path: root/arch/powerpc
2010-11-18Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdb,ppc: Fix regression in evr register handling kgdb,x86: fix regression in detach handling kdb: fix crash when KDB_BASE_CMD_MAX is exceeded kdb: fix memory leak in kdb_main.c
2010-11-18powerpc: Update a BKL related commentAlessio Igor Bogani
The commit 5e3d20a remove bkl from startup code so setup_arch() it isn't called with bkl held anymore. Update the comment on top of that function. Fix also a typo. This work was supported by a hardware donation from the CE Linux Forum. Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-18powerpc/mm: Fix module instruction tlb fault handling on Book-E 64Kumar Gala
We were seeing oops like the following when we did an rmmod on a module: Unable to handle kernel paging request for instruction fetch Faulting instruction address: 0x8000000000008010 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=2 P5020 DS last sysfs file: /sys/devices/qman-portals.2/qman-pool.9/uevent Modules linked in: qman_tester(-) NIP: 8000000000008010 LR: c000000000074858 CTR: 8000000000008010 REGS: c00000002e29bab0 TRAP: 0400 Not tainted (2.6.34.6-00744-g2d21f14) MSR: 0000000080029000 <EE,ME,CE> CR: 24000448 XER: 00000000 TASK = c00000007a8be600[4987] 'rmmod' THREAD: c00000002e298000 CPU: 1 GPR00: 8000000000008010 c00000002e29bd30 8000000000012798 c00000000035fb28 GPR04: 0000000000000002 0000000000000002 0000000024022428 c000000000009108 GPR08: fffffffffffffffe 800000000000a618 c0000000003c13c8 0000000000000000 GPR12: 0000000022000444 c00000000fffed00 0000000000000000 0000000000000000 GPR16: 00000000100c0000 0000000000000000 00000000100dabc8 0000000010099688 GPR20: 0000000000000000 00000000100cfc28 0000000000000000 0000000010011a44 GPR24: 00000000100017b2 0000000000000000 0000000000000000 0000000000000880 GPR28: c00000000035fb28 800000000000a7b8 c000000000376d80 c0000000003cce50 NIP [8000000000008010] .test_exit+0x0/0x10 [qman_tester] LR [c000000000074858] .SyS_delete_module+0x1f8/0x2f0 Call Trace: [c00000002e29bd30] [c0000000000748b4] .SyS_delete_module+0x254/0x2f0 (unreliable) [c00000002e29be30] [c000000000000580] syscall_exit+0x0/0x2c Instruction dump: XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX 38600000 4e800020 60000000 60000000 <4e800020> 60000000 60000000 60000000 ---[ end trace 4f57124939a84dc8 ]--- This appears to be due to checking the wrong permission bits in the instruction_tlb_miss handling if the address that faulted was in vmalloc space. We need to look at the supervisor execute (_PAGE_BAP_SX) bit and not the user bit (_PAGE_BAP_UX/_PAGE_EXEC). Also removed a branch level since it did not appear to be used. Reported-by: Jeffrey Ladouceur <Jeffrey.Ladouceur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-18powerpc: Fix call to subpage_protection()Michael Neuling
In: powerpc/mm: Fix pgtable cache cleanup with CONFIG_PPC_SUBPAGE_PROT commit d28513bc7f675d28b479db666d572e078ecf182d Author: David Gibson <david@gibson.dropbear.id.au> subpage_protection() was changed to to take an mm rather a pgdir but it didn't change calling site in hashpage_preload(). The change wasn't noticed at compile time since hashpage_preload() used a void* as the parameter to subpage_protection(). This is obviously wrong and can trigger the following crash when CONFIG_SLAB, CONFIG_DEBUG_SLAB, CONFIG_PPC_64K_PAGES CONFIG_PPC_SUBPAGE_PROT are enabled. Freeing unused kernel memory: 704k freed Unable to handle kernel paging request for data at address 0x6b6b6b6b6b6c49b7 Faulting instruction address: 0xc0000000000410f4 cpu 0x2: Vector: 300 (Data Access) at [c00000004233f590] pc: c0000000000410f4: .hash_preload+0x258/0x338 lr: c000000000041054: .hash_preload+0x1b8/0x338 sp: c00000004233f810 msr: 8000000000009032 dar: 6b6b6b6b6b6c49b7 dsisr: 40000000 current = 0xc00000007e2c0070 paca = 0xc000000007fe0500 pid = 1, comm = init enter ? for help [c00000004233f810] c000000000041020 .hash_preload+0x184/0x338 (unreliable) [c00000004233f8f0] c00000000003ed98 .update_mmu_cache+0xb0/0xd0 [c00000004233f990] c000000000157754 .__do_fault+0x48c/0x5dc [c00000004233faa0] c000000000158fd0 .handle_mm_fault+0x508/0xa8c [c00000004233fb90] c0000000006acdd4 .do_page_fault+0x428/0x6ac [c00000004233fe30] c000000000005260 handle_page_fault+0x20/0x74 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-18powerpc: Set CONFIG_32BIT on ppc32kerstin jonsson
commit ffe8018c3424892c9590048fc36caa6c3e0c8a76 of the -mm tree fixes the initramfs size calculation for e.g. s390 but breaks it for 32bit architectures which do not define CONFIG_32BIT. This patch fix the problem for PPC32 which will elsewise end up with a __initramfs_size of 0. Signed-off-by: Kerstin Jonsson <kerstin.jonsson@ericsson.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-18powerpc/mm: Fix build error in setup_initial_memory_limitKumar Gala
