path: root/arch/powerpc
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-06Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scsi: drop unused Kconfig symbol pci: drop unused Kconfig symbol stmmac: drop unused Kconfig symbol x86: drop unused Kconfig symbol powerpc: drop unused Kconfig symbols powerpc: 40x: drop unused Kconfig symbol mips: drop unused Kconfig symbols openrisc: drop unused Kconfig symbols arm: at91: drop unused Kconfig symbol samples: drop unused Kconfig symbol m32r: drop unused Kconfig symbol score: drop unused Kconfig symbols sh: drop unused Kconfig symbol um: drop unused Kconfig symbol sparc: drop unused Kconfig symbol alpha: drop unused Kconfig symbol Fix up trivial conflict in drivers/net/ethernet/stmicro/stmmac/Kconfig as per Michal: the STMMAC_DUAL_MAC config variable is still unused and should be deleted.
2011-11-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits) powerpc/p3060qds: Add support for P3060QDS board powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITX powerpc/85xx: Make kexec to interate over online cpus powerpc/fsl_booke: Fix comment in head_fsl_booke.S powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devices powerpc/8xxx: Fix interrupt handling in MPC8xxx GPIO driver powerpc/85xx: Add 'fsl,pq3-gpio' compatiable for GPIO driver powerpc/86xx: Correct Gianfar support for GE boards powerpc/cpm: Clear muram before it is in use. drivers/virt: add ioctl for 32-bit compat on 64-bit to fsl-hv-manager powerpc/fsl_msi: add support for "msi-address-64" property powerpc/85xx: Setup secondary cores PIR with hard SMP id powerpc/fsl-booke: Fix settlbcam for 64-bit powerpc/85xx: Adding DCSR node to dtsi device trees powerpc/85xx: clean up FPGA device tree nodes for Freecsale QorIQ boards powerpc/85xx: fix PHYS_64BIT selection for P1022DS powerpc/fsl-booke: Fix setup_initial_memory_limit to not blindly map powerpc: respect mem= setting for early memory limit setup powerpc: Update corenet64_smp_defconfig powerpc: Update mpc85xx/corenet 32-bit defconfigs ... Fix up trivial conflicts in: - arch/powerpc/configs/40x/hcu4_defconfig removed stale file, edited elsewhere - arch/powerpc/include/asm/udbg.h, arch/powerpc/kernel/udbg.c: added opal and gelic drivers vs added ePAPR driver - drivers/tty/serial/8250.c moved UPIO_TSI to powerpc vs removed UPIO_DWAPB support
2011-11-04Merge branch 'for-3.2/core' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.2/core' of git://git.kernel.dk/linux-block: (29 commits) block: don't call blk_drain_queue() if elevator is not up blk-throttle: use queue_is_locked() instead of lockdep_is_held() blk-throttle: Take blkcg->lock while traversing blkcg->policy_list blk-throttle: Free up policy node associated with deleted rule block: warn if tag is greater than real_max_depth. block: make gendisk hold a reference to its queue blk-flush: move the queue kick into blk-flush: fix invalid BUG_ON in blk_insert_flush block: Remove the control of complete cpu from bio. block: fix a typo in the blk-cgroup.h file block: initialize the bounce pool if high memory may be added later block: fix request_queue lifetime handling by making blk_queue_cleanup() properly shutdown block: drop @tsk from attempt_plug_merge() and explain sync rules block: make get_request[_wait]() fail if queue is dead block: reorganize throtl_get_tg() and blk_throtl_bio() block: reorganize queue draining block: drop unnecessary blk_get/put_queue() in scsi_cmd_ioctl() and blk_get_tg() block: pass around REQ_* flags instead of broken down booleans during request alloc/free block: move blk_throtl prototypes to block/blk.h block: fix genhd refcounting in blkio_policy_parse_and_set() ... Fix up trivial conflicts due to "mddev_t" -> "struct mddev" conversion and making the request functions be of type "void" instead of "int" in - drivers/md/{faulty.c,linear.c,md.c,md.h,multipath.c,raid0.c,raid1.c,raid10.c,raid5.c} - drivers/staging/zram/zram_drv.c
2011-11-03powerpc/p3060qds: Add support for P3060QDS boardShengzhou Liu
The P3060QDS is a Freescale reference board that hosts the six-core P3060 SOC. The P3060 Processor combines six e500mc Power Architecture processor cores with high-performance datapath acceleration architecture(DPAA), CoreNet fabric infrastructure, as well as network and peripheral interfaces. P3060QDS Board Overview: Memory subsystem: - 2G Bytes unbuffered DDR3 SDRAM SO-DIMM(64bit bus) - 128M Bytes NOR flash single-chip memory - 16M Bytes SPI flash - 8K Bytes AT24C64 I2C EEPROM Ethernet: - 4x1G + 4x1G/2.5G Ethernet controllers - 2xRGMII + 1xMII, three VSC8641 PHYs on board - Suport multiple Vitesse VSC8234 SGMII Cards in Slot1/2/3 PCIe: Two PCI Express 2.0 controllers/ports USB: Two USB2.0, USB1(TYPE-A) and USB2(TYPE-AB) on board I2C: Four I2C controllers UART: Supports up to four UARTs RapidIO: Supports two serial RapidIO ports Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-03powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITXFabio Baltieri
