[ Upstream commit 0398d4ab1677f7d8cd43aac2aa29a93dfcf9e2e3 ]
s390_crypto_shash_parmsize() return type is int, it
should not be stored in a unsigned variable, which
compared with zero.
Fixes: 3c2eb6b76cab ("s390/crypto: Support for SHA3 via CPACF (MSA6)")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Signed-off-by: Joerg Schmidbauer <jschmidb@linux.vnet.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"API:
- Add the ability to abort a skcipher walk.
Algorithms:
- Fix XTS to actually do the stealing.
- Add library helpers for AES and DES for single-block users.
- Add library helpers for SHA256.
- Add new DES key verification helper.
- Add surrounding bits for ESSIV generator.
- Add accelerations for aegis128.
- Add test vectors for lzo-rle.
Drivers:
- Add i.MX8MQ support to caam.
- Add gcm/ccm/cfb/ofb aes support in inside-secure.
- Add ofb/cfb aes support in media-tek.
- Add HiSilicon ZIP accelerator support.
Others:
- Fix potential race condition in padata.
- Use unbound workqueues in padata"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (311 commits)
crypto: caam - Cast to long first before pointer conversion
crypto: ccree - enable CTS support in AES-XTS
crypto: inside-secure - Probe transform record cache RAM sizes
crypto: inside-secure - Base RD fetchcount on actual RD FIFO size
crypto: inside-secure - Base CD fetchcount on actual CD FIFO size
crypto: inside-secure - Enable extended algorithms on newer HW
crypto: inside-secure: Corrected configuration of EIP96_TOKEN_CTRL
crypto: inside-secure - Add EIP97/EIP197 and endianness detection
padata: remove cpu_index from the parallel_queue
padata: unbind parallel jobs from specific CPUs
padata: use separate workqueues for parallel and serial work
padata, pcrypt: take CPU hotplug lock internally in padata_alloc_possible
crypto: pcrypt - remove padata cpumask notifier
padata: make padata_do_parallel find alternate callback CPU
workqueue: require CPU hotplug read exclusion for apply_workqueue_attrs
workqueue: unconfine alloc/apply/free_workqueue_attrs()
padata: allocate workqueue internally
arm64: dts: imx8mq: Add CAAM node
random: Use wait_event_freezable() in add_hwgenerator_randomness()
crypto: ux500 - Fix COMPILE_TEST warnings
This patch introduces sha3 support for s390.
- Rework the s390-specific SHA1 and SHA2 related code to
provide the basis for SHA3.
- Provide two new kernel modules sha3_256_s390 and
sha3_512_s390 together with new kernel options.
Signed-off-by: Joerg Schmidbauer <jschmidb@de.ibm.com>
Reviewed-by: Ingo Franzki <ifranzki@linux.ibm.com>
Reviewed-by: Harald Freudenberger <freude@linux.ibm.com>
With 'extra run-time crypto self tests' enabled, the selftest
for s390-xts fails with
alg: skcipher: xts-aes-s390 encryption unexpectedly succeeded on
test vector "random: len=0 klen=64"; expected_error=-22,
cfg="random: inplace use_digest nosimd src_divs=[2.61%@+4006,
84.44%@+21, 1.55%@+13, 4.50%@+344, 4.26%@+21, 2.64%@+27]"
This special case with nbytes=0 is not handled correctly and this
fix now makes sure that -EINVAL is returned when there is en/decrypt
called with 0 bytes to en/decrypt.
Signed-off-by: Harald Freudenberger <freude@linux.ibm.com>
Rename static / file-local functions so that they do not conflict with
the functions declared in crypto/sha256.h.
This is a preparation patch for folding crypto/sha256.h into crypto/sha.h.
Fix a typo XTS_BLOCKSIZE -> XTS_BLOCK_SIZE, causing the build to
break.
Fixes: ce68acbcb6a5 ("crypto: s390/xts-aes - invoke fallback for...")
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
For correctness and compliance with the XTS-AES specification, we are
adding support for ciphertext stealing to XTS implementations, even
though no use cases are known that will be enabled by this.
Since the s390 implementation already has a fallback skcipher standby
for other purposes, let's use it for this purpose as well. If ciphertext
stealing use cases ever become a bottleneck, we can always revisit this.
