commit 7f8998c7aef3ac9c5f3f2943e083dfa6302e90d0 upstream.
The different architectures used their own (and different) declarations:
extern __visible const void __nosave_begin, __nosave_end;
extern const void __nosave_begin, __nosave_end;
extern long __nosave_begin, __nosave_end;
Consolidate them using the first variant in <asm/sections.h>.
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
commit 7261b956b276aa97fbf60d00f1d7717d2ea6ee78 upstream.
The patch to add it_page_shift incorrectly changed the increment of
uaddr to use it_page_shift, rather then (1 << it_page_shift).
This broke booting on at least some Cell blades, as the iommu was
basically non-functional.
Fixes: 3a553170d35d ("powerpc/iommu: Add it_page_shift field to determine iommu page size")
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
commit f7e9e358362557c3aa2c1ec47490f29fe880a09e upstream.
This problem appears to have been introduced in 2.6.29 by commit
93197a36a9c1 "Rewrite sysfs processor cache info code".
This caused lscpu to error out on at least e500v2 devices, eg:
error: cannot open /sys/devices/system/cpu/cpu0/cache/index2/size: No such file or directory
Some embedded powerpc systems use cache-size in DTS for the unified L2
cache size, not d-cache-size, so we need to allow for both DTS names.
Added a new CACHE_TYPE_UNIFIED_D cache_type_info structure to handle
this.
Fixes: 93197a36a9c1 ("powerpc: Rewrite sysfs processor cache info code")
Signed-off-by: Dave Olson <olson@cumulusnetworks.com>
commit 9a5cbce421a283e6aea3c4007f141735bf9da8c3 upstream.
We cap 32bit userspace backtraces to PERF_MAX_STACK_DEPTH
(currently 127), but we forgot to do the same for 64bit backtraces.
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
Cc: stable@vger.kernel.org
[shengyong: Backport to 3.14
- adjust context
- ignore modification for arch nios2, because 3.14 does not support it
- add SIGSEGV handling to powerpc/cell spu_fault.c, because 3.14 does not
separate it to copro_fault.c
- add SIGSEGV handling to mm/memory.c, because 3.14 does not separate it
to gup.c
Signed-off-by: Sheng Yong <shengyong1@huawei.com>
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
move d_rcu from overlapping d_child to overlapping d_alias
Cc: Ben Hutchings <ben@decadent.org.uk>
[hujianyang: Backported to 3.14 refer to the work of Ben Hutchings in 3.2:
- Apply name changes in all the different places we use d_alias and d_child
- Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()]
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit bb344ca5b90df62b1a3b7a35c6a9d00b306a170d upstream.
Commit 746c9e9f92dd "of/base: Fix PowerPC address parsing hack" limited
the applicability of the workaround whereby a missing ranges is treated
as an empty ranges. This workaround was hiding a bug in the etsec2
device tree nodes, which have children with reg, but did not have
ranges.
Reported-by: Alexander Graf <agraf@suse.de>
commit f6ff04149637723261aa4738958b0098b929ee9e upstream.
We currently use the device tree update code in the kernel after resuming
from a suspend operation to re-sync the kernels view of the device tree with
that of the hypervisor. The code as it stands is not endian safe as it relies
on parsing buffers returned by RTAS calls that thusly contains data in big
endian format.
This patch annotates variables and structure members with __be types as well
as performing necessary byte swaps to cpu endian for data that needs to be
parsed.
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: Cyril Bur <cyrilbur@gmail.com>
commit 44d5f6f5901e996744858c175baee320ccf1eda3 upstream.
commit id 2ba9f0d has changed CONFIG_KVM_BOOK3S_64_HV to tristate to allow
HV/PR bits to be built as modules. But the MCE code still depends on
CONFIG_KVM_BOOK3S_64_HV which is wrong. When user selects
CONFIG_KVM_BOOK3S_64_HV=m to build HV/PR bits as a separate module the
relevant MCE code gets excluded.
This patch fixes the MCE code to use CONFIG_KVM_BOOK3S_64_HANDLER. This
makes sure that the relevant MCE code is included when HV/PR bits
are built as a separate modules.
Fixes: 2ba9f0d88750 ("kvm: powerpc: book3s: Support building HV and PR KVM as module")
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
Acked-by: Paul Mackerras <paulus@samba.org>
commit 91117a20245b59f70b563523edbf998a62fc6383 upstream.
The 'pfn' returned by axonram was completely bogus, and has been since
2008.
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit e6eb2eba494d6f99e69ca3c3748cd37a2544ab38 upstream.