This patch add support for calling ctrl_alt_del() when the power button is pressed for more than about 2 seconds on some freescale MPC83xx evaluation boards and reference design. The code uses a kthread to poll the CTRL_BTN bit each second. Also change Kconfig entry of the driver to bool, as device's gpio registration is broken when loading as module. Tested on an MPC8315E RDB board. Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-03powerpc/85xx: Make kexec to interate over online cpusMatthew McClintock
This is not strictly required, because this iterates over logical cpus and they are not (currently) discontigous. But, it's cleaner code and more obvious what is going on Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-03powerpc/fsl_booke: Fix comment in head_fsl_booke.SMatthew McClintock
Fix typo in comments introduced by: commit 6dece0eb69b2a28e18d104bc5d707f1cb673f5e0 Author: Scott Wood <scottwood@freescale.com> Date: Mon Jul 25 11:29:33 2011 +0000 powerpc/32: Pass device tree address as u64 to machine_init Signed-off-by: Matthew McClintock <msm@freescale.com> cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-03powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devicesMatthew McClintock
This is listed as a requirement for Freescale CoreNet based devices (e.g p4080ds with MPIC v4.x) after issuing a core reset to properly clear pending interrupts. Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-03powerpc/86xx: Correct Gianfar support for GE boardsMartyn Welch
The GE DTBs were not updated when the Gianfar driver was converted to an of_platform_driver in commit b31a1d8b41513b96e9c7ec2f68c5734cef0b26a4. Update the DTBs, adding the required TBI entries. Signed-off-by: Martyn Welch <martyn.welch@ge.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-02arch/powerpc/sysdev/fsl_rio.c: release rapidio port I/O region resource if ↵Liu Gang
port failed to initialize The "struct rio_mport" contains a member of master port I/O memory resource structure "struct resource iores". This resource will be read from device tree and be used for rapidio R/W transaction memory space. Rapidio requests the port I/O memory resource under the root resource "iomem_resource". struct rio_mport *port; port = kzalloc(sizeof(struct rio_mport), GFP_KERNEL); request_resource(&iomem_resource, &port->iores); When port failed to initialize, allocated "rio_mport" structure memory will be freed, and the port I/O memory resource structure pointer "&port->iores" will be invalid. If other requests resource under "iomem_resource", "&port->iores" node may be operated in the child resources list and this will cause the system to crash. So the requested port I/O memory resource should be released before freeing allocated "rio_mport" structure. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Acked-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02thp: share get_huge_page_tail()Andrea Arcangeli
This avoids duplicating the function in every arch gup_fast. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02powerpc: gup_huge_pmd() return 0 if pte changesAndrea Arcangeli
powerpc didn't return 0 in that case, if it's rolling back the *nr pointer it should also return zero to avoid adding pages to the array at the wrong offset. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Gibson <david@gibson.dropbear.id.au> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02powerpc: gup_hugepte() support THP based tail recountingAndrea Arcangeli
Up to this point the code assumed old refcounting for hugepages (pre-thp). This updates the code directly to the thp mapcount tail page refcounting. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02powerpc: gup_hugepte() avoid freeing the head page too many timesAndrea Arcangeli
We only taken "refs" pins on the head page not "*nr" pins. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02powerpc: get_hugepte() don't put_page() the wrong pageAndrea Arcangeli
"page" may have changed to point to the next hugepage after the loop completed, The references have been taken on the head page, so the put_page must happen there too. This is a longstanding issue pre-thp inclusion. It's totally unclear how these page_cache_add_speculative and pte_val(pte) != pte_val(*ptep) checks are necessary across all the powerpc gup_fast code, when x86 doesn't need any of that: there's no way the page can be freed with irq disabled so we're guaranteed the atomic_inc will happen on a page with page_count > 0 (so not needing the speculative check). The pte check is also meaningless on x86: no need to rollback on x86 if the pte changed, because the pte can still change a CPU tick after the check succeeded and it won't be rolled back in that case. The important thing is we got a reference on a valid page that was mapped there a CPU tick ago. So not knowing the soft tlb refill code of ppc64 in great detail I'm not removing the "speculative" page_count increase and the pte checks across all the code, but unless there's a strong reason for it they should be later cleaned up too. If a pte can change from huge to non-huge (like it could happen with THP) passing a pte_t *ptep to gup_hugepte() would also require to repeat the is_hugepd in gup_hugepte(), but that shouldn't happen with hugetlbfs only so I'm not altering that. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02powerpc: remove superfluous PageTail checks on the pte gup_fastAndrea Arcangeli
