[ Upstream commit 686cb8b9f6b46787f035afe8fbd132a74e6b1bdd ]
Make sure to free jit_data through kfree() in the error path.
Fixes: 1c8f9b91c456 ("bpf: s390: add JIT support for multi-function programs")
Signed-off-by: Tiezhu Yang <yangtiezhu@loongson.cn>
Acked-by: Ilya Leoshkevich <iii@linux.ibm.com>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
commit 6e61dc9da0b7a0d91d57c2e20b5ea4fd2d4e7e53 upstream.
The JIT uses agfi for subtracting constants, but -(-0x80000000) cannot
be represented as a 32-bit signed binary integer. Fix by using algfi in
this particular case.
Reported-by: Johan Almbladh <johan.almbladh@anyfinetworks.com>
Fixes: 054623105728 ("s390/bpf: Add s390x eBPF JIT compiler backend")
Reviewed-by: Heiko Carstens <hca@linux.ibm.com>
Signed-off-by: Ilya Leoshkevich <iii@linux.ibm.com>
commit db7bee653859ef7179be933e7d1384644f795f26 upstream.
Currently the JIT completely removes things like `reg32 += 0`,
however, the BPF_ALU semantics requires the target register to be
zero-extended in such cases.
Fix by optimizing out only the arithmetic operation, but not the
subsequent zero-extension.
commit f5e81d1117501546b7be050c5fbafa6efd2c722c upstream.
In case of JITs, each of the JIT backends compiles the BPF nospec instruction
/either/ to a machine instruction which emits a speculation barrier /or/ to
/no/ machine instruction in case the underlying architecture is not affected
by Speculative Store Bypass or has different mitigations in place already.
This covers both x86 and (implicitly) arm64: In case of x86, we use 'lfence'
instruction for mitigation. In case of arm64, we rely on the firmware mitigation
as controlled via the ssbd kernel parameter. Whenever the mitigation is enabled,
it works for all of the kernel code with no need to provide any additional
instructions here (hence only comment in arm64 JIT). Other archs can follow
as needed. The BPF nospec instruction is specifically targeting Spectre v4
since i) we don't use a serialization barrier for the Spectre v1 case, and
ii) mitigation instructions for v1 and v4 might be different on some archs.
The BPF nospec is required for a future commit, where the BPF verifier does
annotate intermediate BPF programs with speculation barriers.
Co-developed-by: Piotr Krysiuk <piotras@gmail.com>
Co-developed-by: Benedict Schlueter <benedict.schlueter@rub.de>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Piotr Krysiuk <piotras@gmail.com>
Signed-off-by: Benedict Schlueter <benedict.schlueter@rub.de>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[OP: - adjusted context for 5.4
- apply riscv changes to /arch/riscv/net/bpf_jit_comp.c]
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
[ Upstream commit 91091656252f5d6d8c476e0c92776ce9fae7b445 ]
Currently array jit->seen_reg[r1] is being accessed before the range
checking of index r1. The range changing on r1 should be performed
first since it will avoid any potential out-of-range accesses on the
array seen_reg[] and also it is more optimal to perform checks on r1
before fetching data from the array. Fix this by swapping the order
of the checks before the array access.
Tested-by: Ilya Leoshkevich <iii@linux.ibm.com>
Link: https://lore.kernel.org/bpf/20210715125712.24690-1-colin.king@canonical.com
[ Upstream commit 166f11d11f6f70439830d09bfa5552ec1b368494 ]
A BPF program may consist of 1m instructions, which means JIT
instruction-address mapping can be as large as 4m. s390 has
FORCE_MAX_ZONEORDER=9 (for memory hotplug reasons), which means maximum
kmalloc size is 1m. This makes it impossible to JIT programs with more
than 256k instructions.
Fix by using kvcalloc, which falls back to vmalloc for larger
allocations. An alternative would be to use a radix tree, but that is
not supported by bpf_prog_fill_jited_linfo.
Link: https://lore.kernel.org/bpf/20191107141838.92202-1-iii@linux.ibm.com
Daniel Borkmann says:
The following pull-request contains BPF updates for your *net-next* tree.
The main changes are:
1) Add the ability to use unaligned chunks in the AF_XDP umem. By
relaxing where the chunks can be placed, it allows to use an
arbitrary buffer size and place whenever there is a free
address in the umem. Helps more seamless DPDK AF_XDP driver
integration. Support for i40e, ixgbe and mlx5e, from Kevin and
Maxim.
2) Addition of a wakeup flag for AF_XDP tx and fill rings so the
application can wake up the kernel for rx/tx processing which
avoids busy-spinning of the latter, useful when app and driver
is located on the same core. Support for i40e, ixgbe and mlx5e,
from Magnus and Maxim.
