Use a console_initcall() to initialize the s390 virtio console and
clean up s390 console initialization in setup.c.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
setup_arch() unconditionally sets the preferred console to ttyS.
This breaks the use of 3270 devices as the console. Provide a new
function to set the default preferred console for s390. The preferred
console depends on the conmode parameter that is used to switch
between 3270 and 3215 terminal/console mode.
Dynamic ftrace support for s390.
Start the cpu time accounting very early to catch the cpu time spent
for the initial kernel setup. To make the output of /proc/uptime
match the sum of all cpu accounting values of the boot cpu reset
xtime and wall_to_monotonic to sane values based on the TOD clock.
The values set by timekeeping_init are off by up to a second.
Currently the storage of the machine flags is a globally exported unsigned
long long variable. By moving the storage location into the lowcore struct we
allow assembler code to check machine_flags directly even without needing a
register. Addtionally the lowcore and therefore the machine flags too will be
in cache most of the time.
Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
The Extended Translation Facility 3 (ETF3) added instructions which
allow conversions between different unicode character maps (UTF-8,
UTF-32 ...). These instructions got enhanced with a later version of
the ETF3 allowing malformed multibyte chars to be recognized and
reported correctly. The attached patch reserves bit 8 in the elf
hwcaps vector for the enhanced version of ETF3. The bit corresponds to
the stfle bits 22 and 30 and will only be set if both of the stfle
bits are set.
Signed-off-by: Andreas Krebbel <krebbel@linux.vnet.ibm.com>
The old dfp detection wanted to check bit 43 (dfp high performance), but due
to a wrong calculation always used to check bit 42. Additionally the
"userspace expectation" is, that the dfp capability bit is set is if facility
bit 42 (decimal floating point facility available) and bit 44 (perform floating
point operation facility avail).
The patch fixes the bit calculation and extends the check to work like:
elf hw cap dfp bit = facility bits 42 (dfp) & 44 (pfpo) available
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com>
The zcore code switches to real addressing mode when creating a kernel dump.
This is not possible, if it is built as a kernel module. With this patch
zcore (zfcpdump) can't be built as a kernel module any more.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Disable switch_amode by default because pagetable walk on pre z9
hardware has negative performance impact.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Move all EXPORT_SYMBOLs to their corresponding definitions.
Provide new shutdown action "dump_reipl" for automatic ipl after dump.
Signed-off-by: Frank Munzert <munzert@de.ibm.com>
Standby memory detected with the sclp interface gets always registered
with add_memory calls without considering the limitationt that the
"mem=" kernel paramater implies.
So fix this and only register standby memory that is below the specified
limit.
This fixes zfcpdump since it uses "mem=32M". In case there is appr.
2GB standby memory present all of usable memory would be used for the
struct pages needed for standby memory.
The extract cpu time instruction (ectg) instruction allows the user
process to get the current thread cputime without calling into the
kernel. The code that uses the instruction needs to switch to the
access registers mode to get access to the per-cpu info page that
contains the two base values that are needed to calculate the current
cputime from the CPU timer with the ectg instruction.
This patch sets the default console device for s390.
The console= kernel parameter can be still used to switch the preferred
console to some other device. In that case, console messages are also
printed on the default console device (ttyS0).
Add the machine types for z9-bc, z10-ec and z10-bc to the elf_platform
detection in setup_hwcaps.
stfle will be needed by the ap_bus module to figure out wether the AP
queue adapter interruption facility is installed.
add_active_range() expects start_pfn + size as end_pfn value, i.e. not
the pfn of the last page frame but the one behind that.
We used the pfn of the last page frame so far, which can lead to a
BUG_ON in move_freepages(), when the kernelcore parameter is specified
(page_zone(start_page) != page_zone(end_page)).
This patch enables virtio_console as the default console on kvm for
s390. We currently use the same notify hack as lguest for early
console output. I will try to address this for lguest and s390 later.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Most likely it is broken anyway because of the changes in memory
detection. Since we can't test it and there are probably better ways
that using a P390 card, remove support for it.
Move memory detection code to own file and also simplify it.