This part of gup_fast doesn't seem capable of handling hugetlbfs ptes, those should be handled by gup_hugepd only, so these checks are superfluous. Plus if this wasn't a noop, it would have oopsed because, the insistence of using the speculative refcounting would trigger a VM_BUG_ON if a tail page was encountered in the page_cache_get_speculative(). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02mm: thp: tail page refcounting fixAndrea Arcangeli
Michel while working on the working set estimation code, noticed that calling get_page_unless_zero() on a random pfn_to_page(random_pfn) wasn't safe, if the pfn ended up being a tail page of a transparent hugepage under splitting by __split_huge_page_refcount(). He then found the problem could also theoretically materialize with page_cache_get_speculative() during the speculative radix tree lookups that uses get_page_unless_zero() in SMP if the radix tree page is freed and reallocated and get_user_pages is called on it before page_cache_get_speculative has a chance to call get_page_unless_zero(). So the best way to fix the problem is to keep page_tail->_count zero at all times. This will guarantee that get_page_unless_zero() can never succeed on any tail page. page_tail->_mapcount is guaranteed zero and is unused for all tail pages of a compound page, so we can simply account the tail page references there and transfer them to tail_page->_count in __split_huge_page_refcount() (in addition to the head_page->_mapcount). While debugging this s/_count/_mapcount/ change I also noticed get_page is called by direct-io.c on pages returned by get_user_pages. That wasn't entirely safe because the two atomic_inc in get_page weren't atomic. As opposed to other get_user_page users like secondary-MMU page fault to establish the shadow pagetables would never call any superflous get_page after get_user_page returns. It's safer to make get_page universally safe for tail pages and to use get_page_foll() within follow_page (inside get_user_pages()). get_page_foll() is safe to do the refcounting for tail pages without taking any locks because it is run within PT lock protected critical sections (PT lock for pte and page_table_lock for pmd_trans_huge). The standard get_page() as invoked by direct-io instead will now take the compound_lock but still only for tail pages. The direct-io paths are usually I/O bound and the compound_lock is per THP so very finegrined, so there's no risk of scalability issues with it. A simple direct-io benchmarks with all lockdep prove locking and spinlock debugging infrastructure enabled shows identical performance and no overhead. So it's worth it. Ideally direct-io should stop calling get_page() on pages returned by get_user_pages(). The spinlock in get_page() is already optimized away for no-THP builds but doing get_page() on tail pages returned by GUP is generally a rare operation and usually only run in I/O paths. This new refcounting on page_tail->_mapcount in addition to avoiding new RCU critical sections will also allow the working set estimation code to work without any further complexity associated to the tail page refcounting with THP. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Michel Lespinasse <walken@google.com> Reviewed-by: Michel Lespinasse <walken@google.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: <stable@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31Cross Memory AttachChristopher Yeoh
The basic idea behind cross memory attach is to allow MPI programs doing intra-node communication to do a single copy of the message rather than a double copy of the message via shared memory. The following patch attempts to achieve this by allowing a destination process, given an address and size from a source process, to copy memory directly from the source process into its own address space via a system call. There is also a symmetrical ability to copy from the current process's address space into a destination process's address space. - Use of /proc/pid/mem has been considered, but there are issues with using it: - Does not allow for specifying iovecs for both src and dest, assuming preadv or pwritev was implemented either the area read from or written to would need to be contiguous. - Currently mem_read allows only processes who are currently ptrace'ing the target and are still able to ptrace the target to read from the target. This check could possibly be moved to the open call, but its not clear exactly what race this restriction is stopping (reason appears to have been lost) - Having to send the fd of /proc/self/mem via SCM_RIGHTS on unix domain socket