path: root/arch/powerpc
2006-11-22[POWERPC] Fix ucc_geth of_device discovery on mpc832xKim Phillips
mpc832x, as in mpc8360, needs to explicitly find and create the platform device for ucc_geth in 2.6.19. This code will likely be readapted to Benh's new of_ methods for 2.6.20. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-22[POWERPC] Revert "[POWERPC] Add powerpc get/set_rtc_time interface to new ↵Kim Phillips
generic rtc class" This reverts commit 7a69af63e788a324d162201a0b23df41bcf158dd. As advised by David Brownell: http://marc.theaimsgroup.com/?l=linux-kernel&m=116387226902131&w=2 Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-22[POWERPC] Revert "[POWERPC] Enable generic rtc hook for the MPC8349 mITX"Kim Phillips
This reverts commit a8ed4f7ec3aa472134d7de6176f823b2667e450b. As advised by David Brownell: http://marc.theaimsgroup.com/?l=linux-kernel&m=116387226902131&w=2 Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-14[PATCH] hugetlb: prepare_hugepage_range check offset tooHugh Dickins
(David:) If hugetlbfs_file_mmap() returns a failure to do_mmap_pgoff() - for example, because the given file offset is not hugepage aligned - then do_mmap_pgoff will go to the unmap_and_free_vma backout path. But at this stage the vma hasn't been marked as hugepage, and the backout path will call unmap_region() on it. That will eventually call down to the non-hugepage version of unmap_page_range(). On ppc64, at least, that will cause serious problems if there are any existing hugepage pagetable entries in the vicinity - for example if there are any other hugepage mappings under the same PUD. unmap_page_range() will trigger a bad_pud() on the hugepage pud entries. I suspect this will also cause bad problems on ia64, though I don't have a machine to test it on. (Hugh:) prepare_hugepage_range() should check file offset alignment when it checks virtual address and length, to stop MAP_FIXED with a bad huge offset from unmapping before it fails further down. PowerPC should apply the same prepare_hugepage_range alignment checks as ia64 and all the others do. Then none of the alignment checks in hugetlbfs_file_mmap are required (nor is the check for too small a mapping); but even so, move up setting of VM_HUGETLB and add a comment to warn of what David Gibson discovered - if hugetlbfs_file_mmap fails before setting it, do_mmap_pgoff's unmap_region when unwinding from error will go the non-huge way, which may cause bad behaviour on architectures (powerpc and ia64) which segregate their huge mappings into a separate region of the address space. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-10[POWERPC] cell: set ARCH_SPARSEMEM_DEFAULT in KconfigGeoff Levand
The current cell processor support needs sparsemem, so set it as the default memory model. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-10[POWERPC] Fix cell "new style" mapping and add debugBenjamin Herrenschmidt
This fixes a typo in the "new style" code for mapping SPE resources, which causes it to try to map the same resource 4 times. It also adds some pr_debug's that are useful to track down issues with the firmware when bringinh up new machines. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-10[POWERPC] pseries: Force 4k update_flash block and list sizesJohn Rose
The enablement of 64k pages on pseries platforms exposed a bug in the RTAS mechanism for updating firmware. RTAS assumes 4k for flash block and list sizes, and use of any other sizes results in a failure, even though PAPR does not specify any such requirement. This patch changes the rtas_flash module to force the use of 4k memory block and list sizes when preparing and sending a firmware image to RTAS. The rtas_flash function now uses a slab cache of 4k blocks with 4k alignment, rather than get_zeroed_page(), to allocate the memory for the flash blocks and lists. The 4k alignment requirement is specified in PAPR. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-09[POWERPC] Make sure initrd and dtb sections get into zImage correctlyPaul Mackerras
The "wrapper" script was using the wrong names for the initrd and dtb (device-tree blob) sections. This fixes it, and also ensures the symbols for the start and end of the dtb get defined correctly. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[PATCH] powerpc: Eliminate "exceeds stub group size" linker warningPaul Mackerras
It turns out that the linker warnings on 64-bit powerpc about "section blah exceeds stub group size" were being triggered by conditional branches in head_64.S branching to global symbols, whether in head_64.S or in other files. This eliminates the warnings by making some global symbols in head_64.S no longer global, and by rearranging some branches. Signed-off-by: Paul Mackerras <paulus@samba.org> [ Yee-haa. Maybe I'll notice newly introduced real warnings now - Linus ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-01[POWERPC] Make alignment exception always check exception tableBenjamin Herrenschmidt
