commit 6747e83235caecd30b186d1282e4eba7679f81b7 upstream.
In commit 85fe402 (fs: do not assign default i_ino in new_inode), the
initialisation of i_ino was removed from new_inode() and pushed down
into the callers. However spufs_new_inode() was not updated.
This exhibits as no files appearing in /spu, because all our dirents
have a zero inode, which readdir() seems to dislike.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
commit 29ce3c5073057991217916abc25628e906911757 upstream.
In __after_prom_start we copy the kernel down to zero in two calls to
copy_and_flush. After the first call (copy from 0 to copy_to_here:)
we jump to the newly copied code soon after.
Unfortunately there's no isync between the copy of this code and the
jump to it. Hence it's possible that stale instructions could still be
in the icache or pipeline before we branch to it.
We've seen this on real machines and it's results in no console output
after:
calling quiesce...
returning from prom_init
The below adds an isync to ensure that the copy and flushing has
completed before any branching to the new instructions occurs.
Signed-off-by: Michael Neuling <mikey@neuling.org>
performed before the ANDCOND test
commit 9fb2640159f9d4f5a2a9d60e490482d4cbecafdb upstream.
Some versions of pHyp will perform the adjunct partition test before the
ANDCOND test. The result of this is that H_RESOURCE can be returned and
cause the BUG_ON condition to occur. The HPTE is not removed. So add a
check for H_RESOURCE, it is ok if this HPTE is not removed as
pSeries_lpar_hpte_remove is looking for an HPTE to remove and not a
specific HPTE to remove. So it is ok to just move on to the next slot
and try again.
Signed-off-by: Michael Wolf <mjw@linux.vnet.ibm.com>
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side
struct sigaction declarations'.
flush_signal_handlers() needs to know whether sigaction::sa_restorer
is defined, not whether SA_RESTORER is defined. Define the
__ARCH_HAS_SA_RESTORER macro to indicate this.
commit d63ac5f6cf31c8a83170a9509b350c1489a7262b upstream.
Commit 44ae3ab3358e962039c36ad4ae461ae9fb29596c forgot to update
the entry for the 970MP rev 1.0 processor when moving some CPU
features bits to the MMU feature bit mask. This breaks booting
on some rare G5 models using that chip revision.
Reported-by: Phileas Fogg <phileas-fogg@mail.ru>
commit 13938117a57f88a22f0df9722a5db7271fda85cd upstream.
Commit f5339277eb8d3aed37f12a27988366f68ab68930 accidentally removed
more than just iSeries bits and took out the call to stab_initialize()
thus breaking support for POWER3 processors.
Put it back. (Yes, nobody noticed until now ...)
commit 8520e443aa56cc157b015205ea53e7b9fc831291 upstream.
Disable hard IRQ before kexec a new kernel image.
Not doing it can result in corrupted data in the memory segments
reserved for the new kernel.
Signed-off-by: Phileas Fogg <phileas-fogg@mail.ru>
commit e43a028752fed049e4bd94ef895542f96d79fa74 upstream.
When remembering the direction of a DCR transaction, we should write
to the same variable that we interpret on later when doing vcpu_run
again.
Signed-off-by: CAI Qian <caiqian@redhat.com>
commit e6449c9b2d90c1bd9a5985bf05ddebfd1631cd6b upstream.
The missing NULL terminator can cause a panic on
PPC405 boards during boot:
Linux/PowerPC load: console=ttyS0,115200 root=/dev/mtdblock1 rootfstype=squashfs,jffs2 noinitrd init=/etc/preinit
Finalizing device tree... flat tree at 0x6a5160
bootconsole [udbg0] enabled
Page fault in user mode with in_atomic() = 1 mm = (null)
NIP = c0275f50 MSR = fffffffe
Oops: Weird page fault, sig: 11 [#1]
PowerPC 40x Platform
Modules linked in:
NIP: c0275f50 LR: c0275f60 CTR: c0280000
REGS: c0275eb0 TRAP: 636f7265 Not tainted (3.7.1)
MSR: fffffffe <VEC,VSX,EE,PR,FP,ME,SE,BE,IR,DR,PMM,RI> CR: c06a6190 XER: 00000001
TASK = c02662a8[0] 'swapper' THREAD: c0274000
GPR00: c0275ec0 c000c658 c027c4bf 00000000 c0275ee0 c000a0ec c020a1a8 c020a1f0
GPR08: c020f631 c020f404 c025f078 c025f080 c0275f10
Call Trace:
---[ end trace 31fd0ba7d8756001 ]---
Kernel panic - not syncing: Attempted to kill the idle task!
