path: root/arch/s390
2013-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull more s390 patches from Martin Schwidefsky: "A couple of bug fixes: one of the transparent huge page primitives is broken, the sched_clock function overflows after 417 days, the XFS module has grown too large for -fpic and the new pci code has broken normal channel subsystem notifications." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/chsc: fix SEI usage s390/time: fix sched_clock() overflow s390: use -fPIC for module compile s390/mm: fix pmd_pfn() for thp
2013-01-16s390/time: fix sched_clock() overflowHeiko Carstens
Converting a 64 Bit TOD format value to nanoseconds means that the value must be divided by 4.096. In order to achieve that we multiply with 125 and divide by 512. When used within sched_clock() this triggers an overflow after appr. 417 days. Resulting in a sched_clock() return value that is much smaller than previously and therefore may cause all sort of weird things in subsystems that rely on a monotonic sched_clock() behaviour. To fix this implement a tod_to_ns() helper function which converts TOD values without overflow and call this function from both places that open coded the conversion: sched_clock() and kvm_s390_handle_wait(). Cc: stable@kernel.org Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-12s390: use -fPIC for module compileMartin Schwidefsky
The xfs module uses a lot of tracepoint, with TRACEPOINTS=y and a few debugging options the GOT table of the xfs module will get bigger than 4K. To get a working xfs module it needs to be compiled with -fPIC instead of -fpic. To play safe use -fPIC for all modules. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-12s390/mm: fix pmd_pfn() for thpGerald Schaefer
The pfn calculation in pmd_pfn() is broken for thp, because it uses HPAGE_SHIFT instead of the normal PAGE_SHIFT. This is fixed by removing the distinction between thp and normal pmds in that function, and always using PAGE_SHIFT. Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-10s390/kvm: Fix BUG in include/linux/kvm_host.h:745Christian Borntraeger
commit b080935c8638e08134629d0a9ebdf35669bec14d kvm: Directly account vtime to system on guest switch also removed the irq_disable/enable around kvm guest switch, which is correct in itself. Unfortunately, there is a BUG ON that (correctly) checks for preemptible to cover the call to rcu later on. (Introduced with commit 8fa2206821953a50a3a02ea33fcfb3ced2fd9997 KVM: make guest mode entry to be rcu quiescent state) This check might trigger depending on the kernel config. Lets make sure that no preemption happens during kvm_guest_enter. We can enable preemption again after the call to rcu_virt_note_context_switch returns. Please note that we continue to run s390 guests with interrupts enabled. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> CC: Gleb Natapov <gleb@redhat.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-01-08s390/pci: define read*_relaxed functionsHeiko Carstens
Just map the read*_relaxed() functions to their corresponding read*() functions. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-08s390/topology: export cpu_topologyHeiko Carstens
Export cpu_topology symbol, so it's available for modules. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-08s390/pm: export pm_power_offHeiko Carstens
Export pm_power_off symbol. Needed by at least one of the new device drivers that come with CONFIG_PCI. And all other architectures export that symbol as well. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-08s390/pci: define isa_dma_bridge_buggyHeiko Carstens
Define isa_dma_bridge_buggy. Needed to make pci quirks compile: drivers/pci/quirks.c: In function ‘quirk_isa_dma_hangs’: drivers/pci/quirks.c:88:7: error: ‘isa_dma_bridge_buggy’ undeclared (first use in this function) Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-08s390/irq: count cpu restart eventsHeiko Carstens
Count CPU Restart events and make them visible via /proc/interrupts. Every CPU hotplug (online) event will increase the per cpu counter. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-08s390/irq: remove split irq fields from /proc/statHeiko Carstens