The alignment exception used to only check the exception table for -EFAULT, not for other errors. That opens an oops window if we can coerce the kernel into getting an alignment exception for other reasons in what would normally be a user-protected accessor, which can be done via some of the futex ops. This fixes it by always checking the exception tables. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Disallow kprobes on emulate_step and branch_takenGui,Jian
On powerpc, probing on emulate_step function will crash 2.6.18.1 when it is triggered. When kprobe is triggered, emulate_step() is on its kernel path and will cause recursive kprobe fault. And branch_taken() is called in emulate_step(). This disallows kprobes on both of them. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Make high hugepage areas preempt safeHugh Dickins
Checking source for other get_paca()->field preemption dangers found that open_high_hpage_areas does a structure copy into its paca while preemption is enabled: unsafe however gcc accomplishes it. Just remove that copy: it's done safely afterwards by on_each_cpu, as in open_low_hpage_areas. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] qe_lib: qe_issue_cmd writes wrong value to CECDRTimur Tabi
Changed qe_issue_cmd() to write cmd_input to the CECDR unmodified. It was treating cmd_input as a virtual address and tried to convert it to a physical address. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Use 4kB iommu pages even on 64kB-page systemsLinas Vepstas
The 10Gigabit ethernet device drivers appear to be able to chew up all 256MB of TCE mappings on pSeries systems, as evidenced by numerous error messages: iommu_alloc failed, tbl c0000000010d5c48 vaddr c0000000d875eff0 npages 1 Some experimentation indicates that this is essentially because one 1500 byte ethernet MTU gets mapped as a 64K DMA region when the large 64K pages are enabled. Thus, it doesn't take much to exhaust all of the available DMA mappings for a high-speed card. This patch changes the iommu allocator to work with its own unique, distinct page size. Although the patch is long, its actually quite simple: it just #defines a distinct IOMMU_PAGE_SIZE and then uses this in all the places that matter. As a side effect, it also dramatically improves network performance on platforms with H-calls on iommu translation inserts/removes (since we no longer call it 16 times for a 1500 bytes packet when the iommu HW is still 4k). In the future, we might want to make the IOMMU_PAGE_SIZE a variable in the iommu_table instance, thus allowing support for different HW page sizes in the iommu itself. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Fix oprofile support for e500 in arch/powerpcAndy Fleming
Fixed a compile error in building the 85xx support with oprofile, and in the process cleaned up some issues with the fsl_booke performance monitor code. * Reorganized FSL Book-E performance monitoring code so that the 7450 wouldn't be built if the e500 was, and cleaned it up so it was more self-contained. * Added a cpu_setup function for FSL Book-E. The original cpu_setup function prototype had no arguments, assuming that the reg_setup function would copy the required information into variables which represented the registers. This was silly for e500, since it has 1 register per counter (rather than 3 for all counters), so the code has been restructured to have cpu_setup take the current counter config array as an argument, with op_powerpc_setup() invoking op_powerpc_cpu_setup() through on_each_cpu(), and op_powerpc_cpu_setup() invoking the model-specific cpu_setup function with an argument. The argument is ignored on all other platforms at present. * Fixed a confusing line where a trinary operator only had two arguments Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Fix various offb issuesBenjamin Herrenschmidt
This patch fixes a few issues in offb: - A test was inverted causing the palette hack to never work (no device node was passed down to the init function) - Some cards seem to have their assigned-addresses property in a random order, thus we need to try using of_get_pci_address() first, which will fail if it's not a PCI device, and fallback to of_get_address() in that case. of_get_pci_address() properly parsees assigned-addresses to test the BAR number and thus will get it right whatever the order is. - Some cards (like GXT4500) provide a linebytes of 0xffffffff in the device-tree which does no good. This patch handles that by using the screen width when that happens. (Also fixes btext.c while at it). - Add detection of the GXT4500 in addition to the GXT2000 for the palette hacks (we use the same hack, palette is linear in register space at offset 0x6000). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-27[PATCH] vmlinux.lds: consolidate initcall sectionsAndrew Morton
Add a vmlinux.lds.h helper macro for defining the eight-level initcall table, teach all the architectures to use it. This is a prerequisite for a patch which performs initcall synchronisation for multithreaded-probing. Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> [ Added AVR32 as well ] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-26[POWERPC] Make sure __cpu_preinit_ppc970 gets called on 970GX processorsOlof Johansson
