git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull iommu updates from Joerg Roedel:
"This time including:
- A new IOMMU driver for s390 pci devices
- Common dma-ops support based on iommu-api for ARM64. The plan is
to use this as a basis for ARM32 and hopefully other architectures
as well in the future.
- MSI support for ARM-SMMUv3
- Cleanups and dead code removal in the AMD IOMMU driver
- Better RMRR handling for the Intel VT-d driver
- Various other cleanups and small fixes"
* tag 'iommu-updates-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (41 commits)
iommu/vt-d: Fix return value check of parse_ioapics_under_ir()
iommu/vt-d: Propagate error-value from ir_parse_ioapic_hpet_scope()
iommu/vt-d: Adjust the return value of the parse_ioapics_under_ir
iommu: Move default domain allocation to iommu_group_get_for_dev()
iommu: Remove is_pci_dev() fall-back from iommu_group_get_for_dev
iommu/arm-smmu: Switch to device_group call-back
iommu/fsl: Convert to device_group call-back
iommu: Add device_group call-back to x86 iommu drivers
iommu: Add generic_device_group() function
iommu: Export and rename iommu_group_get_for_pci_dev()
iommu: Revive device_group iommu-ops call-back
iommu/amd: Remove find_last_devid_on_pci()
iommu/amd: Remove first/last_device handling
iommu/amd: Initialize amd_iommu_last_bdf for DEV_ALL
iommu/amd: Cleanup buffer allocation
iommu/amd: Remove cmd_buf_size and evt_buf_size from struct amd_iommu
iommu/amd: Align DTE flag definitions
iommu/amd: Remove old alias handling code
iommu/amd: Set alias DTE in do_attach/do_detach
iommu/amd: WARN when __[attach|detach]_device are called with irqs enabled
Depending on the gcc version we can use builtin_bswap instead of
architecture functions. Doing so is better than the inline assembly
version of load reverse for two reasons:
- the sequence of load reversed, apply constant mask, save reversed can
be optimized to load, apply reversed mask, save
- builtins are slightly better to optimize e.g. gcc instruction
scheduler cannot optimize grouping on inline assemblies.
To enable set we have to ARCH_USE_BUILTIN_BSWAP.
bloat-o-meter results:
add/remove: 1/1 grow/shrink: 75/533 up/down: 1711/-9394 (-7683)
Suggested-by: David Woodhouse <David.Woodhouse@intel.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Use bit 2**1 of the pte and bit 2**14 of the pmd for the soft dirty
bit. The fault mechanism to do dirty tracking is already in place.
This adds an IOMMU API implementation for s390 PCI devices.
Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
There are two kexec load syscalls, kexec_load another and kexec_file_load.
kexec_file_load has been splited as kernel/kexec_file.c. In this patch I
split kexec_load syscall code to kernel/kexec.c.
And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and
use kexec_file_load only, or vice verse.
The original requirement is from Ted Ts'o, he want kexec kernel signature
being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use
kexec_load syscall can bypass the checking.
Vivek Goyal proposed to create a common kconfig option so user can compile
in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects
KEXEC_CORE so that old config files still work.
Because there's general code need CONFIG_KEXEC_CORE, so I updated all the
architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects
KEXEC_CORE in arch Kconfig. Also updated general kernel code with to
kexec_load syscall.
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Petr Tesarik <ptesarik@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
Signed-off-by: Philipp Hachtmann <phacht@linux.vnet.ibm.com>
NUMA emulation (aka fake NUMA) distributes the available memory to nodes
without using real topology information about the physical memory of the
machine.
Splitting the system memory into nodes replicates the memory management
structures for each node. Particularly each node has its own "mm locks"
and its own "kswapd" task.
For large systems, under certain conditions, this results in improved
system performance and/or latency based on reduced pressure on the mm
locks and the kswapd tasks.
NUMA emulation distributes CPUs to nodes while respecting the original
machine topology information. This is done by trying to avoid to separate
CPUs which reside on the same book or even on the same MC. Because the
current Linux scheduler code requires a stable cpu to node mapping, cores
are pinned to nodes when the first CPU thread is set online.