Also add an interface which can be called at any time to get the
current memory layout. This interface is needed by our kernel
internal system dumper.
Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Cc: Michael Holzheu <holzheu@de.ibm.com>
Cc: Frank Munzert <munzert@de.ibm.com>
Now it is possible to specify additional kernel parameters on the IPL
command line using the IPL PARM option.
If the Linux system is already running, the new reipl sysfs attribute
'parm' can be used to change kernel parameters for the next reboot.
Examples:
IPL C PARM dasd=1234 root=/dev/dasda1
IPL 1234 PARM savesys=mylnxnss
echo "init=/bin/bash" > /sys/firmware/reipl/ccw/parm
Using the ipldelay kernel parameter leads to a crash at IPL time.
Since this is broken since a long time it looks like nobody is using
it anymore. So remove it instead of fixing it.
This adds hugetlbfs support on System z, using both hardware large page
support if available and software large page emulation on older hardware.
Shared (large) page tables are implemented in software emulation mode,
by using page->index of the first tail page from a compound large page
to store page table information.
Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com>
This lets us use defines for the magic bits in machine flags instead
of using plain numbers all over the place.
In addition on newer machines features/facilities are indicated by the
result of the stfl instruction. So we use these bits instead of trying
to execute new instructions and check wether we get an exception or
not.
Also the mvpg instruction is always available when in zArch mode,
whereas the idte instruction is only available in zArch mode. This
results in some minor optimizations.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
This patch adds functionality to detect if the kernel runs under the KVM
hypervisor. A macro MACHINE_IS_KVM is exported for device drivers. This
allows drivers to skip device detection if the systems runs non-virtualized.
We also define a preferred console to avoid having the ttyS0, which is a line
mode only console.
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
The SIE instruction on s390 uses the 2nd half of the page table page to
virtualize the storage keys of a guest. This patch offers the s390_enable_sie
function, which reorganizes the page tables of a single-threaded process to
reserve space in the page table:
s390_enable_sie makes sure that the process is single threaded and then uses
dup_mm to create a new mm with reorganized page tables. The old mm is freed
and the process has now a page status extended field after every page table.
Code that wants to exploit pgstes should SELECT CONFIG_PGSTE.
This patch has a small common code hit, namely making dup_mm non-static.
Edit (Carsten): I've modified Martin's patch, following Jeremy Fitzhardinge's
review feedback. Now we do have the prototype for dup_mm in
include/linux/sched.h. Following Martin's suggestion, s390_enable_sie() does now
call task_lock() to prevent race against ptrace modification of mm_users.
Acked-by: Andrew Morton <akpm@linux-foundation.org>
This way we get rid of s390's NO_IDLE_HZ and use the generic dynticks
variant instead. In addition we get high resolution timers for free.
Add s390 backend so we can give the scheduler some hints about the
cpu topology.
Make stfle visible so other code can call this.
This patchset adds a flags variable to reserve_bootmem() and uses the
BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions
between crashkernel area and already used memory.
This patch:
Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE.
If that flag is set, the function returns with -EBUSY if the memory already
has been reserved in the past. This is to avoid conflicts.
Because that code runs before SMP initialisation, there's no race condition
inside reserve_bootmem_core().
[akpm@linux-foundation.org: fix powerpc build]
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: <linux-arch@vger.kernel.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Remove BUILD_BUG_ON() in vmem code since it causes build failures if
the size of struct page increases. Instead calculate at compile time
the address of the highest physical address that can be added to the
1:1 mapping.
This supposed to fix a build failure with the page owner tracking leak
detector patches as reported by akpm.
page-owner-tracking-leak-detector-broken-on-s390.patch can be removed
from -mm again when this is merged.
Fix console detection logic to support configurations in which the
vt220 console is the only available Linux console.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Fix couple of section mismatches. And since we touch the code
anyway change the IPL code to use C99 initializers.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
In case of a kernel panic it is currently possible to specify that a dump
should be created, the system should be rebooted or stopped. Virtual sysfs
files under the directory /sys/firmware/ are used for that configuration.
In addition to that, there are kernel parameters 'vmhalt', 'vmpoff'
and 'vmpanic', which can be used to specify z/VM commands, which are
automatically executed in case of halt, power off or a kernel panic.
