[ Upstream commit 723cacbd9dc79582e562c123a0bacf8bfc69e72a ]
There is a race with multi-threaded applications between context switch and
pagetable upgrade. In switch_mm() a new user_asce is built from mm->pgd and
mm->context.asce_bits, w/o holding any locks. A concurrent mmap with a
pagetable upgrade on another thread in crst_table_upgrade() could already
have set new asce_bits, but not yet the new mm->pgd. This would result in a
corrupt user_asce in switch_mm(), and eventually in a kernel panic from a
translation exception.
Fix this by storing the complete asce instead of just the asce_bits, which
can then be read atomically from switch_mm(), so that it either sees the
old value or the new value, but no mixture. Both cases are OK. Having the
old value would result in a page fault on access to the higher level memory,
but the fault handler would see the new mm->pgd, if it was a valid access
after the mmap on the other thread has completed. So as worst-case scenario
we would have a page fault loop for the racing thread until the next time
slice.
Also remove dead code and simplify the upgrade/downgrade path, there are no
upgrades from 2 levels, and only downgrades from 3 levels for compat tasks.
There are also no concurrent upgrades, because the mmap_sem is held with
down_write() in do_mmap, so the flush and table checks during upgrade can
be removed.
Reported-by: Michael Munday <munday@ca.ibm.com>
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Remove the 31 bit support in order to reduce maintenance cost and
effectively remove dead code. Since a couple of years there is no
distribution left that comes with a 31 bit kernel.
The 31 bit kernel also has been broken since more than a year before
anybody noticed. In addition I added a removal warning to the kernel
shown at ipl for 5 minutes: a960062e5826 ("s390: add 31 bit warning
message") which let everybody know about the plan to remove 31 bit
code. We didn't get any response.
Given that the last 31 bit only machine was introduced in 1999 let's
remove the code.
Anybody with 31 bit user space code can still use the compat mode.
Avoid cache aliasing on z13 by aligning shared objects to multiples
of 512K. The virtual addresses of a page from a shared file needs
to have identical bits in the range 2^12 to 2^18.
In order to make the static inline function is_zero_pfn() callable by
modules, export its symbol dependencies 'zero_pfn' and (for s390 and
mips) 'zero_page_mask'.
We need this for KVM, as CONFIG_KVM is a tristate for all supported
architectures except ARM and arm64, and testing a pfn whether it refers
to the zero page is required to correctly distinguish the zero page
from other special RAM ranges that may also have the PG_reserved bit
set, but need to be treated as MMIO memory.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
The zEC12 machines introduced the local-clearing control for the IDTE
and IPTE instruction. If the control is set only the TLB of the local
CPU is cleared of entries, either all entries of a single address space
for IDTE, or the entry for a single page-table entry for IPTE.
Without the local-clearing control the TLB flush is broadcasted to all
CPUs in the configuration, which is expensive.
The reset of the bit mask of the CPUs that need flushing after a
non-local IDTE is tricky. As TLB entries for an address space remain
in the TLB even if the address space is detached a new bit field is
required to keep track of attached CPUs vs. CPUs in the need of a
flush. After a non-local flush with IDTE the bit-field of attached CPUs
is copied to the bit-field of CPUs in need of a flush. The ordering
of operations on cpu_attach_mask, attach_count and mm_cpumask(mm) is
such that an underindication in mm_cpumask(mm) is prevented but an
overindication in mm_cpumask(mm) is possible.
Just add the new model number where appropiate.
Cc: stable@vger.kernel.org # v3.10
Prepare for removing num_physpages and simplify mem_init().
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Concentrate code to modify totalram_pages into the mm core, so the arch
memory initialized code doesn't need to take care of it. With these
changes applied, only following functions from mm core modify global
variable totalram_pages: free_bootmem_late(), free_all_bootmem(),
free_all_bootmem_node(), adjust_managed_page_count().
With this patch applied, it will be much more easier for us to keep
totalram_pages and zone->managed_pages in consistence.
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: <sworddragon2@aol.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jianguo Wu <wujianguo@huawei.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Address more review comments from last round of code review.
1) Enhance free_reserved_area() to support poisoning freed memory with
pattern '0'. This could be used to get rid of poison_init_mem()
on ARM64.
2) A previous patch has disabled memory poison for initmem on s390
by mistake, so restore to the original behavior.
3) Remove redundant PAGE_ALIGN() when calling free_reserved_area().