3) bpftool fixes for printf()-like functions so compiler can actually
enforce checks, bpftool build system improvements for custom output
directories, and addition of 'bpftool map freeze' command, from Quentin.
4) Support attaching/detaching XDP programs from 'bpftool net' command,
from Daniel.
5) Automatic xskmap cleanup when AF_XDP socket is released, and several
barrier/{read,write}_once fixes in AF_XDP code, from Björn.
6) Relicense of bpf_helpers.h/bpf_endian.h for future libbpf
inclusion as well as libbpf versioning improvements, from Andrii.
7) Several new BPF kselftests for verifier precision tracking, from Alexei.
8) Several BPF kselftest fixes wrt endianess to run on s390x, from Ilya.
9) And more BPF kselftest improvements all over the place, from Stanislav.
10) Add simple BPF map op cache for nfp driver to batch dumps, from Jakub.
11) AF_XDP socket umem mapping improvements for 32bit archs, from Ivan.
12) Add BPF-to-BPF call and BTF line info support for s390x JIT, from Yauheni.
13) Small optimization in arm64 JIT to spare 1 insns for BPF_MOD, from Jerin.
14) Fix an error check in bpf_tcp_gen_syncookie() helper, from Petar.
15) Various minor fixes and cleanups, from Nathan, Masahiro, Masanari,
Peter, Wei, Yue.
This adds support for generating bpf line info for JITed programs
like commit 6f20c71d8505 ("bpf: powerpc64: add JIT support for bpf
line info") does for powerpc, but it should pass the array starting
from 1. This fixes test_btf.
Signed-off-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com>
This adds support for bpf-to-bpf function calls in the s390 JIT
compiler. The JIT compiler converts the bpf call instructions to
native branch instructions. After a round of the usual passes, the
start addresses of the JITed images for the callee functions are
known. Finally, to fixup the branch target addresses, we need to
perform an extra pass.
Because of the address range in which JITed images are allocated on
s390, the offsets of the start addresses of these images from
__bpf_call_base are as large as 64 bits. So, for a function call,
the imm field of the instruction cannot be used to determine the
callee's address. Use bpf_jit_get_func_addr() helper instead.
The patch borrows a lot from:
commit 8c11ea5ce13d ("bpf, arm64: fix getting subprog addr from aux
for calls")
commit e2c95a61656d ("bpf, ppc64: generalize fetching subprog into
bpf_jit_get_func_addr")
commit 8484ce8306f9 ("bpf: powerpc64: add JIT support for
(including the commit message).
test_verifier (5.3-rc6 with CONFIG_BPF_JIT_ALWAYS_ON=y):
without patch:
Summary: 1501 PASSED, 0 SKIPPED, 47 FAILED
with patch:
Summary: 1540 PASSED, 0 SKIPPED, 8 FAILED
"p runtime/jit: pass > 32bit index to tail_call" fails when
bpf_jit_enable=1, because the tail call is not executed.
This in turn is because the generated code assumes index is 64-bit,
while it must be 32-bit, and as a result prog array bounds check fails,
while it should pass. Even if bounds check would have passed, the code
that follows uses 64-bit index to compute prog array offset.
Fix by using clrj instead of clgrj for comparing index with array size,
and also by using llgfr for truncating index to 32 bits before using it
Fixes: 6651ee070b31 ("s390/bpf: implement bpf_tail_call() helper")
Reported-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com>
Acked-by: Vasily Gorbik <gor@linux.ibm.com>
"masking, test in bounds 3" fails on s390, because
BPF_ALU64_IMM(BPF_NEG, BPF_REG_2, 0) ignores the top 32 bits of
BPF_REG_2. The reason is that JIT emits lcgfr instead of lcgr.
The associated comment indicates that the code was intended to
emit lcgr in the first place, it's just that the wrong opcode
was used.
Fix by using the correct opcode.
Signed-off-by: Jiong Wang <jiong.wang@netronome.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
IS_ENABLED should be reserved for CONFIG_<FOO> uses so convert
the uses of IS_ENABLED with a #define to __is_defined.
Pnetids are retrieved from the underlying hardware as EBCDIC. This patch
converts pnetids to ASCII.
Signed-off-by: Hans Wippel <hwippel@linux.ibm.com>
Signed-off-by: Ursula Braun <ubraun@linux.ibm.com>
There is no need to define these PNETID related constants in
the pnet.h file, since they are just used locally within pnet.c.
Just code cleanup, no functional change.
Commit 626a5f66da0d19 ("s390: bpf: implement jitting of JMP32") added
JMP32 code-gen support for s390. However it triggers the warning below
due to some unusual gotos in the original s390 bpf jit code.
Add a couple of additional "is_jmp32" initializations to fix this.
