path: root/arch/ppc
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-29[PATCH] KConfig: Spellchecking 'similarity' and 'independent'Matt LaPlante
Several KConfig files had 'similarity' and 'independent' spelled incorrectly... Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: [PATCH] i386: export memory more than 4G through /proc/iomem [PATCH] 64bit Resource: finally enable 64bit resource sizes [PATCH] 64bit Resource: convert a few remaining drivers to use resource_size_t where needed [PATCH] 64bit resource: change pnp core to use resource_size_t [PATCH] 64bit resource: change pci core and arch code to use resource_size_t [PATCH] 64bit resource: change resource core to use resource_size_t [PATCH] 64bit resource: introduce resource_size_t for the start and end of struct resource [PATCH] 64bit resource: fix up printks for resources in misc drivers [PATCH] 64bit resource: fix up printks for resources in arch and core code [PATCH] 64bit resource: fix up printks for resources in pcmcia drivers [PATCH] 64bit resource: fix up printks for resources in video drivers [PATCH] 64bit resource: fix up printks for resources in ide drivers [PATCH] 64bit resource: fix up printks for resources in mtd drivers [PATCH] 64bit resource: fix up printks for resources in pci core and hotplug drivers [PATCH] 64bit resource: fix up printks for resources in networks drivers [PATCH] 64bit resource: fix up printks for resources in sound drivers [PATCH] 64bit resource: C99 changes for struct resource declarations Fixed up trivial conflict in drivers/ide/pci/cmd64x.c (the printk that was changed by the 64-bit resources had been deleted in the meantime ;)
2006-06-29[PATCH] genirq: cleanup: merge irq_affinity[] into irq_desc[]Ingo Molnar
Consolidation: remove the irq_affinity[NR_IRQS] array and move it into the irq_desc[NR_IRQS].affinity field. [akpm@osdl.org: sparc64 build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] node hotplug: register cpu: remove node structKAMEZAWA Hiroyuki
With Goto-san's patch, we can add new pgdat/node at runtime. I'm now considering node-hot-add with cpu + memory on ACPI. I found acpi container, which describes node, could evaluate cpu before memory. This means cpu-hot-add occurs before memory hot add. In most part, cpu-hot-add doesn't depend on node hot add. But register_cpu(), which creates symbolic link from node to cpu, requires that node should be onlined before register_cpu(). When a node is onlined, its pgdat should be there. This patch-set holds off creating symbolic link from node to cpu until node is onlined. This removes node arguments from register_cpu(). Now, register_cpu() requires 'struct node' as its argument. But the array of struct node is now unified in driver/base/node.c now (By Goto's node hotplug patch). We can get struct node in generic way. So, this argument is not necessary now. This patch also guarantees add cpu under node only when node is onlined. It is necessary for node-hot-add vs. cpu-hot-add patch following this. Moreover, register_cpu calculates cpu->node_id by cpu_to_node() without regard to its 'struct node *root' argument. This patch removes it. Also modify callers of register_cpu()/unregister_cpu, whose args are changed by register-cpu-remove-node-struct patch. [Brice.Goglin@ens-lyon.org: fix it] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit resource: change pci core and arch code to use resource_size_tGreg Kroah-Hartman
Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-27[PATCH] 64bit resource: fix up printks for resources in arch and core codeGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> and Andrew Morton. (tweaked by Andy Isaacson <adi@hexapodia.org>) Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Andy Isaacson <adi@hexapodia.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEVGreg Kroah-Hartman
I've always found this flag confusing. Now that devfs is no longer around, it has been renamed, and the documentation for when this flag should be used has been updated. Also fixes all drivers that use this flag. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26Storage class should be firstTobias Klauser
Storage class should be before const Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[PATCH] mm: remove VM_LOCKED before remap_pfn_range and drop VM_SHMChristoph Lameter