This patch is based on the initial implementation from Philipp Hachtmann.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Enable core NUMA support for s390 and add one simple default mode "plain"
that creates one single NUMA node.
This patch contains several changes from Michael Holzheu.
Add support for the generic CPU feature modalias implementation that wires
up optional CPU features to udev-based module autoprobing.
The <asm/cpufeature.h> file provides definitions to map CPU features to
s390 ELF hardware capabilities.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
The new ebpf code uses e.g. the laal instruction which is part of the
interlocked-access facility 1 which again was introduced with z196.
So we must make sure the ebpf code generator depends on MARCH_Z196_FEATURES.
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull more s390 updates from Martin Schwidefsky:
"The big thing in this second merge for s390 is the new eBPF JIT from
Michael which replaces the old 32-bit backend.
The remaining commits are bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/pci: add locking for fmb access
s390/pci: extract software counters from fmb
s390/dasd: Fix unresumed device after suspend/resume having no paths
s390/dasd: fix unresumed device after suspend/resume
s390/dasd: fix inability to set a DASD device offline
s390/mm: Fix memory hotplug for unaligned standby memory
s390/bpf: Add s390x eBPF JIT compiler backend
s390: Use bool function return values of true/false not 1/0
There are a lot of embedded systems that run most or all of their
functionality in init, running as root:root. For these systems,
supporting multiple users is not necessary.
This patch adds a new symbol, CONFIG_MULTIUSER, that makes support for
non-root users, non-root groups, and capabilities optional. It is enabled
under CONFIG_EXPERT menu.
When this symbol is not defined, UID and GID are zero in any possible case
and processes always have all capabilities.
The following syscalls are compiled out: setuid, setregid, setgid,
setreuid, setresuid, getresuid, setresgid, getresgid, setgroups,
getgroups, setfsuid, setfsgid, capget, capset.
Also, groups.c is compiled out completely.
In kernel/capability.c, capable function was moved in order to avoid
adding two ifdef blocks.
This change saves about 25 KB on a defconfig build. The most minimal
kernels have total text sizes in the high hundreds of kB rather than
low MB. (The 25k goes down a bit with allnoconfig, but not that much.
The kernel was booted in Qemu. All the common functionalities work.
Adding users/groups is not possible, failing with -ENOSYS.
Bloat-o-meter output:
add/remove: 7/87 grow/shrink: 19/397 up/down: 1675/-26325 (-24650)
Signed-off-by: Iulia Manda <iulia.manda21@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Replace 32 bit BPF JIT backend with new 64 bit eBPF backend.
Pull s390 updates from Martin Schwidefsky:
"The major change in this merge is the removal of the support for
31-bit kernels. Naturally 31-bit user space will continue to work via
the compat layer.
And then some cleanup, some improvements and bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (23 commits)
s390/smp: wait until secondaries are active & online
s390/hibernate: fix save and restore of kernel text section
s390/cacheinfo: add missing facility check
s390/syscalls: simplify syscall_get_arch()
s390/irq: enforce correct irqclass_sub_desc array size
s390: remove "64" suffix from mem64.S and swsusp_asm64.S
s390/ipl: cleanup macro usage
s390/ipl: cleanup shutdown_action attributes
s390/ipl: cleanup bin attr usage
s390/uprobes: fix address space annotation
s390: add missing arch_release_task_struct() declaration
s390: make couple of functions and variables static
s390/maccess: improve s390_kernel_write()
s390/maccess: remove potentially broken probe_kernel_write()
s390/watchdog: support for KVM hypervisors and delete pr_info messages
s390/watchdog: enable KEEPALIVE for /dev/watchdog
s390/dasd: remove setting of scheduler from driver
s390/traps: panic() instead of die() on translation exception
s390: remove test_facility(2) (== z/Architecture mode active) checks
s390/cmpxchg: simplify cmpxchg_double
Merge first patchbomb from Andrew Morton:
- arch/sh updates
- ocfs2 updates
- kernel/watchdog feature
- about half of mm/
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (122 commits)
Documentation: update arch list in the 'memtest' entry
Kconfig: memtest: update number of test patterns up to 17
arm: add support for memtest
arm64: add support for memtest
memtest: use phys_addr_t for physical addresses
mm: move memtest under mm
mm, hugetlb: abort __get_user_pages if current has been oom killed
mm, mempool: do not allow atomic resizing
memcg: print cgroup information when system panics due to panic_on_oom
mm: numa: remove migrate_ratelimited
mm: fold arch_randomize_brk into ARCH_HAS_ELF_RANDOMIZE
mm: split ET_DYN ASLR from mmap ASLR
s390: redefine randomize_et_dyn for ELF_ET_DYN_BASE
mm: expose arch_mmap_rnd when available
s390: standardize mmap_rnd() usage
powerpc: standardize mmap_rnd() usage
mips: extract logic for mmap_rnd()
arm64: standardize mmap_rnd() usage
x86: standardize mmap_rnd() usage
arm: factor out mmap ASLR into mmap_rnd
When an architecture fully supports randomizing the ELF load location,
a per-arch mmap_rnd() function is used to find a randomized mmap base.