arch/powerpc/mm/tlb_nohash.c: In function 'setup_initial_memory_limit': arch/powerpc/mm/tlb_nohash.c:588:29: error: 'ppc64_memblock_base' undeclared (first use in this function) arch/powerpc/mm/tlb_nohash.c:588:29: note: each undeclared identifier is reported only once for each function it appears in Due to a copy/paste typo with the following commit: commit cd3db0c4ca3d237e7ad20f7107216e575705d2b0 Author: Benjamin Herrenschmidt <benh@kernel.crashing.org> Date: Tue Jul 6 15:39:02 2010 -0700 memblock: Remove rmo_size, burry it in arch/powerpc where it belongs Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-18powerpc/pseries: Don't override CONFIG_PPC_PSERIES_DEBUGNishanth Aravamudan
EEH and pci_dlpar #undef DEBUG, but I think they were added before the ability to control this from Kconfig. It's really annoying to only get some of the debug messages from these files. Leave the lpar.c #undef alone as it produces so much output as to make the kernel unusable. Update the Kconfig text to indicate this particular quirk :) Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-18powerpc: Fix div64 in bootloaderBenjamin Herrenschmidt
The code is missing a fix that went into the main kernel variant (we should try to share that code again at some stage) Reported-by: Albert Cahalan <acahalan@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-17kgdb,ppc: Fix regression in evr register handlingDongdong Deng
Commit ff10b88b5a05c8f1646dd15fb9f6093c1384ff6d (kgdb,ppc: Individual register get/set for ppc) introduced a problem where memcpy was used incorrectly to read and write the evr registers with a kernel that has: CONFIG_FSL_BOOKE=y CONFIG_SPE=y CONFIG_KGDB=y This patch also fixes the following compilation problems: arch/powerpc/kernel/kgdb.c: In function 'dbg_get_reg': arch/powerpc/kernel/kgdb.c:341: error: passing argument 2 of 'memcpy' makes pointer from integer without a cast arch/powerpc/kernel/kgdb.c: In function 'dbg_set_reg': arch/powerpc/kernel/kgdb.c:366: error: passing argument 1 of 'memcpy' makes pointer from integer without a cast [jason.wessel@windriver.com: Remove void * casts and fix patch header] Reported-by: Milton Miller <miltonm@bga.com> Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> CC: linuxppc-dev@lists.ozlabs.org
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-05KVM: PPC: BookE: Load the lower half of MSRScott Wood
This was preventing the guest from setting any bits in the hardware MSR which aren't forced on, such as MSR[SPE]. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-11-05KVM: PPC: BookE: fix sleep with interrupts disabledScott Wood
It is not legal to call mutex_lock() with interrupts disabled. This will assert with debug checks enabled. If there's a real need to disable interrupts here, it could be done after the mutex is acquired -- but I don't see why it's needed at all. Signed-off-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-11-05KVM: PPC: e500: Call kvm_vcpu_uninit() before kvmppc_e500_tlb_uninit().Scott Wood
The VCPU uninit calls some TLB functions, and the TLB uninit function frees the memory used by them. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-11-05PPC: KVM: Book E doesn't have __end_interrupts.Scott Wood
Fix an unresolved symbol with CONFIG_KVM_GUEST plus CONFIG_RELOCATABLE on Book E. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-11-05KVM: PPC: fix information leak to userlandVasiliy Kulikov
Structure kvm_ppc_pvinfo is copied to userland with flags and pad fields unitialized. It leads to leaking of contents of kernel stack memory. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-30Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (82 commits) mtd: fix build error in m25p80.c mtd: Remove redundant mutex from mtd_blkdevs.c MTD: Fix wrong check register_blkdev return value Revert "mtd: cleanup Kconfig dependencies" mtd: cfi_cmdset_0002: make sector erase command variable mtd: cfi_cmdset_0002: add CFI detection for SST 38VF640x chips mtd: cfi_util: add support for switching SST 39VF640xB chips into QRY mode mtd: cfi_cmdset_0001: use defined value of P_ID_INTEL_PERFORMANCE instead of hardcoded one block2mtd: dubious assignment P4080/mtd: Fix the freescale lbc issue with 36bit mode P4080/eLBC: Make Freescale elbc interrupt common to elbc devices mtd: phram: use KBUILD_MODNAME mtd: OneNAND: S5PC110: Fix double call suspend & resume function mtd: nand: fix MTD_MODE_RAW writes jffs2: use kmemdup mtd: sm_ftl: cosmetic, use bool when possible mtd: r852: remove useless pci powerup/down from suspend/resume routines mtd: blktrans: fix a race vs kthread_stop mtd: blktrans: kill BKL mtd: allow to unload the mtdtrans module if its block devices aren't open ... Fix up trivial whitespace-introduced conflict in drivers/mtd/mtdchar.c
