path: root/arch/powerpc
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: C99 convert ctl_tables in arch/powerpc/kernel/idle.cEric W. Biederman
This was partially done already and there was no ABI breakage what a relief. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[POWERPC] Use udbg_early_init() on ppc32David Gibson
udbg_early_init() is a function used on 64 bit systems, which initializes whichever early udbg backend is configured. This function is not called on 32-bit, however if btext early debug is enabled it does have an explicit, inline, #ifdef-ed assignment performing analagous initialization. This patch makes things more uniform by folding the btext initialization as an option into udbg_early_init() and calling that from the 32-bit setup path. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Open Firmware serial port driverArnd Bergmann
This can be used for serial ports that are connected to an OF platform bus but are not autodetected by the lecacy serial support. It will automatically take over devices that come from the legacy serial detection, which usually is only one device. In some cases, rtas may be set up to use the serial port in the firmware, which allows easier debugging before probing the serial ports. In this case, the "used-by-rtas" property must be set by the firmware. This patch also adds code to the legacy serial driver to check for this. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Move MPIC smp routines into mpic.cMichael Ellerman
Move a couple of MPIC smp routines into mpic.c, they're inside an SMP block in mpic.c - so they're still only built for SMP. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Cleanup pseries kexec codeMichael Ellerman
Move all the pseries kexec code into one file, platforms/pseries/kexec.c Provide helpers for setting up ppc_md.kexec_cpu_down, so that we don't have to have #ifdef CONFIG_KEXEC in setup.c Move the initialisation of the ppc_md kexec callbacks into an init routine. This is well and truly early enough to cause no change in behaviour, we can't kexec until userspace has given us a kernel to kexec into. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Cleanup pseries smp initialisation codeMichael Ellerman
Move some extern declarations from setup.c into the new pseries.h. While we're at it, provide dummy implementations for !SMP, to avoid cluttering the C file with more #ifdefs. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Consolidate pseries platform header files into pseries.hMichael Ellerman
Following the example of platforms/pasemi, consolidate a couple of tiny header files in platforms/pseries into pseries.h. This gives us a convenient place to put things that need to be available to the platform code, but not public. And hopefully will help people resist the temptation of sticking externs in C files. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14Merge branch 'cell-merge' of ↵Paul Mackerras
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arnd/cell-2.6
2007-02-13Merge branch '85xx' into for_paulusKumar Gala
2007-02-13[POWERPC] 85xx: Drop use of SYNC macro in head_fsl_booke.SBecky Bruce
Eliminate needless invocation of the SYNC macro (which always evaluates to nothing on BookE) from head_fsl_booke.S (for both arch/ppc & arch/powerpc). Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-13[POWERPC] cell: pm_rtas_activat_signals routine cleanupMaynard Johnson
The code was setting up the debug bus for group 21 when profiling on the event PPU CYCLES. The debug bus is not actually used by the hardware performance counters when counting PPU CYCLES. Setting up the debug bus for PPU CYCLES causes signal routing conflicts on the debug bus when profiling PPU cycles and another PPU event. This patch fixes the code to only setup the debug bus to route the performance signals for the non PPU CYCLE events. Signed-off-by: Maynard Johnson <mpjohn@us.ibm.com> Signed-off-by: Carl Love <carll@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] cell: PPU Oprofile cleanup patchCarl Love
This is a clean up patch that includes the following changes: -Some comments were added to clarify the code based on feedback from the community. -The write_pm_cntrl() and set_count_mode() were passed a structure element from a global variable. The argument was removed so the functions now just operate on the global directly. -The set_pm_event() function call in the cell_virtual_cntr() routine was moved to a for-loop before the for_each_cpu loop Signed-off-by: Carl Love <carll@us.ibm.com> Signed-off-by: Maynard Johnson <mpjohn@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: avoid accessing kernel memory through mmapped /mem nodeMasato Noguchi