Change signature of free_reserved_area() according to Russell King's
suggestion to fix following build warnings:
arch/arm/mm/init.c: In function 'mem_init':
arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default]
free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL);
In file included from include/linux/mman.h:4:0,
from arch/arm/mm/init.c:15:
include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *'
extern unsigned long free_reserved_area(unsigned long start, unsigned long end,
mm/page_alloc.c: In function 'free_reserved_area':
>> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default]
In file included from arch/mips/include/asm/page.h:49:0,
from include/linux/mmzone.h:20,
from include/linux/gfp.h:4,
from include/linux/mm.h:8,
from mm/page_alloc.c:18:
arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int'
mm/page_alloc.c: In function 'free_area_init_nodes':
mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds]
Also address some minor code review comments.
Commit 0c2c99b1b "memory hotplug: Allow memory blocks to span
multiple memory sections" introduced a weak memory_block_size_bytes()
function which can be used to set the size of a memory block as
seen in sysfs.
Provide an s390 specific override which makes sure that each
memory block has at least a size of 256MB or the increment size of
of a memory increment, whatever is larger.
This way we can make sure that the number of memory sysfs objects
doesn't explode for very large memory configurations.
Reported-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Use common help functions to free reserved pages.
To avoid cache synonyms on System zEC12 32 independent zero pages are
required, one for each combination for bits 2**12 to 2**16 of the virtual
address. To avoid wasting too much memory on small virtual systems the
number of zero pages is limited to 4 if the memory size is less or equal
to 64MB.
For removing memory, we need to remove page tables. But it depends on
architecture. So the patch introduce arch_remove_memory() for removing
page table. Now it only calls __remove_pages().
Note: __remove_pages() for some archtecuture is not implemented
(I don't know how to implement it for s390).
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Wu Jianguo <wujianguo@huawei.com>
Keep related functions together and move to appropriate file.
Just convert fault_init() to an early initcall. That's still early
enough since it only needs be called before user space processes get
executed. No reason to externalize it.
Also add the function to the init section and move the store_indication
variable to the read_mostly section.
Same as 0d26d1d8 "x86/mm: Mark free_initrd_mem() as __init".
In addition also add the __init annotation to setup_zero_pages().
Remove the file name from the comment at top of many files. In most
cases the file name was wrong anyway, so it's rather pointless.
Also unify the IBM copyright statement. We did have a lot of sightly
different statements and wanted to change them one after another
whenever a file gets touched. However that never happened. Instead
people start to take the old/"wrong" statements to use as a template
for new files.
So unify all of them in one go.
Disintegrate asm/system.h for S390.
cc: linux-s390@vger.kernel.org
This fixes a kernel oops with CONFIG_DEBUG_VM triggered by a
VM_BUG_ON(bad_range()): kernel BUG at mm/page_alloc.c:748.
With memory hotplug on System z, it is possible that the memory
online/offline state is preserved over a system restart, e.g. there
may be offline memory blocks in ZONE_DMA or ZONE_NORMAL. So far,
the offline memory range has always been added to ZONE_MOVABLE during
system start, so that it was possible to have ZONE_MOVABLE interleave
with ZONE_DMA or ZONE_NORMAL. This patch fixes that by checking for
zone overlap before adding memory.
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
The kernel address space of a 64 bit kernel currently uses a three level
page table and the vmemmap array has a fixed address and a fixed maximum
size. A three level page table is good enough for systems with less than
3.8TB of memory, for bigger systems four page table levels need to be
used. Each page table level costs a bit of performance, use 3 levels for
normal systems and 4 levels only for the really big systems.
To avoid bloating sparse.o too much set MAX_PHYSMEM_BITS to 46 for a
maximum of 64TB of memory.
Fix several compile errors on s390 caused by splitting module.h.
Some include additions [e.g. qdio_setup.c, zfcp_qdio.c] are in
anticipation of pending changes queued for s390 that increase
the modular use footprint.
[PG: added additional obvious changes since Heiko's original patch]
Add ZONE_DMA to 31-bit config again. The performance gain is minimal
and hardly anybody cares anymore about a 31-bit kernel.
So add ZONE_DMA again to help with SLAB_CACHE_DMA removal for
!CONFIG_ZONE_DMA configurations.
