commit 9e6dabeffd1d0ec2aa19aa076c4886067238d442 upstream.
CPUSTAT_RUNNING was implemented signifying that a vcpu is not stopped.
This is not, however, what the architecture says: RUNNING should be
set when the host is acting on the behalf of the guest operating
system.
CPUSTAT_RUNNING has been changed to be set in kvm_arch_vcpu_load()
and to be unset in kvm_arch_vcpu_put().
For signifying stopped state of a vcpu, a host-controlled bit has
been used and is set/unset basically on the reverse as the old
CPUSTAT_RUNNING bit (including pushing it down into stop handling
proper in handle_stop()).
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit 4d47555a80495657161a7e71ec3014ff2021e450 upstream.
We use the cpu id provided by userspace as array index here. Thus we
clearly need to check it first. Ooops.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
598841ca9919d008b520114d8a4378c4ce4e40a1 ([S390] use gmap address
spaces for kvm guest images) changed kvm on s390 to use a separate
address space for kvm guests. We can now put KVM guests anywhere
in the user address mode with a size up to 8PB - as long as the
memory is 1MB-aligned. This change was done without KVM extension
capability bit.
The change was added after 3.0, but we still have a chance to add
a feature bit before 3.1 (keeping the releases in a sane state).
We use number 71 to avoid collisions with other pending kvm patches
as requested by Alexander Graf.
Acked-by: Avi Kivity <avi@redhat.com>
Cc: Alexander Graf <agraf@suse.de>
spaces for kvm guest images) changed kvm to use a separate address
space for kvm guests. This address space was switched in __vcpu_run
In some cases (preemption, page fault) there is the possibility that
this address space switch is lost.
The typical symptom was a huge amount of validity intercepts or
random guest addressing exceptions.
Fix this by doing the switch in sie_loop and sie_exit and saving the
address space in the gmap structure itself. Also use the preempt
notifier.
SIGP emerg needs to pass the source vpu adress into __LC_CPU_ADDRESS of the
target guest.
Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
This patch removes the mmu reload logic for kvm on s390. Via Martin's
new gmap interface, we can safely add or remove memory slots while
guest CPUs are in-flight. Thus, the mmu reload logic is not needed
anymore.
This patch removes kvm-s390 internal assumption of a linear mapping
of guest address space to user space. Previously, guest memory was
translated to user addresses using a fixed offset (gmsor). The new
code uses gmap_fault to resolve guest addresses.
This patch switches kvm from using (Qemu's) user address space to
Martin's gmap address space. This way QEMU does not have to use a
linker script in order to fit large guests at low addresses in its
address space.
The entry to / exit from sie has subtle dependencies to the first level
interrupt handler. Move the sie assembler code to entry64.S and replace
the SIE_HOOK callback with a test and the new _TIF_SIE bit.
In addition this patch fixes several problems in regard to the check for
the_TIF_EXIT_SIE bits. The old code checked the TIF bits before executing
the interrupt handler and it only modified the instruction address if it
pointed directly to the sie instruction. In both cases it could miss
a TIF bit that normally would cause an exit from the guest and would
reenter the guest context.
When running a kvm guest we can get intercepts for tprot, if the host
page table is read-only or not populated. This patch implements the
most common case (linux memory detection).
This also allows host copy on write for guest memory on newer systems.
virtio has been so far used only in the context of virtualization,
and the virtio Kconfig was sourced directly by the relevant arch
Kconfigs when VIRTUALIZATION was selected.
Now that we start using virtio for inter-processor communications,
we need to source the virtio Kconfig outside of the virtualization
scope too.
Moreover, some architectures might use virtio for both virtualization
and inter-processor communications, so directly sourcing virtio
might yield unexpected results due to conflicting selections.
The simple solution offered by this patch is to always source virtio's
Kconfig in drivers/Kconfig, and remove it from the appropriate arch
Kconfigs. Additionally, a virtio menu entry has been added so virtio
drivers don't show up in the general drivers menu.
This way anyone can use virtio, though it's arguably less accessible
(and neat!) for virtualization users now.
