commit 8e0ab8e26b72a80e991c66a8abc16e6c856abe3d upstream.
Fix two problems found in the strrchr() implementation for s390
architectures: evaluate empty strings (return the string address instead of
NULL, if '\0' is passed as second argument); evaluate the first character
of non-empty strings (the current implementation stops at the second).
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: stable@vger.kernel.org
Reported-by: Heiko Carstens <hca@linux.ibm.com> (incorrect behavior with empty strings)
Signed-off-by: Roberto Sassu <roberto.sassu@huawei.com>
Link: https://lore.kernel.org/r/20211005120836.60630-1-roberto.sassu@huawei.com
Signed-off-by: Heiko Carstens <hca@linux.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
Our memcpy and memcmp variants were implemented by calling the corresponding
gcc builtin variants.
However gcc is free to replace a call to __builtin_memcmp with a call to memcmp
which, when called, will result in an endless recursion within memcmp.
So let's provide asm variants and also fix the variants that are used for
uncompressing the kernel image.
In addition remove all other occurences of builtin function calls.
Remove the file name from the comment at top of many files. In most
cases the file name was wrong anyway, so it's rather pointless.
Also unify the IBM copyright statement. We did have a lot of sightly
different statements and wanted to change them one after another
whenever a file gets touched. However that never happened. Instead
people start to take the old/"wrong" statements to use as a template
for new files.
So unify all of them in one go.
Use builtin variants if gcc 4 or newer is used to compile the kernel.
Generates better code than the asm variants.
infrastructure for it.
Let it rip!