Add check for 970GX for __cpu_preinit_ppc970. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] Fix CHRP platforms with only 8259Benjamin Herrenschmidt
On CHRP platforms with only a 8259 controller, we should set the default IRQ host to the 8259 driver's one for the IRQ probing fallbacks to work in case the IRQ tree is incorrect (like on Pegasos for example). Without this fix, we get a bunch of WARN_ON's during boot. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] IPIC: Fix spinlock recursion in set_irq_handlerScott Wood
This causes ipic_set_irq_type to set the handler directly rather than call set_irq_handler, which causes spinlock recursion because the lock is already held when ipic_set_irq_type is called. I'm also not convinced that ipic_set_irq_type should be changing the handler at all. There seem to be several controllers that don't and several that do. Those that do would break what appears to be a common usage of calling set_irq_chip_and_handler followed by set_irq_type, if a non-standard handler were to be used. OTOH, irq_create_of_mapping() doesn't set the handler, but only calls set_irq_type(). This patch gets things working in the spinlock-debugging-enabled case, but I'm curious as to where the handler setting is ideally supposed to be done. I don't see any documentation on set_irq_type() that clarifies what the semantics are supposed to be. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] Fix the UCC rx/tx clock of QELiu Dave-r63238
MPC8323EMDS board ethernet interface with RMII uses the CLK16 divisor for the rx and tx clock, but the ucc_set_qe_mux_rxtx() function doesn't handle the CLK16 setting of the CMXUCR3 and CMXUCR4 registers. This fixes it. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] cell: update defconfigArnd Bergmann
=================================================================== Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] spufs: fix another off-by-one bug in spufs_mbox_readArnd Bergmann
Currently, spufs_mbox_read transfers more bytes than requested on a read. If you ask for four bytes, you get eight. This fixes it to transfer the largest multiple of four bytes that is less than or equal to the number you asked for. Note: one nasty property of this file in spufs is that you can only read multiples of four bytes in the first place, since there is no way to atomically put back a few bytes into the hardware register. Thus, reading less than four bytes returns -EINVAL. Asking for more than four returns the largest possible multiple of four. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] spufs: fix signal2 file to report signal2Dwayne Grant Mcconnell
This fixes the /signal2 file to actually give signal2 data. Signed-off-by: Dwayne Grant Mcconnell <decimal@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] Fix device_is_compatible() const warningBenjamin Herrenschmidt
Fix a const'ification related warning with device_is_compatible() and friends related to get_property() not properly having const on it's input device node argument. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] Cell timebase bug workaroundBenjamin Herrenschmidt
The Cell CPU timebase has an erratum. When reading the entire 64 bits of the timebase with one mftb instruction, there is a handful of cycles window during which one might read a value with the low order 32 bits already reset to 0x00000000 but the high order bits not yet incremeted by one. This fixes it by reading the timebase again until the low order 32 bits is no longer 0. That might introduce occasional latencies if hitting mftb just at the wrong time, but no more than 70ns on a cell blade, and that was considered acceptable. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] Support feature fixups in modulesBenjamin Herrenschmidt
This patch adds support for feature fixups in modules. This involves adding support for R_PPC64_REL64 relocs to the 64 bits module loader. It also modifies modpost.c to ignore the powerpc fixup sections (or it would warn when used in .init.text). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] Support feature fixups in vdso'sBenjamin Herrenschmidt
