commit 0fe1ac48bef018bed896307cd12f6ca9b5e704ab upstream.
Anton Blanchard found that large POWER systems would occasionally
crash in the exception exit path when profiling with perf_events.
The symptom was that an interrupt would occur late in the exit path
when the MSR[RI] (recoverable interrupt) bit was clear. Interrupts
should be hard-disabled at this point but they were enabled. Because
the interrupt was not recoverable the system panicked.
The reason is that the exception exit path was calling
perf_event_do_pending after hard-disabling interrupts, and
perf_event_do_pending will re-enable interrupts.
The simplest and cleanest fix for this is to use the same mechanism
that 32-bit powerpc does, namely to cause a self-IPI by setting the
decrementer to 1. This means we can remove the tests in the exception
exit path and raw_local_irq_restore.
This also makes sure that the call to perf_event_do_pending from
timer_interrupt() happens within irq_enter/irq_exit. (Note that
calling perf_event_do_pending from timer_interrupt does not mean that
there is a possible 1/HZ latency; setting the decrementer to 1 ensures
that the timer interrupt will happen immediately, i.e. within one
timebase tick, which is a few nanoseconds or 10s of nanoseconds.)
commit a8e6da093ea8642b1320fb5d64134366f2a8d0ac upstream.
Remove debug printks in pseries_mach_cpu_die(). These are
noisy at runtime. Traceevents can be added to instrument this
section of code.
The following KERN_INFO printks are removed:
cpu 62 (hwid 62) returned from cede.
Decrementer value = b2802fff Timebase value = 2fa8f95035f4a
cpu 62 (hwid 62) got prodded to go online
cpu 58 (hwid 58) ceding for offline with hint 2
Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Cc: Gautham R Shenoy <ego@in.ibm.com>
commit 0212f2602a38e740d5a96aba4cebfc2ebc993ecf upstream.
Rearrange condition checks for better code readability and
prevention of possible race conditions when
preferred_offline_state can potentially change during the
execution of pseries_mach_cpu_die(). The patch will make
pseries_mach_cpu_die() put cpu in one of the consistent states
and not hit the run over BUG()
commit 8dbce53cc249a76e9450708d291fce5a7e29c6a1 upstream.
Cpu hotplug (offline) without dlpar operation will place cpu
in cede state and the extended_cede_processor() function will
return when resumed.
Kernel stack pointer needs to be reset before
start_secondary() is called to continue the online operation.
Added new function start_secondary_resume() to do the above
steps.
commit 56151e753468e34aeb322af4b0309ab727c97d2e upstream.
The bypassing of this test is a leftover from 2.4 vintage
kernels, and is no longer appropriate, or even used by KGDB.
Currently KGDB uses probe_kernel_write() for all access to
memory via the KGDB core, so it can simply be deleted.
This fixes CVE-2010-1446.
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: Paul Mackerras <paulus@samba.org>
CC: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Wufei <fei.wu@windriver.com>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
(Cherry-picked from commit 87bf6e7de1134f48681fd2ce4b7c1ec45458cb6d)
Int is not long enough to store the size of a dirty bitmap.
This patch fixes this problem with the introduction of a wrapper
function to calculate the sizes of dirty bitmaps.
Note: in mark_page_dirty(), we have to consider the fact that
__set_bit() takes the offset as int, not long.
Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 5b72d74ce2fccca2a301de60f31b16ddf5c93984 upstream.
Compiling 2.6.33 with SMP enabled and HOTPLUG_CPU disabled gives me the
following link errors:
LD init/built-in.o
LD .tmp_vmlinux1
arch/powerpc/platforms/built-in.o: In function `.smp_xics_setup_cpu':
smp.c:(.devinit.text+0x88): undefined reference to `.set_cpu_current_state'
smp.c:(.devinit.text+0x94): undefined reference to `.set_default_offline_state'
arch/powerpc/platforms/built-in.o: In function `.smp_pSeries_kick_cpu':
smp.c:(.devinit.text+0x13c): undefined reference to `.set_preferred_offline_state'
smp.c:(.devinit.text+0x148): undefined reference to `.get_cpu_current_state'
smp.c:(.devinit.text+0x1a8): undefined reference to `.get_cpu_current_state'
make: *** [.tmp_vmlinux1] Error 1
The following change fixes that for me and seems to work as expected.