I found an exploit in current kernel. Currently, there is no range check about mmapping "/mem" node in spufs. Thus, an application can access privilege memory region. In case this kernel already worked on a public server, I send this information only here. If there are such servers in somewhere, please replace it, ASAP. Signed-off-by: Masato Noguchi <Masato.Noguchi@jp.sony.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spu sched: static timeslicing for SCHED_RR contextsChristoph Hellwig
For SCHED_RR tasks we can do some really trivial timeslicing. Basically we fire up a time for every scheduler tick that searches for a higher or same priority thread that is on the runqueue and if there is one context switches to it. Because we can't lock spus from timer context we actually run this from a delayed runqueue instead of a timer. A nice optimization would be to skip the actual priority bitmap search when there are less contexts than physical spus available. To implement this I need a so far unpublished patch from Andre, and it will be added after we have that patch in. Note that right now we only do the time slicing for SCHED_RR tasks. The code would work for SCHED_OTHER tasks aswell, but their prio value is defered from the one the PPU thread has at time of spu_run, and using this for spu scheduling decisions would make the code very unfair. SCHED_OTHER support will be enabled once we the spu scheduler knows how to calculcate cpu_context.prio (very soon) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spu sched: use DECLARE_BITMAPChristoph Hellwig
use DECLARE_BITMAP in the spu scheduler instead of reimplementing it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spu sched: forced preemption at executionChristoph Hellwig
If we start a spu context with realtime priority we want it to run immediately and not wait until some other lower priority thread has finished. Try to find a suitable victim and use it's spu in this case. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spu sched: update some commentsChristoph Hellwig
Give spu_yield a kerneldoc comment and remove the old comment documenting spu_activate, spu_deactive and spu_yield as all of them now have descriptive kerneldoc comments of their own. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spu sched: simplity spu_remove_from_active_listChristoph Hellwig
If we call spu_remove_from_active_list that spu is always guaranteed to be on the active list and in runnable state, so we can simply do a list_del to remove it and unconditionally take the was_active codepath. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: optimize spu_runChristoph Hellwig
There is no need to directly wake up contexts in spu_activate when called from spu_run, so add a flag to surpress this wakeup. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: runqueue simplificationChristoph Hellwig
This is the biggest patch in this series, and it reworks the guts of the spu scheduler runqueue mechanism: - instead of embedding a waitqueue in the runqueue there is now a simple doubly-linked list, the actual wakeups happen by reusing the stop_wq in the spu context (maybe we should rename it one day) - spu_free and spu_prio_wakeup are merged into a single spu_reschedule function - various functionality is split out into small helpers, and kerneldoc comments are added in various places to document what's going on. - spu_activate is rewritten into a tight loop by removing test for various impossible conditions and using the infrastructure in this patch. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: move prio to spu_contextChristoph Hellwig
It doesn't make any sense to have a priority field in the physical spu structure. Move it into the spu context instead. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: state_mutex cleanupChristoph Hellwig
Various cleanups in code surrounding the state semaphore: - inline spu_acquire/spu_release - cleanup spu_acquire_* and add kerneldoc comments to these functions - remove spu_release_exclusive and replace it with spu_release Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: simplify state_mutexChristoph Hellwig
The r/w semaphore to lock the spus was overkill and can be replaced with a mutex to make it faster, simpler and easier to debug. It also helps to allow making most spufs interruptible in future patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: sched.c cleanupsChristoph Hellwig
Various cleanups to sched.c that don't change the global control flow: - add kerneldoc comments to various functions - add spu_ prefixes to various functions - add/remove context from the runqueue in bind/unbind_context as it's part of the logical operation - add a call to put_active_spu to spu_unbind_contex as it's logically part of the unbind operation Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: bind_context sets SPU_STATE_RUNNABLEChristoph Hellwig