is a bit ugly from a userspace point of view, especially when you may have hundreds if not (eventually) thousands of processes that all need to do this with each other - Doesn't allow for some future use of the interface we would like to consider adding in the future (see below) - Interestingly reading from /proc/pid/mem currently actually involves two copies! (But this could be fixed pretty easily) As mentioned previously use of vmsplice instead was considered, but has problems. Since you need the reader and writer working co-operatively if the pipe is not drained then you block. Which requires some wrapping to do non blocking on the send side or polling on the receive. In all to all communication it requires ordering otherwise you can deadlock. And in the example of many MPI tasks writing to one MPI task vmsplice serialises the copying. There are some cases of MPI collectives where even a single copy interface does not get us the performance gain we could. For example in an MPI_Reduce rather than copy the data from the source we would like to instead use it directly in a mathops (say the reduce is doing a sum) as this would save us doing a copy. We don't need to keep a copy of the data from the source. I haven't implemented this, but I think this interface could in the future do all this through the use of the flags - eg could specify the math operation and type and the kernel rather than just copying the data would apply the specified operation between the source and destination and store it in the destination. Although we don't have a "second user" of the interface (though I've had some nibbles from people who may be interested in using it for intra process messaging which is not MPI). This interface is something which hardware vendors are already doing for their custom drivers to implement fast local communication. And so in addition to this being useful for OpenMPI it would mean the driver maintainers don't have to fix things up when the mm changes. There was some discussion about how much faster a true zero copy would go. Here's a link back to the email with some testing I did on that: http://marc.info/?l=linux-mm&m=130105930902915&w=2 There is a basic man page for the proposed interface here: http://ozlabs.org/~cyeoh/cma/process_vm_readv.txt This has been implemented for x86 and powerpc, other architecture should mainly (I think) just need to add syscall numbers for the process_vm_readv and process_vm_writev. There are 32 bit compatibility versions for 64-bit kernels. For arch maintainers there are some simple tests to be able to quickly verify that the syscalls are working correctly here: http://ozlabs.org/~cyeoh/cma/cma-test-20110718.tgz Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: <linux-man@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31powerpc: remove non-required uses of include <linux/module.h>Paul Gortmaker
None of the files touched here are modules, and they are not exporting any symbols either -- so there is no need to be including the module.h. Builds of all the files remains successful. Even kernel/module.c does not need to include it, since it includes linux/moduleloader.h instead. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: various straight conversions from module.h --> export.hPaul Gortmaker
All these files were including module.h just for the basic EXPORT_SYMBOL infrastructure. We can shift them off to the export.h header which is a way smaller footprint and thus realize some compile time gains. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: convert hvconsole.c to export.h ; fix implicit use of errno.hPaul Gortmaker
This file is only exporting symbols and so should use export.h and not module.h header. But in doing the conversion, we will uncover that it was implicitly using errno.h via module.h: CC arch/powerpc/platforms/pseries/hvconsole.o arch/powerpc/platforms/pseries/hvconsole.c: In function 'hvc_put_chars': arch/powerpc/platforms/pseries/hvconsole.c:77: error: 'EIO' undeclared (first use in this function) Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: fix two implicit header uses in pseries/plpar_wrappers.hPaul Gortmaker
Removing the implicit presence of module.h from almost everywhere will reveal this implicit usage of paca.h and string.h headers as follows: arch/powerpc/platforms/pseries/plpar_wrappers.h:22: error: implicit declaration of function 'get_lppaca' arch/powerpc/platforms/pseries/plpar_wrappers.h:208: error: implicit declaration of function 'memcpy' Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: fix implicit use of mutex.h by include/asm/spu.hPaul Gortmaker
We've been getting the header implicitly via module.h in the past but when we clean that up, we'll get this failure: CC arch/powerpc/platforms/cell/beat_spu_priv1.o In file included from arch/powerpc/platforms/cell/beat_spu_priv1.c:22: arch/powerpc/include/asm/spu.h:190: error: field 'list_mutex' has incomplete type make[2]: *** [arch/powerpc/platforms/cell/beat_spu_priv1.o] Error 1 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: fix implicit use of cache.h in kernel/firmware.cPaul Gortmaker