The panic happens since commit 9597abe00c1bab2aedce6b49866bf6d1e81c9eed
(sections: fix section conflicts in arch/powerpc), however the root
cause of this is that the NULL terminator were not added in commit
a4f740cf33f7f6c164bbde3c0cdbcc77b0c4997c (of/flattree: Add of_flat_dt_match()
helper function).
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
commit ce73ec6db47af84d1466402781ae0872a9e7873c upstream.
The locking in update_vsyscall_tz() is not only unnecessary because the vdso
code copies the data unproteced in __kernel_gettimeofday() but also
introduces a hard to reproduce race condition between update_vsyscall()
and update_vsyscall_tz(), which causes user space process to loop
forever in vdso code.
The following patch removes the locking from update_vsyscall_tz().
Locking is not only unnecessary because the vdso code copies the data
unprotected in __kernel_gettimeofday() but also erroneous because updating
the tb_update_count is not atomic and introduces a hard to reproduce race
condition between update_vsyscall() and update_vsyscall_tz(), which further
causes user space process to loop forever in vdso code.
The below scenario describes the race condition,
x==0 Boot CPU other CPU
proc_P: x==0
timer interrupt
update_vsyscall
x==1 x++;sync settimeofday
update_vsyscall_tz
x==2 x++;sync
x==3 sync;x++
sync;x++
proc_P: x==3 (loops until x becomes even)
Because the ++ operator would be implemented as three instructions and not
atomic on powerpc.
A similar change was made for x86 in commit 6c260d58634
("x86: vdso: Remove bogus locking in update_vsyscall_tz")
Signed-off-by: Shan Hai <shan.hai@windriver.com>
commit 11ee7e99f35ecb15f59b21da6a82d96d2cd3fcc8 upstream.
If we build a kernel with CONFIG_RELOCATABLE=y CONFIG_CRASH_DUMP=n,
the kernel fails when we run at a non zero offset. It turns out
we were incorrectly wrapping some of the relocatable kernel code
with CONFIG_CRASH_DUMP.
commit feadf7c0a1a7c08c74bebb4a13b755f8c40e3bbc upstream.
The EEH core is talking with the PCI device driver to determine the
action (purely reset, or PCI device removal). During the period, the
driver might be unloaded and in turn causes kernel crash as follows:
EEH: Detected PCI bus error on PHB#4-PE#10000
EEH: This PCI device has failed 3 times in the last hour
lpfc 0004:01:00.0: 0:2710 PCI channel disable preparing for reset
Unable to handle kernel paging request for data at address 0x00000490
Faulting instruction address: 0xd00000000e682c90
cpu 0x1: Vector: 300 (Data Access) at [c000000fc75ffa20]
pc: d00000000e682c90: .lpfc_io_error_detected+0x30/0x240 [lpfc]
lr: d00000000e682c8c: .lpfc_io_error_detected+0x2c/0x240 [lpfc]
sp: c000000fc75ffca0
msr: 8000000000009032
dar: 490
dsisr: 40000000
current = 0xc000000fc79b88b0
paca = 0xc00000000edb0380 softe: 0 irq_happened: 0x00
pid = 3386, comm = eehd
enter ? for help
[c000000fc75ffca0] c000000fc75ffd30 (unreliable)
[c000000fc75ffd30] c00000000004fd3c .eeh_report_error+0x7c/0xf0
[c000000fc75ffdc0] c00000000004ee00 .eeh_pe_dev_traverse+0xa0/0x180
[c000000fc75ffe70] c00000000004ffd8 .eeh_handle_event+0x68/0x300
[c000000fc75fff00] c0000000000503a0 .eeh_event_handler+0x130/0x1a0
[c000000fc75fff90] c000000000020138 .kernel_thread+0x54/0x70
1:mon>
The patch increases the reference of the corresponding driver modules
while EEH core does the negotiation with PCI device driver so that the
corresponding driver modules can't be unloaded during the period and
we're safe to refer the callbacks.
Reported-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
[ herton: backported for 3.5, adjusted driver assignments, return 0
instead of NULL, assume dev is not NULL ]
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 1e38b7140185e384da216aff66a711df09b5afc9 upstream.
The kernel crash was reported by Alexy. He was testing some feature
with private kernel, in which Alexy added some code in pci_pm_reset()
to read the CSR after writting it. The bug could be reproduced on
Fiber Channel card (Fibre Channel: Emulex Corporation Saturn-X:
LightPulse Fibre Channel Host Adapter (rev 03)) by the following
commands.
