Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
We've switched over every architecture that supports SMP to it, so
remove the new useless config variable.
arch/arm/Kconfig
block/blk-mq.c
Change-Id: Ic19c3ac07a38a1636d6aa2fed5e55a58833f9b2c
Cc: Jan Kara <jack@suse.cz>
(cherry picked from commit 0a06ff068f1255bcd7965ab07bc0f4adc3eb639a)
commit 03b8c7b623c80af264c4c8d6111e5c6289933666 upstream.
If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there
is no runtime check necessary, allow to skip the test within futex_init().
This allows to get rid of some code which would always give the same result,
and also allows the compiler to optimize a couple of if statements away.
Cc: Finn Thain <fthain@telegraphics.com.au>
Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris
[geert: Backported to v3.10..v3.13]
commit 594712276e737961d30e11eae80d403b2b3815df upstream.
Just add the new model number where appropiate.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
The help text for this config is duplicated across the x86, parisc, and
s390 Kconfig.debug files. Arnd Bergman noted that the help text was
slightly misleading and should be fixed to state that enabling this
option isn't a problem when using pre 4.4 gcc.
To simplify the rewording, consolidate the text into lib/Kconfig.debug
and modify it there to be more explicit about when you should say N to
this config.
Also, make the text a bit more generic by stating that this option
enables compile time checks so we can cover architectures which emit
warnings vs. ones which emit errors. The details of how an
architecture decided to implement the checks isn't as important as the
concept of compile time checking of copy_from_user() calls.
While we're doing this, remove all the copy_from_user_overflow() code
that's duplicated many times and place it into lib/ so that any
architecture supporting this option can get the function for free.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Helge Deller <deller@gmx.de>
Cc: Chris Metcalf <cmetcalf@tilera.com>
We've seen repeatedly that 8KB stack size on 64 bit kernels
is not sufficient.
So simply remove the config option.
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS")
I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where
needed. I am not sure what I was thinking. Instead, just directly
select VIRT_TO_BUS where it is needed.
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures
that already provide virt_to_bus().
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: H Hartley Sweeten <hartleys@visionengravers.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: <linux-arch@vger.kernel.org>
Pull signal handling cleanups from Al Viro:
"This is the first pile; another one will come a bit later and will
contain SYSCALL_DEFINE-related patches.
- a bunch of signal-related syscalls (both native and compat)
unified.
- a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE
(fixing several potential problems with missing argument
validation, while we are at it)
- a lot of now-pointless wrappers killed
- a couple of architectures (cris and hexagon) forgot to save
altstack settings into sigframe, even though they used the
(uninitialized) values in sigreturn; fixed.
- microblaze fixes for delivery of multiple signals arriving at once
- saner set of helpers for signal delivery introduced, several
architectures switched to using those."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits)
x86: convert to ksignal
sparc: convert to ksignal
arm: switch to struct ksignal * passing
alpha: pass k_sigaction and siginfo_t using ksignal pointer
burying unused conditionals
make do_sigaltstack() static
arm64: switch to generic old sigaction() (compat-only)
arm64: switch to generic compat rt_sigaction()
arm64: switch compat to generic old sigsuspend
arm64: switch to generic compat rt_sigqueueinfo()
arm64: switch to generic compat rt_sigpending()
arm64: switch to generic compat rt_sigprocmask()
arm64: switch to generic sigaltstack
sparc: switch to generic old sigsuspend
sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE
sparc: kill sign-extending wrappers for native syscalls
kill sparc32_open()
sparc: switch to use of generic old sigaction
sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE
mips: switch to generic sys_fork() and sys_clone()
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 update from Martin Schwidefsky:
"The most prominent change in this patch set is the software dirty bit
patch for s390. It removes __HAVE_ARCH_PAGE_TEST_AND_CLEAR_DIRTY and
the page_test_and_clear_dirty primitive which makes the common memory
management code a bit less obscure.
Heiko fixed most of the PCI related fallout, more often than not
missing GENERIC_HARDIRQS dependencies. Notable is one of the 3270
patches which adds an export to tty_io to be able to resize a tty.