Now that irq sum accounting for /proc/stat's "intr" line works again we have the oddity that the sum field (first field) contains only the sum of the second (external irqs) and third field (I/O interrupts). The reason for that is that these two fields are already sums of all other fields. So if we would sum up everything we would count every interrupt twice. This is broken since the split interrupt accounting was merged two years ago: 052ff461c8427629aee887ccc27478fc7373237c "[S390] irq: have detailed statistics for interrupt types". To fix this remove the split interrupt fields from /proc/stat's "intr" line again and only have them in /proc/interrupts. This restores the old behaviour, seems to be the only sane fix and mimics a behaviour from other architectures where /proc/interrupts also contains more than /proc/stat's "intr" line does. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-08s390/irq: enable irq sum accounting for /proc/stat againHeiko Carstens
For more than two years, since f2c66cd8eeddedb440f33bc0f5cec1ed7ae376cb "/proc/stat: scalability of irq num per cpu" the output of /proc/stat is broken. The first field in the "intr" line should contain the sum of all interrupts, however since the above mentioned change it is always zero. The reason for that is that a per cpu irq sum variable had been introduced which got incremented when calling kstat_incr_irqs_this_cpu(). However on s390 we directly incremented only the per cpu per irq counter by accessing the array element via kstat_cpu(smp_processor_id()).irqs[...]. So fix this and use the kstat_incr_irqs_this_cpu() wrapper which increments both: the per cpu per irq counter and the per cpu irq sum counter. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-08s390/syscalls: wire up finit_module syscallHeiko Carstens
2013-01-08s390/pci: remove dead codeHeiko Carstens
Get rid of these: arch/s390/pci/pci_dma.c:16:29: warning: ‘zpci_ioat_dt’ defined but not used [-Wunused-variable] arch/s390/pci/pci.c:164:12: warning: ‘zpci_store_fib’ defined but not used [-Wunused-function] Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-08s390/smp: fix section mismatch for smp_add_present_cpu()Heiko Carstens
Fixes this section mismatch: WARNING: vmlinux.o(.text+0x145e4): Section mismatch in reference from the function smp_add_present_cpu() to the function .cpuinit.text:register_cpu() The function smp_add_present_cpu() references the function __cpuinit register_cpu(). This is often because smp_add_present_cpu lacks a __cpuinit annotation or the annotation of register_cpu is wrong. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-08s390/debug: Fix s390dbf lockdep problem in debug_(un)register_view()Michael Holzheu
The debug_register/unregister_view() functions call debugfs_remove() while holding the debug_info spinlock. Because debugfs_remove() takes a mutex and therefore can sleep this is not allowed. To fix the problem we give up the debug_info lock before calling debugfs_remove(). The following shows the lockdep message: [ INFO: possible circular locking dependency detected ] ------------------------------------------------------- rmmod/4379 is trying to acquire lock: (&sb->s_type->i_mutex_key#2){+.+.+.}, at: [<00000000003acae2>] debugfs_remove+0x5e/0xa but task is already holding lock: (&(&rc->lock)->rlock){-.-...}, at: [<000000000010a5ae>] debug_unregister_view+0x3a/0xd which lock already depends on the new lock. -> #0 (&sb->s_type->i_mutex_key#2){+.+.+.}: [<00000000001b1644>] validate_chain+0x880/0x1154 [<00000000001b4d6c>] __lock_acquire+0x414/0xc44 [<00000000001b5c16>] lock_acquire+0xbe/0x178 [<0000000000614016>] mutex_lock_nested+0x66/0x36c [<00000000003acae2>] debugfs_remove+0x5e/0xac [<000000000010a620>] debug_unregister_view+0xac/0xd0 [<000003ff8002f140>] qeth_core_exit+0x48/0xf08 [qeth] [<00000000001c35a4>] SyS_delete_module+0x1a4/0x260 [<0000000000618134>] sysc_noemu+0x22/0x28 [<000003fffd4704da>] 0x3fffd4704da Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-03ARCH: drivers remove __dev* attributes.Greg Kroah-Hartman
This fixes up all of the smaller arches that had __dev* markings for their platform-specific drivers. CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Bob Liu <lliubbo@gmail.com> Cc: Srinivas Kandagatla <srinivas.kandagatla@st.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Myron Stowe <myron.stowe@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Thierry Reding <thierry.reding@avionic-design.de> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Cc: Mark Salter <msalter@redhat.com> Cc: Yong Zhang <yong.zhang0@gmail.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Jan Glauber <jang@linux.vnet.ibm.