Signed-off-by: Adam Lackorzynski <adam@os.inf.tu-dresden.de>
This makes it easier to extend perf_sample_data and fixes a bug on arm
and sparc, which failed to set ->raw to NULL, which can cause crashes
when combined with PERF_SAMPLE_RAW.
It also optimizes PowerPC and tracepoint, because the struct
initialization is forced to zero out the whole structure.
Acked-by: Jean Pihet <jpihet@mvista.com>
Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: Jamie Iles <jamie.iles@picochip.com>
Cc: Stephane Eranian <eranian@google.com>
LKML-Reference: <20100304140100.315416040@chello.nl>
Recent U-Boot commit 5ccd29c3679b3669b0bde5c501c1aa0f325a7acb caused
the "cpu-release-addr" device tree property to contain the physical RAM
location that secondary cores were spinning at. Previously, the
"cpu-release-addr" property contained a value referencing the boot page
translation address range of 0xfffffxxx, which then indirectly accessed
RAM.
The "cpu-release-addr" is currently ioremapped and the secondary cores
kicked. However, due to the recent change in "cpu-release-addr", it
sometimes points to a memory location in low memory that cannot be
ioremapped. For example on a P2020-based board with 512MB of RAM the
following error occurs on bootup:
mpic: requesting IPIs ...
__ioremap(): phys addr 0x1ffff000 is RAM lr c05df9a0
Unable to handle kernel paging request for data at address 0x00000014
Faulting instruction address: 0xc05df9b0
Oops: Kernel access of bad area, sig: 11 [#1]
SMP NR_CPUS=2 P2020 RDB
Modules linked in:
<... eventual kernel panic>
Adding logic to conditionally ioremap or access memory directly resolves
the issue.
Signed-off-by: Nate Case <ncase@xes-inc.com>
Reported-by: Dipen Dudhat <B09055@freescale.com>
Tested-by: Dipen Dudhat <B09055@freescale.com>
MPC85xx chips report the wrong value in feature reporting register,
and that causes the following oops:
Unable to handle kernel paging request for data at address 0x00000c00
Faulting instruction address: 0xc0019294
MPC8569 MDS
Modules linked in:
NIP [c0019294] mpic_set_irq_type+0x2f0/0x368
LR [c0019124] mpic_set_irq_type+0x180/0x368
Call Trace:
[ef851d60] [c0019124] mpic_set_irq_type+0x180/0x368 (unreliable)
[ef851d90] [c007958c] __irq_set_trigger+0x44/0xd4
[ef851db0] [c007b550] set_irq_type+0x40/0x7c
[ef851dc0] [c0004a60] irq_create_of_mapping+0xb4/0x114
[ef851df0] [c0004af0] irq_of_parse_and_map+0x30/0x40
[ef851e20] [c0405678] fsl_of_msi_probe+0x1a0/0x328
[ef851e60] [c02e6438] of_platform_device_probe+0x5c/0x84
This is because mpic_alloc() assigns wrong values to
mpic->isu_{size,shift,mask}, and things eventually break when
_mpic_irq_read() is trying to use them.
This patch fixes the issue by enabling MPIC_BROKEN_FRR_NIRQS quirk.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Commit f71dc176aa06359681c30ba6877ffccab6fba3a6 'Make
hpte_need_flush() correctly mask for multiple page sizes' introduced
bug, which is triggered when a kernel with a 64k base page size is run
on a system whose hardware does not 64k hash PTEs. In this case, we
emulate 64k pages with multiple 4k hash PTEs, however in
hpte_need_flush() we incorrectly only mask the hardware page size from
the address, instead of the logical page size. This causes things to
go wrong when we later attempt to iterate through the hardware
subpages of the logical page.