The rest is the usual bunch of cleanups and bug fixes."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (42 commits)
s390/module: Add missing R_390_NONE relocation type
drivers/gpio: add missing GENERIC_HARDIRQ dependency
drivers/input: add couple of missing GENERIC_HARDIRQS dependencies
s390/cleanup: rename SPP to LPP
s390/mm: implement software dirty bits
s390/mm: Fix crst upgrade of mmap with MAP_FIXED
s390/linker skript: discard exit.data at runtime
drivers/media: add missing GENERIC_HARDIRQS dependency
s390/bpf,jit: add vlan tag support
drivers/net,AT91RM9200: add missing GENERIC_HARDIRQS dependency
iucv: fix kernel panic at reboot
s390/Kconfig: sort list of arch selected config options
phylib: remove !S390 dependeny from Kconfig
uio: remove !S390 dependency from Kconfig
dasd: fix sysfs cleanup in dasd_generic_remove
s390/pci: fix hotplug module init
s390/pci: cleanup clp page allocation
s390/pci: cleanup clp inline assembly
s390/perf: cpum_cf: fallback to software sampling events
s390/mm: provide PAGE_SHARED define
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
Just like on other architectures. The intention is that this will reduce
merge conflicts if new config options get added in sorted order as well.
__ARCH_WANT_SYS_RT_SIGACTION,
__ARCH_WANT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore
CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} -
can be assumed always set.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into irq/core
irq_work fixes and cleanups, in preparation for full dyntics support.
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
"sigaltstack infrastructure + conversion for x86, alpha and um,
COMPAT_SYSCALL_DEFINE infrastructure.
Note that there are several conflicts between "unify
SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline;
resolution is trivial - just remove definitions of SS_ONSTACK and
SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and
include/uapi/linux/signal.h contains the unified variant."
Fixed up conflicts as per Al.
alpha: switch to generic sigaltstack
new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those
generic compat_sys_sigaltstack()
introduce generic sys_sigaltstack(), switch x86 and um to it
new helper: compat_user_stack_pointer()
new helper: restore_altstack()
unify SS_ONSTACK/SS_DISABLE definitions
new helper: current_user_stack_pointer()
missing user_stack_pointer() instances
Bury the conditionals from kernel_thread/kernel_execve series
COMPAT_SYSCALL_DEFINE: infrastructure
All architectures have
CONFIG_GENERIC_KERNEL_THREAD
CONFIG_GENERIC_KERNEL_EXECVE
__ARCH_WANT_SYS_EXECVE
None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers
of kernel_execve() (which is a trivial wrapper for do_execve() now) left.
Kill the conditionals and make both callers use do_execve().
"Add support to generate code for the latest machine zEC12, MOD and XOR
instruction support for the BPF jit compiler, the dasd safe offline
feature and the big one: the s390 architecture gets PCI support!!
Right before the world ends on the 21st ;-)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (41 commits)
s390/qdio: rename the misleading PCI flag of qdio devices
s390/pci: remove obsolete email addresses
s390/pci: speed up __iowrite64_copy by using pci store block insn
s390/pci: enable NEED_DMA_MAP_STATE
s390/pci: no msleep in potential IRQ context
s390/pci: fix potential NULL pointer dereference in dma_free_seg_table()
s390/pci: use kmem_cache_zalloc instead of kmem_cache_alloc/memset
s390/bpf,jit: add support for XOR instruction
s390/bpf,jit: add support MOD instruction
s390/cio: fix pgid reserved check
vga: compile fix, disable vga for s390
s390/pci: add PCI Kconfig options
s390/pci: s390 specific PCI sysfs attributes
s390/pci: PCI hotplug support via SCLP
s390/pci: CHSC PCI support for error and availability events
s390/pci: DMA support
s390/pci: PCI adapter interrupts for MSI/MSI-X
s390/bitops: find leftmost bit instruction support
s390/pci: CLP interface
s390/pci: base support
The DMA API allows to avoid DMA unmaps because they are NOPs on some
plattforms. But not on s390, so force them.
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
CONFIG_PCI is disabled by default currently.
'arch-h8300', 'arch-m32r', 'arch-mn10300', 'arch-score', 'arch-sh' and 'arch-powerpc' into for-next
Allow to generate code that only runs on zEC12 machines.
Also add a check which prevents the kernel to run on machines which
do not have any of the following new facilities installed:
- (48) decimal-floating-point zoned-conversion
- (49) execution-hint
- (49) load-and-trap
- (49) miscellaneous-instruction-extensions
- (49) processor-assist
- (50) constrained transactional-execution
- (73) transactional-execution
48, 49, 50 and 73 are the bit numbers of the facility indications for
each of the required facilities.
Note that we assume that user-space gets compiled with the same
compiler options, therefore we also test for a dfp facility even
if the kernel doesn't make use of it.
irq work can run on any arch even without IPI
support because of the hook on update_process_times().