# echo 1 > /sys/devices/pci0004:01/0004:01:00.0/reset
# rmmod lpfc
# modprobe lpfc
The history behind the test case is that those additional config
space reading operations in pci_pm_reset() would cause EEH error,
but we didn't detect EEH error until "modprobe lpfc". For the case,
all the PCI devices on PCI bus (0004:01) were removed and added after
PE reset. Then the EEH devices would be figured out again based on
the OF nodes. Unfortunately, there were some child OF nodes under
PCI device (0004:01:00.0), but they didn't have attached PCI_DN since
they're invisible from PCI domain. However, we were still trying to
convert OF node to EEH device without checking on the attached PCI_DN.
Eventually, it caused the kernel crash as follows:
Unable to handle kernel paging request for data at address 0x00000030
Faulting instruction address: 0xc00000000004d888
cpu 0x0: Vector: 300 (Data Access) at [c000000fc797b950]
pc: c00000000004d888: .eeh_add_device_tree_early+0x78/0x140
lr: c00000000004d880: .eeh_add_device_tree_early+0x70/0x140
sp: c000000fc797bbd0
dar: 30
dsisr: 40000000
current = 0xc000000fc78d9f70
paca = 0xc00000000edb0000 softe: 0 irq_happened: 0x00
pid = 2951, comm = eehd
enter ? for help
[c000000fc797bc50] c00000000004d848 .eeh_add_device_tree_early+0x38/0x140
[c000000fc797bcd0] c00000000004d848 .eeh_add_device_tree_early+0x38/0x140
[c000000fc797bd50] c000000000051b54 .pcibios_add_pci_devices+0x34/0x190
[c000000fc797bde0] c00000000004fb10 .eeh_reset_device+0x100/0x160
[c000000fc797be70] c0000000000502dc .eeh_handle_event+0x19c/0x300
[c000000fc797bf00] c000000000050570 .eeh_event_handler+0x130/0x1a0
[c000000fc797bf90] c000000000020138 .kernel_thread+0x54/0x70
The patch changes of_node_to_eeh_dev() and just returns NULL if the
passed OF node doesn't have attached PCI_DN.
commit 896c01cb4bb3cfc2c0ea9873fa7a9f8bd0a7c8d8 upstream.
In order for indirect mode on the PIXIS to work properly, both chip selects
need to be set to GPCM mode, otherwise writes to the chip select base
addresses will not actually post to the local bus -- they'll go to the
NAND controller instead. Therefore, we need to set BR0 and BR1 to GPCM
mode before switching to indirect mode.
commit 6269f2584a359766f53005c676daff8aee60cbed upstream.
The Freescale P1022 has a unique pin muxing "feature" where the DIU video
controller's video signals are muxed with 24 of the local bus address signals.
When the DIU is enabled, the bulk of the local bus is disabled, preventing
access to memory-mapped devices like NAND flash and the pixis FPGA.
Therefore, if the DIU is going to be enabled, then memory-mapped devices on
the localbus, like NAND flash, need to be disabled.
This patch is similar to "powerpc/85xx: p1022ds: disable the NOR flash node
if video is enabled", except that it disables the NAND flash node instead.
This PIXIS node needs to remain enabled because it is used by platform code
to switch into indirect mode.
commit 9fb1b36ca1234e64a5d1cc573175303395e3354d upstream.
We have been observing hangs, both of KVM guest vcpu tasks and more
generally, where a process that is woken doesn't properly wake up and
continue to run, but instead sticks in TASK_WAKING state. This
happens because the update of rq->wake_list in ttwu_queue_remote()
is not ordered with the update of ipi_message in
smp_muxed_ipi_message_pass(), and the reading of rq->wake_list in
scheduler_ipi() is not ordered with the reading of ipi_message in
smp_ipi_demux(). Thus it is possible for the IPI receiver not to see
the updated rq->wake_list and therefore conclude that there is nothing
for it to do.
In order to make sure that anything done before smp_send_reschedule()
is ordered before anything done in the resulting call to scheduler_ipi(),
this adds barriers in smp_muxed_message_pass() and smp_ipi_demux().
The barrier in smp_muxed_message_pass() is a full barrier to ensure that
there is a full ordering between the smp_send_reschedule() caller and
scheduler_ipi(). In smp_ipi_demux(), we use xchg() rather than
xchg_local() because xchg() includes release and acquire barriers.
Using xchg() rather than xchg_local() makes sense given that
ipi_message is not just accessed locally.
This moves the barrier between setting the message and calling the
cause_ipi() function into the individual cause_ipi implementations.