This patch corrects the error. It has been tested on pSeries bare
metal by Michael Neuling.
Signed-off-by: David Gibson <dwg@au1.ibm.com>
The code to track the CPPR values added by commit
49bd3647134ea47420067aea8d1401e722bf2aac ("powerpc/pseries: Track previous
CPPR values to correctly EOI interrupts") broke kexec on pseries because
the kexec code in xics.c calls xics_set_cpu_priority() before the IPI has
been EOI'ed. This wasn't a problem previously but it now triggers a BUG_ON
in xics_set_cpu_priority() because os_cppr->index isn't 0.
Fix this problem by setting the index on the CPPR stack to 0 before calling
xics_set_cpu_priority() in xics_teardown_cpu().
Also make it clear that we only want to set the priority when there's just
one CPPR value in the stack, and enforce it by updating the value of
os_cppr->stack[0] rather than os_cppr->stack[os_cppr->index].
While we're at it change the BUG_ON to a WARN_ON.
Reported-by: Anton Blanchard <anton@samba.org>
Signed-off-by: Mark Nelson <markn@au1.ibm.com>
Here are the powerpc bits to remove TIF_ABI_PENDING now that
set_personality() is called at the appropriate place in exec.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
desc->affinity doesn't exit in that case. Let's use a macro for
the UP variant of get_irq_server(), it's the easiest way, avoids
evaluating arguments.
Some of the newer 4xx pci cores need an explicit bit set to send
type 1 transactions instead of just comparing the bus numbers.
This patch enables type 1 transations for pcix nodes, thus enabling
devices behind PCI bridges.
Signed-off-by: Stef van Os <stef.van.os@gmail.com>
Add missing call to pci_fixup_device(pci_fixup_early, ...) when
building the pci_dev from scratch off the Open Firmware device-tree
Add missing hookup to existing pci_slot when building the pci_dev from
We are missing these when building the pci_dev from scratch off
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Embedded PowerPC KVM has an exit timing implementation to track and evaluate
how much time was spent in which exit path.
For Book3S, we don't implement it. So let's not expose it as a config option
either.
Signed-off-by: Avi Kivity <avi@redhat.com>
Move the defintion and lock helper routines for the cpu hotplug driver
lock from pseries to powerpc code to avoid build breaks for platforms
other than pseries that use cpu hotplug.
Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com>
Acked-by: Michael Ellerman <michael@ellerman.id.au>
It looks like the previous patch sent out to move RTAS and
other items from /proc/ppc64 to /proc/powerpc missed a few
files needed for RAS and DLPAR functionality.
Original Patch here:
http://lists.ozlabs.org/pipermail/linuxppc-dev/2009-September/076096.html
This patch updates the remaining files to be created under /proc/powerpc.
The newly added fixup for buggy dcbX insn's has
a bug that always trigger a kernel TLB walk so a user space
dcbX insn will cause a Kernel Machine Check if it hits DTLB error.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
We noticed that recent kernels didn't boot on our 1GHz Canyonlands 460EX
boards anymore. As it seems, patch 8d165db1 [powerpc: Improve
decrementer accuracy] introduced this problem. The routine div_sc()
overflows with shift = 32 resulting in this incorrect setup:
time_init: decrementer frequency = 1000.000012 MHz
time_init: processor frequency = 1000.000012 MHz
clocksource: timebase mult[400000] shift[22] registered
clockevent: decrementer mult[33] shift[32] cpu[0]
This patch now introduces a local div_dc64() version of this function
so that this overflow doesn't happen anymore.
Cc: Detlev Zundel <dzu@denx.de>
get_viotape_info() declares a vio_waitevent on the stack, which
contains a completion, but never initialises the completion.