In preparation for randomizing the location of ET_DYN binaries
separately from mmap, this renames and exports these functions as
arch_mmap_rnd(). Additionally introduces CONFIG_ARCH_HAS_ELF_RANDOMIZE
for describing this feature on architectures that support it
(which is a superset of ARCH_BINFMT_ELF_RANDOMIZE_PIE, since s390
already supports a separated ET_DYN ASLR from mmap ASLR without the
ARCH_BINFMT_ELF_RANDOMIZE_PIE logic).
Cc: Hector Marco-Gisbert <hecmargi@upv.es>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: "David A. Long" <dave.long@linaro.org>
Cc: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Arun Chandran <achandran@mvista.com>
Cc: Yann Droneaud <ydroneaud@opteya.com>
Cc: Min-Hua Chen <orca.chen@gmail.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Alex Smith <alex@alex-smith.me.uk>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Cc: Vineeth Vijayan <vvijayan@mvista.com>
Cc: Jeff Bailey <jeffbailey@google.com>
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Behan Webster <behanw@converseincode.com>
Cc: Ismael Ripoll <iripoll@upv.es>
Cc: Jan-Simon Mller <dl9pf@gmx.de>
We would want to use number of page table level to define mm_struct.
Let's expose it as CONFIG_PGTABLE_LEVELS.
Core mm expects __PAGETABLE_{PUD,PMD}_FOLDED to be defined if these page
table levels folded.
Tested-by: Guenter Roeck <linux@roeck-us.net>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching
Pull livepatching updates from Jiri Kosina:
"These are mostly smaller things that got accumulated during the
development cycle. The unified solution is still being worked on and
is not mature enough for 4.1 yet.
- s390 livepatching support, from Jiri Slaby (has Ack from s390
maintainers)
- error handling simplification, from Josh Poimboeuf
- two minor code cleanups from Josh Poimboeuf and Miroslav Benes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching:
livepatch: add support on s390
livepatch: remove unnecessary call to klp_find_object_module()
livepatch: simplify disable error path
livepatch: remove extern specifier from header files
This is a trivial port from kGraft. Module relocations are not supported yet.
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
Remove the 31 bit support in order to reduce maintenance cost and
effectively remove dead code. Since a couple of years there is no
distribution left that comes with a 31 bit kernel.
The 31 bit kernel also has been broken since more than a year before
anybody noticed. In addition I added a removal warning to the kernel
shown at ipl for 5 minutes: a960062e5826 ("s390: add 31 bit warning
message") which let everybody know about the plan to remove 31 bit
code. We didn't get any response.
Given that the last 31 bit only machine was introduced in 1999 let's
remove the code.
Anybody with 31 bit user space code can still use the compat mode.
With SMT we can have more than 256 CPUs. Let's make them available.
Make use of gcc's hotpatch support to generate better code for ftrace
function tracing.
The generated code now contains only a six byte nop in each function
prologue instead of a 24 byte code block which will be runtime patched to
support function tracing.
With the new code generation the runtime overhead for supporting function
tracing is close to zero, while the original code did show a significant
performance impact.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
The multi-threading facility is introduced with the z13 processor family.