So lets remove HAVE_IRQ_WORK because it doesn't reflect
any backend requirement.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Select HAVE_ALIGNED_STRUCT_PAGE on s390, so that the slub allocator can make
use of compare and swap double for lockless updates. This increases the size
of struct page to 64 bytes (instead of 56 bytes), however the performance gain
justifies the increased size:
- now excactly four struct pages fit into a single cache line; the
case that accessing a struct page causes two cache line loads
does not exist anymore.
- calculating the offset of a struct page within the memmap array
is only a simple shift instead of a more expensive multiplication.
A "hackbench 200 process 200" run on a 32 cpu system did show an 8% runtime
improvement.
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Add missing select statement to arch/s390/Kconfig.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module signing support from Rusty Russell:
"module signing is the highlight, but it's an all-over David Howells frenzy..."
Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG.
* 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits)
X.509: Fix indefinite length element skip error handling
X.509: Convert some printk calls to pr_devel
asymmetric keys: fix printk format warning
MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking
MODSIGN: Make mrproper should remove generated files.
MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs
MODSIGN: Use the same digest for the autogen key sig as for the module sig
MODSIGN: Sign modules during the build process
MODSIGN: Provide a script for generating a key ID from an X.509 cert
MODSIGN: Implement module signature checking
MODSIGN: Provide module signing public keys to the kernel
MODSIGN: Automatically generate module signing keys if missing
MODSIGN: Provide Kconfig options
MODSIGN: Provide gitignore and make clean rules for extra files
MODSIGN: Add FIPS policy
module: signature checking hook
X.509: Add a crypto key parser for binary (DER) X.509 certificates
MPILIB: Provide a function to read raw data into an MPI
X.509: Add an ASN.1 decoder
X.509: Add simple ASN.1 grammar compiler
Pull timer core update from Thomas Gleixner:
- Bug fixes (one for a longstanding dead loop issue)
- Rework of time related vsyscalls
- Alarm timer updates
- Jiffies updates to remove compile time dependencies
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
timekeeping: Cast raw_interval to u64 to avoid shift overflow
timers: Fix endless looping between cascade() and internal_add_timer()
time/jiffies: bring back unconditional LATCH definition
time: Convert x86_64 to using new update_vsyscall
time: Only do nanosecond rounding on GENERIC_TIME_VSYSCALL_OLD systems
time: Introduce new GENERIC_TIME_VSYSCALL
time: Convert CONFIG_GENERIC_TIME_VSYSCALL to CONFIG_GENERIC_TIME_VSYSCALL_OLD
time: Move update_vsyscall definitions to timekeeper_internal.h
time: Move timekeeper structure to timekeeper_internal.h for vsyscall changes
jiffies: Remove compile time assumptions about CLOCK_TICK_RATE
jiffies: Kill unused TICK_USEC_TO_NSEC
alarmtimer: Rename alarmtimer_remove to alarmtimer_dequeue
alarmtimer: Remove unused helpers & defines
alarmtimer: Use hrtimer per-alarm instead of per-base
alarmtimer: Implement minimum alarm interval for allowing suspend
Pull generic execve() changes from Al Viro:
"This introduces the generic kernel_thread() and kernel_execve()
functions, and switches x86, arm, alpha, um and s390 over to them."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits)
s390: convert to generic kernel_execve()
s390: switch to generic kernel_thread()
s390: fold kernel_thread_helper() into ret_from_fork()
s390: fold execve_tail() into start_thread(), convert to generic sys_execve()
um: switch to generic kernel_thread()
x86, um/x86: switch to generic sys_execve and kernel_execve
x86: split ret_from_fork
alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve()
alpha: switch to generic kernel_thread()
alpha: switch to generic sys_execve()
arm: get rid of execve wrapper, switch to generic execve() implementation
arm: optimized current_pt_regs()
arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve()
arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk]
new helper: current_pt_regs()
preparation for generic kernel_thread()
um: kill thread->forking
um: let signal_delivered() do SIGTRAP on singlestepping into handler
Introduce SYSCTL_EXCEPTION_TRACE config option and selec it in the
architectures requiring support for the "exception-trace" debug_table
entry in kernel/sysctl.c.
Introduce HAVE_DEBUG_KMEMLEAK config option and select it in corresponding
architecture Kconfig files. DEBUG_KMEMLEAK now only depends on
HAVE_DEBUG_KMEMLEAK.