The commit 3b8a3c010969 ("powerpc/pseries: Fix endiannes issue in RTAS
call from xmon") was fixing an endianness issue in the call made from
xmon to RTAS.
However, as Michael Ellerman noticed, this fix was not complete, the
token value was not byte swapped. This lead to call an unexpected and
most of the time unexisting RTAS function, which is silently ignored by
RTAS.
This fix addresses this hole.
Reported-by: Michael Ellerman <mpe@ellerman.id.au>
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
commit 3e14dcf7cb80b34a1f38b55bc96f02d23fdaaaaf upstream.
Commit 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
changed the automatic module loading when requesting crypto algorithms
to prefix all module requests with "crypto-". This requires all crypto
modules to have a crypto specific module alias even if their file name
would otherwise match the requested crypto algorithm.
Even though commit 5d26a105b5a7 added those aliases for a vast amount of
modules, it was missing a few. Add the required MODULE_ALIAS_CRYPTO
annotations to those files to make them get loaded automatically, again.
This fixes, e.g., requesting 'ecb(blowfish-generic)', which used to work
with kernels v3.18 and below.
Also change MODULE_ALIAS() lines to MODULE_ALIAS_CRYPTO(). The former
won't work for crypto modules any more.
Fixes: 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 682e77c861c4c60f79ffbeae5e1938ffed24a575 upstream.
The existing MCE code calls flush_tlb hook with IS=0 (single page) resulting
in partial invalidation of TLBs which is not right. This patch fixes
that by passing IS=0xc00 to invalidate whole TLB for successful recovery
from TLB and ERAT errors.
commit cd32e2dcc9de6c27ecbbfc0e2079fb64b42bad5f upstream.
We have some code in udbg_uart_getc_poll() that tries to protect
against a NULL udbg_uart_in, but gets it all wrong.
Found with the LLVM static analyzer (scan-build).
Fixes: 309257484cc1 ("powerpc: Cleanup udbg_16550 and add support for LPC PIO-only UARTs")
[mpe: Add some newlines for readability while we're here]
commit 152d44a853e42952f6c8a504fb1f8eefd21fd5fd upstream.
I used some 64 bit instructions when adding the 32 bit getcpu VDSO
function. Fix it.
Fixes: 18ad51dd342a ("powerpc: Add VDSO version of getcpu")
commit 360743814c4082515581aa23ab1d8e699e1fbe88 upstream.
Instead of the arch specific quirk which we are deprecating
and that drivers don't understand.
commit 3b8a3c01096925a824ed3272601082289d9c23a5 upstream.
On pseries system (LPAR) xmon failed to enter when running in LE mode,
system is hunging. Inititating xmon will lead to such an output on the
console:
SysRq : Entering xmon
cpu 0x15: Vector: 0 at [c0000003f39ffb10]
pc: c00000000007ed7c: sysrq_handle_xmon+0x5c/0x70
lr: c00000000007ed7c: sysrq_handle_xmon+0x5c/0x70
sp: c0000003f39ffc70
msr: 8000000000009033
current = 0xc0000003fafa7180
paca = 0xc000000007d75e80 softe: 0 irq_happened: 0x01
pid = 14617, comm = bash
Bad kernel stack pointer fafb4b0 at eca7cc4
cpu 0x15: Vector: 300 (Data Access) at [c000000007f07d40]
pc: 000000000eca7cc4
lr: 000000000eca7c44
sp: fafb4b0
msr: 8000000000001000
dar: 10000000
dsisr: 42000000
cpu 0x15: Exception 300 (Data Access) in xmon, returning to main loop
xmon: WARNING: bad recursive fault on cpu 0x15
The root cause is that xmon is calling RTAS to turn off the surveillance
when entering xmon, and RTAS is requiring big endian parameters.
This patch is byte swapping the RTAS arguments when running in LE mode.
commit 415072a041bf50dbd6d56934ffc0cbbe14c97be8 upstream.
commit 10ccaf178b2b961d8bca252d647ed7ed8aae2a20 upstream.
In powerpc pseries platform dlpar operations, use device_online() and
device_offline() instead of cpu_up() and cpu_down().
Calling cpu_up/down() directly does not update the cpu device offline
field, which is used to online/offline a cpu from sysfs. Calling
device_online/offline() instead keeps the sysfs cpu online value
correct. The hotplug lock, which is required to be held when calling
device_online/offline(), is already held when dlpar_online/offline_cpu()
are called, since they are called only from cpu_probe|release_store().