This file only needs export.h to get EXPORT_SYMBOL, but in doing so, it uncovers an implicit use of linux/cache.h as follows: CC arch/powerpc/kernel/firmware.o arch/powerpc/kernel/firmware.c:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__read_mostly' arch/powerpc/kernel/firmware.c:21: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__used' make[2]: *** [arch/powerpc/kernel/firmware.o] Error 1 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: fix implicit notifier use in converting to export.hPaul Gortmaker
We can convert this file to using export.h since it only wants to export symbols, but when we do we'll see also that it was implicitly getting notifier.h from module.h via this failure: CC arch/powerpc/platforms/cell/spu_notify.o arch/powerpc/platforms/cell/spu_notify.c:28: warning: type defaults to 'int' in declaration of 'BLOCKING_NOTIFIER_HEAD' arch/powerpc/platforms/cell/spu_notify.c:28: warning: parameter names (without types) in function declaration arch/powerpc/platforms/cell/spu_notify.c: In function 'spu_switch_notify': arch/powerpc/platforms/cell/spu_notify.c:32: error: implicit declaration of function 'blocking_notifier_call_chain' arch/powerpc/platforms/cell/spu_notify.c:32: error: 'spu_switch_notifier' undeclared (first use in this function) Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: cell/beat_wrapper.h is implicitly using memcpy functionsPaul Gortmaker
This has been relying on the fact that the parent file would have module.h (and thus nearly everything) present. But once we fix that, we'll get stuck with this failure: In file included from arch/powerpc/platforms/cell/beat_spu_priv1.c:26: arch/powerpc/platforms/cell/beat_wrapper.h: In function 'beat_eeprom_write': arch/powerpc/platforms/cell/beat_wrapper.h:160: error: implicit declaration of function 'memcpy' and many more instances of the same. Fix it in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: Fix up implicit sched.h usersPaul Gortmaker
They are getting it through device.h --> module.h path, but we want to clean that up. This is a sample of what will happen if we don't: pseries/iommu.c: In function 'tce_build_pSeriesLP': pseries/iommu.c:136: error: implicit declaration of function 'show_stack' pseries/eeh.c: In function 'eeh_token_to_phys': pseries/eeh.c:359: error: 'init_mm' undeclared (first use in this function) pseries/eeh_event.c: In function 'eeh_event_handler': pseries/eeh_event.c:63: error: implicit declaration of function 'daemonize' pseries/eeh_event.c:64: error: implicit declaration of function 'set_current_state' pseries/eeh_event.c:64: error: 'TASK_INTERRUPTIBLE' undeclared (first use in this function) pseries/eeh_event.c:64: error: (Each undeclared identifier is reported only once pseries/eeh_event.c:64: error: for each function it appears in.) pseries/eeh_event.c: In function 'eeh_thread_launcher': pseries/eeh_event.c:109: error: 'CLONE_KERNEL' undeclared (first use in this function) hotplug-cpu.c: In function 'pseries_mach_cpu_die': hotplug-cpu.c:115: error: implicit declaration of function 'idle_task_exit' kernel/swsusp_64.c: In function 'do_after_copyback': kernel/swsusp_64.c:17: error: implicit declaration of function 'touch_softlockup_watchdog' cell/spufs/context.c: In function 'alloc_spu_context': cell/spufs/context.c:60: error: implicit declaration of function 'get_task_mm' cell/spufs/context.c:60: warning: assignment makes pointer from integer without a cast cell/spufs/context.c: In function 'spu_forget': cell/spufs/context.c:127: error: implicit declaration of function 'mmput' pasemi/dma_lib.c: In function 'pasemi_dma_stop_chan': pasemi/dma_lib.c:332: error: implicit declaration of function 'cond_resched' sysdev/fsl_lbc.c: In function 'fsl_lbc_ctrl_irq': sysdev/fsl_lbc.c:247: error: 'TASK_NORMAL' undeclared (first use in this function) Add in sched.h so these get the definitions they are looking for. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: Fix up implicit stat.h usersPaul Gortmaker
They get it via module.h (via device.h) but we want to clean that up. When we do, we'll get things like: ibmebus.c:314: error: 'S_IWUSR' undeclared here (not in a function) vio.c:972: error: 'S_IWUSR' undeclared here (not in a function) so add in the stat header it is using explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: Fix up modules that should be including module.hPaul Gortmaker
So that we can clean up the header files and not be relying on implicit includes from device.h ---> module.h Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: include export.h for files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