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "sigaltstack infrastructure + conversion for x86, alpha and um, COMPAT_SYSCALL_DEFINE infrastructure. Note that there are several conflicts between "unify SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline; resolution is trivial - just remove definitions of SS_ONSTACK and SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and include/uapi/linux/signal.h contains the unified variant." Fixed up conflicts as per Al. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to generic sigaltstack new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those generic compat_sys_sigaltstack() introduce generic sys_sigaltstack(), switch x86 and um to it new helper: compat_user_stack_pointer() new helper: restore_altstack() unify SS_ONSTACK/SS_DISABLE definitions new helper: current_user_stack_pointer() missing user_stack_pointer() instances Bury the conditionals from kernel_thread/kernel_execve series COMPAT_SYSCALL_DEFINE: infrastructure
2012-12-19unify SS_ONSTACK/SS_DISABLE definitionsAl Viro
2012-12-19Bury the conditionals from kernel_thread/kernel_execve seriesAl Viro
All architectures have CONFIG_GENERIC_KERNEL_THREAD CONFIG_GENERIC_KERNEL_EXECVE __ARCH_WANT_SYS_EXECVE None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers of kernel_execve() (which is a trivial wrapper for do_execve() now) left. Kill the conditionals and make both callers use do_execve(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-19COMPAT_SYSCALL_DEFINE: infrastructureAl Viro
2012-12-17s390/ccwdev: Include asm/schid.h.Cornelia Huck
Get the definition of struct subchannel_id. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-12-14s390/pci: performance statistics and debug infrastructureJan Glauber
Add support for reading the PCI function measurement block counters provided by the hypervisor. Add two s390 debug features, one for critical errors and one for tracing and provide wrappers to log data. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-12-13Merge tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Marcelo Tosatti: "Considerable KVM/PPC work, x86 kvmclock vsyscall support, IA32_TSC_ADJUST MSR emulation, amongst others." Fix up trivial conflict in kernel/sched/core.c due to cross-cpu migration notifier added next to rq migration call-back. * tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (156 commits) KVM: emulator: fix real mode segment checks in address linearization VMX: remove unneeded enable_unrestricted_guest check KVM: VMX: fix DPL during entry to protected mode x86/kexec: crash_vmclear_local_vmcss needs __rcu kvm: Fix irqfd resampler list walk KVM: VMX: provide the vmclear function and a bitmap to support VMCLEAR in kdump x86/kexec: VMCLEAR VMCSs loaded on all cpus if necessary KVM: MMU: optimize for set_spte KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation KVM: PPC: bookehv: Add guest computation mode for irq delivery KVM: PPC: Make EPCR a valid field for booke64 and bookehv KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation KVM: PPC: e500: Add emulation helper for getting instruction ea KVM: PPC: bookehv64: Add support for interrupt handling KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler KVM: PPC: booke: Fix get_tb() compile error on 64-bit KVM: PPC: e500: Silence bogus GCC warning in tlb code ...
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 update from Martin Schwidefsky: "Add support to generate code for the latest machine zEC12, MOD and XOR instruction support for the BPF jit compiler, the dasd safe offline feature and the big one: the s390 architecture gets PCI support!! Right before the world ends on the 21st ;-)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (41 commits) s390/qdio: rename the misleading PCI flag of qdio devices s390/pci: remove obsolete email addresses s390/pci: speed up __iowrite64_copy by using pci store block insn s390/pci: enable NEED_DMA_MAP_STATE s390/pci: no msleep in potential IRQ context s390/pci: fix potential NULL pointer dereference in dma_free_seg_table() s390/pci: use kmem_cache_zalloc instead of kmem_cache_alloc/memset s390/bpf,jit: add support for XOR instruction s390/bpf,jit: add support MOD instruction s390/cio: fix pgid reserved check vga: compile fix, disable vga for s390 s390/pci: add PCI Kconfig options s390/pci: s390 specific PCI sysfs attributes s390/pci: PCI hotplug support via SCLP s390/pci: CHSC PCI support for error and availability events s390/pci: DMA support s390/pci: PCI adapter interrupts for MSI/MSI-X s390/bitops: find leftmost bit instruction support s390/pci: CLP interface s390/pci: base support ...