Most of them -- those that used outb, out_8 or similar -- already had
a full barrier because out_8 etc. include a sync before the MMIO
store. This adds an explicit barrier in the two remaining cases.
These changes made no measurable difference to the speed of IPIs as
measured using a simple ping-pong latency test across two CPUs on
different cores of a POWER7 machine.
The analysis of the reason why processes were not waking up properly
is due to Milton Miller.
Reported-by: Milton Miller <miltonm@bga.com>
commit 714332858bfd40dcf8f741498336d93875c23aa7 upstream.
During a context switch we always restore the per thread DSCR value.
If we aren't doing explicit DSCR management
(ie thread.dscr_inherit == 0) and the default DSCR changed while
the process has been sleeping we end up with the wrong value.
Check thread.dscr_inherit and select the default DSCR or per thread
DSCR as required.
This was found with the following test case, when running with
more threads than CPUs (ie forcing context switching):
http://ozlabs.org/~anton/junkcode/dscr_default_test.c
With the four patches applied I can run a combination of all
test cases successfully at the same time:
http://ozlabs.org/~anton/junkcode/dscr_explicit_test.c
http://ozlabs.org/~anton/junkcode/dscr_inherit_test.c
commit 1021cb268b3025573c4811f1dee4a11260c4507b upstream.
If the default DSCR is non zero we set thread.dscr_inherit in
copy_thread() meaning the new thread and all its children will ignore
future updates to the default DSCR. This is not intended and is
a change in behaviour that a number of our users have hit.
We just need to inherit thread.dscr and thread.dscr_inherit from
the parent which ends up being much simpler.
This was found with the following test case:
commit 00ca0de02f80924dfff6b4f630e1dff3db005e35 upstream.
When we update the DSCR either via emulation of mtspr(DSCR) or via
a change to dscr_default in sysfs we don't update thread.dscr.
We will eventually update it at context switch time but there is
a period where thread.dscr is incorrect.
If we fork at this point we will copy the old value of thread.dscr
into the child. To avoid this, always keep thread.dscr in sync with
reality.
This issue was found with the following testcase:
commit 1b6ca2a6fe56e7697d57348646e07df08f43b1bb upstream.
Writing to dscr_default in sysfs doesn't actually change the DSCR -
we rely on a context switch on each CPU to do the work. There is no
guarantee we will get a context switch in a reasonable amount of time
so fire off an IPI to force an immediate change.
This issue was found with the following test case:
commit 6bd825f02966be8ba544047cab313d6032c23819 upstream.
In order to enable the DIU video controller on the P1022DS, the FPGA needs
to be switched to "indirect mode", where the localbus is disabled and
the FPGA is accessed via writes to localbus chip select signals CS0 and CS1.
To obtain the address of CS0 and CS1, the platform driver uses an "indirect
pixis mode" device tree node. This node assumes that the localbus 'ranges'
property is sorted in chip-select order. That is, reg value 0 maps to
CS0, reg value 1 maps to CS1, etc. This is how the 'ranges' property is
supposed to be arranged.
Unfortunately, the 'ranges' property is often mis-arranged, and not just on
the P1022DS. Linux normally does not care, since it does not program the
localbus. But the indirect-mode code on the P1022DS does care.
The "proper" fix is to have U-Boot fix the 'ranges' property, but this would
be too cumbersome. The names and 'reg' properties of all the localbus
devices would also need to be updated, and determining which localbus device
maps to which chip select is board-specific.
Instead, we determine the CS0/CS1 base addresses the same way that U-boot
does -- by reading the BRx registers directly and mapping them to physical
addresses. This code is simpler and more reliable, and it does not require
a U-boot or device tree change.
Since the indirect pixis device tree node is no longer needed, the node is
deleted from the DTS.
commit 10db8d212864cb6741df7d7fafda5ab6661f6f88 upstream.
Function eeh_event_handler() dereferences the pointer returned by
handle_eeh_events() without checking, causing a crash if NULL was
returned, which is expected in some situations.
This patch fixes this bug by checking for the value returned by
handle_eeh_events() before dereferencing it.
Signed-off-by: Kleber Sacilotto de Souza <klebers@linux.vnet.ibm.com>
commit b416c9a10baae6a177b4f9ee858b8d309542fbef upstream.
Add "memory" attribute in inline assembly language as a compiler
barrier to make sure 4.6.x GCC don't reorder mfmsr().
Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com>
commit fd5a42980e1cf327b7240adf5e7b51ea41c23437 upstream.
Just like the module loader, ftrace needs to be updated to use r12
instead of r11 with newer gcc's.