Fix failures in powerpc associated with the previously allowed implicit module.h presence that now lead to things like this: arch/powerpc/mm/mmu_context_hash32.c:76:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL' arch/powerpc/mm/tlb_hash32.c:48:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' arch/powerpc/kernel/pci_32.c:51:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL' arch/powerpc/kernel/iomap.c:36:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' arch/powerpc/platforms/44x/canyonlands.c:126:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' arch/powerpc/kvm/44x.c:168:59: error: 'THIS_MODULE' undeclared (first use in this function) [with several contibutions from Stephen Rothwell <sfr@canb.auug.org.au>] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: add export.h to files making use of EXPORT_SYMBOLPaul Gortmaker
With module.h being implicitly everywhere via device.h, the absence of explicitly including something for EXPORT_SYMBOL went unnoticed. Since we are heading to fix things up and clean module.h from the device.h file, we need to explicitly include these files now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: io-workarounds.c was implicitly getting init_mmPaul Gortmaker
It was coming in via device.h --> module.h etc. but we want to clean that up. So explicitly include the header where init_mm is being declared. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31powerpc: drop unused Kconfig symbolsPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-10-31powerpc: 40x: drop unused Kconfig symbolPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-10-30Merge branch 'kvm-updates/3.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates/3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: (75 commits) KVM: SVM: Keep intercepting task switching with NPT enabled KVM: s390: implement sigp external call KVM: s390: fix register setting KVM: s390: fix return value of kvm_arch_init_vm KVM: s390: check cpu_id prior to using it KVM: emulate lapic tsc deadline timer for guest x86: TSC deadline definitions KVM: Fix simultaneous NMIs KVM: x86 emulator: convert push %sreg/pop %sreg to direct decode KVM: x86 emulator: switch lds/les/lss/lfs/lgs to direct decode KVM: x86 emulator: streamline decode of segment registers KVM: x86 emulator: simplify OpMem64 decode KVM: x86 emulator: switch src decode to decode_operand() KVM: x86 emulator: qualify OpReg inhibit_byte_regs hack KVM: x86 emulator: switch OpImmUByte decode to decode_imm() KVM: x86 emulator: free up some flag bits near src, dst KVM: x86 emulator: switch src2 to generic decode_operand() KVM: x86 emulator: expand decode flags to 64 bits KVM: x86 emulator: split dst decode to a generic decode_operand() KVM: x86 emulator: move memop, memopp into emulation context ...
2011-10-30Merge branch 'fbdev-next' of git://github.com/schandinat/linux-2.6Linus Torvalds
* 'fbdev-next' of git://github.com/schandinat/linux-2.6: (270 commits) video: platinumfb: Add __devexit_p at necessary place drivers/video: fsl-diu-fb: merge diu_pool into fsl_diu_data drivers/video: fsl-diu-fb: merge diu_hw into fsl_diu_data drivers/video: fsl-diu-fb: only DIU modes 0 and 1 are supported drivers/video: fsl-diu-fb: remove unused panel operating mode support drivers/video: fsl-diu-fb: use an enum for the AOI index drivers/video: fsl-diu-fb: add several new video modes drivers/video: fsl-diu-fb: remove broken screen blanking support drivers/video: fsl-diu-fb: move some definitions out of the header file drivers/video: fsl-diu-fb: fix some ioctls video: da8xx-fb: Increased resolution configuration of revised LCDC IP OMAPDSS: picodlp: add missing #include <linux/module.h> fb: fix au1100fb bitrot. mx3fb: fix NULL pointer dereference in screen blanking. video: irq: Remove IRQF_DISABLED smscufx: change edid data to u8 instead of char OMAPDSS: DISPC: zorder support for DSS overlays OMAPDSS: DISPC: VIDEO3 pipeline support OMAPDSS/OMAP_VOUT: Fix incorrect OMAP3-alpha compatibility setting video/omap: fix build dependencies ... Fix up conflicts in: - drivers/staging/xgifb/XGI_main_26.c Changes to XGIfb_pan_var() - drivers/video/omap/{lcd_apollon.c,lcd_ldp.c,lcd_overo.c} Removed (or in the case of apollon.c, merged into the generic DSS panel in drivers/video/omap2/displays/panel-generic-dpi.c)
2011-10-28Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue: (21 commits) leases: fix write-open/read-lease race nfs: drop unnecessary locking in llseek ext4: replace cut'n'pasted llseek code with generic_file_llseek_size vfs: add generic_file_llseek_size vfs: do (nearly) lockless generic_file_llseek direct-io: merge direct_io_walker into __blockdev_direct_IO direct-io: inline the complete submission path direct-io: separate map_bh from dio direct-io: use a slab cache for struct dio direct-io: rearrange fields in dio/dio_submit to avoid holes direct-io: fix a wrong comment direct-io: separate fields only used in the submission path from struct dio vfs: fix spinning prevention in prune_icache_sb vfs: add a comment to inode_permission() vfs: pass all mask flags check_acl and posix_acl_permission vfs: add hex format for MAY_* flag values vfs: indicate that the permission functions take all the MAY_* flags compat: sync compat_stats with statfs. vfs: add "device" tag to /proc/self/mountstats cleanup: vfs: small comment fix for block_invalidatepage ... Fix up trivial conflict in fs/gfs2/file.c (llseek changes)
