CPUSTAT_RUNNING was implemented signifying that a vcpu is not stopped.
This is not, however, what the architecture says: RUNNING should be
set when the host is acting on the behalf of the guest operating
system.
CPUSTAT_RUNNING has been changed to be set in kvm_arch_vcpu_load()
and to be unset in kvm_arch_vcpu_put().
For signifying stopped state of a vcpu, a host-controlled bit has
been used and is set/unset basically on the reverse as the old
CPUSTAT_RUNNING bit (including pushing it down into stop handling
proper in handle_stop()).
Cc: stable@kernel.org
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Linux on System z uses a ballooner based on diagnose 0x10. (aka as
collaborative memory management). This patch implements diagnose
0x10 on the guest address space.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
ENOTSUPP is not supposed to leak to userspace so lets just use
EOPNOTSUPP everywhere.
Doesn't fix a bug, but makes future reviews easier.
As requested by Andrew. Same as what sparc did.
diag 0x44 is the common way on s390 to yield the cpu to the hypervisor.
It is called by the guest in cpu_relax and in the spinlock code to
yield to other guest cpus.
This semantic is similar to yield. Lets replace the call to schedule with
yield to make sure that current is really yielding.
Signed-off-by: Avi Kivity <avi@qumranet.com>
This patch introduces interpretation of some diagnose instruction intercepts.
Diagnose is our classic architected way of doing a hypercall. This patch
features the following diagnose codes:
- vm storage size, that tells the guest about its memory layout
- time slice end, which is used by the guest to indicate that it waits
for a lock and thus cannot use up its time slice in a useful way
- ipl functions, which a guest can use to reset and reboot itself
In order to implement ipl functions, we also introduce an exit reason that
causes userspace to perform various resets on the virtual machine. All resets
are described in the principles of operation book, except KVM_S390_RESET_IPL
which causes a reboot of the machine.
Acked-by: Martin Schwidefsky <martin.schwidefsky@de.ibm.com>