Acked-by: David Rientjes <rientjes@google.com>
Rework the architecture page table functions to access the bits in the
page table extension array (pgste). There are a number of changes:
1) Fix missing pgste update if the attach_count for the mm is <= 1.
2) For every operation that affects the invalid bit in the pte or the
rcp byte in the pgste the pcl lock needs to be acquired. The function
pgste_get_lock gets the pcl lock and returns the current pgste value
for a pte pointer. The function pgste_set_unlock stores the pgste
and releases the lock. Between these two calls the bits in the pgste
can be shuffled.
3) Define two software bits in the pte _PAGE_SWR and _PAGE_SWC to avoid
calling SetPageDirty and SetPageReferenced from pgtable.h. If the
host reference backup bit or the host change backup bit has been
set the dirty/referenced state is transfered to the pte. The common
code will pick up the state from the pte.
4) Add ptep_modify_prot_start and ptep_modify_prot_commit for mprotect.
5) Remove pgd_populate_kernel, pud_populate_kernel, pmd_populate_kernel
pgd_clear_kernel, pud_clear_kernel, pmd_clear_kernel and ptep_invalidate.
6) Rename kvm_s390_test_and_clear_page_dirty to
ptep_test_and_clear_user_dirty and add ptep_test_and_clear_user_young.
7) Define mm_exclusive() and mm_has_pgste() helper to improve readability.
Use the store indication bit in the translation exception code on
page faults to avoid the protection faults that immediatly follow
the page fault if the access has been a write.
Implement get_user_pages_fast without locking in the fastpath on s390.
If the zero page is mapped to virtual user space addresses that differ
only in bit 2^12 or 2^13 we get L1 cache synonyms which can affect
performance. Follow the mips model and use multiple zero pages to avoid
the synonyms.
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration,
it maps:
local_irq_enable() -> raw_local_irq_enable()
local_irq_disable() -> raw_local_irq_disable()
local_irq_save() -> raw_local_irq_save()
and under the other configuration, it maps:
raw_local_irq_enable() -> local_irq_enable()
raw_local_irq_disable() -> local_irq_disable()
raw_local_irq_save() -> local_irq_save()
This is quite confusing. There should be one set of names expected of the
arch, and this should be wrapped to give another set of names that are expected
by users of this facility.
Change this to have the arch provide:
flags = arch_local_save_flags()
flags = arch_local_irq_save()
arch_local_irq_restore(flags)
arch_local_irq_disable()
arch_local_irq_enable()
arch_irqs_disabled_flags(flags)
arch_irqs_disabled()
arch_safe_halt()
Then linux/irqflags.h wraps these to provide:
raw_local_save_flags(flags)
raw_local_irq_save(flags)
raw_local_irq_restore(flags)
raw_irqs_disabled_flags(flags)
raw_irqs_disabled()
raw_safe_halt()
with type checking on the flags 'arguments', and then wraps those to provide:
local_irq_disable()
local_irq_enable()
irqs_disabled()
safe_halt()
with tracing included if enabled.
The arch functions can now all be inline functions rather than some of them
having to be macros.
Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300]
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile]
Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze]
Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM]
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR]
Acked-by: Tony Luck <tony.luck@intel.com> [IA-64]
Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R]
Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU]
Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS]
Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC]
Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC]
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390]
Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score]
Acked-by: Matt Fleming <matt@console-pimps.org> [SH]
Acked-by: David S. Miller <davem@davemloft.net> [Sparc]
Acked-by: Chris Zankel <chris@zankel.net> [Xtensa]
Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha]
Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300]
Cc: starvik@axis.com [CRIS]
Cc: jesper.nilsson@axis.com [CRIS]
Cc: linux-cris-kernel@axis.com
The tlb flushing code uses the mm_users field of the mm_struct to
decide if each page table entry needs to be flushed individually with
IPTE or if a global flush for the mm_struct is sufficient after all page
table updates have been done. The comment for mm_users says "How many
users with user space?" but the /proc code increases mm_users after it
found the process structure by pid without creating a new user process.
Which makes mm_users useless for the decision between the two tlb
flusing methods. The current code can be confused to not flush tlb
entries by a concurrent access to /proc files if e.g. a fork is in
progres. The solution for this problem is to make the tlb flushing
logic independent from the mm_users field.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
free_initmem() and free_initrd_mem() are nearly identical. So make them
call a common function.
Also fixes a bug: if the initrd wouldn't start on a page boundary also
memory after the initrd would be initialized with the poison value.