I have no idea how this ever worked, and on recent kernels it causes
an oops in handle_tape_event() when we access the non-initialised
completion.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
Make sure compiler won't do weird things with limits. E.g. fetching
them twice may return 2 different values after writable limits are
implemented.
I.e. either use rlimit helpers added in
3e10e716abf3c71bdb5d86b8f507f9e72236c9cd
or ACCESS_ONCE if not applicable.
Cc: linuxppc-dev@ozlabs.org
pcibus_to_node can return -1 if we cannot determine which node a pci bus
is on. If passed -1, cpumask_of_node will negatively index the lookup array
and pull in random data:
# cat /sys/devices/pci0000:00/0000:00:01.0/local_cpus
00000000,00000003,00000000,00000000
# cat /sys/devices/pci0000:00/0000:00:01.0/local_cpulist
64-65
Change cpumask_of_node to check for -1 and return cpu_all_mask in this
case:
ffffffff,ffffffff,ffffffff,ffffffff
0-127
cc1: warnings being treated as errors
arch/powerpc/platforms/pseries/dlpar.c: In function 'dlpar_attach_node':
arch/powerpc/platforms/pseries/dlpar.c:239: error: unused variable 'ent'
arch/powerpc/platforms/pseries/dlpar.c: In function 'dlpar_detach_node':
arch/powerpc/platforms/pseries/dlpar.c:271: error: unused variable 'prop'
arch/powerpc/platforms/pseries/dlpar.c:270: error: unused variable 'parent'
make[3]: *** [arch/powerpc/platforms/pseries/dlpar.o] Error 1
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Commit 57b150cce8e004ddd36330490a68bfb59b7271e9 (irq: only update affinity if
->set_affinity() is sucessfull) broke xics irq affinity.
We need to use the cpumask passed in, instead of accessing ->affinity directly.
It seems there is a thinko in the TLB invalidation code that makes the
tlbie in the loop executed just once. The intended check was probably
'gt', not 'lt'.
Various kernel asm modifies SRR0/SRR1 just before executing
a rfi. If such code crosses a page boundary you risk a TLB miss
which will clobber SRR0/SRR1. Avoid this by always pinning
kernel instruction TLB space.
Commit ac4c2a3bbe5db5fc570b1d0ee1e474db7cb22585 broke the build
of all powerpc boot wrappers.
It attempts to add an include of autoconf.h but used the wrong
path for it. It also adds -D__KERNEL__ to our boot wrapper, both
things that we pretty much didn't do on purpose so far.
We want our boot wrapper to remain independent enough of the kernel
for various reasons, one of them being that you can "wrap" an existing
kernel at distro install time which allows to ship one kernel image
and a set of boot wrappers for different platforms, the wrappers
don't have to be built out of the same kernel build tree.
It's also incorrect to do what the patch does in our boot environment
since we may not have a proper alignment exception handler which means
we may not be able to fixup the few cases where an unaligned access will
need SW emulation (depends on the core variant, could be when crossing
page or segment boundaries for example).
This patch fixes it by putting the old code back in and using the
new "fancy" variant only when CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS
is set, which happens not to be set on powerpc since we don't include
autoconf.h. It also reverts the changes to our boot wrapper Makefile.
This means that x86 should, afaik, keep the optimisations since its
boot wrapper does include autoconf.h and define __KERNEL__ (though I
doubt they make that much different outside of slow embedded processors).
JFFS2 uses lesser compression ratio and inflate always ends up in "copy
direct from output" case.
This patch tries to optimize the direct copy procedure. Uses
get_unaligned() but only in one place.
The copy loop just above this one can also use this optimization, but I
havn't done so as I have not tested if it is a win there too.
On my MPC8321 this is about 17% faster on my JFFS2 root FS than the
original.
Cc: Roel Kluin <roel.kluin@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Update the 40x defconfigs for 2.6.33
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Update the 44x defconfig files for 2.6.33
mkuboot.sh provides a basic wrapper for the 'mkimage' utility. Using
mkuboot.sh provides clearer error reporting and allows a toolchain to
use its own 'mkimage' executable specified by ${CROSS_COMPILE}mkimage.