Note: some architectures (mips and sh) seem to have a VIRTUALIZATION
menu merely for sourcing virtio's Kconfig, so that menu is removed too.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Currently KVM masks out the known good facilities only for the first
double word, but passed the 2nd double word without filtering. This
breaks some code on newer systems:
[ 0.593966] ------------[ cut here ]------------
[ 0.594086] WARNING: at arch/s390/oprofile/hwsampler.c:696
[ 0.594213] Modules linked in:
[ 0.594321] Modules linked in:
[ 0.594439] CPU: 0 Not tainted 3.0.0-rc1 #46
[ 0.594564] Process swapper (pid: 1, task: 00000001effa8038, ksp: 00000001effafab8)
[ 0.594735] Krnl PSW : 0704100180000000 00000000004ab89a (hwsampler_setup+0x75a/0x7b8)
[ 0.594910] R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:1 PM:0 EA:3
[ 0.595120] Krnl GPRS: ffffffff00000000 00000000ffffffea ffffffffffffffea 00000000004a98f8
[ 0.595351] 00000000004aa002 0000000000000001 000000000080e720 000000000088b9f8
[ 0.595522] 000000000080d3e8 0000000000000000 0000000000000000 000000000080e464
[ 0.595725] 0000000000000000 00000000005db198 00000000004ab3a2 00000001effafd98
[ 0.595901] Krnl Code: 00000000004ab88c: c0e5000673ca brasl %r14,57a020
[ 0.596071] 00000000004ab892: a7f4fc77 brc 15,4ab180
[ 0.596276] 00000000004ab896: a7f40001 brc 15,4ab898
[ 0.596454] >00000000004ab89a: a7c8ffa1 lhi %r12,-95
[ 0.596657] 00000000004ab89e: a7f4fc71 brc 15,4ab180
[ 0.596854] 00000000004ab8a2: a7f40001 brc 15,4ab8a4
[ 0.597029] 00000000004ab8a6: a7f4ff22 brc 15,4ab6ea
[ 0.597230] 00000000004ab8aa: c0200011009a larl %r2,6cb9de
[ 0.597441] Call Trace:
[ 0.597511] ([<00000000004ab3a2>] hwsampler_setup+0x262/0x7b8)
[ 0.597676] [<0000000000875812>] oprofile_arch_init+0x32/0xd0
[ 0.597834] [<0000000000875788>] oprofile_init+0x28/0x74
[ 0.597991] [<00000000001001be>] do_one_initcall+0x3a/0x170
[ 0.598151] [<000000000084fa22>] kernel_init+0x142/0x1ec
[ 0.598314] [<000000000057db16>] kernel_thread_starter+0x6/0xc
[ 0.598468] [<000000000057db10>] kernel_thread_starter+0x0/0xc
[ 0.598606] Last Breaking-Event-Address:
[ 0.598707] [<00000000004ab896>] hwsampler_setup+0x756/0x7b8
[ 0.598863] ---[ end trace ce3179037f4e3e5b ]---
So lets also mask the 2nd double word. Facilites 66,76,76,77 should be fine.
commit 9ff4cfb3fcfd48b49fdd9be7381b3be340853aa4 ([S390] kvm-390: Let
kernel exit SIE instruction on work) fixed a problem of commit
commit cd3b70f5d4d82f85d1e1d6e822f38ae098cf7c72 ([S390] virtualization
aware cpu measurement) but uncovered another one.
If a kvm guest accesses guest real memory that doesnt exist, the
page fault handler calls the sie hook, which then rewrites
the return psw from sie_inst to either sie_exit or sie_reenter.
On return, the page fault handler will then detect the wrong access
as a kernel fault causing a kernel oops in sie_reenter or sie_exit.
We have to add these two addresses to the exception table to allow
graceful exits.
From: Christian Borntraeger <borntraeger@de.ibm.com>
This patch fixes the sie exit on interrupts. The low level
interrupt handler returns to the PSW address in pt_regs and not
to the PSW address in the lowcore.