2012-12-13Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge misc VM changes from Andrew Morton: "The rest of most-of-MM. The other MM bits await a slab merge. This patch includes the addition of a huge zero_page. Not a performance boost but it an save large amounts of physical memory in some situations. Also a bunch of Fujitsu engineers are working on memory hotplug. Which, as it turns out, was badly broken. About half of their patches are included here; the remainder are 3.8 material." However, this merge disables CONFIG_MOVABLE_NODE, which was totally broken. We don't add new features with "default y", nor do we add Kconfig questions that are incomprehensible to most people without any help text. Does the feature even make sense without compaction or memory hotplug? * akpm: (54 commits) mm/bootmem.c: remove unused wrapper function reserve_bootmem_generic() mm/memory.c: remove unused code from do_wp_page() asm-generic, mm: pgtable: consolidate zero page helpers mm/hugetlb.c: fix warning on freeing hwpoisoned hugepage hwpoison, hugetlbfs: fix RSS-counter warning hwpoison, hugetlbfs: fix "bad pmd" warning in unmapping hwpoisoned hugepage mm: protect against concurrent vma expansion memcg: do not check for mm in __mem_cgroup_count_vm_event tmpfs: support SEEK_DATA and SEEK_HOLE (reprise) mm: provide more accurate estimation of pages occupied by memmap fs/buffer.c: remove redundant initialization in alloc_page_buffers() fs/buffer.c: do not inline exported function writeback: fix a typo in comment mm: introduce new field "managed_pages" to struct zone mm, oom: remove statically defined arch functions of same name mm, oom: remove redundant sleep in pagefault oom handler mm, oom: cleanup pagefault oom handler memory_hotplug: allow online/offline memory to result movable node numa: add CONFIG_MOVABLE_NODE for movable-dedicated node mm, memcg: avoid unnecessary function call when memcg is disabled ...
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-12-12asm-generic, mm: pgtable: consolidate zero page helpersKirill A. Shutemov
We have two different implementation of is_zero_pfn() and my_zero_pfn() helpers: for architectures with and without zero page coloring. Let's consolidate them in <asm-generic/pgtable.h>. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull big execve/kernel_thread/fork unification series from Al Viro: "All architectures are converted to new model. Quite a bit of that stuff is actually shared with architecture trees; in such cases it's literally shared branch pulled by both, not a cherry-pick. A lot of ugliness and black magic is gone (-3KLoC total in this one): - kernel_thread()/kernel_execve()/sys_execve() redesign. We don't do syscalls from kernel anymore for either kernel_thread() or kernel_execve(): kernel_thread() is essentially clone(2) with callback run before we return to userland, the callbacks either never return or do successful do_execve() before returning. kernel_execve() is a wrapper for do_execve() - it doesn't need to do transition to user mode anymore. As a result kernel_thread() and kernel_execve() are arch-independent now - they live in kernel/fork.c and fs/exec.c resp. sys_execve() is also in fs/exec.c and it's completely architecture-independent. - daemonize() is gone, along with its parts in fs/*.c - struct pt_regs * is no longer passed to do_fork/copy_process/ copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump. - sys_fork()/sys_vfork()/sys_clone() unified; some architectures still need wrappers (ones with callee-saved registers not saved in pt_regs on syscall entry), but the main part of those suckers is in kernel/fork.c now." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits) do_coredump(): get rid of pt_regs argument print_fatal_signal(): get rid of pt_regs argument ptrace_signal(): get rid of unused arguments get rid of ptrace_signal_deliver() arguments new helper: signal_pt_regs() unify default ptrace_signal_deliver flagday: kill pt_regs argument of do_fork() death to idle_regs() don't pass regs to copy_process() flagday: don't pass regs to copy_thread() bfin: switch to generic vfork, get rid of pointless wrappers xtensa: switch to generic clone() openrisc: switch to use of generic fork and clone unicore32: switch to generic clone(2) score: switch to generic fork/vfork/clone c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone() take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h mn10300: switch to generic fork/vfork/clone h8300: switch to generic fork/vfork/clone tile: switch to generic clone() ... Conflicts: arch/microblaze/include/asm/Kbuild
2012-12-11Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The biggest change affects group scheduling: we now track the runnable average on a per-task entity basis, allowing a smoother, exponential decay average based load/weight estimation instead of the previous binary on-the-runqueue/off-the-runqueue load weight method. This will inevitably disturb workloads that were in some sort of borderline balancing state or unstable equilibrium, so an eye has to be kept on regressions. For that reason the new load average is only limited to group scheduling (shares distribution) at the moment (which was also hurting the most from the prior, crude weight calculation and whose scheduling quality wins most from this change) - but we plan to extend this to regular SMP balancing as well in the future, which will simplify and speed up things a bit. Other changes involve ongoing preparatory work to extend NOHZ to the scheduler as well, eventually allowing completely irq-free user-space execution." * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits) Revert "sched/autogroup: Fix crash on reboot when autogroup is disabled" cputime: Comment cputime's adjusting code cputime: Consolidate cputime adjustment code cputime: Rename thread_group_times to thread_group_cputime_adjusted cputime: Move thread_group_cputime() to sched code vtime: Warn if irqs aren't disabled on system time accounting APIs vtime: No need to disable irqs on vtime_account() vtime: Consolidate a bit the ctx switch code vtime: Explicitly account pending user time on process tick vtime: Remove the underscore prefix invasion sched/autogroup: Fix crash on reboot when autogroup is disabled cputime: Separate irqtime accounting from generic vtime cputime: Specialize irq vtime hooks kvm: Directly account vtime to system on guest switch vtime: Make vtime_account_system() irqsafe vtime: Gather vtime declarations to their own header file sched: Describe CFS load-balancer sched: Introduce temporary FAIR_GROUP_SCHED dependency for load-tracking sched: Make __update_entity_runnable_avg() fast sched: Update_cfs_shares at period edge ...