This patch adds code to detect the multi-threading facility. With the
facility enabled each core will surface multiple hardware threads to the
system. Each hardware threads looks like a normal CPU to the operating
system with all its registers and properties.
The SCLP interface reports the SMT topology indirectly via the maximum
thread id. Each reported CPU in the result of a read-scp-information
is a core representing a number of hardware threads.
To reflect the reduced CPU capacity if two hardware threads run on a
single core the MT utilization counter set is used to normalize the
raw cputime obtained by the CPU timer deltas. This scaled cputime is
reported via the taskstats interface. The normal /proc/stat numbers
are based on the raw cputime and are not affected by the normalization.
Allow to generate code that only runs on z13 machines.
Following the suggestions from Andrew Morton and Stephen Rothwell,
Dont expand the ARCH list in kernel/gcov/Kconfig. Instead,
define a ARCH_HAS_GCOV_PROFILE_ALL bool which architectures
can enable.
set ARCH_HAS_GCOV_PROFILE_ALL on Architectures where it was
previously allowed + ARM64 which I tested.
Signed-off-by: Riku Voipio <riku.voipio@linaro.org>
Cc: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
"This patch set contains the main portion of the changes for 3.18 in
regard to the s390 architecture. It is a bit bigger than usual,
mainly because of a new driver and the vector extension patches.
The interesting bits are:
- Quite a bit of work on the tracing front. Uprobes is enabled and
the ftrace code is reworked to get some of the lost performance
back if CONFIG_FTRACE is enabled.
- To improve boot time with CONFIG_DEBIG_PAGEALLOC, support for the
IPTE range facility is added.
- The rwlock code is re-factored to improve writer fairness and to be
able to use the interlocked-access instructions.
- The kernel part for the support of the vector extension is added.
- The device driver to access the CD/DVD on the HMC is added, this
will hopefully come in handy to improve the installation process.
- Add support for control-unit initiated reconfiguration.
- The crypto device driver is enhanced to enable the additional AP
domains and to allow the new crypto hardware to be used.
- Bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (39 commits)
s390/ftrace: simplify enabling/disabling of ftrace_graph_caller
s390/ftrace: remove 31 bit ftrace support
s390/kdump: add support for vector extension
s390/disassembler: add vector instructions
s390: add support for vector extension
s390/zcrypt: Toleration of new crypto hardware
s390/idle: consolidate idle functions and definitions
s390/nohz: use a per-cpu flag for arch_needs_cpu
s390/vtime: do not reset idle data on CPU hotplug
s390/dasd: add support for control unit initiated reconfiguration
s390/dasd: fix infinite loop during format
s390/mm: make use of ipte range facility
s390/setup: correct 4-level kernel page table detection
s390/topology: call set_sched_topology early
s390/uprobes: architecture backend for uprobes
s390/uprobes: common library for kprobes and uprobes
s390/rwlock: use the interlocked-access facility 1 instructions
s390/rwlock: improve writer fairness
s390/rwlock: remove interrupt-enabling rwlock variant.
s390/mm: remove change bit override support
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull dma-mapping update from Marek Szyprowski:
"Provide the dma write coherent api (available previously on ARM
architecture) for all other architectures, which use dma_ops-based dma
mapping implementation.
This lets one to use the same code in the device drivers regardless of
the selected architecture"
* 'for-v3.18' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
dma-mapping: Provide write-combine allocations
s390: Implement dma_{alloc,free}_attrs()
31 bit and 64 bit diverge more and more and it is rather painful
to keep both parts running.
To make things simpler just remove the 31 bit support which nobody
uses anyway.
Signed-off-by: Jan Willeke <willeke@de.ibm.com>
We have too many combinations for function tracing. Lets simply stick to
the most advanced option, so we don't have to care of other combinations.
This means we always select DYNAMIC_FTRACE if FUNCTION_TRACER is selected.
In the s390 Makefile also remove CONFIG_FTRACE_SYSCALLS since that
functionality got moved to architecture independent code in the meantime.