Signed-off-by: Roger Blofeld <blofeldus@yahoo.com>
commit 21b2de341270bd7bb7a811027ffe63276d9b3b75 upstream.
There was a typo, checking for CONFIG_TRACE_IRQFLAG instead of
CONFIG_TRACE_IRQFLAGS causing some useful debug code to not be
built
This in turns causes a build error on BookE 64-bit due to incorrect
semicolons at the end of a couple of macros, so let's fix that too
commit be2cf20a5ad31ebb13562c1c866ecc626fbd721e upstream.
Looks like we still have issues with pSeries and Cell idle code
vs. the lazy irq state. In fact, the reset fixes that went upstream
are exposing the problem more by causing BUG_ON() to trigger (which
this patch turns into a WARN_ON instead).
We need to be careful when using a variant of low power state that
has the side effect of turning interrupts back on, to properly set
all the SW & lazy state to look as if everything is enabled before
we enter the low power state with MSR:EE off as we will return with
MSR:EE on. If not, we have a discrepancy of state which can cause
things to go very wrong later on.
This patch moves the logic into a helper and uses it from the
pseries and cell idle code. The power4/970 idle code already got
things right (in assembly even !) so I'm not touching it. The power7
"bare metal" idle code is subtly different and correct. Remains PA6T
and some hypervisor based Cell platforms which have questionable
code in there, but they are mostly dead platforms so I'll fix them
when I manage to get final answers from the respective maintainers
about how the low power state actually works on them.
commit bc1d7702910c7c7e88eb60b58429dbfe293683ce upstream.
We have a bug report where the kernel hits a warning in the cpumask
code:
WARNING: at include/linux/cpumask.h:107
Which is:
WARN_ON_ONCE(cpu >= nr_cpumask_bits);
The backtrace is:
cpu_cmd
cmds
xmon_core
xmon
die
xmon is iterating through 0 to NR_CPUS. I'm not sure why we are still
open coding this but iterating above nr_cpu_ids is definitely a bug.
This patch iterates through all possible cpus, in case we issue a
system reset and CPUs in an offline state call in.
Perhaps the old code was trying to handle CPUs that were in the
partition but were never started (eg kexec into a kernel with an
nr_cpus= boot option). They are going to die way before we get into
xmon since we haven't set any kernel state up for them.
commit 2f584a146a2965b82fce89b8d2f95dc5cfe468d0 upstream.
Since we are taking a registers, this should never have been an sldi.
Talking to paulus offline, this is the correct fix.
Was introduced by:
commit 19ccb76a1938ab364a412253daec64613acbf3df
Author: Paul Mackerras <paulus@samba.org>
Date: Sat Jul 23 17:42:46 2011 +1000
Talking to paulus, this shouldn't be a literal.
commit 0b17ba7258db83cd02da560884e053b85de371f2 upstream.
Commit f948501b36c6 ("Make hard_irq_disable() actually hard-disable
interrupts") caused check_and_cede_processor to stop working.
->irq_happened will never be zero right after a hard_irq_disable
so the compiler removes the call to cede_processor completely.
The bug was introduced back in the lazy interrupt handling rework
of 3.4 but was hidden until recently because hard_irq_disable did
nothing.
This issue will eventually appear in 3.4 stable since the
hard_irq_disable fix is marked stable, so mark this one for stable
too.
commit bc6dc752f35488160ffac07ae91bed1bddaea32a upstream.
The following added support for powernv but broke pseries/BML:
1f1616e powerpc/powernv: Add TCE SW invalidation support
TCE_PCI_SW_INVAL was split into FREE and CREATE flags but the tests in
the pseries code were not updated to reflect this.
commit 82b2521d257b5c0efd51821cf5fa306e53bbb6ba upstream.
chroma_defconfig currently gives me this with gcc 4.6:
arch/powerpc/mm/numa.c:638:13: error: 'dm' may be used uninitialized in this function [-Werror=uninitialized]
It's a bogus warning/error since of_get_drconf_memory() only writes it
anyway.
commit 2d773aa4810d4a612d1c879faacc38594cc3f841 upstream.
As I was adding code that affects all archs, I started testing function
tracer against PPC64 and found that it currently locks up with 3.4
kernel. I figured it was due to tracing a function that shouldn't be, so
I went through the following process to bisect to find the culprit:
cat /debug/tracing/available_filter_functions > t
num=`wc -l t`
sed -ne "1,${num}p" t > t1
let num=num+1
sed -ne "${num},$p" t > t2
cat t1 > /debug/tracing/set_ftrace_filter
echo function /debug/tracing/current_tracer
<failed? bisect t1, if not bisect t2>
It finally came down to this function: restore_interrupts()
I'm not sure why this locks up the system. It just seems to prevent
scheduling from occurring. Interrupts seem to still work, as I can ping
the box. But all user processes freeze.