Only bind_context/unbind_context change the spu context state. Thus we can move all assignents of SPU_STATE_RUNNABLE into bind_context, which parallels the unbind side aswell. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: remove superfluous SPU_STATE_SAVED assignmentsChristoph Hellwig
unbind_context already sets the context state to SPU_STATE_SAVED, thus the spu_deactivate callers don't need to do it again. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: remove empty last line in run.cChristoph Hellwig
Remove the empty last line in arch/powerpc/platforms/cell/spufs/run.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13[POWERPC] spufs: remove SPU_CONTEXT_PREEMPTChristoph Hellwig
Remove the SPU_CONTEXT_PREEMPT define. It's unused and won't be used in this form after the scheduler rework. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-02-13Merge branch '83xx' into for_paulusKumar Gala
2007-02-13[POWERPC] 83xx: Updated mpc834x_itx_defconfigTimur Tabi
This patch updates the defconfig for the MPC8349E-mITX. In addition to picking up changes from recent kernels, disables support for e100 (which doesn't ship with the system), turns off input devices, turns on some I2C support, turns off HW monitoring (HW not yet supported), turns off OHCI USB (not used), turns off USB gadget support (HW not yet supported), turns on DOS FS support, and turns off kernel debugging. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-13[POWERPC] 83xx: Add support for MPC8349E-mITX-GPTimur Tabi
This patch adds a defconfig and a DTS for the MPC8349E-mITX-GP, a variant of the MPC8349E-mITX. USB is disabled because the only USB port is not setup properly by firmware/kernel Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-13[POWERPC] 85xx: Add a defconfig for the 8568 MDSAndy Fleming
Add defconfig for the MPC8568 MDS reference board Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-13[POWERPC] 85xx: Add support for the 8568 MDS boardAndy Fleming
Add support for the MPC8568 MDS reference board Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-12Merge branch 'master' into 85xxKumar Gala
2007-02-13[POWERPC] spufs: Fix bitrot of the SPU mmap facilityBenjamin Herrenschmidt
It looks like we've had some serious bitrot there mostly due to tracking of address_space's of mmap'ed files getting out of sync with the actual mmap code. The mfc, mss and psmap were not tracked properly and thus not invalidated on context switches (oops !) I also removed the various file->f_mapping = inode->i_mapping; assignments that were done in the other open() routines since that is already done for us by __dentry_open. One improvement we might want to do later is to assign the various ctx-> fields at mmap time instead of file open/close time so that we don't call unmap_mapping_range() on thing that have not been mmap'ed Finally, I added some smp_wmb's after assigning the ctx-> fields to make sure they are visible to other CPUs. I don't think this is really necessary as I suspect locking in the fs layer will make that happen anyway but better safe than sorry. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] powerpc: Remove SPU struct pages for PS3Benjamin Herrenschmidt
Struct page are no longer needed for SPUs, so let's not create them on PS3 anymore. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] spufs: remove need for struct page for SPEsBenjamin Herrenschmidt
This patch removes the need for struct page for SPE local store and registers from spufs. It also makes the locking much more obvious and no longer relying on the truncate logic black magic for protecting against races between unmap_mapping_range() and new pages faulted in. It does so by switching to a nopfn() handler and using the new vm_insert_pfn() to setup the PTEs itself while holding a lock on the SPE. The nice thing is that this patch actually removes a lot more code than it adds :-) Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] Small cleanup of EFIKA platformSylvain Munaut
The efika platform used three files efika-pci.c efika-setup.c and a 2 line efika.h to link the two. The total of code in those is really not much and therefore, I think they're better merged in a single file. There is absolutely _no_code_change_ at all, just merged the files. Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] Fix unbalanced of_node_{get,put} in efika-setup.cSylvain Munaut
2007-02-13[POWERPC] Use common 52xx of_platform probe code for EFIKASylvain Munaut
Now that the device tree has the good properties, we can remove all the efika_init code by a single call to common code. While we're modifying that file, a few whitespaces/alignement/typo fixes are made (nothing significant). Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] Restore 'proper' link order in platformSylvain Munaut