2010-10-30Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git Conflicts: drivers/mtd/mtd_blkdevs.c Merge Grant's device-tree bits so that we can apply the subsequent fixes. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-29Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdb,ppc: Individual register get/set for ppc kgdbts: prevent re-entry to kgdbts before it unregisters debug_core,x86,blackfin: Clean up hw debug disable API kdb: Fix early debugging crash regression kgdb,arm: fix register dump kdb: fix per_cpu command to remove supress mask kdb: Add kdb kernel module sample
2010-10-29kgdb,ppc: Individual register get/set for ppcDongdong Deng
commit 534af1082329392bc29f6badf815e69ae2ae0f4c(kgdb,kdb: individual register set and and get API) introduce dbg_get_reg/dbg_set_reg API for individual register get and set. This patch implement those APIs for ppc. Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-29convert get_sb_single() usersAl Viro
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (48 commits) DMAENGINE: move COH901318 to arch_initcall dma: imx-dma: fix signedness bug dma/timberdale: simplify conditional ste_dma40: remove channel_type ste_dma40: remove enum for endianess ste_dma40: remove TIM_FOR_LINK option ste_dma40: move mode_opt to separate config ste_dma40: move channel mode to a separate field ste_dma40: move priority to separate field ste_dma40: add variable to indicate valid dma_cfg async_tx: make async_tx channel switching opt-in move async raid6 test to lib/Kconfig.debug dmaengine: Add Freescale i.MX1/21/27 DMA driver intel_mid_dma: change the slave interface intel_mid_dma: fix the WARN_ONs intel_mid_dma: Add sg list support to DMA driver intel_mid_dma: Allow DMAC2 to share interrupt intel_mid_dma: Allow IRQ sharing intel_mid_dma: Add runtime PM support DMAENGINE: define a dummy filter function for ste_dma40 ...
2010-10-27taskstats: use real microsecond granularity for CPU timesMichael Holzheu
The taskstats interface uses microsecond granularity for the user and system time values. The conversion from cputime to the taskstats values uses the cputime_to_msecs primitive which effectively limits the granularity to milliseconds. Add the cputime_to_usecs primitive for architectures that have better, more precise CPU time values. Remove cputime_to_msecs primitive because there are no more users left. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Luck Tony <tony.luck@intel.com> Cc: Shailabh Nagar <nagar1234@in.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Shailabh Nagar <nagar@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: add handling of redundant routesAlexandre Bounine
Detects RIO link to the already enumerated device and properly sets links between device objects. Changes to the enumeration/discovery logic: 1. Use Master Enable bit to signal end of the enumeration - agents may start their discovery process as soon as they see this bit set (Component Tag register was used before for this purpose). 2. Enumerator sets Component Tag (!= 0) immediately during device setup. This allows to identify the device if the redundant route exists in a RIO system. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio:powerpc/85xx: modify RIO port-write interrupt handlerAlexandre Bounine
- Rearrange RIO port-write interrupt handling to perform message buffering as soon as possible. - Modify to disable port-write controller when clearing Transaction Error (TE) bit. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: cleanup arch_ptrace() on powerpcNamhyung Kim
Use new 'datavp' and 'datalp' variables in order to remove unnecessary castings. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27mm: fix race in kunmap_atomic()Peter Zijlstra
Christoph reported a nice splat which illustrated a race in the new stack based kmap_atomic implementation. The problem is that we pop our stack slot before we're completely done resetting its state -- in particular clearing the PTE (sometimes that's CONFIG_DEBUG_HIGHMEM). If an interrupt happens before we actually clear the PTE used for the last slot, that interrupt can reuse the slot in a dirty state, which triggers a BUG in kmap_atomic(). Fix this by introducing kmap_atomic_idx() which reports the current slot index without actually releasing it and use that to find the PTE and delay the _pop() until after we're completely done. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Christoph Hellwig <hch@infradead.org> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26replace nested max/min macros with {max,min}3 macroHagen Paul Pfeifer