This patch fixes errors on phyp (PowerVM) systems that have cpu(s)
added/removed using dlpar operations; without this patch, the
/sys/devices/system/cpu/cpuN/online nodes do not correctly show the
online state of added/removed cpus.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Fixes: 0902a9044fa5 ("Driver core: Use generic offline/online for CPU offline/online")
commit 9410e0185e65394c0c6d046033904b53b97a9423 upstream.
rtas_call() accepts and returns values in CPU endianness.
The ddw_query_response and ddw_create_response structs members are
defined and treated as BE but as they are passed to rtas_call() as
(u32 *) and they get byteswapped automatically, the data is CPU-endian.
This fixes ddw_query_response and ddw_create_response definitions and use.
of_read_number() is designed to work with device tree cells - it assumes
the input is big-endian and returns data in CPU-endian. However due
to the ddw_create_response struct fix, create.addr_hi/lo are already
CPU-endian so do not byteswap them.
ddw_avail is a pointer to the "ibm,ddw-applicable" property which contains
3 cells which are big-endian as it is a device tree. rtas_call() accepts
a RTAS token in CPU-endian. This makes use of of_property_read_u32_array
to byte swap and avoid the need for a number of be32_to_cpu calls.
[aik: folded Anton's patch with of_property_read_u32_array]
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Acked-by: Anton Blanchard <anton@samba.org>
commit 78e05b1421fa41ae8457701140933baa5e7d9479 upstream.
Similar to the previous commit which described why we need to add a
barrier to arch_spin_is_locked(), we have a similar problem with
spin_unlock_wait().
We need a barrier on entry to ensure any spinlock we have previously
taken is visibly locked prior to the load of lock->slock.
It's also not clear if spin_unlock_wait() is intended to have ACQUIRE
semantics. For now be conservative and add a barrier on exit to give it
ACQUIRE semantics.
commit 51d7d5205d3389a32859f9939f1093f267409929 upstream.
The kernel defines the function spin_is_locked(), which can be used to
check if a spinlock is currently locked.
Using spin_is_locked() on a lock you don't hold is obviously racy. That
is, even though you may observe that the lock is unlocked, it may become
locked at any time.
There is (at least) one exception to that, which is if two locks are
used as a pair, and the holder of each checks the status of the other
before doing any update.
Assuming *A and *B are two locks, and *COUNTER is a shared non-atomic
value:
The first CPU does:
spin_lock(*A)
if spin_is_locked(*B)
# nothing
else
smp_mb()
LOAD r = *COUNTER
r++
STORE *COUNTER = r
spin_unlock(*A)
And the second CPU does:
spin_lock(*B)
if spin_is_locked(*A)
# nothing
else
smp_mb()
LOAD r = *COUNTER
r++
STORE *COUNTER = r
spin_unlock(*B)
Although this is a strange locking construct, it should work.
It seems to be understood, but not documented, that spin_is_locked() is
not a memory barrier, so in the examples above and below the caller
inserts its own memory barrier before acting on the result of
spin_is_locked().
For now we assume spin_is_locked() is implemented as below, and we break
it out in our examples:
bool spin_is_locked(*LOCK) {
LOAD l = *LOCK
return l.locked
Our intuition is that there should be no problem even if the two code
sequences run simultaneously such as:
CPU 0 CPU 1
spin_lock(*A) spin_lock(*B)
LOAD b = *B LOAD a = *A
if b.locked # true if a.locked # true
# nothing # nothing
spin_unlock(*A) spin_unlock(*B)
If one CPU gets the lock before the other then it will do the update and
the other CPU will back off:
CPU 0 CPU 1
spin_lock(*A)
LOAD b = *B
spin_lock(*B)
if b.locked # false LOAD a = *A
else if a.locked # true
smp_mb() # nothing
LOAD r1 = *COUNTER spin_unlock(*B)
r1++
STORE *COUNTER = r1
spin_unlock(*A)
However in reality spin_lock() itself is not indivisible. On powerpc we
implement it as a load-and-reserve and store-conditional.
Ignoring the retry logic for the lost reservation case, it boils down to:
spin_lock(*LOCK) {
LOAD l = *LOCK
l.locked = true
STORE *LOCK = l
ACQUIRE_BARRIER
The ACQUIRE_BARRIER is required to give spin_lock() ACQUIRE semantics as
defined in memory-barriers.txt:
This acts as a one-way permeable barrier. It guarantees that all
memory operations after the ACQUIRE operation will appear to happen
after the ACQUIRE operation with respect to the other components of
the system.