This code is based on a patch from Vojtech Pavlik.
http://marc.info/?l=linux-s390&m=140438885114413&w=2
The actual implementation now differs significantly:
Instead of adding a second function "ftrace_regs_caller" which would be nearly
identical to the existing ftrace_caller function, the current ftrace_caller
function is now an alias to ftrace_regs_caller and always passes the needed
pt_regs structure and function_trace_op parameters unconditionally.
Besides that also use asm offsets to correctly allocate and access the new
struct pt_regs on the stack.
While at it we can make use of new instruction to get rid of some indirect
loads if compiled for new machines.
The passed struct pt_regs can be changed by the called function and it's new
contents will replace the current contents.
Note: to change the return address the embedded psw member of the pt_regs
structure must be changed. The psw member is right now incomplete, since
the mask part is missing. For all current use cases this should be sufficent.
Providing and restoring a sane mask would mean we need to add an epsw/lpswe
pair to the mcount code. Only these two instruction would cost us ~120 cycles
which currently seems not necessary.
Cc: Vojtech Pavlik <vojtech@suse.cz>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Jiri Slaby <jslaby@suse.cz>
New system call depends on crypto. As it did not have a separate config
option, CONFIG_KEXEC was modified to select CRYPTO and CRYPTO_SHA256.
But now previous patch introduced a new config option for new syscall.
So CONFIG_KEXEC does not require crypto. Remove that dependency.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Shaun Ruffell <sruffell@digium.com>
The S390 architecture advertises support for HAVE_DMA_ATTRS when PCI is
enabled. Patches to unify some of the DMA API would like to rely on the
dma_alloc_attrs() and dma_free_attrs() functions to be provided when an
architecture supports DMA attributes.
Rename dma_alloc_coherent() and dma_free_coherent() to dma_alloc_attrs()
and dma_free_attrs() since they are functionally equivalent and alias
the former to the latter for compatibility.
For consistency with other architectures, also reuse the existing symbol
HAVE_DMA_ATTRS defined in arch/Kconfig instead of providing a duplicate.
Select it when PCI is enabled.
While at it, drop a redundant 'default n' from the PCI Kconfig symbol.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Acked-By: Sebastian Ott <sebott@linux.vnet.ibm.com>
Load purgatory code in RAM and relocate it based on the location.
Relocation code has been inspired by module relocation code and purgatory
relocation code in kexec-tools.
Also compute the checksums of loaded kexec segments and store them in
purgatory.
Arch independent code provides this functionality so that arch dependent
bootloaders can make use of it.
Helper functions are provided to get/set symbol values in purgatory which
are used by bootloaders later to set things like stack and entry point of
second kernel etc.
Cc: Borislav Petkov <bp@suse.de>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Greg Kroah-Hartman <greg@kroah.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: WANG Chao <chaowang@redhat.com>
Cc: Baoquan He <bhe@redhat.com>
Rather than have architectures #define ARCH_HAS_SG_CHAIN in an
architecture specific scatterlist.h, make it a proper Kconfig option and
use that instead. At same time, remove the header files are are now
mostly useless and just include asm-generic/scatterlist.h.
[sfr@canb.auug.org.au: powerpc files now need asm/dma.h]
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Acked-by: Thomas Gleixner <tglx@linutronix.de> [x86]
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [powerpc]
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
"Mostly cleanups and bug-fixes, with two exceptions.
The first is lazy flushing of I/O-TLBs for PCI to improve performance,
the second is software dirty bits in the pmd for the madvise-free
implementation"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (24 commits)
s390/locking: Reenable optimistic spinning
s390/mm: implement dirty bits for large segment table entries
KVM: s390/mm: Fix page table locking vs. split pmd lock
s390/dasd: fix camel case
s390/3215: fix hanging console issue
s390/irq: improve displayed interrupt order in /proc/interrupts
s390/seccomp: fix error return for filtered system calls
s390/pci: introduce lazy IOTLB flushing for DMA unmap
dasd: fix error recovery for alias devices during format
dasd: fix list_del corruption during format
dasd: fix unresponsive device during format
dasd: use aliases for formatted devices during format
s390/pci: fix kmsg component
s390/kdump: Return NOTIFY_OK for all actions other than MEM_GOING_OFFLINE
s390/watchdog: Fix module name in Kconfig help text
s390/dasd: replace seq_printf by seq_puts
s390/dasd: replace pr_warning by pr_warn
s390/dasd: Move EXPORT_SYMBOL after function/variable
s390/dasd: remove unnecessary null test before debugfs_remove
s390/zfcp: use qdio buffer helpers
commit 4badad352a6bb202ec68afa7a574c0bb961e5ebc (locking/mutex: Disable
optimistic spinning on some architectures) fenced spinning for
architectures without proper cmpxchg.