Without this fix a cpu bound guest might never leave guest state
since the host interrupt handler would blindly return to the
SIE instruction, even on need_resched and friends.
Cc: stable@kernel.org
Replace EXTRA_CFLAGS with ccflags-y.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
* 'kvm-updates/2.6.38' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (142 commits)
KVM: Initialize fpu state in preemptible context
KVM: VMX: when entering real mode align segment base to 16 bytes
KVM: MMU: handle 'map_writable' in set_spte() function
KVM: MMU: audit: allow audit more guests at the same time
KVM: Fetch guest cr3 from hardware on demand
KVM: Replace reads of vcpu->arch.cr3 by an accessor
KVM: MMU: only write protect mappings at pagetable level
KVM: VMX: Correct asm constraint in vmcs_load()/vmcs_clear()
KVM: MMU: Initialize base_role for tdp mmus
KVM: VMX: Optimize atomic EFER load
KVM: VMX: Add definitions for more vm entry/exit control bits
KVM: SVM: copy instruction bytes from VMCB
KVM: SVM: implement enhanced INVLPG intercept
KVM: SVM: enhance mov DR intercept handler
KVM: SVM: enhance MOV CR intercept handler
KVM: SVM: add new SVM feature bit names
KVM: cleanup emulate_instruction
KVM: move complete_insn_gp() into x86.c
KVM: x86: fix CR8 handling
KVM guest: Fix kvm clock initialization when it's configured out
IA64 support forces us to abstract the allocation of the kvm structure.
But instead of mixing this up with arch-specific initialization and
doing the same on destruction, split both steps. This allows to move
generic destruction calls into generic code.
It also fixes error clean-up on failures of kvm_create_vm for IA64.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Make use of def_bool and def_tristate where possible and add sensible
defaults to the config symbols where applicable. This shortens the
defconfig file by another ~40 lines.
Store the facility list once at system startup with stfl/stfle and
reuse the result for all facility tests.
Enable PFPO, floating point extension, distinct-operands,
fast-BCR-serialization, high-word, interlocked-access, load/store-
on-condition, and population-count facilities for guests.
(bits 37, 44 and 45).
As advertised in feature-removal-schedule.txt. Equivalent support is provided
by overlapping memory regions.
Newer (guest) kernels use sigp sense running in their spinlock
implementation to check if the other cpu is running before yielding
the processor. This revealed some wrong guest settings, causing
unnecessary exits for every sigp sense running.
This patch fixes
ERROR: "__kvm_s390_vcpu_store_status" [arch/s390/kvm/kvm.ko] undefined!
triggered by
commit 3268c56840dcee78c3e928336550f4e1861504c4 (kvm.git)
Author: Avi Kivity <avi@redhat.com>
Date: Thu May 13 12:21:46 2010 +0300
KVM: s390: Centrally lock arch specific vcpu ioctls
Reported-by: Sachin Sant <sachinp@in.ibm.com>
Now that all arch specific ioctls have centralized locking, it is easy to
move it to the central dispatcher.
All vcpu ioctls need to be locked, so instead of locking each one specifically
we lock at the generic dispatcher.
This patch only updates generic ioctls and leaves arch specific ioctls alone.
The containing function is called from several places. At one of them, in
the function __sigp_stop, the spin lock &fi->lock is held.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@gfp exists@
identifier fn;
position p;
fn(...) {
... when != spin_unlock
when any
GFP_KERNEL@p
... when any
@locked@
identifier gfp.fn;
spin_lock(...)
fn(...)
@depends on locked@
position gfp.p;
- GFP_KERNEL@p
+ GFP_ATOMIC
// </smpl>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Add missing GFP flag to memory allocations. The part in cio only
changes a comment.
This config option enables or disables three single instructions
which aren't expensive. This is too fine grained.
Besided that everybody who uses kvm would enable it anyway in order
to debug performance problems.
Just remove it.