On modern powerpc systems we use lwsync for ACQUIRE_BARRIER. lwsync is
also know as "lightweight sync", or "sync 1".
As described in Power ISA v2.07 section B.2.1.1, in this scenario the
lwsync is not the barrier itself. It instead causes the LOAD of *LOCK to
act as the barrier, preventing any loads or stores in the locked region
from occurring prior to the load of *LOCK.
Whether this behaviour is in accordance with the definition of ACQUIRE
semantics in memory-barriers.txt is open to discussion, we may switch to
a different barrier in future.
What this means in practice is that the following can occur:
CPU 0 CPU 1
LOAD a = *A LOAD b = *B
a.locked = true b.locked = true
STORE *A = a STORE *B = b
if b.locked # false if a.locked # false
else else
smp_mb() smp_mb()
LOAD r1 = *COUNTER LOAD r2 = *COUNTER
r1++ r2++
STORE *COUNTER = r1
STORE *COUNTER = r2 # Lost update
That is, the load of *B can occur prior to the store that makes *A
visibly locked. And similarly for CPU 1. The result is both CPUs hold
their lock and believe the other lock is unlocked.
The easiest fix for this is to add a full memory barrier to the start of
spin_is_locked(), so adding to our previous definition would give us:
smp_mb()
LOAD l = *LOCK
return l.locked
The new barrier orders the store to the lock we are locking vs the load
of the other lock:
CPU 0 CPU 1
smp_mb() smp_mb()
# nothing # nothing
Although the above example is theoretical, there is code similar to this
example in sem_lock() in ipc/sem.c. This commit in addition to the next
commit appears to be a fix for crashes we are seeing in that code where
we believe this race happens in practice.
commit 85101af13bb854a6572fa540df7c7201958624b9 upstream.
ABIv2 kernels are failing to backtrace through the kernel. An example:
39.30% readseek2_proce [kernel.kallsyms] [k] find_get_entry
--- find_get_entry
__GI___libc_read
The problem is in valid_next_sp() where we check that the new stack
pointer is at least STACK_FRAME_OVERHEAD below the previous one.
ABIv1 has a minimum stack frame size of 112 bytes consisting of 48 bytes
and 64 bytes of parameter save area. ABIv2 changes that to 32 bytes
with no paramter save area.
STACK_FRAME_OVERHEAD is in theory the minimum stack frame size,
but we over 240 uses of it, some of which assume that it includes
space for the parameter area.
We need to work through all our stack defines and rationalise them
but let's fix perf now by creating STACK_FRAME_MIN_SIZE and using
in valid_next_sp(). This fixes the issue:
30.64% readseek2_proce [kernel.kallsyms] [k] find_get_entry
--- find_get_entry
pagecache_get_page
generic_file_read_iter
new_sync_read
vfs_read
sys_read
syscall_exit
__GI___libc_read
Reported-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 7e467245bf5226db34c4b12d3cbacfa2f7a15a8b upstream.
We would get wrong results in compiler recomputed old_pmd. Avoid
that by using ACCESS_ONCE
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 969b7b208f7408712a3526856e4ae60ad13f6928 upstream.
As per ISA, for 4k base page size we compare 14..65 bits of VA specified
with the entry_VA in tlb. That implies we need to make sure we do a
tlbie with all the possible 4k va we used to access the 16MB hugepage.
With 64k base page size we compare 14..57 bits of VA. Hence we cannot
ignore the lower 24 bits of va while tlbie .We also cannot tlb
invalidate a 16MB entry with just one tlbie instruction because
we don't track which va was used to instantiate the tlb entry.
commit fc0479557572375100ef16c71170b29a98e0d69a upstream.
If we changed base page size of the segment, either via sub_page_protect
or via remap_4k_pfn, we do a demote_segment which doesn't flush the hash
table entries. We do a lazy hash page table flush for all mapped pages
in the demoted segment. This happens when we handle hash page fault for
these pages.
We use _PAGE_COMBO bit along with _PAGE_HASHPTE to indicate whether a
pte is backed by 4K hash pte. If we find _PAGE_COMBO not set on the pte,
that implies that we could possibly have older 64K hash pte entries in
the hash page table and we need to invalidate those entries.
Use _PAGE_COMBO to determine the page size with which we should
invalidate the hash table entries on unmap.
commit 629149fae478f0ac6bf705a535708b192e9c6b59 upstream.
for these pages.
Handle this correctly for 16M pages
commit fa1f8ae80f8bb996594167ff4750a0b0a5a5bb5d upstream.