Use the new {max,min}3 macros to save some cycles and bytes on the stack. This patch substitutes trivial nested macros with their counterpart. Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Cc: Joe Perches <joe@perches.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: remove pte_*map_nested()Peter Zijlstra
Since we no longer need to provide KM_type, the whole pte_*map_nested() API is now redundant, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: stack based kmap_atomic()Peter Zijlstra
Keep the current interface but ignore the KM_type and use a stack based approach. The advantage is that we get rid of crappy code like: #define __KM_PTE \ (in_nmi() ? KM_NMI_PTE : \ in_irq() ? KM_IRQ_PTE : \ KM_PTE0) and in general can stop worrying about what context we're in and what kmap slots might be appropriate for that. The downside is that FRV kmap_atomic() gets more expensive. For now we use a CPP trick suggested by Andrew: #define kmap_atomic(page, args...) __kmap_atomic(page) to avoid having to touch all kmap_atomic() users in a single patch. [ not compiled on: - mn10300: the arch doesn't actually build with highmem to begin with ] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-25Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mtd/m25p80: add support to parse the partitions by OF node of/irq: of_irq.c needs to include linux/irq.h of/mips: Cleanup some include directives/files. of/mips: Add device tree support to MIPS of/flattree: Eliminate need to provide early_init_dt_scan_chosen_arch of/device: Rework to use common platform_device_alloc() for allocating devices of/xsysace: Fix OF probing on little-endian systems of: use __be32 types for big-endian device tree data of/irq: remove references to NO_IRQ in drivers/of/platform.c of/promtree: add package-to-path support to pdt of/promtree: add of_pdt namespace to pdt code of/promtree: no longer call prom_ functions directly; use an ops structure of/promtree: make drivers/of/pdt.c no longer sparc-only sparc: break out some PROM device-tree building code out into drivers/of of/sparc: convert various prom_* functions to use phandle sparc: stop exporting openprom.h header powerpc, of_serial: Endianness issues setting up the serial ports of: MTD: Fix OF probing on little-endian systems of: GPIO: Fix OF probing on little-endian systems
2010-10-25P4080/mtd: Fix the freescale lbc issue with 36bit modeLan Chunhe-B25806
When system uses 36bit physical address, res.start is 36bit physical address. But the function of in_be32 returns 32bit physical address. Then both of them compared each other is wrong. So by converting the address of res.start into the right format fixes this issue. Signed-off-by: Lan Chunhe-B25806 <b25806@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-25P4080/eLBC: Make Freescale elbc interrupt common to elbc devicesRoy Zang
Move Freescale elbc interrupt from nand driver to elbc driver. Then all elbc devices can use the interrupt instead of ONLY nand. For former nand driver, it had the two functions: 1. detecting nand flash partitions; 2. registering elbc interrupt. Now, second function is removed to fsl_lbc.c. Signed-off-by: Lan Chunhe-B25806 <b25806@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com> Cc: Wood Scott-B07421 <B07421@freescale.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-25Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: arch/powerpc/platforms/85xx/p1022_ds.c
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-24Merge branch 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (321 commits) KVM: Drop CONFIG_DMAR dependency around kvm_iommu_map_pages KVM: Fix signature of kvm_iommu_map_pages stub KVM: MCE: Send SRAR SIGBUS directly KVM: MCE: Add MCG_SER_P into KVM_MCE_CAP_SUPPORTED KVM: fix typo in copyright notice KVM: Disable interrupts around get_kernel_ns() KVM: MMU: Avoid sign extension in mmu_alloc_direct_roots() pae root address KVM: MMU: move access code parsing to FNAME(walk_addr) function KVM: MMU: audit: check whether have unsync sps after root sync KVM: MMU: audit: introduce audit_printk to cleanup audit code KVM: MMU: audit: unregister audit tracepoints before module unloaded KVM: MMU: audit: fix vcpu's spte walking KVM: MMU: set access bit for direct mapping KVM: MMU: cleanup for error mask set while walk guest page table KVM: MMU: update 'root_hpa' out of loop in PAE shadow path KVM: x86 emulator: Eliminate compilation warning in x86_decode_insn() KVM: x86: Fix constant type in kvm_get_time_scale KVM: VMX: Add AX to list of registers clobbered by guest switch KVM guest: Move a printk that's using the clock before it's ready KVM: x86: TSC catchup mode ...