2011-10-28compat: sync compat_stats with statfs.Eric W. Biederman
This was found by inspection while tracking a similar bug in compat_statfs64, that has been fixed in mainline since decemeber. - This fixes a bug where not all of the f_spare fields were cleared on mips and s390. - Add the f_flags field to struct compat_statfs - Copy f_flags to userspace in case someone cares. - Use __clear_user to copy the f_spare field to userspace to ensure that all of the elements of f_spare are cleared. On some architectures f_spare is has 5 ints and on some architectures f_spare only has 4 ints. Which makes the previous technique of clearing each int individually broken. I don't expect anyone actually uses the old statfs system call anymore but if they do let them benefit from having the compat and the native version working the same. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-10-26Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) rtmutex: Add missing rcu_read_unlock() in debug_rt_mutex_print_deadlock() lockdep: Comment all warnings lib: atomic64: Change the type of local lock to raw_spinlock_t locking, lib/atomic64: Annotate atomic64_lock::lock as raw locking, x86, iommu: Annotate qi->q_lock as raw locking, x86, iommu: Annotate irq_2_ir_lock as raw locking, x86, iommu: Annotate iommu->register_lock as raw locking, dma, ipu: Annotate bank_lock as raw locking, ARM: Annotate low level hw locks as raw locking, drivers/dca: Annotate dca_lock as raw locking, powerpc: Annotate uic->lock as raw locking, x86: mce: Annotate cmci_discover_lock as raw locking, ACPI: Annotate c3_lock as raw locking, oprofile: Annotate oprofilefs lock as raw locking, video: Annotate vga console lock as raw locking, latencytop: Annotate latency_lock as raw locking, timer_stats: Annotate table_lock as raw locking, rwsem: Annotate inner lock as raw locking, semaphores: Annotate inner lock as raw locking, sched: Annotate thread_group_cputimer as raw ... Fix up conflicts in kernel/posix-cpu-timers.c manually: making cputimer->cputime a raw lock conflicted with the ABBA fix in commit bcd5cff7216f ("cputimer: Cure lock inversion").
2011-10-26Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (79 commits) TTY: serial_core: Fix crash if DCD drop during suspend tty/serial: atmel_serial: bootconsole removed from auto-enumerates Revert "TTY: call tty_driver_lookup_tty unconditionally" tty/serial: atmel_serial: add device tree support tty/serial: atmel_serial: auto-enumerate ports tty/serial: atmel_serial: whitespace and braces modifications tty/serial: atmel_serial: change platform_data variable name tty/serial: RS485 bindings for device tree TTY: call tty_driver_lookup_tty unconditionally TTY: pty, release tty in all ptmx_open fail paths TTY: make tty_add_file non-failing TTY: drop driver reference in tty_open fail path 8250_pci: Fix kernel panic when pch_uart is disabled h8300: drivers/serial/Kconfig was moved parport_pc: release IO region properly if unsupported ITE887x card is found tty: Support compat_ioctl get/set termios_locked hvc_console: display printk messages on console. TTY: snyclinkmp: forever loop in tx_load_dma_buffer() tty/n_gsm: avoid fifo overflow in gsm_dlci_data_output tty/n_gsm: fix a bug in gsm_dlci_data_output (adaption = 2 case) ... Fix up Conflicts in: - drivers/tty/serial/8250_pci.c Trivial conflict with removed duplicate device ID - drivers/tty/serial/atmel_serial.c Annoying silly conflict between "specify the port num via platform_data" and other changes to atmel_console_init
2011-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits) dp83640: free packet queues on remove dp83640: use proper function to free transmit time stamping packets ipv6: Do not use routes from locally generated RAs |PATCH net-next] tg3: add tx_dropped counter be2net: don't create multiple RX/TX rings in multi channel mode be2net: don't create multiple TXQs in BE2 be2net: refactor VF setup/teardown code into be_vf_setup/clear() be2net: add vlan/rx-mode/flow-control config to be_setup() net_sched: cls_flow: use skb_header_pointer() ipv4: avoid useless call of the function check_peer_pmtu TCP: remove TCP_DEBUG net: Fix driver name for mdio-gpio.c ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces ipv4: fix ipsec forward performance regression jme: fix irq storm after suspend/resume route: fix ICMP redirect validation net: hold sock reference while processing tx timestamps tcp: md5: add more const attributes Add ethtool -g support to virtio_net ... Fix up conflicts in: - drivers/net/Kconfig: The split-up generated a trivial conflict with removal of a stale reference to Documentation/networking/net-modules.txt. Remove it from the new location instead. - fs/sysfs/dir.c: Fairly nasty conflicts with the sysfs rb-tree usage, conflicting with Eric Biederman's changes for tagged directories.