2012-12-11Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Lots of activity: 211 files changed, 8328 insertions(+), 4116 deletions(-) most of it on the tooling side. Main changes: * ftrace enhancements and fixes from Steve Rostedt. * uprobes fixes, cleanups and preparation for the ARM port from Oleg Nesterov. * UAPI fixes, from David Howels - prepares the arch/x86 UAPI transition * Separate perf tests into multiple objects, one per test, from Jiri Olsa. * Make hardware event translations available in sysfs, from Jiri Olsa. * Fixes to /proc/pid/maps parsing, preparatory to supporting data maps, from Namhyung Kim * Implement ui_progress for GTK, from Namhyung Kim * Add framework for automated perf_event_attr tests, where tools with different command line options will be run from a 'perf test', via python glue, and the perf syscall will be intercepted to verify that the perf_event_attr fields set by the tool are those expected, from Jiri Olsa * Add a 'link' method for hists, so that we can have the leader with buckets for all the entries in all the hists. This new method is now used in the default 'diff' output, making the sum of the 'baseline' column be 100%, eliminating blind spots. * libtraceevent fixes for compiler warnings trying to make perf it build on some distros, like fedora 14, 32-bit, some of the warnings really pointed to real bugs. * Add a browser for 'perf script' and make it available from the report and annotate browsers. It does filtering to find the scripts that handle events found in the perf.data file used. From Feng Tang * perf inject changes to allow showing where a task sleeps, from Andrew Vagin. * Makefile improvements from Namhyung Kim. * Add --pre and --post command hooks in 'stat', from Peter Zijlstra. * Don't stop synthesizing threads when one vanishes, this is for the existing threads when we start a tool like trace. * Use sched:sched_stat_runtime to provide a thread summary, this produces the same output as the 'trace summary' subcommand of tglx's original "trace" tool. * Support interrupted syscalls in 'trace' * Add an event duration column and filter in 'trace'. * There are references to the man pages in some tools, so try to build Documentation when installing, warning the user if that is not possible, from Borislav Petkov. * Give user better message if precise is not supported, from David Ahern. * Try to find cross-built objdump path by using the session environment information in the perf.data file header, from Irina Tirdea, original patch and idea by Namhyung Kim. * Diplays more output on features check for make V=1, so that one can figure out what is happening by looking at gcc output, etc. From Jiri Olsa. * Add on_exit implementation for systems without one, e.g. Android, from Bernhard Rosenkraenzer. * Only process events for vcpus of interest, helps handling large number of events, from David Ahern. * Cross compilation fixes for Android, from Irina Tirdea. * Add documentation on compiling for Android, from Irina Tirdea. * perf diff improvements from Jiri Olsa. * Target (task/user/cpu/syswide) handling improvements, from Namhyung Kim. * Add support in 'trace' for tracing workload given by command line, from Namhyung Kim. * ... and much more." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (194 commits) uprobes: Use percpu_rw_semaphore to fix register/unregister vs dup_mmap() race perf evsel: Introduce is_group_member method perf powerpc: Use uapi/unistd.h to fix build error tools: Pass the target in descend tools: Honour the O= flag when tool build called from a higher Makefile tools: Define a Makefile function to do subdir processing perf ui: Always compile browser setup code perf ui: Add ui_progress__finish() perf ui gtk: Implement ui_progress functions perf ui: Introduce generic ui_progress helper perf ui tui: Move progress.c under ui/tui directory perf tools: Add basic event modifier sanity check perf tools: Omit group members from perf_evlist__disable/enable perf tools: Ensure single disable call per event in record comand perf tools: Fix 'disabled' attribute config for record command perf tools: Fix attributes for '{}' defined event groups perf tools: Use sscanf for parsing /proc/pid/maps perf tools: Add gtk.<command> config option for launching GTK browser perf tools: Fix compile error on NO_NEWT=1 build perf hists: Initialize all of he->stat with zeroes ...