This patch reworks the feature fixup mecanism so vdso's can be fixed up. The main issue was that the construct: .long label (or .llong on 64 bits) will not work in the case of a shared library like the vdso. It will generate an empty placeholder in the fixup table along with a reloc, which is not something we can deal with in the vdso. The idea here (thanks Alan Modra !) is to instead use something like: 1: .long label - 1b That is, the feature fixup tables no longer contain addresses of bits of code to patch, but offsets of such code from the fixup table entry itself. That is properly resolved by ld when building the .so's. I've modified the fixup mecanism generically to use that method for the rest of the kernel as well. Another trick is that the 32 bits vDSO included in the 64 bits kernel need to have a table in the 64 bits format. However, gas does not support 32 bits code with a statement of the form: .llong label - 1b (Or even just .llong label) That is, it cannot emit the right fixup/relocation for the linker to use to assign a 32 bits address to an .llong field. Thus, in the specific case of the 32 bits vdso built as part of the 64 bits kernel, we are using a modified macro that generates: .long 0xffffffff .llong label - 1b Note that is assumes that the value is negative which is enforced by the .lds (those offsets are always negative as the .text is always before the fixup table and gas doesn't support emiting the reloc the other way around). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] Consolidate feature fixup codeBenjamin Herrenschmidt
There are currently two versions of the functions for applying the feature fixups, one for CPU features and one for firmware features. In addition, they are both in assembly and with separate implementations for 32 and 64 bits. identify_cpu() is also implemented in assembly and separately for 32 and 64 bits. This patch replaces them with a pair of C functions. The call sites are slightly moved on ppc64 as well to be called from C instead of from assembly, though it's a very small change, and thus shouldn't cause any problem. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-23[POWERPC] Fix spelling errors in ucc_fast.c and ucc_slow.cTimur Tabi
In ucc_fast.c and ucc_slow.c, "illegal" is twice spelled "illagal". Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-23[POWERPC] Don't require execute perms on wrapper when building zImage.initrdMark A. Greer
Don't require that the wrapper script be executable when building zImage.initrds. This has already been fixed for zImages. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-23[POWERPC] Add 970GX cputable entryJake Moilanen
970GX cputable entry from Steve Winiecki. Signed-off-by: Jake Moilanen <moilanen@austin.ibm.com> arch/powerpc/kernel/cputable.c | 15 +++++++++++++++ arch/powerpc/oprofile/op_model_power4.c | 2 +- include/asm-powerpc/reg.h | 1 + 3 files changed, 17 insertions(+), 1 deletion(-) Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-23[POWERPC] Fix build breakage with CONFIG_PPC32Srinivasa Ds
low_cpu_die is called from the CPU hotplug code on 32-bit powermacs, but it is only defined if CONFIG_PM || CONFIG_CPU_FREQ_PMAC. This changes the ifdef so it is defined for CONFIG_HOTPLUG_CPU on 32-bit machines. Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-23[POWERPC] Fix compiler warning message on get_property callZang Roy-r61911
This fixes the warning message from the return value of function get_property(), by making sure that the variable that receives the value is marked as const. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> -- Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-23[POWERPC] Simplify stolen time calculationStephen Rothwell
In calculating stolen time, we were trying to actually account for time spent in the hypervisor. We don't really have enough information to do that accurately, so don't try. Instead, we now calculate stolen time as time that the current cpu thread is not actually dispatching instructions. On chips without a PURR, we cannot do this, so stolen time will always be zero. On chips with a PURR, this is merely the difference between the elapsed PURR values and the elapsed TB values. This gives us much more sane vaules from tools such as mpstat, even if they are still a bit strange e.g. 2 busy threads on one cpu will both appear to have 50% user time and 50% stolen time while 1 busy thread on a cpu will look like 100% user on one of them and 100% idle on the other. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-21[PATCH] Reintroduce NODES_SPAN_OTHER_NODES for powerpcAndy Whitcroft
Reintroduce NODES_SPAN_OTHER_NODES for powerpc Revert "[PATCH] Remove SPAN_OTHER_NODES config definition" This reverts commit f62859bb6871c5e4a8e591c60befc8caaf54db8c. Revert "[PATCH] mm: remove arch independent NODES_SPAN_OTHER_NODES" This reverts commit a94b3ab7eab4edcc9b2cb474b188f774c331adf7. Also update the comments to indicate that this is still required and where its used. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Kravetz <kravetz@us.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-16[POWERPC] Check for offline nodes in pci NUMA codeAnton Blanchard
During boot we bring up all memory and cpu nodes. Normally a PCI device will be in one of these online nodes, however in some weird setups it may not. We have only seen this in the lab but we may as well check for the case and fallback to -1 (all nodes). Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-16[POWERPC] Better check in show_instructionsAnton Blanchard
Instead of just checking that an address is in the right range, use the provided __kernel_text_address() helper which covers both the kernel and module text sections. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-16[POWERPC] POWER6 has 6 PMCsAnton Blanchard