When restore_interrupts() is not traced, function tracing works fine.
commit f948501b36c6b3d9352ce212a197098a7e958971 upstream.
At present, hard_irq_disable() does nothing on powerpc because of
this code in include/linux/interrupt.h:
#ifndef hard_irq_disable
#define hard_irq_disable() do { } while(0)
#endif
So we need to make our hard_irq_disable be a macro. It was previously
a macro until commit 7230c56441 ("powerpc: Rework lazy-interrupt
handling") changed it to a static inline function.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
arch/powerpc/include/asm/hw_irq.h | 3 +++
1 file changed, 3 insertions(+)
commit 3c75296562f43e6fbc6cddd3de948a7b3e4e9bcf upstream.
This fixes a problem which can causes kernel oopses while loading
a kernel module.
According to the PowerPC EABI specification, GPR r11 is assigned
the dedicated function to point to the previous stack frame.
In the powerpc-specific kernel module loader, do_plt_call()
(in arch/powerpc/kernel/module_32.c), GPR r11 is also used
to generate trampoline code.
This combination crashes the kernel, in the case where the compiler
chooses to use a helper function for saving GPRs on entry, and the
module loader has placed the .init.text section far away from the
.text section, meaning that it has to generate a trampoline for
functions in the .init.text section to call the GPR save helper.
Because the trampoline trashes r11, references to the stack frame
using r11 can cause an oops.
The fix just uses GPR r12 instead of GPR r11 for generating the
trampoline code. According to the statements from Freescale, this is
safe from an EABI perspective.
I've tested the fix for kernel 2.6.33 on MPC8541.
Signed-off-by: Steffen Rumler <steffen.rumler.ext@nsn.com>
[paulus@samba.org: reworded the description]
commit 860aed25a1f0936d4852ab936252b47cd1e630f1 upstream.
This reverts 68568add2c ("powerpc/time: Remove unnecessary sanity check
of decrementer expiration"). We do need to check whether we have reached
the expiration time of the next event, because we sometimes get an early
decrementer interrupt, most notably when we set the decrementer to 1 in
arch_irq_work_raise(). The effect of not having the sanity check is that
if timer_interrupt() gets called early, we leave the decrementer set to
its maximum value, which means we then don't get any more decrementer
interrupts for about 4 seconds (or longer, depending on timebase
frequency). I saw these pauses as a consequence of getting a stray
hypervisor decrementer interrupt left over from exiting a KVM guest.
This isn't quite a straight revert because of changes to the surrounding
code, but it restores the same algorithm as was previously used.
Acked-by: Anton Blanchard <anton@samba.org>
commit 9cd75e13de2dcf32ecc21c7f277cff3c0ced059e upstream.
commit 771dae818 (powerpc/cpuidle: Add cpu_idle_wait() to allow
switching of idle routines) implemented cpu_idle_wait() for powerpc.
The changelog says:
"The equivalent routine for x86 is in arch/x86/kernel/process.c
but the powerpc implementation is different.":
Unfortunately the changelog is completely useless as it does not tell
_WHY_ it is different.
Aside of being different the implementation is patently wrong.
The rescheduling IPI is async. That means that there is no guarantee,
that the other cores have executed the IPI when cpu_idle_wait()
returns. But that's the whole purpose of this function: to guarantee
that no CPU uses the old idle handler anymore.
Use the smp_functional_call() based implementation, which fulfils the
requirements.
[ This code is going to replaced by a core version to remove all the
pointless copies in arch/*, but this one should go to stable ]
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Cc: Trinabh Gupta <g.trinabh@gmail.com>
Cc: Arun R Bharadwaj <arun.r.bharadwaj@gmail.com>
Link: http://lkml.kernel.org/r/20120507175651.980164748@linutronix.de
When handling the H_BULK_REMOVE hypercall, we were forgetting to
invalidate and unlock the hashed page table entry (HPTE) in the case
where the page had been paged out. This fixes it by clearing the
first doubleword of the HPTE in that case.
This fixes a regression introduced in commit a92bce95f0 ("KVM: PPC:
Book3S HV: Keep HPTE locked when invalidating"). The effect of the
regression is that the host kernel will sometimes hang when under
memory pressure.
The code forgot to scramble the VSIDs the way we normally do
and was basically using the "proto VSID" directly with the MMU.
This means that in practice, KVM used random VSIDs that could
collide with segments used by other user space programs.