2010-10-24KVM: PPC: Move of include to __KERNEL__ sectionAlexander Graf
We have to protect the include for linux/of.h by __KERNEL__ so it doesn't accidently get referenced outside. This patch fixes this and makes the tree compile again. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Fix compile error in e500_tlb.cAlexander Graf
The e500_tlb.c file didn't compile for me due to the following error: arch/powerpc/kvm/e500_tlb.c: In function ‘kvmppc_e500_shadow_map’: arch/powerpc/kvm/e500_tlb.c:300: error: format ‘%lx’ expects type ‘long unsigned int’, but argument 2 has type ‘gfn_t’ So let's explicitly cast the argument to make printk happy. Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: e500_tlb: Fix a minor copy-paste tracing bugKyle Moffett
The kvmppc_e500_stlbe_invalidate() function was trying to pass too many parameters to trace_kvm_stlb_inval(). This appears to be a bad copy-paste from a call to trace_kvm_stlb_write(). Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Implement level interrupts for BookEAlexander Graf
BookE also wants to support level based interrupts, so let's implement all the necessary logic there. We need to trick a bit here because the irqprios are 1:1 assigned to architecture defined values. But since there is some space left there, we can just pick a random one and move it later on - it's internal anyways. Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Expose level based interrupt capAlexander Graf
Now that we have all the level interrupt magic in place, let's expose the capability to user space, so it can make use of it! Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Implement Level interrupts on Book3SAlexander Graf
The current interrupt logic is just completely broken. We get a notification from user space, telling us that an interrupt is there. But then user space expects us that we just acknowledge an interrupt once we deliver it to the guest. This is not how real hardware works though. On real hardware, the interrupt controller pulls the external interrupt line until it gets notified that the interrupt was received. So in reality we have two events: pulling and letting go of the interrupt line. To maintain backwards compatibility, I added a new request for the pulling part. The letting go part was implemented earlier already. With this in place, we can now finally start guests that do not randomly stall and stop to work at random times. This patch implements above logic for Book3S. Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Enable napping only for Book3s_64Alexander Graf
Before I incorrectly enabled napping also for BookE, which would result in needless dcache flushes. Since we only need to force enable napping on Book3s_64 because it doesn't go into MSR_POW otherwise, we can just #ifdef that code to this particular platform. Reported-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: allow ppc440gp to pass the compatibility checkHollis Blanchard
Match only the first part of cur_cpu_spec->platform. 440GP (the first 440 processor) is identified by the string "ppc440gp", while all later 440 processors use simply "ppc440". Signed-off-by: Hollis Blanchard <hollis_blanchard@mentor.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: fix compilation of "dump tlbs" debug functionHollis Blanchard
Missing local variable. Signed-off-by: Hollis Blanchard <hollis_blanchard@mentor.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: initialize IVORs in addition to IVPRHollis Blanchard
Developers can now tell at a glace the exact type of the premature interrupt, instead of just knowing that there was some premature interrupt. Signed-off-by: Hollis Blanchard <hollis_blanchard@mentor.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Don't put MSR_POW in MSRAlexander Graf
On Book3S a mtmsr with the MSR_POW bit set indicates that the OS is in idle and only needs to be waked up on the next interrupt. Now, unfortunately we let that bit slip into the stored MSR value which is not what the real CPU does, so that we ended up executing code like this: r = mfmsr(); /* r containts MSR_POW */ mtmsr(r | MSR_EE); This obviously breaks, as we're going into idle mode in code sections that don't expect to be idling. This patch masks MSR_POW out of the stored MSR value on wakeup, making guests happy again. Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Implement correct SID mapping on Book3s_32Alexander Graf
Up until now we were doing segment mappings wrong on Book3s_32. For Book3s_64 we were using a trick where we know that a single mmu_context gives us 16 bits of context ids. The mm system on Book3s_32 instead uses a clever algorithm to distribute VSIDs across the available range, so a context id really only gives us 16 available VSIDs. To keep at least a few guest processes in the SID shadow, let's map a number of contexts that we can use as VSID pool. This makes the code be actually correct and shouldn't hurt performance too much. Signed-off-by: Alexander Graf <agraf@suse.de>