Also fix the wrong opcode for the "llilf" instruction that was
introduced with the same commit.
arch/s390/net/bpf_jit_comp.c: In function 'bpf_jit_insn':
arch/s390/net/bpf_jit_comp.c:248:55: warning: 'is_jmp32' may be used uninitialized in this function [-Wmaybe-uninitialized]
_EMIT6(op1 | reg(b1, b2) << 16 | (rel & 0xffff), op2 | mask); \
arch/s390/net/bpf_jit_comp.c:1211:8: note: 'is_jmp32' was declared here
bool is_jmp32 = BPF_CLASS(insn->code) == BPF_JMP32;
Fixes: 626a5f66da0d19 ("s390: bpf: implement jitting of JMP32")
Cc: Jiong Wang <jiong.wang@netronome.com>
Acked-by: Jiong Wang <jiong.wang@netronome.com>
This patch implements code-gen for new JMP32 instructions on s390.
This patch implements code-gen for BPF_ALU | BPF_ARSH | BPF_*.
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Heiko Carstens:
"Since Martin is on vacation you get the s390 pull request from me:
- Host large page support for KVM guests. As the patches have large
impact on arch/s390/mm/ this series goes out via both the KVM and
the s390 tree.
- Add an option for no compression to the "Kernel compression mode"
menu, this will come in handy with the rework of the early boot
code.
- A large rework of the early boot code that will make life easier
for KASAN and KASLR. With the rework the bootable uncompressed
image is not generated anymore, only the bzImage is available. For
debuggung purposes the new "no compression" option is used.
- Re-enable the gcc plugins as the issue with the latent entropy
plugin is solved with the early boot code rework.
- More spectre relates changes:
+ Detect the etoken facility and remove expolines automatically.
+ Add expolines to a few more indirect branches.
- A rewrite of the common I/O layer trace points to make them
consumable by 'perf stat'.
- Add support for format-3 PCI function measurement blocks.
- Changes for the zcrypt driver:
+ Add attributes to indicate the load of cards and queues.
+ Restructure some code for the upcoming AP device support in KVM.
- Build flags improvements in various Makefiles.
- A few fixes for the kdump support.
- A couple of patches for gcc 8 compile warning cleanup.
- Cleanup s390 specific proc handlers.
- Add s390 support to the restartable sequence self tests.
- Some PTR_RET vs PTR_ERR_OR_ZERO cleanup.
- Lots of bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (107 commits)
s390/dasd: fix hanging offline processing due to canceled worker
s390/dasd: fix panic for failed online processing
s390/mm: fix addressing exception after suspend/resume
rseq/selftests: add s390 support
s390: fix br_r1_trampoline for machines without exrl
s390/lib: use expoline for all bcr instructions
s390/numa: move initial setup of node_to_cpumask_map
s390/kdump: Fix elfcorehdr size calculation
s390/cpum_sf: save TOD clock base in SDBs for time conversion
KVM: s390: Add huge page enablement control
s390/mm: Add huge page gmap linking support
s390/mm: hugetlb pages within a gmap can not be freed
KVM: s390: Add skey emulation fault handling
s390/mm: Add huge pmd storage key handling
s390/mm: Clear skeys for newly mapped huge guest pmds
s390/mm: Clear huge page storage keys on enable_skey
s390/mm: Add huge page dirty sync support
s390/mm: Add gmap pmd invalidation and clearing
s390/mm: Add gmap pmd notification bit setting
s390/mm: Add gmap pmd linking
For machines without the exrl instruction the BFP jit generates
code that uses an "br %r1" instruction located in the lowcore page.
Unfortunately there is a cut & paste error that puts an additional
"larl %r1,.+14" instruction in the code that clobbers the branch
target address in %r1. Remove the larl instruction.
Cc: <stable@vger.kernel.org> # v4.17+
Fixes: de5cb6eb51 ("s390: use expoline thunks in the BPF JIT")
If we would ever fail in the bpf_jit_prog() pass that writes the
actual insns to the image after we got header via bpf_jit_binary_alloc()
then we also need to make sure to free it through bpf_jit_binary_free()
again when bailing out. Given we had prior bpf_jit_prog() passes to
initially probe for clobbered registers, program size and to fill in
addrs arrray for jump targets, this is more of a theoretical one,
but at least make sure this doesn't break with future changes.
Pull networking updates from David Miller:
1) Add Maglev hashing scheduler to IPVS, from Inju Song.
2) Lots of new TC subsystem tests from Roman Mashak.
3) Add TCP zero copy receive and fix delayed acks and autotuning with
SO_RCVLOWAT, from Eric Dumazet.
4) Add XDP_REDIRECT support to mlx5 driver, from Jesper Dangaard
Brouer.
5) Add ttl inherit support to vxlan, from Hangbin Liu.