[agraf: simplify ppc32 case]
When jumping back into the kernel to code that knows that it would be
using HSRR registers instead of SRR registers, we need to make sure we
pass it all information on where to jump to in HSRR registers.
Unfortunately, we used r10 to store the information to distinguish between
the HSRR and SRR case. That register got clobbered in between though,
rendering the later comparison invalid.
Instead, let's use cr1 to store this information. That way we don't
need yet another register and everyone's happy.
This fixes PR KVM on POWER7 bare metal for me.
When running on a system that is HV capable, some interrupts use HSRR
SPRs instead of the normal SRR SPRs. These are also used in the Linux
handlers to jump back to code after an interrupt got processed.
Unfortunately, in our "jump back to the real host handler after we've
done the context switch" code, we were only setting the SRR SPRs,
rendering Linux to jump back to some invalid IP after it's processed
the interrupt.
This fixes random crashes on p7 opal mode with PR KVM for me.
In addition to normal "priviledged instruction" traps, we can also receive
"emulation assist" traps on newer hardware that has the HV bit set.
Handle that one the same way as a privileged instruction, including the
instruction fetching. That way we don't execute old instructions that we
happen to still leave in that field when an emul assist trap comes.
This fixes -M mac99 / -M g3beige on p7 bare metal for me.
So we have another case of paca->irq_happened getting out of
sync with the HW irq state. This can happen when a perfmon
interrupt occurs while soft disabled, as it will return to a
soft disabled but hard enabled context while leaving a stale
PACA_IRQ_HARD_DIS flag set.
This patch fixes it, and also adds a test for the condition
of those flags being out of sync in arch_local_irq_restore()
when CONFIG_TRACE_IRQFLAGS is enabled.
This helps catching those gremlins faster (and so far I
can't seem see any anymore, so that's good news).
Pull KVM fixes from Avi Kivity:
"Two asynchronous page fault fixes (one guest, one host), a powerpc
page refcount fix, and an ia64 build fix."
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: ia64: fix build due to typo
KVM: PPC: Book3S HV: Fix refcounting of hugepages
KVM: Do not take reference to mm during async #PF
KVM: ensure async PF event wakes up vcpu from halt
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc fixes from Benjamin Herrenschmidt:
"Here are a couple of last minute fixes for 3.4 for regressions
introduced by my rewrite of the lazy irq masking code."
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/irq: Make alignment & program interrupt behave the same
powerpc/irq: Fix bug with new lazy IRQ handling code
Alignment was the last user of the ENABLE_INTS macro, which we can
now remove. All non-syscall exceptions now disable interrupts on
entry, they get re-enabled conditionally from C code. Don't
unconditionally re-enable in program check either, check the
original context.
We had a case where we could turn on hard interrupts while
leaving the PACA_IRQ_HARD_DIS bit set in the PACA. This can
in turn cause a BUG_ON() to hit in __check_irq_replay() due
to interrupt state getting out of sync.
The assembly code was also way too convoluted. Instead, we
now leave it to the C code to do the right thing which ends
up being smaller and more readable.
The H_REGISTER_VPA hcall implementation in HV Power KVM needs to pin some
guest memory pages into host memory so that they can be safely accessed
from usermode. It does this used get_user_pages_fast(). When the VPA is
unregistered, or the VCPUs are cleaned up, these pages are released using
put_page().
However, the get_user_pages() is invoked on the specific memory are of the
VPA which could lie within hugepages. In case the pinned page is huge,
we explicitly find the head page of the compound page before calling
put_page() on it.
At least with the latest kernel, this is not correct. put_page() already
handles finding the correct head page of a compound, and also deals with
various counts on the individual tail page which are important for
transparent huge pages. We don't support transparent hugepages on Power,
but even so, bypassing this count maintenance can lead (when the VM ends)
to a hugepage being released back to the pool with a non-zero mapcount on
one of the tail pages. This can then lead to a bad_page() when the page
is released from the hugepage pool.
This removes the explicit compound_head() call to correct this bug.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Acked-by: Alexander Graf <agraf@suse.de>
Signed-off-by: Avi Kivity <avi@redhat.com>
Pull networking fixes from David Miller:
1) Transfer padding was wrong for full-speed USB in ASIX driver, fix
from Ingo van Lil.
2) Propagate the negative packet offset fix into the PowerPC BPF JIT.
From Jan Seiffert.
3) dl2k driver's private ioctls were letting unprivileged tasks make
MII writes and other ugly bits like that. Fix from Jeff Mahoney.
4) Fix TX VLAN and RX packet drops in ucc_geth, from Joakim Tjernlund.