* 'kvm-updates/2.6.35' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (269 commits)
KVM: x86: Add missing locking to arch specific vcpu ioctls
KVM: PPC: Add missing vcpu_load()/vcpu_put() in vcpu ioctls
KVM: MMU: Segregate shadow pages with different cr0.wp
KVM: x86: Check LMA bit before set_efer
KVM: Don't allow lmsw to clear cr0.pe
KVM: Add cpuid.txt file
KVM: x86: Tell the guest we'll warn it about tsc stability
x86, paravirt: don't compute pvclock adjustments if we trust the tsc
x86: KVM guest: Try using new kvm clock msrs
KVM: x86: export paravirtual cpuid flags in KVM_GET_SUPPORTED_CPUID
KVM: x86: add new KVMCLOCK cpuid feature
KVM: x86: change msr numbers for kvmclock
x86, paravirt: Add a global synchronization point for pvclock
x86, paravirt: Enable pvclock flags in vcpu_time_info structure
KVM: x86: Inject #GP with the right rip on efer writes
KVM: SVM: Don't allow nested guest to VMMCALL into host
KVM: x86: Fix exception reinjection forced to true
KVM: Fix wallclock version writing race
KVM: MMU: Don't read pdptrs with mmu spinlock held in mmu_alloc_roots
KVM: VMX: enable VMXON check with SMX enabled (Intel TXT)
vmx and svm vcpus have different contents and therefore may have different
alignmment requirements. Let each specify its required alignment.
The RCU/SRCU API have already changed for proving RCU usage.
I got the following dmesg when PROVE_RCU=y because we used incorrect API.
This patch coverts rcu_deference() to srcu_dereference() or family API.
[ INFO: suspicious rcu_dereference_check() usage. ]
arch/x86/kvm/mmu.c:3020 invoked rcu_dereference_check() without protection!
rcu_scheduler_active = 1, debug_locks = 0
2 locks held by qemu-system-x86/8550:
#0: (&kvm->slots_lock){+.+.+.}, at: [<ffffffffa011a6ac>] kvm_set_memory_region+0x29/0x50 [kvm]
#1: (&(&kvm->mmu_lock)->rlock){+.+...}, at: [<ffffffffa012262d>] kvm_arch_commit_memory_region+0xa6/0xe2 [kvm]
stack backtrace:
Pid: 8550, comm: qemu-system-x86 Not tainted 2.6.34-rc4-tip-01028-g939eab1 #27
Call Trace:
[<ffffffff8106c59e>] lockdep_rcu_dereference+0xaa/0xb3
[<ffffffffa012f6c1>] kvm_mmu_calculate_mmu_pages+0x44/0x7d [kvm]
[<ffffffffa012263e>] kvm_arch_commit_memory_region+0xb7/0xe2 [kvm]
[<ffffffffa011a5d7>] __kvm_set_memory_region+0x636/0x6e2 [kvm]
[<ffffffffa011a6ba>] kvm_set_memory_region+0x37/0x50 [kvm]
[<ffffffffa015e956>] vmx_set_tss_addr+0x46/0x5a [kvm_intel]
[<ffffffffa0126592>] kvm_arch_vm_ioctl+0x17a/0xcf8 [kvm]
[<ffffffff810a8692>] ? unlock_page+0x27/0x2c
[<ffffffff810bf879>] ? __do_fault+0x3a9/0x3e1
[<ffffffffa011b12f>] kvm_vm_ioctl+0x364/0x38d [kvm]
[<ffffffff81060cfa>] ? up_read+0x23/0x3d
[<ffffffff810f3587>] vfs_ioctl+0x32/0xa6
[<ffffffff810f3b19>] do_vfs_ioctl+0x495/0x4db
[<ffffffff810e6b2f>] ? fget_light+0xc2/0x241
[<ffffffff810e416c>] ? do_sys_open+0x104/0x116
[<ffffffff81382d6d>] ? retint_swapgs+0xe/0x13
[<ffffffff810f3ba6>] sys_ioctl+0x47/0x6a
[<ffffffff810021db>] system_call_fastpath+0x16/0x1b
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
This patch fixed possible memory leak in kvm_arch_vcpu_create()
under s390, which would happen when kvm_arch_vcpu_create() fails.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Acked-by: Carsten Otte <cotte@de.ibm.com>
Use the SPP instruction to set a tag on entry to / exit of the virtual
machine context. This allows the cpu measurement facility to distinguish
the samples from the host and the different guests.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (145 commits)
KVM: x86: Add KVM_CAP_X86_ROBUST_SINGLESTEP
