Kernel-doc: Convention: Use a "Return" section to describe return values
radeon: Fix typo and copy/paste error in comments
doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c
various: Fix spelling of "asynchronous" in comments.
Fix misspellings of "whether" in comments.
eisa: Fix spelling of "asynchronous".
various: Fix spelling of "registered" in comments.
doc: fix quite a few typos within Documentation
target: iscsi: fix comment typos in target/iscsi drivers
treewide: fix typo of "suport" in various comments and Kconfig
treewide: fix typo of "suppport" in various comments
Pull networking changes from David Miller:
1) Allow to dump, monitor, and change the bridge multicast database
using netlink. From Cong Wang.
2) RFC 5961 TCP blind data injection attack mitigation, from Eric
Dumazet.
3) Networking user namespace support from Eric W. Biederman.
4) tuntap/virtio-net multiqueue support by Jason Wang.
5) Support for checksum offload of encapsulated packets (basically,
tunneled traffic can still be checksummed by HW). From Joseph
Gasparakis.
6) Allow BPF filter access to VLAN tags, from Eric Dumazet and
Daniel Borkmann.
7) Bridge port parameters over netlink and BPDU blocking support
from Stephen Hemminger.
8) Improve data access patterns during inet socket demux by rearranging
socket layout, from Eric Dumazet.
9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and
Jon Maloy.
10) Update TCP socket hash sizing to be more in line with current day
realities. The existing heurstics were choosen a decade ago.
From Eric Dumazet.
11) Fix races, queue bloat, and excessive wakeups in ATM and
associated drivers, from Krzysztof Mazur and David Woodhouse.
12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions
in VXLAN driver, from David Stevens.
13) Add "oops_only" mode to netconsole, from Amerigo Wang.
14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also
allow DCB netlink to work on namespaces other than the initial
namespace. From John Fastabend.
15) Support PTP in the Tigon3 driver, from Matt Carlson.
16) tun/vhost zero copy fixes and improvements, plus turn it on
by default, from Michael S. Tsirkin.
17) Support per-association statistics in SCTP, from Michele
Baldessari.
And many, many, driver updates, cleanups, and improvements. Too
numerous to mention individually.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
net/mlx4_en: Add support for destination MAC in steering rules
net/mlx4_en: Use generic etherdevice.h functions.
net: ethtool: Add destination MAC address to flow steering API
bridge: add support of adding and deleting mdb entries
bridge: notify mdb changes via netlink
ndisc: Unexport ndisc_{build,send}_skb().
uapi: add missing netconf.h to export list
pkt_sched: avoid requeues if possible
solos-pci: fix double-free of TX skb in DMA mode
bnx2: Fix accidental reversions.
bna: Driver Version Updated to 3.1.2.1
bna: Firmware update
bna: Add RX State
bna: Rx Page Based Allocation
bna: TX Intr Coalescing Fix
bna: Tx and Rx Optimizations
bna: Code Cleanup and Enhancements
ath9k: check pdata variable before dereferencing it
ath5k: RX timestamp is reported at end of frame
ath9k_htc: RX timestamp is reported at end of frame
out_of_memory() is a globally defined function to call the oom killer.
x86, sh, and powerpc all use a function of the same name within file scope
in their respective fault.c unnecessarily. Inline the functions into the
pagefault handlers to clean the code up.
Signed-off-by: David Rientjes <rientjes@google.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Pull big execve/kernel_thread/fork unification series from Al Viro:
"All architectures are converted to new model. Quite a bit of that
stuff is actually shared with architecture trees; in such cases it's
literally shared branch pulled by both, not a cherry-pick.
A lot of ugliness and black magic is gone (-3KLoC total in this one):
- kernel_thread()/kernel_execve()/sys_execve() redesign.
We don't do syscalls from kernel anymore for either kernel_thread()
or kernel_execve():
kernel_thread() is essentially clone(2) with callback run before we
return to userland, the callbacks either never return or do
successful do_execve() before returning.
kernel_execve() is a wrapper for do_execve() - it doesn't need to
do transition to user mode anymore.
As a result kernel_thread() and kernel_execve() are
arch-independent now - they live in kernel/fork.c and fs/exec.c
resp. sys_execve() is also in fs/exec.c and it's completely
architecture-independent.
- daemonize() is gone, along with its parts in fs/*.c
- struct pt_regs * is no longer passed to do_fork/copy_process/
copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump.