There is no need to disable mutex spinning on s390, though:
The instructions CS,CSG and friends provide the proper guarantees.
(We dont implement cmpxchg with locks).
Cc: <stable@vger.kernel.org>
Pull timer and time updates from Thomas Gleixner:
"A rather large update of timers, timekeeping & co
- Core timekeeping code is year-2038 safe now for 32bit machines.
Now we just need to fix all in kernel users and the gazillion of
user space interfaces which rely on timespec/timeval :)
- Better cache layout for the timekeeping internal data structures.
- Proper nanosecond based interfaces for in kernel users.
- Tree wide cleanup of code which wants nanoseconds but does hoops
and loops to convert back and forth from timespecs. Some of it
definitely belongs into the ugly code museum.
- Consolidation of the timekeeping interface zoo.
- A fast NMI safe accessor to clock monotonic for tracing. This is a
long standing request to support correlated user/kernel space
traces. With proper NTP frequency correction it's also suitable
for correlation of traces accross separate machines.
- Checkpoint/restart support for timerfd.
- A few NOHZ[_FULL] improvements in the [hr]timer code.
- Code move from kernel to kernel/time of all time* related code.
- New clocksource/event drivers from the ARM universe. I'm really
impressed that despite an architected timer in the newer chips SoC
manufacturers insist on inventing new and differently broken SoC
specific timers.
[ Ed. "Impressed"? I don't think that word means what you think it means ]
- Another round of code move from arch to drivers. Looks like most
of the legacy mess in ARM regarding timers is sorted out except for
a few obnoxious strongholds.
- The usual updates and fixlets all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits)
timekeeping: Fixup typo in update_vsyscall_old definition
clocksource: document some basic timekeeping concepts
timekeeping: Use cached ntp_tick_length when accumulating error
timekeeping: Rework frequency adjustments to work better w/ nohz
timekeeping: Minor fixup for timespec64->timespec assignment
ftrace: Provide trace clocks monotonic
timekeeping: Provide fast and NMI safe access to CLOCK_MONOTONIC
seqcount: Add raw_write_seqcount_latch()
seqcount: Provide raw_read_seqcount()
timekeeping: Use tk_read_base as argument for timekeeping_get_ns()
timekeeping: Create struct tk_read_base and use it in struct timekeeper
timekeeping: Restructure the timekeeper some more
clocksource: Get rid of cycle_last
clocksource: Move cycle_last validation to core code
clocksource: Make delta calculation a function
wireless: ath9k: Get rid of timespec conversions
drm: vmwgfx: Use nsec based interfaces
drm: i915: Use nsec based interfaces
timekeeping: Provide ktime_get_raw()
hangcheck-timer: Use ktime_get_ns()
The non-scalar ktime_t implementation is basically a timespec
which has to be changed to support dates past 2038 on 32bit
systems.
This patch removes the non-scalar ktime_t implementation, forcing
the scalar s64 nanosecond version on all architectures.
This may have additional performance overhead on some 32bit
systems when converting between ktime_t and timespec structures,
however the majority of 32bit systems (arm and i386) were already
using scalar ktime_t, so no performance regressions will be seen
on those platforms.
On affected platforms, I'm open to finding optimizations, including
avoiding converting to timespecs where possible.
[ tglx: We can now cleanup the ktime_t.tv64 mess, but thats a
different issue and we can throw a coccinelle script at it ]
Signed-off-by: John Stultz <john.stultz@linaro.org>
Remove check of obsolete variable function_trace_stop as requested by
Steven Rostedt.