Remove VM_LOCKED before remap_pfn range from device drivers and get rid of VM_SHM. remap_pfn_range() already sets VM_IO. There is no need to set VM_SHM since it does nothing. VM_LOCKED is of no use since the remap_pfn_range does not place pages on the LRU. The pages are therefore never subject to swap anyways. Remove all the vm_flags settings before calling remap_pfn_range. After removing all the vm_flag settings no use of VM_SHM is left. Drop it. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (139 commits) [POWERPC] re-enable OProfile for iSeries, using timer interrupt [POWERPC] support ibm,extended-*-frequency properties [POWERPC] Extra sanity check in EEH code [POWERPC] Dont look for class-code in pci children [POWERPC] Fix mdelay badness on shared processor partitions [POWERPC] disable floating point exceptions for init [POWERPC] Unify ppc syscall tables [POWERPC] mpic: add support for serial mode interrupts [POWERPC] pseries: Print PCI slot location code on failure [POWERPC] spufs: one more fix for 64k pages [POWERPC] spufs: fail spu_create with invalid flags [POWERPC] spufs: clear class2 interrupt status before wakeup [POWERPC] spufs: fix Makefile for "make clean" [POWERPC] spufs: remove stop_code from struct spu [POWERPC] spufs: fix spu irq affinity setting [POWERPC] spufs: further abstract priv1 register access [POWERPC] spufs: split the Cell BE support into generic and platform dependant parts [POWERPC] spufs: dont try to access SPE channel 1 count [POWERPC] spufs: use kzalloc in create_spu [POWERPC] spufs: fix initial state of wbox file ... Manually resolved conflicts in: drivers/net/phy/Makefile include/asm-powerpc/spu.h
2006-06-22Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (27 commits) [PATCH] PCI: nVidia quirk to make AER PCI-E extended capability visible [PATCH] PCI: fix issues with extended conf space when MMCONFIG disabled because of e820 [PATCH] PCI: Bus Parity Status sysfs interface [PATCH] PCI: fix memory leak in MMCONFIG error path [PATCH] PCI: fix error with pci_get_device() call in the mpc85xx driver [PATCH] PCI: MSI-K8T-Neo2-Fir: run only where needed [PATCH] PCI: fix race with pci_walk_bus and pci_destroy_dev [PATCH] PCI: clean up pci documentation to be more specific [PATCH] PCI: remove unneeded msi code [PATCH] PCI: don't move ioapics below PCI bridge [PATCH] PCI: cleanup unused variable about msi driver [PATCH] PCI: disable msi mode in pci_disable_device [PATCH] PCI: Allow MSI to work on kexec kernel [PATCH] PCI: AMD 8131 MSI quirk called too late, bus_flags not inherited ? [PATCH] PCI: Move various PCI IDs to header file [PATCH] PCI Bus Parity Status-broken hardware attribute, EDAC foundation [PATCH] PCI: i386/x86_84: disable PCI resource decode on device disable [PATCH] PCI ACPI: Rename the functions to avoid multiple instances. [PATCH] PCI: don't enable device if already enabled [PATCH] PCI: Add a "enable" sysfs attribute to the pci devices to allow userspace (Xorg) to enable devices without doing foul direct access ...
2006-06-22[PATCH] zlib_inflate: Upgrade library code to a recent versionRichard Purdie
Upgrade the zlib_inflate implementation in the kernel from a patched version 1.1.3/4 to a patched 1.2.3. The code in the kernel is about seven years old and I noticed that the external zlib library's inflate performance was significantly faster (~50%) than the code in the kernel on ARM (and faster again on x86_32). For comparison the newer deflate code is 20% slower on ARM and 50% slower on x86_32 but gives an approx 1% compression ratio improvement. I don't consider this to be an improvement for kernel use so have no plans to change the zlib_deflate code. Various changes have been made to the zlib code in the kernel, the most significant being the extra functions/flush option used by ppp_deflate. This update reimplements the features PPP needs to ensure it continues to work. This code has been tested on ARM under both JFFS2 (with zlib compression enabled) and ppp_deflate and on x86_32. JFFS2 sees an approx. 10% real world file read speed improvement. This patch also removes ZLIB_VERSION as it no longer has a correct value. We don't need version checks anyway as the kernel's module handling will take care of that for us. This removal is also more in keeping with the zlib author's wishes (http://www.zlib.net/zlib_faq.html#faq24) and I've added something to the zlib.h header to note its a modified version. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Acked-by: Joern Engel <joern@wh.fh-wedel.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-21[PATCH] USB: allow multiple types of EHCI controllers to be built as modulesKumar Gala
In some systems we may have both a platform EHCI controller and PCI EHCI controller. Previously we couldn't build the EHCI support as a module due to conflicting module_init() calls in the code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] PCI: fix error with pci_get_device() call in the mpc85xx driverGreg Kroah-Hartman
2006-06-15[POWERPC] ppc32: fix CPCI405 board supportMatthias Fuchs
Hi, this patch brings the CPCI405 board support up to date and fixes several outstanding issues: -add bios_fixup() -enable RTC only when CONFIG_GEN_RTC defined -corrected CompactPCI interrupt map -added cpci405_early_serial_map for correct UART clocking -removed unused code Matthias Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-13powerpc: Fix some missed ppc32 mm->context.id conversionsPaul Mackerras
2006-06-11powerpc: add context.vdso_base for 32-bit tooPaul Mackerras
