path: root/arch/s390/include/asm/crw.h
2012-07-20s390/comments: unify copyright messages and remove file namesHeiko Carstens
Remove the file name from the comment at top of many files. In most cases the file name was wrong anyway, so it's rather pointless. Also unify the IBM copyright statement. We did have a lot of sightly different statements and wanted to change them one after another whenever a file gets touched. However that never happened. Instead people start to take the old/"wrong" statements to use as a template for new files. So unify all of them in one go. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2010-02-26[S390] cio: wait for channel reportSebastian Ott
To fetch a pending channel report word (crw) we use a kernel thread which triggers stcrw and sleeps on a semaphore. The s390 machine check handler uses crw_handle_channel_report to handle one crw if needed. This patch replaces the semaphore with a waitqueue (to block the kernel thread) and an atomic_t (to count the number of pending requests). By this we achieve the ability to force this thread to check for a pending crw (independent on when it is triggered by the machine check handler) and wait for this action to finish. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-03-26[S390] split/move machine check handler codeHeiko Carstens
Split machine check handler code and move it to cio and kernel code where it belongs to. No functional change. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
