path: root/arch/s390/oprofile
2007-10-19Combine instrumentation menus in kernel/Kconfig.instrumentationMathieu Desnoyers
Quoting Randy: "It seems sad that this patch sources Kconfig.marker, a 7-line file, 20-something times. Yes, you (we) don't want to put those 7 lines into 20-something different files, so sourcing is the right thing. However, what you did for avr32 seems more on the right track to me: make _one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES, and MARKERS and then use (source) that in all of the arches." Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-06[PATCH] s390: add oprofile callgraph supportAndreas Krebbel
Signed-off-by: Andreas Krebbel <krebbel1@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