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()")
modified nr_free_pages() to return 'unsigned long' instead of 'unsigned
int'. This made the casts to 'unsigned long' in most callers superfluous,
so remove them.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Chris Zankel <zankel@tensilica.com>
Move all EXPORT_SYMBOLs to their corresponding definitions.
Show node to memory section relationship with symlinks in sysfs
Add /sys/devices/system/node/nodeX/memoryY symlinks for all
the memory sections located on nodeX. For example:
/sys/devices/system/node/node1/memory135 -> ../../memory/memory135
indicates that memory section 135 resides on node1.
Also revises documentation to cover this change as well as updating
Documentation/ABI/testing/sysfs-devices-memory to include descriptions
of memory hotremove files 'phys_device', 'phys_index', and 'state'
that were previously not described there.
In addition to it always being a good policy to provide users with
the maximum possible amount of physical location information for
resources that can be hot-added and/or hot-removed, the following
are some (but likely not all) of the user benefits provided by
this change.
Immediate:
- Provides information needed to determine the specific node
on which a defective DIMM is located. This will reduce system
downtime when the node or defective DIMM is swapped out.
- Prevents unintended onlining of a memory section that was
previously offlined due to a defective DIMM. This could happen
during node hot-add when the user or node hot-add assist script
onlines _all_ offlined sections due to user or script inability
to identify the specific memory sections located on the hot-added
node. The consequences of reintroducing the defective memory
could be ugly.
- Provides information needed to vary the amount and distribution
of memory on specific nodes for testing or debugging purposes.
Future:
- Will provide information needed to identify the memory
sections that need to be offlined prior to physical removal
of a specific node.
Symlink creation during boot was tested on 2-node x86_64, 2-node
ppc64, and 2-node ia64 systems. Symlink creation during physical
memory hot-add tested on a 2-node x86_64 system.
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
There is nothing architecture specific about remove_memory().
remove_memory() function is common for all architectures which support
hotplug memory remove. Instead of duplicating it in every architecture,
collapse them into arch neutral function.
[akpm@linux-foundation.org: fix the export]
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Gary Hade <garyhade@us.ibm.com>
This patch enables memory hot-remove on s390.
Remove arch-specific show_mem() in favor of the generic version.
This also removes the following redundant information display:
- pages in swapcache, printed by show_swap_cache_info()
where show_mem() calls show_free_areas(), which calls
show_swap_cache_info().
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Convert show_mem() so its nearly the same as on x86/powerpc.
Gives us proper locking and we get also rid of the only use of max_mapnr.
Also the number of pages was contained in an int which might not be
sufficient not too far in the future.
Cc: Johannes Weiner <hannes@saeurebad.de>
Use the existing arch_alloc_page/arch_free_page callbacks to do
the guest page state transitions between stable and unused.
Convert s390 to SPARSEMEM and SPARSEMEM_VMEMMAP. We do a select
of SPARSEMEM_VMEMMAP since it is configurable. This is because
SPARSEMEM without SPARSEMEM_VMEMMAP gives us a hell of broken
include dependencies that I don't want to fix.
This adds hugetlbfs support on System z, using both hardware large page
support if available and software large page emulation on older hardware.
Shared (large) page tables are implemented in software emulation mode,
by using page->index of the first tail page from a compound large page
to store page table information.
Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com>
Add support for different number of page table levels dependent
on the highest address used for a process. This will cause a 31 bit
process to use a two level page table instead of the four level page
table that is the default after the pud has been introduced. Likewise
a normal 64 bit process will use three levels instead of four. Only
if a process runs out of the 4 tera bytes which can be addressed with
a three level page table the fourth level is dynamically added. Then
the process can use up to 8 peta byte.
This patch implements 1K/2K page table pages for s390.
Get independent from asm-generic/4level-fixup.h
- De-confuse the defines for the address-space-control-elements
and the segment/region table entries.
- Create out of line functions for page table allocation / freeing.
- Simplify get_shadow_xxx functions.
There are several s390 diagnose calls, which must be executed below the
2GB memory boundary. In order to enforce this, those diagnoses must be
compiled into the kernel. Currently diag 14 can be called within the
vmur kernel module from addresses above 2GB. This leads to specification
exceptions. This patch moves diag10, diag14 and diag210 into the new
diag.c file.
Signed-off-by: Michael Holzheu <holzheu@de.ibm.com>