Change ->num_pmcs to match the number of PMCs in POWER6. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-16[POWERPC] Never panic when taking altivec exceptions from userspaceAnton Blanchard
At the moment we rely on a cpu feature bit or a firmware property to detect altivec. If we dont have either of these and the cpu does in fact support altivec we can cause a panic from userspace. It seems safer to always send a signal if we manage to get an 0xf20 exception from userspace. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-16[POWERPC] Fix IO Window Updates on P2P bridges.Randy Vinson
When update_bridge_base() updates the IO window on a PCI-to-PCI bridge, it fails to zero the upper 16 bits of the base and limit registers if the window size is less than 64K. This fixes it. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-16[POWERPC] Add Makefile entry for MPC832x_mds supportLi Yang
Add missing entry in Makefile for MPC832x MDS support. It also change white space to tab in MPC8360 entry. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-16[POWERPC] Fix MPC8360EMDS PB board supportLi Yang
MPC8360EMDS PB support is broken as some code was missing in last submission. This patch adds missing code and makes MPC8360EMDS PB support working. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-16[POWERPC] Add DOS partition table support to mpc834x_itx_defconfigTimur Tabi
The default configuration file for the MPC8349E-mITX reference board, mpc834x_itx_defconfig, did not include support for DOS partition table types. This support is necessary because the hard drive that comes with the ITX is formatted with this partition table type. Without this config option, no partitions on the drive can be mounted. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-16[POWERPC] spufs: fix support for read/write on cntlNoguchi, Masato
This fixes a memory leak introduced by "spufs: add support for read/write oncntl", which was missing a call to simple_attr_close. Signed-off-by: Masato Noguchi <Masato.Noguchi@jp.sony.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-16[POWERPC] Don't crash on cell with 2 BEs when !CONFIG_NUMABenjamin Herrenschmidt
The SPU code will crash if CONFIG_NUMA is not set and SPUs are found on a non-0 node. This workaround will ignore those SPEs and just print an message in the kernel log. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-11[PATCH] mm: use symbolic names instead of indices for zone initialisationMel Gorman
Arch-independent zone-sizing is using indices instead of symbolic names to offset within an array related to zones (max_zone_pfns). The unintended impact is that ZONE_DMA and ZONE_NORMAL is initialised on powerpc instead of ZONE_DMA and ZONE_HIGHMEM when CONFIG_HIGHMEM is set. As a result, the the machine fails to boot but will boot with CONFIG_HIGHMEM turned off. The following patch properly initialises the max_zone_pfns[] array and uses symbolic names instead of indices in each architecture using arch-independent zone-sizing. Two users have successfully booted their powerpcs with it (one an ibook G4). It has also been boot tested on x86, x86_64, ppc64 and ia64. Please merge for 2.6.19-rc2. Credit to Benjamin Herrenschmidt for identifying the bug and rolling the first fix. Additional credit to Johannes Berg and Andreas Schwab for reporting the problem and testing on powerpc. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Fix windfarm platform device usage [POWERPC] Fix i2c-powermac platform device usage [POWERPC] Fix secondary CPU startup on old "powersurge" SMP powermacs [POWERPC] ARCH=ppc pt_regs fixes [POWERPC] Update maple defconfig [POWERPC] Fix Maple secondary IDE interrupt [POWERPC] Make U4 PCIe work on maple [POWERPC] cell: fix default zImage build target [POWERPC] Fix boot wrapper invocation if CROSS_COMPILE contains spaces [POWERPC] Fix xmon IRQ handler for pt_regs removal
2006-10-10[POWERPC] Fix secondary CPU startup on old "powersurge" SMP powermacsPaul Mackerras
On the old "powersurge" SMP powermacs, the second CPU is started up by sending it an IPI, which has the side effect of stopping the timebase clock (so the secondary CPU's timebase can be synchronized with the primary's). The routine that did this used udelay, which will hang forever when the timebase is stopped, since udelay now spins until the timebase reaches a certain value. The end result is that the kernel would hang when bringing up the second CPU. This fixes it by using a simple loop which just does a fixed number of iterations to generate the delay. These old systems were all clocked at around 200 MHz or so, so a fixed number of iterations is acceptable. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-10[POWERPC] Update maple defconfigBenjamin Herrenschmidt
This updates the Maple defconfig to 4 CPUs (along with current defaults) to support the "tigerwood" 970MP evaluation board. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