The segment identifier and segment size will remain the same in
the loop, So we can compute it outside. We also change the
hugepage_invalidate interface so that we can use it the later patch
commit b0aa44a3dfae3d8f45bd1264349aa87f87b7774f upstream.
With hugepages, we store the hpte valid information in the pte page
whose address is stored in the second half of the PMD. Use a
write barrier to make sure clearing pmd busy bit and updating
hpte valid info are ordered properly.
commit 5efbabe09d986f25c02d19954660238fcd7f008a upstream.
Function remove_ddw() could be called in of_reconfig_notifier and
we potentially remove the dynamic DMA window property, which invokes
of_reconfig_notifier again. Eventually, it leads to the deadlock as
following backtrace shows.
The patch fixes the above issue by deferring releasing the dynamic
DMA window property while releasing the device node.
[ INFO: possible recursive locking detected ]
3.16.0+ #428 Tainted: G W
drmgr/2273 is trying to acquire lock:
((of_reconfig_chain).rwsem){.+.+..}, at: [<c000000000091890>] \
.__blocking_notifier_call_chain+0x40/0x78
but task is already holding lock:
Possible unsafe locking scenario:
CPU0
lock((of_reconfig_chain).rwsem);
*** DEADLOCK ***
May be due to missing lock nesting notation
2 locks held by drmgr/2273:
#0: (sb_writers#4){.+.+.+}, at: [<c0000000001cbe70>] \
.vfs_write+0xb0/0x1f8
#1: ((of_reconfig_chain).rwsem){.+.+..}, at: [<c000000000091890>] \
stack backtrace:
CPU: 17 PID: 2273 Comm: drmgr Tainted: G W 3.16.0+ #428
Call Trace:
[c0000000137e7000] [c000000000013d9c] .show_stack+0x88/0x148 (unreliable)
[c0000000137e70b0] [c00000000083cd34] .dump_stack+0x7c/0x9c
[c0000000137e7130] [c0000000000b8afc] .__lock_acquire+0x128c/0x1c68
[c0000000137e7280] [c0000000000b9a4c] .lock_acquire+0xe8/0x104
[c0000000137e7350] [c00000000083588c] .down_read+0x4c/0x90
[c0000000137e73e0] [c000000000091890] .__blocking_notifier_call_chain+0x40/0x78
[c0000000137e7490] [c000000000091900] .blocking_notifier_call_chain+0x38/0x48
[c0000000137e7520] [c000000000682a28] .of_reconfig_notify+0x34/0x5c
[c0000000137e75b0] [c000000000682a9c] .of_property_notify+0x4c/0x54
[c0000000137e7650] [c000000000682bf0] .of_remove_property+0x30/0xd4
[c0000000137e76f0] [c000000000052a44] .remove_ddw+0x144/0x168
[c0000000137e7790] [c000000000053204] .iommu_reconfig_notifier+0x30/0xe0
[c0000000137e7820] [c00000000009137c] .notifier_call_chain+0x6c/0xb4
[c0000000137e78c0] [c0000000000918ac] .__blocking_notifier_call_chain+0x5c/0x78
[c0000000137e7970] [c000000000091900] .blocking_notifier_call_chain+0x38/0x48
[c0000000137e7a00] [c000000000682a28] .of_reconfig_notify+0x34/0x5c
[c0000000137e7a90] [c000000000682e14] .of_detach_node+0x44/0x1fc
[c0000000137e7b40] [c0000000000518e4] .ofdt_write+0x3ac/0x688
[c0000000137e7c20] [c000000000238430] .proc_reg_write+0xb8/0xd4
[c0000000137e7cd0] [c0000000001cbeac] .vfs_write+0xec/0x1f8
[c0000000137e7d70] [c0000000001cc3b0] .SyS_write+0x58/0xa0
[c0000000137e7e30] [c00000000000a064] syscall_exit+0x0/0x98
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
commit f1b3929c232784580e5d8ee324b6bc634e709575 upstream.
While running command "drmgr -c phb -r -s 'PHB 528'", following
backtrace jumped out because the target device node isn't marked
with OF_DETACHED by of_detach_node(), which caused by error
returned from memory hotplug related reconfig notifier when
disabling CONFIG_MEMORY_HOTREMOVE. The patch fixes it.