6) Properly separate ipv6 routes into their logically independant
components. fib6_info for the routing table, and fib6_nh for sets of
nexthops, which thus can be shared. From David Ahern.
7) Add bpf_xdp_adjust_tail helper, which can be used to generate ICMP
messages from XDP programs. From Nikita V. Shirokov.
8) Lots of long overdue cleanups to the r8169 driver, from Heiner
Kallweit.
9) Add BTF ("BPF Type Format"), from Martin KaFai Lau.
10) Add traffic condition monitoring to iwlwifi, from Luca Coelho.
11) Plumb extack down into fib_rules, from Roopa Prabhu.
12) Add Flower classifier offload support to igb, from Vinicius Costa
Gomes.
13) Add UDP GSO support, from Willem de Bruijn.
14) Add documentation for eBPF helpers, from Quentin Monnet.
15) Add TLS tx offload to mlx5, from Ilya Lesokhin.
16) Allow applications to be given the number of bytes available to read
on a socket via a control message returned from recvmsg(), from
Soheil Hassas Yeganeh.
17) Add x86_32 eBPF JIT compiler, from Wang YanQing.
18) Add AF_XDP sockets, with zerocopy support infrastructure as well.
From Björn Töpel.
19) Remove indirect load support from all of the BPF JITs and handle
these operations in the verifier by translating them into native BPF
instead. From Daniel Borkmann.
20) Add GRO support to ipv6 gre tunnels, from Eran Ben Elisha.
21) Allow XDP programs to do lookups in the main kernel routing tables
for forwarding. From David Ahern.
22) Allow drivers to store hardware state into an ELF section of kernel
dump vmcore files, and use it in cxgb4. From Rahul Lakkireddy.
23) Various RACK and loss detection improvements in TCP, from Yuchung
Cheng.
24) Add TCP SACK compression, from Eric Dumazet.
25) Add User Mode Helper support and basic bpfilter infrastructure, from
Alexei Starovoitov.
26) Support ports and protocol values in RTM_GETROUTE, from Roopa
Prabhu.
27) Support bulking in ->ndo_xdp_xmit() API, from Jesper Dangaard
Brouer.
28) Add lots of forwarding selftests, from Petr Machata.
29) Add generic network device failover driver, from Sridhar Samudrala.
* ra.kernel.org:/pub/scm/linux/kernel/git/davem/net-next: (1959 commits)
strparser: Add __strp_unpause and use it in ktls.
rxrpc: Fix terminal retransmission connection ID to include the channel
net: hns3: Optimize PF CMDQ interrupt switching process
net: hns3: Fix for VF mailbox receiving unknown message
net: hns3: Fix for VF mailbox cannot receiving PF response
bnx2x: use the right constant
Revert "net: sched: cls: Fix offloading when ingress dev is vxlan"
net: dsa: b53: Fix for brcm tag issue in Cygnus SoC
enic: fix UDP rss bits
netdev-FAQ: clarify DaveM's position for stable backports
rtnetlink: validate attributes in do_setlink()
mlxsw: Add extack messages for port_{un, }split failures
netdevsim: Add extack error message for devlink reload
devlink: Add extack to reload and port_{un, }split operations
net: metrics: add proper netlink validation
ipmr: fix error path when ipmr_new_table fails
ip6mr: only set ip6mr_table from setsockopt when ip6mr_new_table succeeds
net: hns3: remove unused hclgevf_cfg_func_mta_filter
netfilter: provide udp*_lib_lookup for nf_tproxy
qed*: Utilize FW 8.37.2.0
s390 hardware supports the definition of a so-call Physical NETwork
IDentifier (short PNETID) per network device port. These PNETIDS
can be used to identify network devices that are attached to the same
physical network (broadcast domain).
This patch provides the interface to extract the PNETID of a port of
a device attached to the ccw-bus or pci-bus.
Parts of this patch are based on an initial implementation by
Thomas Richter.
S390 bpf_jit.S is removed in net-next and had changes in 'net',
since that code isn't used any more take the removal.
TLS data structures split the TX and RX components in 'net-next',
put the new struct members from the bug fix in 'net' into the RX
part.
The 'net-next' tree had some reworking of how the ERSPAN code works in
the GRE tunneling code, overlapping with a one-line headroom
calculation fix in 'net'.
Overlapping changes in __sock_map_ctx_update_elem(), keep the bits
that read the prog members via READ_ONCE() into local variables
before using them.
The BPF JIT need safe guarding against spectre v2 in the sk_load_xxx
assembler stubs and the indirect branches generated by the JIT itself
need to be converted to expolines.
Since LD_ABS/LD_IND instructions are now removed from the core and
reimplemented through a combination of inlined BPF instructions and
a slow-path helper, we can get rid of the complexity from s390x JIT.