- sys_fork()/sys_vfork()/sys_clone() unified; some architectures
still need wrappers (ones with callee-saved registers not saved in
pt_regs on syscall entry), but the main part of those suckers is in
kernel/fork.c now."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits)
do_coredump(): get rid of pt_regs argument
print_fatal_signal(): get rid of pt_regs argument
ptrace_signal(): get rid of unused arguments
get rid of ptrace_signal_deliver() arguments
new helper: signal_pt_regs()
unify default ptrace_signal_deliver
flagday: kill pt_regs argument of do_fork()
death to idle_regs()
don't pass regs to copy_process()
flagday: don't pass regs to copy_thread()
bfin: switch to generic vfork, get rid of pointless wrappers
xtensa: switch to generic clone()
openrisc: switch to use of generic fork and clone
unicore32: switch to generic clone(2)
score: switch to generic fork/vfork/clone
c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone()
take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h
mn10300: switch to generic fork/vfork/clone
h8300: switch to generic fork/vfork/clone
tile: switch to generic clone()
arch/microblaze/include/asm/Kbuild
Pull scheduler updates from Ingo Molnar:
"The biggest change affects group scheduling: we now track the runnable
average on a per-task entity basis, allowing a smoother, exponential
decay average based load/weight estimation instead of the previous
binary on-the-runqueue/off-the-runqueue load weight method.
This will inevitably disturb workloads that were in some sort of
borderline balancing state or unstable equilibrium, so an eye has to
be kept on regressions.
For that reason the new load average is only limited to group
scheduling (shares distribution) at the moment (which was also hurting
the most from the prior, crude weight calculation and whose scheduling
quality wins most from this change) - but we plan to extend this to
regular SMP balancing as well in the future, which will simplify and
speed up things a bit.
Other changes involve ongoing preparatory work to extend NOHZ to the
scheduler as well, eventually allowing completely irq-free user-space
execution."
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits)
Revert "sched/autogroup: Fix crash on reboot when autogroup is disabled"
cputime: Comment cputime's adjusting code
cputime: Consolidate cputime adjustment code
cputime: Rename thread_group_times to thread_group_cputime_adjusted
cputime: Move thread_group_cputime() to sched code
vtime: Warn if irqs aren't disabled on system time accounting APIs
vtime: No need to disable irqs on vtime_account()
vtime: Consolidate a bit the ctx switch code
vtime: Explicitly account pending user time on process tick
vtime: Remove the underscore prefix invasion
cputime: Separate irqtime accounting from generic vtime
cputime: Specialize irq vtime hooks
kvm: Directly account vtime to system on guest switch
vtime: Make vtime_account_system() irqsafe
vtime: Gather vtime declarations to their own header file
sched: Describe CFS load-balancer
sched: Introduce temporary FAIR_GROUP_SCHED dependency for load-tracking
sched: Make __update_entity_runnable_avg() fast
sched: Update_cfs_shares at period edge
Pull perf updates from Ingo Molnar:
"Lots of activity:
211 files changed, 8328 insertions(+), 4116 deletions(-)
most of it on the tooling side.
Main changes:
* ftrace enhancements and fixes from Steve Rostedt.
* uprobes fixes, cleanups and preparation for the ARM port from Oleg
Nesterov.
* UAPI fixes, from David Howels - prepares the arch/x86 UAPI
transition
* Separate perf tests into multiple objects, one per test, from Jiri
Olsa.
* Make hardware event translations available in sysfs, from Jiri
Olsa.
* Fixes to /proc/pid/maps parsing, preparatory to supporting data
maps, from Namhyung Kim
* Implement ui_progress for GTK, from Namhyung Kim
* Add framework for automated perf_event_attr tests, where tools with
different command line options will be run from a 'perf test', via
python glue, and the perf syscall will be intercepted to verify
that the perf_event_attr fields set by the tool are those expected,
from Jiri Olsa
* Add a 'link' method for hists, so that we can have the leader with
buckets for all the entries in all the hists. This new method is
now used in the default 'diff' output, making the sum of the
'baseline' column be 100%, eliminating blind spots.
* libtraceevent fixes for compiler warnings trying to make perf it
build on some distros, like fedora 14, 32-bit, some of the warnings
really pointed to real bugs.
* Add a browser for 'perf script' and make it available from the
report and annotate browsers. It does filtering to find the
scripts that handle events found in the perf.data file used. From
Feng Tang
* perf inject changes to allow showing where a task sleeps, from
Andrew Vagin.
* Makefile improvements from Namhyung Kim.
