path: root/arch/ppc/syslib/open_pic2.c
2008-06-10powerpc: Remove arch/ppc and include/asm-ppcPaul Mackerras
All the maintained platforms are now in arch/powerpc, so the old arch/ppc stuff can now go away. Acked-by: Adrian Bunk <bunk@kernel.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Becky Bruce <becky.bruce@freescale.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jochen Friedrich <jochen@scram.de> Acked-by: John Linn <john.linn@xilinx.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Scott Wood <scottwood@freescale.com> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Acked-by: Segher Boessenkool <segher@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-10[POWERPC] ARCH=ppc pt_regs fixesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-10[PATCH] powerpc: trivial: modify comments to refer to new location of filesJon Mason
This patch removes all self references and fixes references to files in the now defunct arch/ppc64 tree. I think this accomplises everything wanted, though there might be a few references I missed. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-12Merge from Linus' treePaul Mackerras
2005-10-11ppc: Various minor compile fixesPaul Mackerras
This fixes up a variety of minor problems in compiling with ARCH=ppc arising from using the merged versions of various header files. A lot of the changes are just adding #include <asm/machdep.h> to files that use ppc_md or smp_ops_t. This also arranges for us to use semaphore.c, vecemu.c, vector.S and fpu.S from arch/powerpc/kernel when compiling with ARCH=ppc. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-30[PATCH] useless includes of linux/irq.h (arch/ppc)Al Viro
2005-09-17[PATCH] Fix up some pm_message_t typesRichard Purdie
Fix up some pm_message_t types Signed-Off-By: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] PPC: C99 initializers for hw_interrupt_type structuresThomas Gleixner
Convert the initializers of hw_interrupt_type structures to C99 initializers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ppc32: remove some unnecessary includes of prom.hKumar Gala
Fight the Good Fight: Limit prom.h header creep. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