Tested on s390x instance on LinuxONE.
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Since we've changed div/mod exception handling for src_reg in
eBPF verifier itself, remove the leftovers from s390x JIT.
Having a pure_initcall() callback just to permanently enable BPF
JITs under CONFIG_BPF_JIT_ALWAYS_ON is unnecessary and could leave
a small race window in future where JIT is still disabled on boot.
Since we know about the setting at compilation time anyway, just
initialize it properly there. Also consolidate all the individual
bpf_jit_enable variables into a single one and move them under one
location. Moreover, don't allow for setting unspecified garbage
values on them.
Lots of overlapping changes. Also on the net-next side
the XDP state management is handled more in the generic
layers so undo the 'net' nfp fix which isn't applicable
in net-next.
Include a necessary change by Jakub Kicinski, with log message:
cls_bpf no longer takes care of offload tracking. Make sure
netdevsim performs necessary checks. This fixes a warning
caused by TC trying to remove a filter it has not added.
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Reviewed-by: Quentin Monnet <quentin.monnet@netronome.com>
pull-request: bpf-next 2017-12-18
1) Allow arbitrary function calls from one BPF function to another BPF function.
As of today when writing BPF programs, __always_inline had to be used in
the BPF C programs for all functions, unnecessarily causing LLVM to inflate
code size. Handle this more naturally with support for BPF to BPF calls
such that this __always_inline restriction can be overcome. As a result,
it allows for better optimized code and finally enables to introduce core
BPF libraries in the future that can be reused out of different projects.
x86 and arm64 JIT support was added as well, from Alexei.
2) Add infrastructure for tagging functions as error injectable and allow for
BPF to return arbitrary error values when BPF is attached via kprobes on
those. This way of injecting errors generically eases testing and debugging
without having to recompile or restart the kernel. Tags for opting-in for
this facility are added with BPF_ALLOW_ERROR_INJECTION(), from Josef.
3) For BPF offload via nfp JIT, add support for bpf_xdp_adjust_head() helper
call for XDP programs. First part of this work adds handling of BPF
capabilities included in the firmware, and the later patches add support
to the nfp verifier part and JIT as well as some small optimizations,
from Jakub.
4) The bpftool now also gets support for basic cgroup BPF operations such
as attaching, detaching and listing current BPF programs. As a requirement
for the attach part, bpftool can now also load object files through
'bpftool prog load'. This reuses libbpf which we have in the kernel tree
as well. bpftool-cgroup man page is added along with it, from Roman.
5) Back then commit e87c6bc3852b ("bpf: permit multiple bpf attachments for
a single perf event") added support for attaching multiple BPF programs
to a single perf event. Given they are configured through perf's ioctl()
interface, the interface has been extended with a PERF_EVENT_IOC_QUERY_BPF
command in this work in order to return an array of one or multiple BPF
prog ids that are currently attached, from Yonghong.
6) Various minor fixes and cleanups to the bpftool's Makefile as well
as a new 'uninstall' and 'doc-uninstall' target for removing bpftool
itself or prior installed documentation related to it, from Quentin.
7) Add CONFIG_CGROUP_BPF=y to the BPF kernel selftest config file which is
required for the test_dev_cgroup test case to run, from Naresh.
8) Fix reporting of XDP prog_flags for nfp driver, from Jakub.
9) Fix libbpf's exit code from the Makefile when libelf was not found in
the system, also from Jakub.
global bpf_jit_enable variable is tested multiple times in JITs,
blinding and verifier core. The malicious root can try to toggle
it while loading the programs. This race condition was accounted
for and there should be no issues, but it's safer to avoid
this race condition.
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
The assumption of unconditionally reloading skb pointers on
BPF helper calls where bpf_helper_changes_pkt_data() holds
true is wrong. There can be different contexts where the
BPF helper would enforce a reload such as in case of XDP.
Here, we do have a struct xdp_buff instead of struct sk_buff
as context, thus this will access garbage.
JITs only ever need to deal with cached skb pointer reload
when ld_abs/ind was seen, therefore guard the reload behind
SEEN_SKB only. Tested on s390x.
Fixes: 9db7f2b81880 ("s390/bpf: recache skb->data/hlen for skb_vlan_push/pop")
Add the correct SPDX license to a few more files under arch/s390 and
drivers/s390 which have been missed to far.
The SPDX identifier is a legally binding shorthand, which can be used
instead of the full boiler plate text.
"Since Martin is on vacation you get the s390 pull request for the
v4.15 merge window this time from me.