* Add --pre and --post command hooks in 'stat', from Peter Zijlstra.
* Don't stop synthesizing threads when one vanishes, this is for the
existing threads when we start a tool like trace.
* Use sched:sched_stat_runtime to provide a thread summary, this
produces the same output as the 'trace summary' subcommand of
tglx's original "trace" tool.
* Support interrupted syscalls in 'trace'
* Add an event duration column and filter in 'trace'.
* There are references to the man pages in some tools, so try to
build Documentation when installing, warning the user if that is
not possible, from Borislav Petkov.
* Give user better message if precise is not supported, from David
Ahern.
* Try to find cross-built objdump path by using the session
environment information in the perf.data file header, from Irina
Tirdea, original patch and idea by Namhyung Kim.
* Diplays more output on features check for make V=1, so that one can
figure out what is happening by looking at gcc output, etc. From
Jiri Olsa.
* Add on_exit implementation for systems without one, e.g. Android,
from Bernhard Rosenkraenzer.
* Only process events for vcpus of interest, helps handling large
number of events, from David Ahern.
* Cross compilation fixes for Android, from Irina Tirdea.
* Add documentation on compiling for Android, from Irina Tirdea.
* perf diff improvements from Jiri Olsa.
* Target (task/user/cpu/syswide) handling improvements, from Namhyung
Kim.
* Add support in 'trace' for tracing workload given by command line,
from Namhyung Kim.
* ... and much more."
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (194 commits)
uprobes: Use percpu_rw_semaphore to fix register/unregister vs dup_mmap() race
perf evsel: Introduce is_group_member method
perf powerpc: Use uapi/unistd.h to fix build error
tools: Pass the target in descend
tools: Honour the O= flag when tool build called from a higher Makefile
tools: Define a Makefile function to do subdir processing
perf ui: Always compile browser setup code
perf ui: Add ui_progress__finish()
perf ui gtk: Implement ui_progress functions
perf ui: Introduce generic ui_progress helper
perf ui tui: Move progress.c under ui/tui directory
perf tools: Add basic event modifier sanity check
perf tools: Omit group members from perf_evlist__disable/enable
perf tools: Ensure single disable call per event in record comand
perf tools: Fix 'disabled' attribute config for record command
perf tools: Fix attributes for '{}' defined event groups
perf tools: Use sscanf for parsing /proc/pid/maps
perf tools: Add gtk.<command> config option for launching GTK browser
perf tools: Fix compile error on NO_NEWT=1 build
perf hists: Initialize all of he->stat with zeroes
Merge misc updates from Andrew Morton:
"About half of most of MM. Going very early this time due to
uncertainty over the coreautounifiednumasched things. I'll send the
other half of most of MM tomorrow. The rest of MM awaits a slab merge
from Pekka."
* emailed patches from Andrew Morton: (71 commits)
memory_hotplug: ensure every online node has NORMAL memory
memory_hotplug: handle empty zone when online_movable/online_kernel
mm, memory-hotplug: dynamic configure movable memory and portion memory
drivers/base/node.c: cleanup node_state_attr[]
bootmem: fix wrong call parameter for free_bootmem()
avr32, kconfig: remove HAVE_ARCH_BOOTMEM
mm: cma: remove watermark hacks
mm: cma: skip watermarks check for already isolated blocks in split_free_page()
mm, oom: fix race when specifying a thread as the oom origin
mm, oom: change type of oom_score_adj to short
mm: cleanup register_node()
mm, mempolicy: remove duplicate code
mm/vmscan.c: try_to_freeze() returns boolean
mm: introduce putback_movable_pages()
virtio_balloon: introduce migration primitives to balloon pages
mm: introduce compaction and migration for ballooned pages
mm: introduce a common interface for balloon pages mobility
mm: redefine address_space.assoc_mapping
mm: adjust address_space_operations.migratepage() return code
arch/sparc/kernel/sys_sparc_64.c: s/COLOUR/COLOR/
It is strange that alloc_bootmem() returns a virtual address and
free_bootmem() requires a physical address. Anyway, free_bootmem()'s
first parameter should be physical address.
There are some call sites for free_bootmem() with virtual address. So fix
them.
[akpm@linux-foundation.org: improve free_bootmem() and free_bootmem_pate() documentation]
Signed-off-by: Joonsoo Kim <js1304@gmail.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
We use a static array to store struct node. In many cases, we don't have
too many nodes, and some memory will be unused. Convert it to per-device
dynamically allocated memory.
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