Switch to the refactored DES key verification routines. While at it,
rename the DES encrypt/decrypt routines so they will not conflict with
the DES library later on.
The context used to store the key blob used a fixed 80 bytes
buffer. And all the set_key functions did not even check the given key
size. With CCA variable length AES cipher keys there come key blobs
with about 136 bytes and maybe in the future there will arise the need
to store even bigger key blobs.
This patch reworks the paes set_key functions and the context
buffers to work with small key blobs (<= 128 bytes) directly in the
context buffer and larger blobs by allocating additional memory and
storing the pointer in the context buffer. If there has been memory
allocated for storing a key blob, it also needs to be freed on release
of the tfm. So all the paes ciphers now have a init and exit function
implemented for this job.
The newly introduced AES library exposes aes_encrypt/aes_decrypt
routines so rename existing occurrences of those identifiers in
the s390 driver.
To help avoid confusion, add a comment to ghash-generic.c which explains
the convention that the kernel's implementation of GHASH uses.
Also update the Kconfig help text and module descriptions to call GHASH
a "hash function" rather than a "message digest", since the latter
normally means a real cryptographic hash function, which GHASH is not.
Cc: Pascal Van Leeuwen <pvanleeuwen@verimatrix.com>
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Pascal Van Leeuwen <pvanleeuwen@verimatrix.com>
Let's use the error value that is typically used if HW support is not
available when trying to load a module - this is also what systemd's
systemd-modules-load.service expects.
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
Signed-off-by: David Hildenbrand <david@redhat.com>
This patch fixes a complain about possible sleep during
spinlock aquired
"BUG: sleeping function called from invalid context at
include/crypto/algapi.h:426"
for the ctr(aes) and ctr(des) s390 specific ciphers.
Instead of using a spinlock this patch introduces a mutex
which is save to be held in sleeping context. Please note
a deadlock is not possible as mutex_trylock() is used.
Reported-by: Julian Wiedmann <jwi@linux.ibm.com>
Cc: stable@vger.kernel.org
The current kernel uses improved crypto selftests. These
tests showed that the current implementation of gcm-aes-s390
is not able to deal with chunks of output buffers which are
not a multiple of 16 bytes. This patch introduces a rework
of the gcm aes s390 scatter walk handling which now is able
to handle any input and output scatter list chunk sizes
correctly.
Code has been verified by the crypto selftests, the tcrypt
kernel module and additional tests ran via the af_alg interface.
Cc: <stable@vger.kernel.org>
Reviewed-by: Patrick Steuer <steuer@linux.ibm.com>
Pull crypto update from Herbert Xu:
"API:
- Add support for AEAD in simd
- Add fuzz testing to testmgr
- Add panic_on_fail module parameter to testmgr
- Use per-CPU struct instead multiple variables in scompress
- Change verify API for akcipher
Algorithms:
- Convert x86 AEAD algorithms over to simd
- Forbid 2-key 3DES in FIPS mode
- Add EC-RDSA (GOST 34.10) algorithm
Drivers:
- Set output IV with ctr-aes in crypto4xx
- Set output IV in rockchip
- Fix potential length overflow with hashing in sun4i-ss
- Fix computation error with ctr in vmx
- Add SM4 protected keys support in ccree
- Remove long-broken mxc-scc driver
- Add rfc4106(gcm(aes)) cipher support in cavium/nitrox"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (179 commits)
crypto: ccree - use a proper le32 type for le32 val
crypto: ccree - remove set but not used variable 'du_size'
crypto: ccree - Make cc_sec_disable static
crypto: ccree - fix spelling mistake "protedcted" -> "protected"
crypto: caam/qi2 - generate hash keys in-place
crypto: caam/qi2 - fix DMA mapping of stack memory
crypto: caam/qi2 - fix zero-length buffer DMA mapping
crypto: stm32/cryp - update to return iv_out
crypto: stm32/cryp - remove request mutex protection
crypto: stm32/cryp - add weak key check for DES
crypto: atmel - remove set but not used variable 'alg_name'
crypto: picoxcell - Use dev_get_drvdata()
crypto: crypto4xx - get rid of redundant using_sd variable
crypto: crypto4xx - use sync skcipher for fallback
crypto: crypto4xx - fix cfb and ofb "overran dst buffer" issues
crypto: crypto4xx - fix ctr-aes missing output IV
crypto: ecrdsa - select ASN1 and OID_REGISTRY for EC-RDSA
crypto: ux500 - use ccflags-y instead of CFLAGS_<basename>.o
crypto: ccree - handle tee fips error during power management resume
crypto: ccree - add function to handle cryptocell tee fips error
The assembler code in arch/s390 misses proper ENDPROC statements
to properly end functions in a few places. Add them.