5) OOPS and network namespace fixes in IPVS from Hans Schillstrom and
Julian Anastasov.
6) Fix races and sleeping in locked context bugs in drop_monitor, from
Neil Horman.
7) Fix link status indication in smsc95xx driver, from Paolo Pisati.
8) Fix bridge netfilter OOPS, from Peter Huang.
9) L2TP sendmsg can return on error conditions with the socket lock
held, oops. Fix from Sasha Levin.
10) udp_diag should return meaningful values for socket memory usage,
from Shan Wei.
11) Eric Dumazet is so awesome he gets his own section:
Socket memory cgroup code (I never should have applied those
patches, grumble...) made erroneous changes to
sk_sockets_allocated_read_positive(). It was changed to
use percpu_counter_sum_positive (which requires BH disabling)
instead of percpu_counter_read_positive (which does not).
Revert back to avoid crashes and lockdep warnings.
Adjust the default tcp_adv_win_scale and tcp_rmem[2] values
to fix throughput regressions. This is necessary as a result
of our more precise skb->truesize tracking.
Fix SKB leak in netem packet scheduler.
12) New device IDs for various bluetooth devices, from Manoj Iyer,
AceLan Kao, and Steven Harms.
13) Fix command completion race in ipw2200, from Stanislav Yakovlev.
14) Fix rtlwifi oops on unload, from Larry Finger.
15) Fix hard_mtu when adjusting hard_header_len in smsc95xx driver.
From Stephane Fillod.
16) ehea driver registers it's IRQ before all the necessary state is
setup, resulting in crashes. Fix from Thadeu Lima de Souza
Cascardo.
17) Fix PHY connection failures in davinci_emac driver, from Anatolij
Gustschin.
18) Missing break; in switch statement in bluetooth's
hci_cmd_complete_evt(). Fix from Szymon Janc.
19) Fix queue programming in iwlwifi, from Johannes Berg.
20) Interrupt throttling defaults not being actually programmed into the
hardware, fix from Jeff Kirsher and Ying Cai.
21) TLAN driver SKB encoding in descriptor busted on 64-bit, fix from
Benjamin Poirier.
22) Fix blind status block RX producer pointer deref in TG3 driver, from
Matt Carlson.
23) Promisc and multicast are busted on ehea, fixes from Thadeu Lima de
Souza Cascardo.
24) Fix crashes in 6lowpan, from Alexander Smirnov.
25) tcp_complete_cwr() needs to be careful to not rewind the CWND to
ssthresh if ssthresh has the "infinite" value. Fix from Yuchung
Cheng.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (81 commits)
sungem: Fix WakeOnLan
tcp: change tcp_adv_win_scale and tcp_rmem[2]
net: l2tp: unlock socket lock before returning from l2tp_ip_sendmsg
drop_monitor: prevent init path from scheduling on the wrong cpu
usbnet: fix failure handling in usbnet_probe
usbnet: fix leak of transfer buffer of dev->interrupt
ucc_geth: Add 16 bytes to max TX frame for VLANs
net: ucc_geth, increase no. of HW RX descriptors
netem: fix possible skb leak
sky2: fix receive length error in mixed non-VLAN/VLAN traffic
sky2: propogate rx hash when packet is copied
net: fix two typos in skbuff.h
cxgb3: Don't call cxgb_vlan_mode until q locks are initialized
ixgbe: fix calling skb_put on nonlinear skb assertion bug
ixgbe: Fix a memory leak in IEEE DCB
igbvf: fix the bug when initializing the igbvf
smsc75xx: enable mac to detect speed/duplex from phy
smsc75xx: declare smsc75xx's MII as GMII capable
smsc75xx: fix phy interrupt acknowledge
smsc75xx: fix phy init reset loop
Now the helper function from filter.c for negative offsets is exported,
it can be used it in the jit to handle negative offsets.
First modify the asm load helper functions to handle:
- know positive offsets
- know negative offsets
- any offset
then the compiler can be modified to explicitly use these helper
when appropriate.
This fixes the case of a negative X register and allows to lift
the restriction that bpf programs with negative offsets can't
be jited.
Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Jan Seiffert <kaffeemonster@googlemail.com>
Recently, Ryan Wang tried to compile PPC pSeries platform without
CONFIG_EEH and eventually run into errors. Nishanth Aravamudan
helped to narrow down the root cause. Actually, the pSeries platform
depends on CONFIG_EEH heavily and that won't work properly without
EEH support.
According to Ben's suggestion, the patch make CONFIG_EEH invisible
and keep it as always selected on pSeries platform.