Currently there are two s390 kernel dump config options "CONFIG_ZFCPDUMP"
and "CONFIG_CRASH_DUMP". In order to keep things simple and because the
"CONFIG_ZFCPDUMP" option already has a dependency to "CONFIG_CRASH_DUMP"
remove the CONFIG_ZFCPDUMP option.
Reviewed-by: Eric Farman <farman@linux.vnet.ibm.com>
The original bootmem allocator is getting replaced by memblock. To
cover the needs of the s390 kdump implementation the physical memory
list is used.
With this patch the bootmem allocator and its bitmaps are completely
removed from s390.
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
If the renamed symbol is defined lib/iomap.c implements ioport_map and
ioport_unmap and currently (nearly) all platforms define the port
accessor functions outb/inb and friend unconditionally. So
HAS_IOPORT_MAP is the better name for this.
Consequently NO_IOPORT is renamed to NO_IOPORT_MAP.
The motivation for this change is to reintroduce a symbol HAS_IOPORT
that signals if outb/int et al are available. I will address that at
least one merge window later though to keep surprises to a minimum and
catch new introductions of (HAS|NO)_IOPORT.
The changes in this commit were done using:
$ git grep -l -E '(NO|HAS)_IOPORT' | xargs perl -p -i -e 's/\b((?:CONFIG_)?(?:NO|HAS)_IOPORT)\b/$1_MAP/'
"There are two memory management related changes, the CMMA support for
KVM to avoid swap-in of freed pages and the split page table lock for
the PMD level. These two come with common code changes in mm/.
A fix for the long standing theoretical TLB flush problem, this one
comes with a common code change in kernel/sched/.
Another set of changes is Heikos uaccess work, included is the initial
set of patches with more to come.
And fixes and cleanups as usual"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (36 commits)
s390/con3270: optionally disable auto update
s390/mm: remove unecessary parameter from pgste_ipte_notify
s390/mm: remove unnecessary parameter from gmap_do_ipte_notify
s390/mm: fixing comment so that parameter name match
s390/smp: limit number of cpus in possible cpu mask
hypfs: Add clarification for "weight_min" attribute
s390: update defconfigs
s390/ptrace: add support for PTRACE_SINGLEBLOCK
s390/perf: make print_debug_cf() static
s390/topology: Remove call to update_cpu_masks()
s390/compat: remove compat exec domain
s390: select CONFIG_TTY for use of tty in unconditional keyboard driver
s390/appldata_os: fix cpu array size calculation
s390/checksum: remove memset() within csum_partial_copy_from_user()
s390/uaccess: remove copy_from_user_real()
s390/sclp_early: Return correct HSA block count also for zero
s390: add some drivers/subsystems to the MAINTAINERS file
s390: improve debug feature usage
s390/airq: add support for irq ranges
s390/mm: enable split page table lock for PMD level
Currently AUDITSYSCALL has a long list of architecture depencency:
depends on AUDIT && (X86 || PARISC || PPC || S390 || IA64 || UML ||
SPARC64 || SUPERH || (ARM && AEABI && !OABI_COMPAT) || ALPHA)
The purpose of this patch is to replace it with HAVE_ARCH_AUDITSYSCALL
for simplicity.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com> (arm)
Acked-by: Richard Guy Briggs <rgb@redhat.com> (audit)
Acked-by: Matt Turner <mattst88@gmail.com> (alpha)
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Signed-off-by: Eric Paris <eparis@redhat.com>
The unconditionally built keyboard driver, drivers/s390/char/keyboard.c,
requires CONFIG_TTY, so select it from CONFIG_S390 to prevent a build
error.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there
is no runtime check necessary, allow to skip the test within futex_init().
This allows to get rid of some code which would always give the same result,
and also allows the compiler to optimize a couple of if statements away.
Cc: Finn Thain <fthain@telegraphics.com.au>
Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris
Add the pgtable_pmd_page_ctor/pgtable_pmd_page_dtor calls to the pmd
allocation and free functions and enable ARCH_ENABLE_SPLIT_PMD_PTLOCK
for 64 bit.