With the z14 machine there came also a CPACF hardware extension
which provides a True Random Number Generator. This TRNG can
be accessed with a new subfunction code within the CPACF prno
instruction and provides random data with very high entropy.
So if there is a TRNG available, let's use it for initial seeding
and reseeding instead of the current implementation which tries
to generate entropy based on stckf (store clock fast) jitters.
For details about the amount of data needed and pulled for
seeding and reseeding there can be explaining comments in the
code found.
Here is a rework of the generate_entropy function of the pseudo random
device driver exploiting the prno CPACF instruction.
George Spelvin pointed out some issues with the existing
implementation. One point was, that the buffer used to store the stckf
values is 2 pages which are initially filled with get_random_bytes()
for each 64 byte junk produced by the function. Another point was that
the stckf values only carry entropy in the LSB and thus a buffer of
2 pages is not really needed. Then there was a comment about the use
of the kimd cpacf function without proper initialization.
The rework addresses these points and now one page is used and only
one half of this is filled with get_random_bytes() on each chunk of 64
bytes requested data. The other half of the page is filled with stckf
values exored into with an overlap of 4 bytes. This can be done due to
the fact that only the lower 4 bytes carry entropy we need. For more
details about the algorithm used, see the header of the function.
The generate_entropy() function now uses the cpacf function klmd with
proper initialization of the parameter block to perform the sha512
hash.
George also pointed out some issues with the internal buffers used for
seeding and reads. These buffers are now zeroed with memzero_implicit
after use.
Reported-by: George Spelvin <lkml@sdf.org>
Suggested-by: George Spelvin <lkml@sdf.org>
This patch forbids the use of 2-key 3DES (K1 == K3) in FIPS mode.
CRYPTO_TFM_REQ_WEAK_KEY confuses newcomers to the crypto API because it
sounds like it is requesting a weak key. Actually, it is requesting
that weak keys be forbidden (for algorithms that have the notion of
"weak keys"; currently only DES and XTS do).
Also it is only one letter away from CRYPTO_TFM_RES_WEAK_KEY, with which
it can be easily confused. (This in fact happened in the UX500 driver,
though just in some debugging messages.)
Therefore, make the intent clear by renaming it to
CRYPTO_TFM_REQ_FORBID_WEAK_KEYS.
'cipher' algorithms (single block ciphers) are always synchronous, so
passing CRYPTO_ALG_ASYNC in the mask to crypto_alloc_cipher() has no
effect. Many users therefore already don't pass it, but some still do.
This inconsistency can cause confusion, especially since the way the
'mask' argument works is somewhat counterintuitive.
Thus, just remove the unneeded CRYPTO_ALG_ASYNC flags.
This patch shouldn't change any actual behavior.
"API:
- Remove VLA usage
- Add cryptostat user-space interface
- Add notifier for new crypto algorithms
Algorithms:
- Add OFB mode
- Remove speck
Drivers:
- Remove x86/sha*-mb as they are buggy
- Remove pcbc(aes) from x86/aesni
- Improve performance of arm/ghash-ce by up to 85%
- Implement CTS-CBC in arm64/aes-blk, faster by up to 50%
- Remove PMULL based arm64/crc32 driver
- Use PMULL in arm64/crct10dif
- Add aes-ctr support in s5p-sss
- Add caam/qi2 driver
Others:
- Pick better transform if one becomes available in crc-t10dif"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (124 commits)
crypto: chelsio - Update ntx queue received from cxgb4
crypto: ccree - avoid implicit enum conversion
crypto: caam - add SPDX license identifier to all files
crypto: caam/qi - simplify CGR allocation, freeing
crypto: mxs-dcp - make symbols 'sha1_null_hash' and 'sha256_null_hash' static
crypto: arm64/aes-blk - ensure XTS mask is always loaded
crypto: testmgr - fix sizeof() on COMP_BUF_SIZE
crypto: chtls - remove set but not used variable 'csk'
crypto: axis - fix platform_no_drv_owner.cocci warnings
crypto: x86/aes-ni - fix build error following fpu template removal
crypto: arm64/aes - fix handling sub-block CTS-CBC inputs
crypto: caam/qi2 - avoid double export
crypto: mxs-dcp - Fix AES issues
crypto: mxs-dcp - Fix SHA null hashes and output length
crypto: mxs-dcp - Implement sha import/export
crypto: aegis/generic - fix for big endian systems
crypto: morus/generic - fix for big endian systems
crypto: lrw - fix rebase error after out of bounds fix
crypto: cavium/nitrox - use pci_alloc_irq_vectors() while enabling MSI-X.