ERROR: Bad of_node_put() on /pci@800000020000210/ethernet@0
CPU: 14 PID: 2252 Comm: drmgr Tainted: G W 3.16.0+ #427
Call Trace:
[c000000012a776a0] [c000000000013d9c] .show_stack+0x88/0x148 (unreliable)
[c000000012a77750] [c00000000083cd34] .dump_stack+0x7c/0x9c
[c000000012a777d0] [c0000000006807c4] .of_node_release+0x58/0xe0
[c000000012a77860] [c00000000038a7d0] .kobject_release+0x174/0x1b8
[c000000012a77900] [c00000000038a884] .kobject_put+0x70/0x78
[c000000012a77980] [c000000000681680] .of_node_put+0x28/0x34
[c000000012a77a00] [c000000000681ea8] .__of_get_next_child+0x64/0x70
[c000000012a77a90] [c000000000682138] .of_find_node_by_path+0x1b8/0x20c
[c000000012a77b40] [c000000000051840] .ofdt_write+0x308/0x688
[c000000012a77c20] [c000000000238430] .proc_reg_write+0xb8/0xd4
[c000000012a77cd0] [c0000000001cbeac] .vfs_write+0xec/0x1f8
[c000000012a77d70] [c0000000001cc3b0] .SyS_write+0x58/0xa0
[c000000012a77e30] [c00000000000a064] syscall_exit+0x0/0x98
commit 85c1fafd7262e68ad821ee1808686b1392b1167d upstream.
On ppc64 we support 4K hash pte with 64K page size. That requires
us to track the hash pte slot information on a per 4k basis. We do that
by storing the slot details in the second half of pte page. The pte bit
_PAGE_COMBO is used to indicate whether the second half need to be
looked while building real_pte. We need to use read memory barrier while
doing that so that load of hidx is not reordered w.r.t _PAGE_COMBO
check. On the store side we already do a lwsync in __hash_page_4K
commit b00fc6ec1f24f9d7af9b8988b6a198186eb3408c upstream.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81631
Reported-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com>
commit a32305bf90a2ae0e6a9a93370c7616565f75e15a upstream.
powerpc defines various machine-specific routines for handling
pci_set_dma_mask(). The routines for machine "PowerNV" may neglect
to set dev->dma_mask. This could confuse anyone (e.g. drivers) that
consult dev->dma_mask to find the current mask. Set the dma_mask in
the PowerNV leaf routine.
Signed-off-by: Brian W. Hart <hartb@linux.vnet.ibm.com>
commit 7340056567e32b2c9d3554eb146e1977c93da116 upstream.
Commit bcdde7e made __sysfs_remove_dir() recursive and introduced a BUG_ON
during PHB removal while attempting to delete the power managment attribute
group of the bus. This is a result of tearing the bridge and bus devices down
out of order in remove_phb_dynamic. Since, the the bus resides below the bridge
in the sysfs device tree it should be torn down first.
This patch simply moves the device_unregister call for the PHB bridge device
after the device_unregister call for the PHB bus.
Fixes: bcdde7e221a8 ("sysfs: make __sysfs_remove_dir() recursive")
commit 4badad352a6bb202ec68afa7a574c0bb961e5ebc upstream.
The optimistic spin code assumes regular stores and cmpxchg() play nice;
this is found to not be true for at least: parisc, sparc32, tile32,
metag-lock1, arc-!llsc and hexagon.
There is further wreckage, but this in particular seemed easy to
trigger, so blacklist this.
Opt in for known good archs.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: James Bottomley <James.Bottomley@hansenpartnership.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Jason Low <jason.low2@hp.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: John David Anglin <dave.anglin@bell.net>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/20140606175316.GV13930@laptop.programming.kicks-ass.net
commit fb43e8477ed9006c4f397f904c691a120503038c upstream.
powerpc:allmodconfig has been failing for some time with the following
error.
arch/powerpc/kernel/exceptions-64s.S: Assembler messages:
arch/powerpc/kernel/exceptions-64s.S:1312: Error: attempt to move .org backwards
make[1]: *** [arch/powerpc/kernel/head_64.o] Error 1
A number of attempts to fix the problem by moving around code have been
unsuccessful and resulted in failed builds for some configurations and
the discovery of toolchain bugs.
Fix the problem by disabling RELOCATABLE for COMPILE_TEST builds instead.
While this is less than perfect, it avoids substantial code changes
which would otherwise be necessary just to make COMPILE_TEST builds
happy and might have undesired side effects.
commit b50a6c584bb47b370f84bfd746770c0bbe7129b7 upstream.
On POWER8 when switching to a KVM guest we set bits in MMCR2 to freeze
the PMU counters. Aside from on boot they are then never reset,
resulting in stuck perf counters for any user in the guest or host.