The 52xx was put before CHRP to allow EFIKA to be recognized properly. Now the efika tree is fixed up in prom_init so no need for this ugly hack. So we restore the 'normal' order. Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] Add device tree fixups for the EFIKASylvain Munaut
We make the efika device tree compliant with the defined bindings (at least compliant enough). This is mostly done by mangling the device_type and compatible properties, but also adding some missing bits. Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] mpc5200 device tree bindings refinementGrant Likely
Much needed refinement of mpc5200 device tree binding specifications. Short list: - drop mpc52xx designator; only two supported chips exist, 5200 and 5200b. It's premature to refer to them as '52xx'. - Specify optional 'model' and 'revision' properties in the soc5200 node - Specify reqiured 'cell-index' property to identify between multiple SOC devices of the same type. (Useful for arbitrating shared register access) - Specify optional 'port-number' property for adjusting the logical serial port assignments. - Specify optional 'has-wdt' property for gpt0 node. - Add system-frequency property to soc5200 node Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] Fixup mp5200 drivers to match device tree changesGrant Likely
2007-02-13[POWERPC] correct a prototypeStephen Rothwell
This rids us of a warning. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] Fix vDSO page count calculationBenjamin Herrenschmidt
The recent vDSO consolidation patches broke powerpc due to a mistake in the definition of MAXPAGES constants. This fixes it by moving to a dynamically allocated array of pages instead as I don't like much hard coded size limits. Also move the vdso initialisation to an initcall since it doesn't really need to be done -that- early. Applogies for not catching the breakage earlier, Roland _did_ CC me on his patches a while ago, I got busy with other things and forgot to test them. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] Mark winbond IDE PCI resources with start 0 as unassignedOlaf Hering
libata calls pci_request_regions to claim PCI BAR 0 - 5 pci_request_regions fails if one of the regions cant be claimed. bar 5 has start == 0, __request_resource will fail. Tested on a p630 in SMP mode with pata_sl82c105 00:03.1 IDE interface: Symphony Labs SL82c105 (rev 05) (prog-if 8f [Master SecP SecO PriP PriO]) Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- Interrupt: pin A routed to IRQ 86 Region 0: I/O ports at 3fd3000f000 [size=8] Region 1: I/O ports at 3fd3000f010 [size=4] Region 2: I/O ports at 3fd3000f020 [size=8] Region 3: I/O ports at 3fd3000f030 [size=4] Region 4: I/O ports at 3fd3000f040 [size=16] Region 5: I/O ports at 3fd30000000 [size=16] 00: ad 10 05 01 41 01 80 02 05 8f 01 01 08 48 80 00 10: 01 f0 00 00 11 f0 00 00 21 f0 00 00 31 f0 00 00 20: 41 f0 00 00 01 00 00 00 00 00 00 00 00 00 00 00 30: 00 00 00 00 00 00 00 00 00 00 00 00 56 01 02 28 40: b3 08 ff 00 09 09 00 00 09 09 00 00 09 09 00 00 50: 09 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70: 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 00 00 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 name "ide" linux,phandle 00d5cdc0 (14011840) assigned-addresses 81001910 00000000 0000f000 00000000 00000008 81001914 00000000 0000f010 00000000 00000004 81001918 00000000 0000f020 00000000 00000008 8100191c 00000000 0000f030 00000000 00000004 81001920 00000000 0000f040 00000000 00000010 81001924 00000000 00000000 00000000 00000010 interrupts 00000003 built-in #size-cells 00000000 #address-cells 00000001 device_type "ide" reg 00001900 00000000 00000000 00000000 00000000 41001910 00000000 00000000 00000000 00000008 41001914 00000000 00000000 00000000 00000004 41001918 00000000 00000000 00000000 00000008 4100191c 00000000 00000000 00000000 00000004 41001920 00000000 00000000 00000000 00000010 41001924 00000000 00000000 00000000 00000010 compatible "pci10ad,105" "pciclass,01018f" ibm,fw-slot-number 00000000 fast-back-to-back devsel-speed 00000001 max-latency 00000028 (40) min-grant 00000002 class-code 0001018f (65935) revision-id 00000005 device-id 00000105 (261) vendor-id 000010ad (4269) ibm,loc-code "U0.1-P1/Q6" Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] Celleb: improve MMU hashtable lockingAkira Iguchi
Disabling IRQ is required only in invalidation. This changes "spin_lock_irqsave" to "spin_lock" in other ops. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] Remove ibm4{xx,4x}.h from arch/powerpcDavid Gibson
ARCH=powerpc should not use the ghastly un-multiplatformable tangle of includes that starts with asm-ppc/ibm4xx.h. This patch removes a compile-breaking include of it from head_44x.S. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