crypto: cavium/nitrox - NITROX command queue changes.
Enhance the paes_s390 kernel module to allow the paes cipher to
accept variable length key material. The key material accepted by
the paes cipher is a key blob of various types. As of today, two
key blob types are supported: CCA secure key blobs and protected
key blobs.
Signed-off-by: Ingo Franzki <ifranzki@linux.ibm.com>
Reviewed-by: Hendrik Brueckner <brueckner@linux.ibm.com>
In the quest to remove all stack VLA usage from the kernel[1], this
replaces struct crypto_skcipher and SKCIPHER_REQUEST_ON_STACK() usage
with struct crypto_sync_skcipher and SYNC_SKCIPHER_REQUEST_ON_STACK(),
which uses a fixed stack size.
[1] https://lkml.kernel.org/r/CA+55aFzCG-zNmZwX4A2FQpadafLfEzK6CC=qPXydAacU1RqZWA@mail.gmail.com
Cc: linux-s390@vger.kernel.org
The return code of cpacf_kmc() is less than the number of
bytes to process in case of an error, not greater.
The crypt routines for the other cipher modes already have
this correctly.
Cc: stable@vger.kernel.org # v4.11+
Fixes: 279378430768 ("s390/crypt: Add protected key AES module")
Acked-by: Harald Freudenberger <freude@linux.ibm.com>
Some aead algorithms set .cra_flags = CRYPTO_ALG_TYPE_AEAD. But this is
redundant with the C structure type ('struct aead_alg'), and
crypto_register_aead() already sets the type flag automatically,
clearing any type flag that was already there. Apparently the useless
assignment has just been copy+pasted around.
So, remove the useless assignment from all the aead algorithms.
Many shash algorithms set .cra_flags = CRYPTO_ALG_TYPE_SHASH. But this
is redundant with the C structure type ('struct shash_alg'), and
crypto_register_shash() already sets the type flag automatically,
So, remove the useless assignment from all the shash algorithms.
The arch_get_random_seed_long() invocation done by the random device
driver is done in interrupt context and may be invoked very very
frequently. The existing s390 arch_get_random_seed*() implementation
uses the PRNO(TRNG) instruction which produces excellent high quality
entropy but is relatively slow and thus expensive.
This fix reworks the arch_get_random_seed* implementation. It
introduces a buffer concept to decouple the delivery of random data
via arch_get_random_seed*() from the generation of new random
bytes. The buffer of random data is filled asynchronously by a
workqueue thread.
If there are enough bytes in the buffer the s390_arch_random_generate()
just delivers these bytes. Otherwise false is returned until the worker
thread refills the buffer.
The worker fills the rng buffer by pulling fresh entropy from the
high quality (but slow) true hardware random generator. This entropy
is then spread over the buffer with an pseudo random generator.
As the arch_get_random_seed_long() fetches 8 bytes and the calling
function add_interrupt_randomness() counts this as 1 bit entropy the
distribution needs to make sure there is in fact 1 bit entropy
contained in 8 bytes of the buffer. The current values pull 32 byte
entropy and scatter this into a 2048 byte buffer. So 8 byte in the
buffer will contain 1 bit of entropy.
The worker thread is rescheduled based on the charge level of the
buffer but at least with 500 ms delay to avoid too much cpu consumption.
So the max. amount of rng data delivered via arch_get_random_seed is
limited to 4Kb per second.
Signed-off-by: Harald Freudenberger <freude@de.ibm.com>
Reviewed-by: Patrick Steuer <patrick.steuer@de.ibm.com>
The return from the crc32_le_vgfm_16/crc32c_le_vgfm_16 and the
crc32_be_vgfm_16 functions are done with "br %r14". These are indirect
branches as well and need to use execute trampolines for CONFIG_EXPOLINE=y.