We now set MMCR2 to 0 whenever enabling the PMU, which provides a sane
state for perf to use the PMU counters under either the guest or the
host.
This was manifesting as a bug with ppc64_cpu --frequency:
$ sudo ppc64_cpu --frequency
WARNING: couldn't run on cpu 0
WARNING: couldn't run on cpu 8
WARNING: couldn't run on cpu 144
WARNING: couldn't run on cpu 152
min: 18446744073.710 GHz (cpu -1)
max: 0.000 GHz (cpu -1)
avg: 0.000 GHz
The command uses a perf counter to measure CPU cycles over a fixed
amount of time, in order to approximate the frequency of the machine.
The counters were returning zero once a guest was started, regardless of
weather it was still running or had been shut down.
By dumping the value of MMCR2, it was observed that once a guest is
running MMCR2 is set to 1s - which stops counters from running:
$ sudo sh -c 'echo p > /proc/sysrq-trigger'
CPU: 0 PMU registers, ppmu = POWER8 n_counters = 6
PMC1: 5b635e38 PMC2: 00000000 PMC3: 00000000 PMC4: 00000000
PMC5: 1bf5a646 PMC6: 5793d378 PMC7: deadbeef PMC8: deadbeef
MMCR0: 0000000080000000 MMCR1: 000000001e000000 MMCRA: 0000040000000000
MMCR2: fffffffffffffc00 EBBHR: 0000000000000000
EBBRR: 0000000000000000 BESCR: 0000000000000000
SIAR: 00000000000a51cc SDAR: c00000000fc40000 SIER: 0000000001000000
This is done unconditionally in book3s_hv_interrupts.S upon entering the
guest, and the original value is only save/restored if the host has
indicated it was using the PMU. This is okay, however the user of the
PMU needs to ensure that it is in a defined state when it starts using
it.
Fixes: e05b9b9e5c10 ("powerpc/perf: Power8 PMU support")
Signed-off-by: Joel Stanley <joel@jms.id.au>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
commit 4d9690dd56b0d18f2af8a9d4a279cb205aae3345 upstream.
Instead of separate bits for every POWER8 PMU feature, have a single one
for v2.07 of the architecture.
This saves us adding a MMCR2 define for a future patch.
commit f56029410a13cae3652d1f34788045c40a13ffc7 upstream.
We are seeing a lot of PMU warnings on POWER8:
Can't find PMC that caused IRQ
Looking closer, the active PMC is 0 at this point and we took a PMU
exception on the transition from negative to 0. Some versions of POWER8
have an issue where they edge detect and not level detect PMC overflows.
A number of places program the PMC with (0x80000000 - period_left),
where period_left can be negative. We can either fix all of these or
just ensure that period_left is always >= 1.
This patch takes the second option.
commit 6663a4fa6711050036562ddfd2086edf735fae21 upstream.
Commit 59a53afe70fd530040bdc69581f03d880157f15a "powerpc: Don't setup
CPUs with bad status" broke ePAPR SMP booting. ePAPR says that CPUs
that aren't presently running shall have status of disabled, with
enable-method being used to determine whether the CPU can be enabled.
Fix by checking for spin-table, which is currently the only supported
enable-method.
Cc: Michael Neuling <mikey@neuling.org>
Cc: Emil Medve <Emilian.Medve@Freescale.com>
commit dd58a092c4202f2bd490adab7285b3ff77f8e467 upstream.
The Vector Crypto category instructions are supported by current POWER8
chips, advertise them to userspace using a specific bit to properly
differentiate with chips of the same architecture level that might not
have them.
commit 59a53afe70fd530040bdc69581f03d880157f15a upstream.
OPAL will mark a CPU that is guarded as "bad" in the status property of the CPU
node.
Unfortunatley Linux doesn't check this property and will put the bad CPU in the
present map. This has caused hangs on booting when we try to unsplit the core.
This patch checks the CPU is avaliable via this status property before putting
it in the present map.
Signed-off-by: Michael Neuling <mikey@neuling.org>
Tested-by: Anton Blanchard <anton@samba.org>
commit b69a1da94f3d1589d1942b5d1b384d8cfaac4500 upstream.
Commit cd64d1697cf0 ("powerpc: mtmsrd not defined") added a check for
CONFIG_PPC_CPU were a check for CONFIG_PPC_FPU was clearly intended.
Fixes: cd64d1697cf0 ("powerpc: mtmsrd not defined")
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
commit 3df48c981d5a9610e02e9270b1bc4274fb536710 upstream.