2012-12-11mm: add comment on storage key dirty bit semanticsJan Kara
Add comments that dirty bit in storage key gets set whenever page content is changed. Hopefully if someone will use this function, he'll have a look at one of the two places where we comment on this. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11s390/pci: remove obsolete email addressesJan Glauber
2012-12-11s390/pci: speed up __iowrite64_copy by using pci store block insnJan Glauber
Benefit from pci store block instruction by writing up to 128 bytes with a single instruction to MMIO space. Depending on the workload this can result in a huge performance increase due to the reduced number of instructions. The ordering guarantees of single stores vs. one store block are identical. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-12-08Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/core Pull ftrace updates from Steve Rostedt. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-12-08Merge tag 'sched-cputime-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into sched/core Pull more cputime cleanups from Frederic Weisbecker: * Get rid of underscores polluting the vtime namespace * Consolidate context switch and tick handling * Improve debuggability by detecting irq unsafe callers Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-12-07Merge branch 'linus' into sched/coreIngo Molnar
Pick up the autogroups fix and other fixes. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-12-05s390/pci: enable NEED_DMA_MAP_STATEJan Glauber
The DMA API allows to avoid DMA unmaps because they are NOPs on some plattforms. But not on s390, so force them. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-12-05s390/pci: no msleep in potential IRQ contextJan Glauber
The PCI instructions may be used in IRQ context so scheduling is forbidden. Use udelay and shorten the delay since we are now polling. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-12-03s390/pci: fix potential NULL pointer dereference in dma_free_seg_table()Wei Yongjun
The dereference to 'zdev' should be moved below the NULL test. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-12-03s390/pci: use kmem_cache_zalloc instead of kmem_cache_alloc/memsetWei Yongjun
Using kmem_cache_zalloc() instead of kmem_cache_alloc() and memset(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-12-03s390/bpf,jit: add support for XOR instructionHeiko Carstens
Add support for XOR instruction for use with X/K. s390 JIT support for the new BPF_S_ALU_XOR_* instructions introduced with 9e49e889 "filter: add XOR instruction for use with X/K". Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-12-03s390/bpf,jit: add support MOD instructionHeiko Carstens
Add support for MOD operation for s390's JIT. Same as 280050cc "x86 bpf_jit: support MOD operation" for x86 which adds JIT support for the generic new MOD operation introduced with b6069a9570 "filter: add MOD operation". Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-12-02open*(2) compat fixes (s390, arm64)Al Viro
The usual rules for open()/openat()/open_by_handle_at() are 1) native 32bit - don't force O_LARGEFILE in flags 2) native 64bit - force O_LARGEFILE in flags 3) compat on 64bit host - as for native 32bit 4) native 32bit ABI for 64bit system (mips/n32, x86/x32) - as for native 64bit There are only two exceptions - s390 compat has open() forcing O_LARGEFILE and arm64 compat has open_by_handle_at() doing the same thing. The same binaries on native host (s390/31 and arm resp.) will *not* force O_LARGEFILE, so IMO both are emulation bugs. Objections? The fix is obvious... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-30vga: compile fix, disable vga for s390Jan Glauber
2012-11-30s390/pci: add PCI Kconfig optionsJan Glauber
CONFIG_PCI is disabled by default currently. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-30s390/pci: s390 specific PCI sysfs attributesJan Glauber
Add some s390 specific sysfs attributes to the PCI device directory. The following attributes are introduced: - function_id (PCI function ID) - function_handle (PCI function handle) - pchid (PCI channel ID) - pfgid (PCI function group ID aka PCI root complex) Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-30s390/pci: PCI hotplug support via SCLPJan Glauber
Add SCLP PCI configure/deconfigure and implement a PCI hotplug controller (s390_pci_hpc). The hotplug controller creates a slot for every PCI function in stand-by or configured state. The PCI functions are named after the PCI function ID (fid). By writing to the power attribute in /sys/bus/pci/slots/<fid>/power the PCI function is moved to stand-by or configured state. If moved to the configured state the device is automatically scanned by the s390 PCI layer. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-30s390/pci: CHSC PCI support for error and availability eventsJan Glauber
Add CHSC store-event-information support for PCI (notfication type 2) and report error and availability events to the PCI architecture layer. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-30s390/pci: DMA supportJan Glauber
Add DMA IOMMU support using 4K page table entries. Implement dma_map_ops. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