This patch combines both functionalities and allows to specify the z/VM CP
commands also via sysfs attributes. In addition to that, it enhances the
existing handling of shutdown triggers (e.g. halt or panic) and associated
shutdown actions (e.g. dump or reipl) and makes it more flexible.
Signed-off-by: Michael Holzheu <holzheu@de.ibm.com>
It caused only a lot of confusion. From now on cpu hotplug of up to
NR_CPUS will work by default. If somebody wants to limit that then
the possible_cpus parameter can be used.
Align everything to MAX_ORDER so we can get rid of the extra checks.
Currently the vmalloc area starts at a dynamic address depending on
the memory size. There was also an 8MB security hole after the
physical memory to catch out-of-bounds accesses.
We can simplify the code by putting the vmalloc area explicitely at
the top of the kernel mapping and setting the vmalloc size to a fixed
value of 128MB/128GB for 31bit/64bit systems. Part of the vmalloc
area will be used for the vmem_map. This leaves an area of 96MB/1GB
for normal vmalloc allocations.
Add a new interface so that cpus can be put into standby state and
configured state.
Only offline cpus can be put into standby state or configured state.
For that the new percpu sysfs attribute "configure" must be used.
To put a cpu in standby state a "0" must be written to the attribute.
In order to switch it into configured state a "1" must be written to
the attribute.
Only cpus in configured state can be brought online.
In addition this patch introduces a static mapping of physical to
logical cpus. As a result only the sysfs directories of present cpus
will be created. To scan for new cpus the new sysfs attribute "rescan"
must be used.
Writing to /sys/devices/system/cpu/rescan will trigger a rescan of
cpus and will create directories for new cpus.
On IPL only configured cpus will be used. And on reboot/shutdown all
cpus will remain in their current state (configured/standby).
In case of TRACE_IRQFLAGS the restore psw masks will not be
initialized if noexec is turned on. This will lead to an
immediate system crash.
Current support for TRACE_IRQFLAGS and lockdep_sys_exit is broken.
IRQ flag tracing is broken for program checks. Even worse is that
the newly introduced calls to lockdep_sys_exit are in the critical
section code which is not supposed to call any C functions. In
addition the checks if locks are still held are also done when
returning to kernel code which is broken as well.
Fix all this by disabling interrupts and machine checks at the
exit paths and then do the appropriate checks and calls.
When doing an magic sysrq reboot on s390 the following bug message
appears:
SysRq : Resetting
BUG: sleeping function called from invalid context at include/asm/semaphore.h:61
in_atomic():1, irqs_disabled():0
07000000004002a8 000000000fe6bc48 0000000000000002 0000000000000000
000000000fe6bce8 000000000fe6bc60 000000000fe6bc60 000000000012a79a
0000000000000000 07000000004002a8 0000000000000006 0000000000000000
0000000000000000 000000000fe6bc48 000000000000000d 000000000fe6bcb8
00000000004000c8 0000000000103234 000000000fe6bc48 000000000fe6bc90
Call Trace:
(¬<00000000001031b2>| show_trace+0x12e/0x148)
¬<000000000011ffca>| __might_sleep+0x10a/0x118
¬<0000000000129fba>| acquire_console_sem+0x92/0xf4
¬<000000000012a2ca>| console_unblank+0xc2/0xc8
¬<0000000000107bb4>| machine_restart+0x54/0x6c
¬<000000000028e806>| sysrq_handle_reboot+0x26/0x30
¬<000000000028e52a>| __handle_sysrq+0xa6/0x180
¬<0000000000140134>| run_workqueue+0xcc/0x18c
¬<000000000014029a>| worker_thread+0xa6/0x108
¬<00000000001458e4>| kthread+0x64/0x9c
¬<0000000000106f0e>| kernel_thread_starter+0x6/0xc
¬<0000000000106f08>| kernel_thread_starter+0x0/0xc
The only reason for doing a console_unblank on s390 is to flush the
log buffer. We have to check for in_atomic before doing a
console_unblank as the console is otherwise filled with an unrelated
bug message.