Cc: stable@vger.kernel.org # 4.16
Fixes: f19fbd5ed6 ("s390: introduce execute-trampolines for branches")
Reviewed-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Tests with paes-xts and debugging investigations showed
that the ciphers are not always correctly resolved.
The rules for cipher priorities seem to be:
- Ecb-aes should have a prio greater than the
generic ecb-aes.
- The mode specialized ciphers (like cbc-aes-s390)
should have a prio greater than the sum of the
more generic combinations (like cbs(aes)).
This patch adjusts the cipher priorities for the
s390 aes and paes in kernel crypto implementations.
Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com>
A kernel crash occurs when the aes_s390 kernel module is
removed on machines < z14. This only happens on kernel
version 4.15 and higher on machines not supporting MSA 8.
The reason for the crash is a unconditional
crypto_unregister_aead() invocation where no previous
crypto_register_aead() had been called. The fix now
remembers if there has been a successful registration and
only then calls the unregister function upon kernel module
remove.
The code now crashing has been introduced with
"bf7fa03 s390/crypto: add s390 platform specific aes gcm support."
We need to consistently enforce that keyed hashes cannot be used without
setting the key. To do this we need a reliable way to determine whether
a given hash algorithm is keyed or not. AF_ALG currently does this by
checking for the presence of a ->setkey() method. However, this is
actually slightly broken because the CRC-32 algorithms implement
->setkey() but can also be used without a key. (The CRC-32 "key" is not
actually a cryptographic key but rather represents the initial state.
If not overridden, then a default initial state is used.)
Prepare to fix this by introducing a flag CRYPTO_ALG_OPTIONAL_KEY which
indicates that the algorithm has a ->setkey() method, but it is not
required to be called. Then set it on all the CRC-32 algorithms.
The same also applies to the Adler-32 implementation in Lustre.
Also, the cryptd and mcryptd templates have to pass through the flag
from their underlying algorithm.
More files under arch/s390 have been tagged with the SPDX identifier,
a few of those files have a GPL license text. Remove the GPL text
as it is no longer needed.
Add the correct SPDX license to a few more files under arch/s390 and
drivers/s390 which have been missed to far.
The SPDX identifier is a legally binding shorthand, which can be used
instead of the full boiler plate text.
Now that the SPDX tag is in all arch/s390/crypto/ files, that identifies
the license in a specific and legally-defined manner. So the extra GPL
text wording can be removed as it is no longer needed at all.
This is done on a quest to remove the 700+ different ways that files in
the kernel describe the GPL license text. And there's unneeded stuff
like the address (sometimes incorrect) for the FSF which is never
needed.
No copyright headers or other non-license-description text was removed.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
It's good to have SPDX identifiers in all files to make it easier to
audit the kernel tree for correct licenses.
Update the arch/s390/crypto/ files with the correct SPDX license
identifier based on the license text in the file itself. The SPDX
identifier is a legally binding shorthand, which can be used instead of
This work is based on a script and data from Thomas Gleixner, Philippe
Ombredanne, and Kate Stewart.
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Heiko Carstens:
"Since Martin is on vacation you get the s390 pull request for the
v4.15 merge window this time from me.
Besides a lot of cleanups and bug fixes these are the most important
changes:
- a new regset for runtime instrumentation registers
- hardware accelerated AES-GCM support for the aes_s390 module
- support for the new CEX6S crypto cards
- support for FORTIFY_SOURCE
- addition of missing z13 and new z14 instructions to the in-kernel
disassembler
- generate opcode tables for the in-kernel disassembler out of a
simple text file instead of having to manually maintain those
tables
- fast memset16, memset32 and memset64 implementations
- removal of named saved segment support
- hardware counter support for z14
- queued spinlocks and queued rwlocks implementations for s390
- use the stack_depth tracking feature for s390 BPF JIT
- a new s390_sthyi system call which emulates the sthyi (store
hypervisor information) instruction
- removal of the old KVM virtio transport
- an s390 specific CPU alternatives implementation which is used in
the new spinlock code"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (88 commits)
MAINTAINERS: add virtio-ccw.h to virtio/s390 section
s390/noexec: execute kexec datamover without DAT
s390: fix transactional execution control register handling
s390/bpf: take advantage of stack_depth tracking
s390: simplify transactional execution elf hwcap handling
s390/zcrypt: Rework struct ap_qact_ap_info.