Besides a lot of cleanups and bug fixes these are the most important
changes:
- a new regset for runtime instrumentation registers
- hardware accelerated AES-GCM support for the aes_s390 module
- support for the new CEX6S crypto cards
- support for FORTIFY_SOURCE
- addition of missing z13 and new z14 instructions to the in-kernel
disassembler
- generate opcode tables for the in-kernel disassembler out of a
simple text file instead of having to manually maintain those
tables
- fast memset16, memset32 and memset64 implementations
- removal of named saved segment support
- hardware counter support for z14
- queued spinlocks and queued rwlocks implementations for s390
- use the stack_depth tracking feature for s390 BPF JIT
- a new s390_sthyi system call which emulates the sthyi (store
hypervisor information) instruction
- removal of the old KVM virtio transport
- an s390 specific CPU alternatives implementation which is used in
the new spinlock code"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (88 commits)
MAINTAINERS: add virtio-ccw.h to virtio/s390 section
s390/noexec: execute kexec datamover without DAT
s390: fix transactional execution control register handling
s390/bpf: take advantage of stack_depth tracking
s390: simplify transactional execution elf hwcap handling
s390/zcrypt: Rework struct ap_qact_ap_info.
s390/virtio: remove unused header file kvm_virtio.h
s390: avoid undefined behaviour
s390/disassembler: generate opcode tables from text file
s390/disassembler: remove insn_to_mnemonic()
s390/dasd: avoid calling do_gettimeofday()
s390: vfio-ccw: Do not attempt to free no-op, test and tic cda.
s390: remove named saved segment support
s390/archrandom: Reconsider s390 arch random implementation
s390/pci: do not require AIS facility
s390/qdio: sanitize put_indicator
s390/qdio: use atomic_cmpxchg
s390/nmi: avoid using long-displacement facility
s390: pass endianness info to sparse
s390/decompressor: remove informational messages
Make use of the "stack_depth" tracking feature introduced with
commit 8726679a0fa31 ("bpf: teach verifier to track stack depth") for the
s390 JIT, so that stack usage can be reduced.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This work implements jiting of BPF_J{LT,LE,SLT,SLE} instructions
with BPF_X/BPF_K variants for the s390x eBPF JIT.
Acked-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
While testing some other work that required JIT modifications, I
run into test_bpf causing a hang when JIT enabled on s390. The
problematic test case was the one from ddc665a4bb4b (bpf, arm64:
fix jit branch offset related to ldimm64), and turns out that we
do have a similar issue on s390 as well. In bpf_jit_prog() we
update next instruction address after returning from bpf_jit_insn()
with an insn_count. bpf_jit_insn() returns either -1 in case of
error (e.g. unsupported insn), 1 or 2. The latter is only the
case for ldimm64 due to spanning 2 insns, however, next address
is only set to i + 1 not taking actual insn_count into account,
thus fix is to use insn_count instead of 1. bpf_jit_enable in
mode 2 provides also disasm on s390:
Before fix:
000003ff800349b6: a7f40003 brc 15,3ff800349bc ; target
000003ff800349ba: 0000 unknown
000003ff800349bc: e3b0f0700024 stg %r11,112(%r15)
000003ff800349c2: e3e0f0880024 stg %r14,136(%r15)
000003ff800349c8: 0db0 basr %r11,%r0
000003ff800349ca: c0ef00000000 llilf %r14,0
000003ff800349d0: e320b0360004 lg %r2,54(%r11)
000003ff800349d6: e330b03e0004 lg %r3,62(%r11)
000003ff800349dc: ec23ffeda065 clgrj %r2,%r3,10,3ff800349b6 ; jmp
000003ff800349e2: e3e0b0460004 lg %r14,70(%r11)
000003ff800349e8: e3e0b04e0004 lg %r14,78(%r11)
000003ff800349ee: b904002e lgr %r2,%r14
000003ff800349f2: e3b0f0700004 lg %r11,112(%r15)
000003ff800349f8: e3e0f0880004 lg %r14,136(%r15)
000003ff800349fe: 07fe bcr 15,%r14
After fix:
000003ff80ef3db4: a7f40003 brc 15,3ff80ef3dba
000003ff80ef3db8: 0000 unknown
000003ff80ef3dba: e3b0f0700024 stg %r11,112(%r15)
000003ff80ef3dc0: e3e0f0880024 stg %r14,136(%r15)
000003ff80ef3dc6: 0db0 basr %r11,%r0
000003ff80ef3dc8: c0ef00000000 llilf %r14,0
000003ff80ef3dce: e320b0360004 lg %r2,54(%r11)
000003ff80ef3dd4: e330b03e0004 lg %r3,62(%r11)
000003ff80ef3dda: ec230006a065 clgrj %r2,%r3,10,3ff80ef3de6 ; jmp
000003ff80ef3de0: e3e0b0460004 lg %r14,70(%r11)
000003ff80ef3de6: e3e0b04e0004 lg %r14,78(%r11) ; target
000003ff80ef3dec: b904002e lgr %r2,%r14
000003ff80ef3df0: e3b0f0700004 lg %r11,112(%r15)
000003ff80ef3df6: e3e0f0880004 lg %r14,136(%r15)
000003ff80ef3dfc: 07fe bcr 15,%r14
test_bpf.ko suite runs fine after the fix.