Introduce HAVE_UID16 config option and select it in corresponding
architecture Kconfig files. UID16 now only depends on HAVE_UID16.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Pull virtio changes from Rusty Russell:
"New workflow: same git trees pulled by linux-next get sent straight to
Linus. Git is awkward at shuffling patches compared with quilt or mq,
but that doesn't happen often once things get into my -next branch."
* 'virtio-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (24 commits)
lguest: fix occasional crash in example launcher.
virtio-blk: Disable callback in virtblk_done()
virtio_mmio: Don't attempt to create empty virtqueues
virtio_mmio: fix off by one error allocating queue
drivers/virtio/virtio_pci.c: fix error return code
virtio: don't crash when device is buggy
virtio: remove CONFIG_VIRTIO_RING
virtio: add help to CONFIG_VIRTIO option.
virtio: support reserved vqs
virtio: introduce an API to set affinity for a virtqueue
virtio-ring: move queue_index to vring_virtqueue
virtio_balloon: not EXPERIMENTAL any more.
virtio-balloon: dependency fix
virtio-blk: fix NULL checking in virtblk_alloc_req()
virtio-blk: Add REQ_FLUSH and REQ_FUA support to bio path
virtio-blk: Add bio-based IO path for virtio-blk
virtio: console: fix error handling in init() function
tools: Fix pthread flag for Makefile of trace-agent used by virtio-trace
tools: Add guest trace agent as a user tool
virtio/console: Allocate scatterlist according to the current pipe size
Pull s390 updates from Martin Schwidefsky:
"The main new feature is machine support for System zEC12 including
transactional memory, runtime instrumentation, support for scm block
devices via eadm subchannels, and support for CEX4 crypto cards.
In addition there are some nice improvements: bpf jit compiler, arch
backend for cmpxchg_double, relative exception table entries, dasd
partition detection independent from the dasd driver ioctls, and cpu
cache information in /proc/cpuinfo and /sys/device/cpu.
And last but not least a series of cleanup patches from Heiko."
Fix up trivial add-add conflict in arch/s390/Kconfig due to commit
b952741c8079 ("cputime: Generalize CONFIG_VIRT_CPU_ACCOUNTING")
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (76 commits)
s390: update defconfig
s390/jump label,nss: let shared kernel support depend on !JUMP_LABEL
s390/disassembler: fix decoding of risblg instruction
s390/bpf,jit: add support for BPF_S_ANC_ALU_XOR_X instruction
s390/traps: move call to print_modules() out of show_regs()
s390/mm: mark free_initrd_mem() as __init
s390/dasd: check count address during online setting
drivers/s390/char/monreader.c: fix error return code
s390/cmpxchg,percpu: implement cmpxchg_double()
s390/percpu: implement this_cpu_add_return()
s390/percpu: implement this_cpu_xchg()
s390/kexec: remove CONFIG_KEXEC
s390/irq: use designated initializers for irq class array
s390: add uninitialized_var() to suppress false positive compiler warnings
s390/crashdump: move fill_cpu_elf_notes() prototype to header file
s390/process: add missing header include
s390/ptrace: add missing ifdef
s390/ipl,decrompressor: disable branch profiling
s390/perf_events: compile only for CONFIG_64BIT
s390/tape: remove even more tape block leftovers
Everyone who selects VIRTIO is also made to select VIRTIO_RING; just make
them synonymous, since we removed the indirection layer some time ago.
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela,
ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version
into asm-generic/module.h for all arches bar MIPS.
Also, use the generic definition mod_arch_specific where possible.
To this end, I've defined three new config bools:
(*) HAVE_MOD_ARCH_SPECIFIC
Arches define this if they don't want to use the empty generic
mod_arch_specific struct.
(*) MODULES_USE_ELF_RELA
Arches define this if their modules can contain RELA records. This causes
the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be
defined by the arch rather than have the core emit an error message.
Arches define this if their modules can contain REL records. This causes
the Elf_Rel mapping to be emitted and allows apply_relocate() to be
Note that it is possible to allow both REL and RELA records: m68k and mips are
two arches that do this.
With this, some arch asm/module.h files can be deleted entirely and replaced
with a generic-y marker in the arch Kbuild file.
Additionally, I have removed the bits from m32r and score that handle the
unsupported type of relocation record as that's now handled centrally.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
We can have either shared kernel or jump label support, but not both.
If a kernel gets IPL'ed from an NSS it's not possible to patch the
text segment, since it's read-only.
Therefore any static branches cannot be updated. So we need to make
sure that shared kernel support is disabled if jump label support
is enabled.
