path: root/arch/ppc/platforms/residual.c
2008-06-10powerpc: Remove arch/ppc and include/asm-ppcPaul Mackerras
All the maintained platforms are now in arch/powerpc, so the old arch/ppc stuff can now go away. Acked-by: Adrian Bunk <bunk@kernel.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Becky Bruce <becky.bruce@freescale.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jochen Friedrich <jochen@scram.de> Acked-by: John Linn <john.linn@xilinx.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Scott Wood <scottwood@freescale.com> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Acked-by: Segher Boessenkool <segher@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-12[POWERPC] ppc: More compile fixesPaul Mackerras
This fixes a few more miscellaneous compile problems with ARCH=ppc. 1. Don't compile devres.c on ARCH=ppc, it doesn't have ioremap_flags. 2. Include <asm/irq.h> in setup.c for the __DO_IRQ_CANON definition. 3. Include <linux/proc_fs.h> in residual.c for the definition of create_proc_read_entry. 4. Fix xchg_ptr to be a static inline to eliminate a compiler warning. Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-18ppc: don't include <linux/ide.h>Bartlomiej Zolnierkiewicz
Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-09-19[PATCH] powerpc: Remove sections use from ppcJon Loeliger
Here is a new patch that removes all notion of the pmac, prep, chrp and openfirmware initialization sections, and then unifies the sections.h files without those __pmac, etc, sections identifiers cluttering things up. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