Additionally, this brings PowerPC in line with other architectures
which already call mkimage via mkuboot.sh.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI/cardbus: Add a fixup hook and fix powerpc
PCI: change PCI nomenclature in drivers/pci/ (non-comment changes)
PCI: change PCI nomenclature in drivers/pci/ (comment changes)
PCI: fix section mismatch on update_res()
PCI: add Intel 82599 Virtual Function specific reset method
PCI: add Intel USB specific reset method
PCI: support device-specific reset methods
PCI: Handle case when no pci device can provide cache line size hint
PCI/PM: Propagate wake-up enable for PCIe devices too
vgaarbiter: fix a typo in the vgaarbiter Documentation
We were shifting the Ks/Kp/N bits one bit too far on mtsrin. It took
me some time to figure that out, so I also put in some debugging and a
comment explaining the conversion.
This fixes current OpenBIOS boot on PPC64 KVM.
Fix the following build failures:
arch/powerpc/platforms/embedded6xx/flipper-pic.c: In function 'flipper_pic_map':
arch/powerpc/platforms/embedded6xx/flipper-pic.c:105: error: implicit declaration of function 'get_irq_desc'
arch/powerpc/platforms/embedded6xx/hlwd-pic.c: In function 'hlwd_pic_map':
arch/powerpc/platforms/embedded6xx/hlwd-pic.c:98: error: implicit declaration of function 'get_irq_desc'
These failures are caused by the changes introduced in commit
"powerpc: Remove get_irq_desc()". The reason these drivers were not
updated is that they weren't merged yet.
Signed-off-by: Albert Herranz <albert_herranz@yahoo.es>
arch/powerpc/platforms/embedded6xx/hlwd-pic.c: In function 'hlwd_pic_irq_cascade':
arch/powerpc/platforms/embedded6xx/hlwd-pic.c:135: error: passing argument 1 of 'spin_lock' from incompatible pointer type
arch/powerpc/platforms/embedded6xx/hlwd-pic.c:137: error: passing argument 1 of 'spin_unlock' from incompatible pointer type
arch/powerpc/platforms/embedded6xx/hlwd-pic.c:145: error: passing argument 1 of 'spin_lock' from incompatible pointer type
arch/powerpc/platforms/embedded6xx/hlwd-pic.c:149: error: passing argument 1 of 'spin_unlock' from incompatible pointer type
"genirq: Convert irq_desc.lock to raw_spinlock". The reason this driver
was not updated is that it wasn't merged yet.
The retry logic in ug_putc() is broken.
If the TX fifo is not ready and the counter runs out it will have a
value of -1 and no transfer should be attempted. Also, a counter
with a value of 0 means that the TX fifo got ready in the last try
and the transfer should be attempted.
Reported-by: "Juha Leppanen" <juha_motorsportcom@luukku.com>
Signed-off-by: "Juha Leppanen" <juha_motorsportcom@luukku.com>
Since commit 57b150cce8e004ddd36330490a68bfb59b7271e9, desc->affinity
of an irq is changed after calling desc->chip->set_affinity.
Therefore we need to fix the irq_choose_cpu() not to depend on the
desc->affinity for new mask.
Signed-off-by: Jiajun Wu <b06378@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Commit d28513bc7f675d28b479db666d572e078ecf182d ("Fix bug in pagetable
cache cleanup with CONFIG_PPC_SUBPAGE_PROT"), itself a fix for
breakage caused by an earlier clean up patch of mine, contains a
stupid bug. I changed the parameters of the subpage_protection()
function, but failed to update one of the callers.
This patch fixes it, and replaces a void * with a typed pointer so
that the compiler will warn on such an error in future.
The _ONSTACK variant should be used for on-stack completion,
otherwise it will break lockdep.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
