path: root/arch/s390/scripts
2019-08-08s390/build: use size command to perform empty .bss checkVasily Gorbik
Currently empty .bss checks performed do not pay attention to "common objects" in object files which end up in .bss section eventually. The "size" tool is a part of binutils and since version 2.18 provides "--common" command line option, which allows to account "common objects" sizes in .bss section size. Utilize "size --common" to perform accurate check that .bss section is unused. Besides that the size tool handles object files without .bss section gracefully and doesn't require additional objdump run. The linux kernel requires binutils 2.20 since 4.13. Kbuild exports OBJSIZE to reference the right size tool. Link: http://lkml.kernel.org/r/patch-2.thread-2257a1.git-2257a1c53d4a.your-ad-here.call-01565088755-ext-5120@work.hours Reported-and-tested-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
2019-04-11s390: make chkbss work with clangArnd Bergmann
llvm skips an empty .bss section entirely, which makes the check fail with an unexpected error: /tmp/binutils-multi-test/bin/s390x-linux-gnu-objdump: section '.bss' mentioned in a -j option, but not found in any input file error: arch/s390/boot/compressed/decompressor.o .bss section is not empty ../arch/s390/scripts/Makefile.chkbss:20: recipe for target 'arch/s390/boot/compressed/decompressor.o.chkbss' failed Change the check so we first see if a .bss section exists before trying to read its size. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2019-01-28s390: make built-in.a not directly depend on *.o.chkbss filesMasahiro Yamada
When I was refactoring cmd_ar_builtin in scripts/Makefile.build, I noticed the build breakage of s390. Some Makefiles of s390 add extra dependencies to built-in.a; built-in.a depends on timestamp files *.o.chkbss, but $(AR) does not want to include them into built-in.a. Insert a phony target 'chkbss' in between so that $(AR) can take $(filter-out $(PHONY), $^) as input. While I was here, I refactored Makefile.chkbss a little bit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2018-07-02s390/build: add *.o.chkbss files to targets listVasily Gorbik
Adding *.o.chkbss files to targets list makes sure that the kbuild is aware of them and removes them during make clean. Also remove *.o.chkbss file before an actual check, to avoid having stale *.o.chkbss file left even if the check is failed. Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Vasily Gorbik <gor@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2018-06-25s390: add custom target and make path extension optional for .bss checkVasily Gorbik
"chkbss-target" could be now used to override default target .bss check is bound to. Objects to be checked are only path extended when needed. Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Vasily Gorbik <gor@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2018-05-09s390: introduce compile time check for empty .bss sectionVasily Gorbik
Introduce compile time check for files which should avoid using .bss section, because of the following reasons: - .bss section has not been zeroed yet, - initrd has not been moved to a safe location and could be overlapping with .bss section. Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Vasily Gorbik <gor@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