Tested-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Add jited_len to struct bpf_prog. It will be
useful for the struct bpf_prog_info which will
be added in the later patch.
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Acked-by: Alexei Starovoitov <ast@fb.com>
free up BPF_JMP | BPF_CALL | BPF_X opcode to be used by actual
indirect call by register and use kernel internal opcode to
mark call instruction into bpf_tail_call() helper.
set_memory_* functions have moved to set_memory.h. Switch to this
explicitly
Link: http://lkml.kernel.org/r/1488920133-27229-5-git-send-email-labbott@redhat.com
Signed-off-by: Laura Abbott <labbott@redhat.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Pull s390 updates from Martin Schwidefsky:
- New entropy generation for the pseudo random number generator.
- Early boot printk output via sclp to help debug crashes on boot. This
needs to be enabled with a kernel parameter.
- Add proper no-execute support with a bit in the page table entry.
- Bug fixes and cleanups.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (65 commits)
s390/syscall: fix single stepped system calls
s390/zcrypt: make ap_bus explicitly non-modular
s390/zcrypt: Removed unneeded debug feature directory creation.
s390: add missing "do {} while (0)" loop constructs to multiline macros
s390/mm: add cond_resched call to kernel page table dumper
s390: get rid of MACHINE_HAS_PFMF and MACHINE_HAS_HPAGE
s390/mm: make memory_block_size_bytes available for !MEMORY_HOTPLUG
s390: replace ACCESS_ONCE with READ_ONCE
s390: Audit and remove any remaining unnecessary uses of module.h
s390: mm: Audit and remove any unnecessary uses of module.h
s390: kernel: Audit and remove any unnecessary uses of module.h
s390/kdump: Use "LINUX" ELF note name instead of "CORE"
s390: add no-execute support
s390: report new vector facilities
s390: use correct input data address for setup_randomness
s390/sclp: get rid of common response code handling
s390/sclp: don't add new lines to each printed string
s390/sclp: make early sclp code readable
s390/sclp: disable early sclp code as soon as the base sclp driver is active
s390/sclp: move early printk code to drivers
Eric and Willem reported that they recently saw random crashes when
JIT was in use and bisected this to 74451e66d516 ("bpf: make jited
programs visible in traces"). Issue was that the consolidation part
added bpf_jit_binary_unlock_ro() that would unlock previously made
read-only memory back to read-write. However, DEBUG_SET_MODULE_RONX
cannot be used for this to test for presence of set_memory_*()
functions. We need to use ARCH_HAS_SET_MEMORY instead to fix this;
also add the corresponding bpf_jit_binary_lock_ro() to filter.h.
Fixes: 74451e66d516 ("bpf: make jited programs visible in traces")
Reported-by: Eric Dumazet <edumazet@google.com>
Reported-by: Willem de Bruijn <willemb@google.com>
Bisected-by: Eric Dumazet <edumazet@google.com>
Tested-by: Willem de Bruijn <willemb@google.com>
Long standing issue with JITed programs is that stack traces from
function tracing check whether a given address is kernel code
through {__,}kernel_text_address(), which checks for code in core
kernel, modules and dynamically allocated ftrace trampolines. But
what is still missing is BPF JITed programs (interpreted programs
are not an issue as __bpf_prog_run() will be attributed to them),
thus when a stack trace is triggered, the code walking the stack
won't see any of the JITed ones. The same for address correlation
done from user space via reading /proc/kallsyms. This is read by
tools like perf, but the latter is also useful for permanent live
tracing with eBPF itself in combination with stack maps when other
eBPF types are part of the callchain. See offwaketime example on
dumping stack from a map.
This work tries to tackle that issue by making the addresses and
symbols known to the kernel. The lookup from *kernel_text_address()
is implemented through a latched RB tree that can be read under
RCU in fast-path that is also shared for symbol/size/offset lookup
for a specific given address in kallsyms. The slow-path iteration
through all symbols in the seq file done via RCU list, which holds
a tiny fraction of all exported ksyms, usually below 0.1 percent.
Function symbols are exported as bpf_prog_<tag>, in order to aide
debugging and attribution. This facility is currently enabled for
root-only when bpf_jit_kallsyms is set to 1, and disabled if hardening
is active in any mode. The rationale behind this is that still a lot
of systems ship with world read permissions on kallsyms thus addresses
should not get suddenly exposed for them. If that situation gets
much better in future, we always have the option to change the
default on this. Likewise, unprivileged programs are not allowed
to add entries there either, but that is less of a concern as most
such programs types relevant in this context are for root-only anyway.