In commit 330a1eb "Core EBB support for 64-bit book3s" I messed up
clear_task_ebb(). It clears some but not all of the task's Event Based
Branch (EBB) registers when we duplicate a task struct.
That allows a child task to observe the EBBHR & EBBRR of its parent,
which it should not be able to do.
Fix it by clearing EBBHR & EBBRR.
commit 6e0fdf9af216887e0032c19d276889aad41cad00 upstream.
Commit b0d278b7d3ae ("powerpc/perf_event: Reduce latency of calling
perf_event_do_pending") added a check for CONFIG_PMAC were a check for
CONFIG_PPC_PMAC was clearly intended.
Fixes: b0d278b7d3ae ("powerpc/perf_event: Reduce latency of calling perf_event_do_pending")
commit 5d73320a96fcce80286f1447864c481b5f0b96fa upstream.
commit 8f9c0119d7ba (compat: fs: Generic compat_sys_sendfile
implementation) changed the PowerPC 64bit sendfile call from
sys_sendile64 to sys_sendfile.
Unfortunately this broke sendfile of lengths greater than 2G because
sys_sendfile caps at MAX_NON_LFS. Restore what we had previously which
fixes the bug.
commit c4cad90f9e9dcb85afc5e75a02ae3522ed077296 upstream.
We had a mix & match of flags used when creating legacy ports
depending on where we found them in the device-tree. Among others
we were missing UPF_SKIP_TEST for some kind of ISA ports which is
a problem as quite a few UARTs out there don't support the loopback
test (such as a lot of BMCs).
Let's pick the set of flags used by the SoC code and generalize it
which means autoconf, no loopback test, irq maybe shared and fixed
port.
Sending to stable as the lack of UPF_SKIP_TEST is breaking
serial on some machines so I want this back into distros
commit 09567e7fd44291bfc08accfdd67ad8f467842332 upstream.
We have a bug in our hugepage handling which exhibits as an infinite
loop of hash faults. If the fault is being taken in the kernel it will
typically trigger the softlockup detector, or the RCU stall detector.
The bug is as follows:
1. mmap(0xa0000000, ..., MAP_FIXED | MAP_HUGE_TLB | MAP_ANONYMOUS ..)
2. Slice code converts the slice psize to 16M.
3. The code on lines 539-540 of slice.c in slice_get_unmapped_area()
synchronises the mm->context with the paca->context. So the paca slice
mask is updated to include the 16M slice.
3. Either:
* mmap() fails because there are no huge pages available.
* mmap() succeeds and the mapping is then munmapped.
In both cases the slice psize remains at 16M in both the paca & mm.
4. mmap(0xa0000000, ..., MAP_FIXED | MAP_ANONYMOUS ..)
5. The slice psize is converted back to 64K. Because of the check on line 539
of slice.c we DO NOT update the paca->context. The paca slice mask is now
out of sync with the mm slice mask.
6. User/kernel accesses 0xa0000000.
7. The SLB miss handler slb_allocate_realmode() **uses the paca slice mask**
to create an SLB entry and inserts it in the SLB.
18. With the 16M SLB entry in place the hardware does a hash lookup, no entry
is found so a data access exception is generated.
19. The data access handler calls do_page_fault() -> handle_mm_fault().
10. __handle_mm_fault() creates a THP mapping with do_huge_pmd_anonymous_page().
11. The hardware retries the access, there is still nothing in the hash table
so once again a data access exception is generated.
12. hash_page() calls into __hash_page_thp() and inserts a mapping in the
hash. Although the THP mapping maps 16M the hashing is done using 64K
as the segment page size.
13. hash_page() returns immediately after calling __hash_page_thp(), skipping
over the code at line 1125. Resulting in the mismatch between the
paca->context and mm->context not being detected.
14. The hardware retries the access, the hash it generates using the 16M
SLB entry does NOT match the hash we inserted.
15. We take another data access and go into __hash_page_thp().
16. We see a valid entry in the hpte_slot_array and so we call updatepp()
which succeeds.
17. Goto 14.
We could fix this in two ways. The first would be to remove or modify
the check on line 539 of slice.c.
The second option is to cause the check of paca psize in hash_page() on
line 1125 to also be done for THP pages.
We prefer the latter, because the check & update of the paca psize is
not done until we know it's necessary. It's also done only on the
current cpu, so we don't need to IPI all other cpus.
Without further rearranging the code, the simplest fix is to pull out
the code that checks paca psize and call it in two places. Firstly for
THP/hugetlb, and secondly for other mappings as before.
Thanks to Dave Jones for trinity, which originally found this bug.
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
