path: root/arch/s390/kernel/s390_ext.c
2008-04-17[S390] Fix a lot of sparse warnings.Heiko Carstens
Most noteable part of this commit is the new local header file entry.h which contains all the function declarations of functions that get only called from asm code or are arch internal. That way we can avoid extern declarations in C files. This is more or less the same that was done for sparc64. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] Convert s390 to GENERIC_CLOCKEVENTS.Heiko Carstens
This way we get rid of s390's NO_IDLE_HZ and use the generic dynticks variant instead. In addition we get high resolution timers for free. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] Convert monitor calls to function calls.Heiko Carstens
Remove the program check generating monitor calls and use function calls instead. Theres is no real advantage in using monitor calls, but they do make debugging harder, because of all the program checks it generates. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-02-05[S390] ETR support.Martin Schwidefsky
This patch adds support for clock synchronization to an external time reference (ETR). The external time reference sends an oscillator signal and a synchronization signal every 2^20 microseconds to keep the TOD clocks of all connected servers in sync. For availability two ETR units can be connected to a machine. If the clock deviates for more than the sync-check tolerance all cpus get a machine check that indicates that the clock is out of sync. For the lovely details how to get the clock back in sync see the code below. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[S390] irq change improvements.Heiko Carstens
Remove the last few places where a pointer to pt_regs gets passed. Also make sure we call set_irq_regs() before irq_enter() and after irq_exit(). This doesn't fix anything but makes sure s390 looks the same like all other architectures. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-10-06[S390] irq change build fixes.Heiko Carstens
2006-07-12[S390] Fix sparse warnings.Heiko Carstens
2005-07-27[PATCH] s390: external call performanceHeiko Carstens
The kernel uses the SIGP external call order code to signal other CPUs. When running with dedicated CPUs external calls don't get delivered immediately but within a fixed polling invervall. This can lead to delays where the system appears to do nothing. Replace the SIGP external call order with the SIGP emergency call order since this one gets delivered immediately. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