If enabled, call graphs and stack traces will then show a correct
attribution; one example is illustrated below, where the trace is
now visible in tooling such as perf script --kallsyms=/proc/kallsyms
and friends.
Before:
7fff8166889d bpf_clone_redirect+0x80007f0020ed (/lib/modules/4.9.0-rc8+/build/vmlinux)
f5d80 __sendmsg_nocancel+0xffff006451f1a007 (/usr/lib64/libc-2.18.so)
After:
7fff816688b7 bpf_clone_redirect+0x80007f002107 (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fffa0575728 bpf_prog_33c45a467c9e061a+0x8000600020fb (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fffa07ef1fc cls_bpf_classify+0x8000600020dc (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff81678b68 tc_classify+0x80007f002078 (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff8164d40b __netif_receive_skb_core+0x80007f0025fb (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff8164d718 __netif_receive_skb+0x80007f002018 (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff8164e565 process_backlog+0x80007f002095 (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff8164dc71 net_rx_action+0x80007f002231 (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff81767461 __softirqentry_text_start+0x80007f0020d1 (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff817658ac do_softirq_own_stack+0x80007f00201c (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff810a2c20 do_softirq+0x80007f002050 (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff810a2cb5 __local_bh_enable_ip+0x80007f002085 (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff8168d452 ip_finish_output2+0x80007f002152 (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff8168ea3d ip_finish_output+0x80007f00217d (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff8168f2af ip_output+0x80007f00203f (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff81005854 do_syscall_64+0x80007f002054 (/lib/modules/4.9.0-rc8+/build/vmlinux)
7fff817649eb return_from_SYSCALL_64+0x80007f002000 (/lib/modules/4.9.0-rc8+/build/vmlinux)
f5d80 __sendmsg_nocancel+0xffff01c484812007 (/usr/lib64/libc-2.18.so)
Remove the dummy bpf_jit_compile() stubs for eBPF JITs and make
that a single __weak function in the core that can be overridden
similarly to the eBPF one. Also remove stale pr_err() mentions
of bpf_jit_compile.
After we already allocated the jit.prg_buf image via
bpf_jit_binary_alloc() and filled it out with instructions,
jit.prg_buf cannot be NULL anymore. Thus, remove the
unnecessary check. Tested on s390x with test_bpf module.
This patch allows XDP prog to extend/remove the packet
data at the head (like adding or removing header). It is
done by adding a new XDP helper bpf_xdp_adjust_head().
It also renames bpf_helper_changes_skb_data() to
bpf_helper_changes_pkt_data() to better reflect
that XDP prog does not work on skb.
This patch adds one "xdp_adjust_head" bit to bpf_prog for the
XDP-capable driver to check if the XDP prog requires
bpf_xdp_adjust_head() support. The driver can then decide
to error out during XDP_SETUP_PROG.
Acked-by: John Fastabend <john.r.fastabend@intel.com>
In case of usage of skb_vlan_push/pop, in the prologue we store
the SKB pointer on the stack and restore it after BPF_JMP_CALL
to skb_vlan_push/pop.
Unfortunately currently there are two bugs in the code:
1) The wrong stack slot (offset 170 instead of 176) is used
2) The wrong register (W1 instead of B1) is saved
So fix this and use correct stack slot and register.
Cc: stable@vger.kernel.org # 4.3+
The s390 BFP compiler currently uses relative branch instructions
that only support jumps up to 64 KB. Examples are "j", "jnz", "cgrj",
etc. Currently the maximum size of s390 BPF programs is set
to 0x7ffff. If branches over 64 KB are generated the, kernel can
crash due to incorrect code.
So fix this an reduce the maximum size to 64 KB. Programs larger than
that will be interpreted.
Fixes: ce2b6ad9c185 ("s390/bpf: increase BPF_SIZE_MAX")
This patch adds recently added constant blinding helpers into the
s390 eBPF JIT. In the bpf_int_jit_compile() path, requirements are
to utilize bpf_jit_blind_constants()/bpf_jit_prog_release_other()
pair for rewriting the program into a blinded one, and to map the
BPF_REG_AX register to a CPU register. The mapping of BPF_REG_AX
is at r12 and similarly like in x86 case performs reloading when
ld_abs/ind is used. When blinding is not used, there's no additional
overhead in the generated image.
When BPF_REG_AX is used, we don't need to emit skb->data reload when
helper function changed skb->data, as this will be reloaded later
on anyway from stack on ld_abs/ind, where skb->data is needed. s390
allows for this w/o much additional complexity unlike f.e. x86.
