path: root/arch/s390/mm/mmap.c
2008-02-09[S390] dynamic page tables.Martin Schwidefsky
Add support for different number of page table levels dependent on the highest address used for a process. This will cause a 31 bit process to use a two level page table instead of the four level page table that is the default after the pud has been introduced. Likewise a normal 64 bit process will use three levels instead of four. Only if a process runs out of the 4 tera bytes which can be addressed with a three level page table the fourth level is dynamically added. Then the process can use up to 8 peta byte. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