This adds a vdso_base element to the mm_context_t for 32-bit compiles (both for ARCH=powerpc and ARCH=ppc). This fixes the compile errors that have been reported in arch/powerpc/kernel/signal_32.c. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-01Merge branch 'merge'Paul Mackerras
2006-05-29ppc: Fix typo in TI_LOCAL_FLAGS definitionPaul Mackerras
A typo crept in with commit ea1e847cc202e805769c3c46ba5e5c53714068a1 which defined TI_LOCAL_FLAGS to be the offset of the `flags' field of struct thread_info, rather than the `local_flags' field. This fixes it. The typo was pointed out by Guennadi Liakhovetski. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-26[PATCH] ppc32 CPM_UART: various fixes for pq2 uart usersVitaly Bordug
This fixes various odd things that missed update together with cpm_uart platform_device move. Unified resources names, restructurisation, etc. Also, addressed issue with recent phys/virt translation rework. Being cache-coherent, CPM2's do alloc_bootmem() for the console stuff, and it was used to treat console buffer descriptor mapping 1:1 (as in CPM1 case), which is definitely wrong. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-24[PATCH] remove powerpc bitops in favor of existing generic bitopsJon Mason
There already exists a big endian safe bitops implementation in lib/find_next_bit.c. The code in it is 90%+ common with the powerpc specific version, so the powerpc version is redundant. This patch makes the necessary changes to use the generic bitops in powerpc, and removes the powerpc specific version. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-09[PATCH] ppc32/8xx: Fix r3 trashing due to 8MB TLB page instantiationMarcelo Tosatti
Instantiation of 8MB pages on the TLB cache for the kernel static mapping trashes r3 register on !CONFIG_8xx_CPU6 configurations. This ensures r3 gets saved and restored. Signed-off-by: Marcelo Tosatti <marcelo@kvack.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-03[PATCH] ppc32 CPM_UART: fixes and improvementsVitaly Bordug
A number of small issues are fixed, and added the header file, missed from the original series. With this, driver should be pretty stable as tested among both platform-device-driven and "old way" boards. Also added missing GPL statement , and updated year field on existing ones to reflect code update. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-28[PATCH] ppc32: Update board-specific code of the CPM UART usersVitaly Bordug
This has the relevant updates/additions to the BSP code so that proper platform_info struct well be passed to the CPM UART drivers. The changes covered mpc866ads, mpc885ads and mpc8272ads. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-28[PATCH] ppc32: odd fixes and improvements in ppc_sysVitaly Bordug
This consists of offsets fix in ..._devices.c, and update of ppc_sys_fixup_mem_resource() function to prevent subsequent fixups Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-28[PATCH] ppc32: add 440GX erratum 440_43 workaroundEugene Surovegin
This patch adds workaround for PPC 440GX erratum 440_43. According to this erratum spurious MachineChecks (caused by L1 cache parity) can happen during DataTLB miss processing. We disable L1 cache parity checking for 440GX rev.C and rev.F Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-22Merge branch 'misc' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into merge
2006-04-21[PATCH] ppc: Fix powersave code on arch/ppcBecky Bruce
Fix asm_offsets.c and entry.S to work with the new power save code. Changes in arch/powerpc needed to exist in arch/ppc as well since the idle code is shared by both ppc and powerpc.. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-merge: powerpc: Use correct sequence for putting CPU into nap mode [PATCH] spufs: fix context-switch decrementer code [PATCH] powerpc32: Set cpu explicitly in kernel compiles [PATCH] powerpc/pseries: bugfix: balance calls to pci_device_put [PATCH] powerpc: Fix machine detection in prom_init.c [PATCH] ppc32: Fix string comparing in platform_notify_map [PATCH] powerpc: Avoid __initcall warnings [PATCH] powerpc: Ensure runlatch is off in the idle loop powerpc: Fix CHRP booting - needs a define_machine call powerpc: iSeries has only 256 IRQs
2006-04-13[PATCH] ppc32: Fix string comparing in platform_notify_mapVitaly Bordug
Fixed odd function behavior when dev->bus_id does not contain '.' - it compared that case 0 characters of the string and hereby reported success and executed callback. Now bus_id's are compared correctly, extra callback triggering eliminated. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-04kbuild: use relative path to -ISam Ravnborg
Using a relative path has the advantage that when the kernel source tree is moved the relevant .o files will not be rebuild just because the path to the kernel src has changed. This also got rid of a user of TOPDIR - which has been deprecated for a long time now. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-04-02powerpc/ppc: export strncasecmpKumar Gala