KVM: VMX: Update instruction length on intercepted BP
KVM: Fix emulate_sys[call, enter, exit]()'s fault handling
KVM: Fix segment descriptor loading
KVM: Fix load_guest_segment_descriptor() to inject page fault
KVM: x86 emulator: Forbid modifying CS segment register by mov instruction
KVM: Convert kvm->requests_lock to raw_spinlock_t
KVM: Convert i8254/i8259 locks to raw_spinlocks
KVM: x86 emulator: disallow opcode 82 in 64-bit mode
KVM: x86 emulator: code style cleanup
KVM: Plan obsolescence of kernel allocated slots, paravirt mmu
KVM: x86 emulator: Add LOCK prefix validity checking
KVM: x86 emulator: Check CPL level during privilege instruction emulation
KVM: x86 emulator: Fix popf emulation
KVM: x86 emulator: Check IOPL level during io instruction emulation
KVM: x86 emulator: fix memory access during x86 emulation
KVM: x86 emulator: Add Virtual-8086 mode of emulation
KVM: x86 emulator: Add group9 instruction decoding
KVM: x86 emulator: Add group8 instruction decoding
KVM: do not store wqh in irqfd
Trivial conflicts in Documentation/feature-removal-schedule.txt
cleanup_srcu_struct on VM destruction remains broken:
BUG: unable to handle kernel paging request at ffffffffffffffff
IP: [<ffffffff802533d2>] srcu_read_lock+0x16/0x21
RIP: 0010:[<ffffffff802533d2>] [<ffffffff802533d2>] srcu_read_lock+0x16/0x21
Call Trace:
[<ffffffffa05354c4>] kvm_arch_vcpu_uninit+0x1b/0x48 [kvm]
[<ffffffffa05339c6>] kvm_vcpu_uninit+0x9/0x15 [kvm]
[<ffffffffa0569f7d>] vmx_free_vcpu+0x7f/0x8f [kvm_intel]
[<ffffffffa05357b5>] kvm_arch_destroy_vm+0x78/0x111 [kvm]
[<ffffffffa053315b>] kvm_put_kvm+0xd4/0xfe [kvm]
Move it to kvm_arch_destroy_vm.
Reported-by: Jan Kiszka <jan.kiszka@siemens.com>
Required for SRCU convertion later.
drivers/firmware/iscsi_ibft.c
Use asm offsets to make sure the offset defines to struct _lowcore and
its layout don't get out of sync.
Also add a BUILD_BUG_ON() which checks that the size of the structure
is sane.
And while being at it change those sites which use odd casts to access
the current lowcore. These should use S390_lowcore instead.
ENOTSUPP is not supposed to leak to userspace so lets just use
EOPNOTSUPP everywhere.
Doesn't fix a bug, but makes future reviews easier.
Remove support to be able to dump 31 bit systems with a 64 bit dumper.
This is mostly useless since no distro ships 31 bit kernels together
We also get rid of a bit of hacky code.
kvm_handle_sie_intercept uses a jump table to get the intercept handler
for a SIE intercept. Static code analysis revealed a potential problem:
the intercept_funcs jump table was defined to contain (0x48 >> 2) entries,
but we only checked for code > 0x48 which would cause an off-by-one
array overflow if code == 0x48.
Use the compiler and ARRAY_SIZE to automatically set the limits.
What it is: vhost net is a character device that can be used to reduce
the number of system calls involved in virtio networking.
Existing virtio net code is used in the guest without modification.
There's similarity with vringfd, with some differences and reduced scope
- uses eventfd for signalling
- structures can be moved around in memory at any time (good for
migration, bug work-arounds in userspace)
- write logging is supported (good for migration)
- support memory table and not just an offset (needed for kvm)
common virtio related code has been put in a separate file vhost.c and
can be made into a separate module if/when more backends appear. I used
Rusty's lguest.c as the source for developing this part : this supplied
me with witty comments I wouldn't be able to write myself.