2011-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits) MAINTAINERS: linux-m32r is moderated for non-subscribers linux@lists.openrisc.net is moderated for non-subscribers Drop default from "DM365 codec select" choice parisc: Kconfig: cleanup Kernel page size default Kconfig: remove redundant CONFIG_ prefix on two symbols cris: remove arch/cris/arch-v32/lib/nand_init.S microblaze: add missing CONFIG_ prefixes h8300: drop puzzling Kconfig dependencies MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers tty: drop superfluous dependency in Kconfig ARM: mxc: fix Kconfig typo 'i.MX51' Fix file references in Kconfig files aic7xxx: fix Kconfig references to READMEs Fix file references in drivers/ide/ thinkpad_acpi: Fix printk typo 'bluestooth' bcmring: drop commented out line in Kconfig btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888' doc: raw1394: Trivial typo fix CIFS: Don't free volume_info->UNC until we are entirely done with it. treewide: Correct spelling of successfully in comments ...
2011-10-22powerpc/cpm: Clear muram before it is in use.Hongjun Chen
We need to ensure that MURAM is in a known and cleared out state before using it as the bootloader could have utilized it from its own purposes and left it in an unknown state. If we don't clear it out we've seen issues with UCC ethernet: * Multi ethernet interfaces can't work simultanously. * Multi up/down Ethernet interfaces will halt these ports. * UCC1 RGMII can't work when kernel boots from some hosts. Signed-off-by: Kai.Jiang <Kai.Jiang@freescale.com> Signed-off-by: Hongjun Chen <Hong-jun.Chen@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-19Merge branch 'v3.1-rc10' into for-3.2/coreJens Axboe
Conflicts: block/blk-core.c include/linux/blkdev.h Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-15Merge commit 'v3.1-rc9' into fbdev-nextFlorian Tobias Schandinat
2011-10-14powerpc/fsl_msi: add support for "msi-address-64" propertyTimur Tabi
Add support for the msi-address-64 property of a PCI node. This property specifies the PCI address of MSIIR (message signaled interrupt index register). In commit 3da34aae ("powerpc/fsl: Support unique MSI addresses per PCIe Root Complex"), the msi_addr_hi/msi_addr_lo fields of struct fsl_msi were redefined from an actual address to just an offset, but the fields were not renamed accordingly. These fields are replace with a single field, msiir_offset, to reflect the new meaning. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-13Kconfig: remove redundant CONFIG_ prefix on two symbolsPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-13powerpc/85xx: Setup secondary cores PIR with hard SMP idKumar Gala
Normally logical and hard cpu ID are the same, however in same cases like on the P3060 they may differ. Where the logical is 0..5, the hard id goes 0,1,4..7. This can causes issues for places we utilize PIR to index into array like in debug exception handlers for finding the exception stack. Move to setting up PIR with hard_smp_processor_id fixes the issue. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-12powerpc/fsl-booke: Fix settlbcam for 64-bitBecky Bruce
Currently, it does a cntlzd on the size and then subtracts it from 21.... this doesn't take into account the varying size of a "long". Just use __ilog instead (and subtract the 10 we have to subtract to get to the tsize encoding). Also correct the comment about page sizes supported. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