We have a strncasecmp so we might as well export it Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-03-29[PATCH] for_each_possible_cpu: ppcKAMEZAWA Hiroyuki
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes in the past where people were using for_each_cpu() where they should have been iterating across only online or present CPUs. This is inefficient and possibly buggy. We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the future. This patch replaces for_each_cpu with for_each_possible_cpu. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-29[PATCH] lock PTE before updating it in 440/BookE page fault handlerEugene Surovegin
Fix 44x and BookE page fault handler to correctly lock PTE before trying to pte_update() it, otherwise this PTE might be swapped out after pte_present() check but before pte_uptdate() call, resulting in corrupted PTE. This can happen with enabled preemption and low memory condition. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-29Merge ../linux-2.6Paul Mackerras
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] RTC: Fix up some RTC whitespace and styleMatt Mackall
Fix up some RTC whitespace and style Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] RTC: Remove RTC UIP synchronization on PPC CHRP (arch/ppc)Matt Mackall
Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] powerpc: Kill _machine and hard-coded platform numbersBenjamin Herrenschmidt
This removes statically assigned platform numbers and reworks the powerpc platform probe code to use a better mechanism. With this, board support files can simply declare a new machine type with a macro, and implement a probe() function that uses the flattened device-tree to detect if they apply for a given machine. We now have a machine_is() macro that replaces the comparisons of _machine with the various PLATFORM_* constants. This commit also changes various drivers to use the new macro instead of looking at _machine. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-28ppc: Fix compile error in arch/ppc/lib/strcase.cPaul Mackerras
Now that the strncasecmp implementation takes a size_t third parameter, we need to get a definition of size_t from somewhere. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-28Merge branch '85xx' of ↵Paul Mackerras
git://git.kernel.org/pub/scm/linux/kernel/git/galak/powerpc
2006-03-28Merge branch 'misc' of ↵Paul Mackerras
2006-03-27powerpc: move math-emu over to arch/powerpcKumar Gala
Towards the goal of having arch/powerpc not build anything over in arch/ppc move math-emu over. Also, killed some references to arch/ppc/ in the arch/powerpc Makefile which should belong in drivers/ when the particular sub-arch's move over to arch/powerpc. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-03-27ppc: fix strncasecmp prototypeKumar Gala
Match, Linus's fix to arch/powerpc in arch/ppc. strcasecmp takes a size_t, not an int, as its third argument. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-03-28ppc: Remove CHRP, POWER3 and POWER4 support from arch/ppcPaul Mackerras
32-bit CHRP machines are now supported only in arch/powerpc, as are all 64-bit PowerPC processors. This means that we don't use Open Firmware on any platform in arch/ppc any more. This makes PReP support a single-platform option like every other platform support option in arch/ppc now, thus CONFIG_PPC_MULTIPLATFORM is gone from arch/ppc. CONFIG_PPC_PREP is the option that selects PReP support and is generally what has replaced CONFIG_PPC_MULTIPLATFORM within arch/ppc. _machine is all but dead now, being #defined to 0. Updated Makefiles, comments and Kconfig options generally to reflect these changes. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27ppc: Remove duplicate exports of __down, __up etc.Paul Mackerras
__down, __down_interruptible and __up are defined and exported in arch/powerpc/kernel/semaphore.c, and used from there for ARCH=ppc, so there is no need to export them in arch/ppc/kernel/ppc_ksyms.c. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27powerpc: Don't compile in arch/ppc/kernel for 32-bit ARCH=powerpcPaul Mackerras
All of the things needed for 32-bit ARCH=powerpc builds have now moved to arch/powerpc/kernel, so we don't need to go down into arch/ppc/kernel any more, and we can remove the CONFIG_PPC_MERGE conditional from arch/ppc/kernel/Makefile. There were two files still referenced in the merge section of arch/ppc/kernel/Makefile: ppc-stub.o, depending on CONFIG_KGDB, and dma-mapping.o, depending on CONFIG_NOT_COHERENT_CACHE. None of the platforms currently in ARCH=powerpc have caches that aren't coherent with DMA, but when we do get one we'll move dma-mapping.c over. As for CONFIG_KGDB, none of the Kconfig files in the tree define it, so I'll let it languish for now. Signed-off-by: Paul Mackerras <paulus@samba.org>