s390/virtio: remove unused header file kvm_virtio.h
s390: avoid undefined behaviour
s390/disassembler: generate opcode tables from text file
s390/disassembler: remove insn_to_mnemonic()
s390/dasd: avoid calling do_gettimeofday()
s390: vfio-ccw: Do not attempt to free no-op, test and tic cda.
s390: remove named saved segment support
s390/archrandom: Reconsider s390 arch random implementation
s390/pci: do not require AIS facility
s390/qdio: sanitize put_indicator
s390/qdio: use atomic_cmpxchg
s390/nmi: avoid using long-displacement facility
s390: pass endianness info to sparse
s390/decompressor: remove informational messages
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This patch introduces gcm(aes) support into the aes_s390 kernel module.
Signed-off-by: Patrick Steuer <patrick.steuer@de.ibm.com>
The s390_paes and the s390_aes kernel module used just one
config symbol CONFIG_CRYPTO_AES. As paes has a dependency
to PKEY and this requires ZCRYPT the aes module also had
a dependency to the zcrypt device driver which is not true.
Fixed by introducing a new config symbol CONFIG_CRYPTO_PAES
which has dependencies to PKEY and ZCRYPT. Removed the
dependency for the aes module to ZCRYPT.
Add missing include statements to make sure that prototypes match
implementation. As reported by sparse:
arch/s390/crypto/arch_random.c:18:1:
warning: symbol 's390_arch_random_available' was not declared. Should it be static?
arch/s390/kernel/traps.c:279:13: warning:
symbol 'trap_init' was not declared. Should it be static?
For automatic module loading (e.g. as it is used with cryptsetup)
an alias "paes" for the paes_s390 kernel module is needed.
Correct the paes_s390 module alias from "aes-all" to "paes".
This patch introduces s390 specific arch random functionality.
There exists a generic kernel API for arch specific random
number implementation (see include/linux/random.h). Here
comes the header file and a very small static code part
implementing the arch_random_* API based on the TRNG
subfunction coming with the reworked PRNG instruction.
The arch random implementation hooks into the kernel
initialization and checks for availability of the TRNG
function. In accordance to the arch random API all functions
return false if the TRNG is not available. Otherwise the new
high quality entropy source provides fresh random on each
invocation.
The s390 arch random feature build is controlled via
CONFIG_ARCH_RANDOM. This config option located in
arch/s390/Kconfig is enabled by default and appears
as entry "s390 architectural random number generation API"
in the submenu "Processor type and features" for s390 builds.
The PPNO (Perform Pseudorandom Number Operation) instruction
has been renamed to PRNO (Perform Random Number Operation).
To avoid confusion and conflicts with future extensions with
this instruction (like e.g. provide a true random number
generator) this patch renames all occurences in cpacf.h and
adjusts the only exploiter code which is the prng device
driver and one line in the s390 kvm feature check.
Pull s390 fixes from Martin Schwidefsky:
- four patches to get the new cputime code in shape for s390
- add the new statx system call
- a few bug fixes
s390: wire up statx system call
KVM: s390: Fix guest migration for huge guests resulting in panic
s390/ipl: always use load normal for CCW-type re-IPL
s390/timex: micro optimization for tod_to_ns
s390/cputime: provide archicture specific cputime_to_nsecs
s390/cputime: reset all accounting fields on fork
s390/cputime: remove last traces of cputime_t
s390: fix in-kernel program checks
s390/crypt: fix missing unlock in ctr_paes_crypt on error path
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
The ctr mode of protected key aes uses the ctrblk page if the
ctrblk_lock could be acquired. If the protected key has to be
reestablished and this operation fails the unlock for the
ctrblk_lock is missing. Add it.
This patch introduces a new in-kernel-crypto blockcipher
called 'paes' which implements AES with protected keys.
The paes blockcipher can be used similar to the aes
blockcipher but uses secure key material to derive the
working protected key and so offers an encryption
implementation where never a clear key value is exposed
in memory.
The paes module is only available for the s390 platform
providing a minimal hardware support of CPACF enabled
with at least MSA level 3. Upon module initialization
these requirements are checked.
Includes additional contribution from Harald Freudenberger.
