path: root/arch/s390/kernel/asm-offsets.c
2008-04-29s390: use kbuild.h instead of defining macros in asm-offsets.cChristoph Lameter
New version that does not preserve the marker. Arch maintainers indicate that the marker functionality is is not needed anymore. Note you may simplify the s390 asm-offsets.c code further if you use the OFFSET() macro instead of the DEFINE. See kbuild.h Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
s390 has a strange marker in DEFINE. Undefine the DEFINE from kbuild.h and define it the way s390 wants it to preserve things as they were. May be good if the arch maintainer could go over this and check if this workaround is really necessary. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09rename thread_info to stackRoman Zippel
This finally renames the thread_info field in task structure to stack, so that the assumptions about this field are gone and archs have more freedom about placing the thread_info structure. Nonbroken archs which have a proper thread pointer can do the access to both current thread and task structure via a single pointer. It'll allow for a few more cleanups of the fork code, from which e.g. ia64 could benefit. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> [akpm@linux-foundation.org: build fix] Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Andi Kleen <ak@muc.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