What it is not: vhost net is not a bus, and not a generic new system
call. No assumptions are made on how guest performs hypercalls.
Userspace hypervisors are supported as well as kvm.
How it works: Basically, we connect virtio frontend (configured by
userspace) to a backend. The backend could be a network device, or a tap
device. Backend is also configured by userspace, including vlan/mac
etc.
Status: This works for me, and I haven't see any crashes.
Compared to userspace, people reported improved latency (as I save up to
4 system calls per packet), as well as better bandwidth and CPU
utilization.
Features that I plan to look at in the future:
- mergeable buffers
- zero copy
- scalability tuning: figure out the best threading model to use
Note on RCU usage (this is also documented in vhost.h, near
private_pointer which is the value protected by this variant of RCU):
what is happening is that the rcu_dereference() is being used in a
workqueue item. The role of rcu_read_lock() is taken on by the start of
execution of the workqueue item, of rcu_read_unlock() by the end of
execution of the workqueue item, and of synchronize_rcu() by
flush_workqueue()/flush_work(). In the future we might need to apply
some gcc attribute or sparse annotation to the function passed to
INIT_WORK(). Paul's ack below is for this RCU usage.
(Includes fixes by Alan Cox <alan@linux.intel.com>,
David L Stevens <dlstevens@us.ibm.com>,
Chris Wright <chrisw@redhat.com>)
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (72 commits)
[S390] 3215/3270 console: remove wrong comment
[S390] dasd: remove BKL from extended error reporting code
[S390] vmlogrdr: remove BKL
[S390] vmur: remove BKL
[S390] zcrypt: remove BKL
[S390] 3270: remove BKL
[S390] vmwatchdog: remove lock_kernel() from open() function
[S390] monwriter: remove lock_kernel() from open() function
[S390] monreader: remove lock_kernel() from open() function
[S390] s390: remove unused nfsd #includes
[S390] ftrace: build ftrace.o when CONFIG_FTRACE_SYSCALLS is set for s390
[S390] etr/stp: put correct per cpu variable
[S390] tty3270: move keyboard compat ioctls
[S390] sclp: improve servicability setting
[S390] s390: use change recording override for kernel mapping
[S390] MAINTAINERS: Add s390 drivers block
[S390] use generic sockios.h header file
[S390] use generic termbits.h header file
[S390] smp: remove unused typedef and defines
[S390] cmm: free pages on hibernate.
Introduce user_mode to replace the two variables switch_amode and
s390_noexec. There are three valid combinations of the old values:
1) switch_amode == 0 && s390_noexec == 0
2) switch_amode == 1 && s390_noexec == 0
3) switch_amode == 1 && s390_noexec == 1
They get replaced by
1) user_mode == HOME_SPACE_MODE
2) user_mode == PRIMARY_SPACE_MODE
3) user_mode == SECONDARY_SPACE_MODE
The new kernel parameter user_mode=[primary,secondary,home] lets
you choose the address space mode the user space processes should
use. In addition the CONFIG_S390_SWITCH_AMODE config option
is removed.
This patch corrects the checking of the new address for the prefix register.
On s390, the prefix register is used to address the cpu's lowcore (address
0...8k). This check is supposed to verify that the memory is readable and
present.
copy_from_guest is a helper function, that can be used to read from guest
memory. It applies prefixing, adds the start address of the guest memory in
user, and then calls copy_from_user. Previous code was obviously broken for
two reasons:
- prefixing should not be applied here. The current prefix register is
going to be updated soon, and the address we're looking for will be
0..8k after we've updated the register
- we're adding the guest origin (gmsor) twice: once in subject code
and once in copy_from_guest
With kuli, we did not hit this problem because (a) we were lucky with
previous prefix register content, and (b) our guest memory was mmaped
very low into user address space.
Reported-by: Alexander Graf <agraf@suse.de>
