commit ab874f22d35a8058d8fdee5f13eb69d8867efeae upstream.
On older HW or under a hypervisor, w/o the instruction-execution-
protection (IEP) facility, and also w/o EDAT-1, a translation-specification
exception may be recognized when bit 55 of a pte is one (_PAGE_NOEXEC).
The current code tries to prevent setting _PAGE_NOEXEC in such cases,
by removing it within set_pte_at(). However, ptep_set_access_flags()
will modify a pte directly, w/o using set_pte_at(). There is at least
one scenario where this can result in an active pte with _PAGE_NOEXEC
set, which would then lead to a panic due to a translation-specification
exception (write to swapped out page):
do_swap_page
pte = mk_pte (with _PAGE_NOEXEC bit)
set_pte_at (will remove _PAGE_NOEXEC bit in page table, but keep it
in local variable pte)
vmf->orig_pte = pte (pte still contains _PAGE_NOEXEC bit)
do_wp_page
wp_page_reuse
entry = vmf->orig_pte (still with _PAGE_NOEXEC bit)
ptep_set_access_flags (writes entry with _PAGE_NOEXEC bit)
Fix this by clearing _PAGE_NOEXEC already in mk_pte_phys(), where the
pgprot value is applied, so that no pte with _PAGE_NOEXEC will ever be
visible, if it is not supported. The check in set_pte_at() can then also
be removed.
Cc: <stable@vger.kernel.org> # 4.11+
Fixes: 57d7f939e7bd ("s390: add no-execute support")
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
The mainline commit 8fde12ca79af ("mm: prevent get_user_pages() from
overflowing page refcount") was backported to 4.14.y stable as commit
04198de24771. The backport however missed that in 4.14, there are several
arch-specific gup.c versions with fast gup implementations, so these do not
prevent refcount overflow.
This stable-only commit fixes the s390 version, and is based on the backport in
SUSE SLES/openSUSE 4.12-based kernels.
The remaining architectures with own gup.c are sparc, mips, sh. It's unlikely
the known overflow scenario based on FUSE, which needs 140GB of RAM, is a
problem for those architectures, and I don't feel confident enough to patch
them.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
[ Upstream commit 308c3e6673b012beecb96ef04cc65f4a0e7cdd99 ]
Make sure the debug feature and its allocated resources get
released upon unsuccessful architecture initialization.
A related indication of the issue will be reported as kernel
message.
Signed-off-by: Michael Mueller <mimu@linux.ibm.com>
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
Reviewed-by: Pierre Morel <pmorel@linux.ibm.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Message-Id: <20181130143215.69496-2-mimu@linux.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
[ Upstream commit ec0c0bb489727de0d4dca6a00be6970ab8a3b30a ]
Return an error when the function debug_register() fails allocating
the debug handle.
Also remove the registered debug handle when the initialization fails
later on.
Signed-off-by: Thomas Richter <tmricht@linux.ibm.com>
Reviewed-by: Hendrik Brueckner <brueckner@linux.ibm.com>
[ Upstream commit 348498458505e202df41b6b9a78da448d39298b7 ]
vdso is mapped into user space processes, which won't have kasan
shodow mapped.
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 0d9ce162cf46c99628cc5da9510b959c7976735b upstream.
It doesn't seem as if there is any particular need for kvm_lock to be a
spinlock, so convert the lock to a mutex so that sleepable functions (in
particular cond_resched()) can be called while holding it.
Signed-off-by: Junaid Shahid <junaids@google.com>
commit 3d7efa4edd07be5c5c3ffa95ba63e97e070e1f3f upstream.
The idle time reported in /proc/stat sometimes incorrectly contains
huge values on s390. This is caused by a bug in arch_cpu_idle_time().
The kernel tries to figure out when a different cpu entered idle by
accessing its per-cpu data structure. There is an ordering problem: if
the remote cpu has an idle_enter value which is not zero, and an
idle_exit value which is zero, it is assumed it is idle since
"now". The "now" timestamp however is taken before the idle_enter
value is read.
Which in turn means that "now" can be smaller than idle_enter of the
remote cpu. Unconditionally subtracting idle_enter from "now" can thus
lead to a negative value (aka large unsigned value).
Fix this by moving the get_tod_clock() invocation out of the
loop. While at it also make the code a bit more readable.
A similar bug also exists for show_idle_time(). Fix this is as well.
commit b8e51a6a9db94bc1fb18ae831b3dab106b5a4b5f upstream.
The problem is that we were putting the NUL terminator too far:
buf[sizeof(buf) - 1] = '\0';
If the user input isn't NUL terminated and they haven't initialized the
whole buffer then it leads to an info leak. The NUL terminator should
be:
buf[len - 1] = '\0';
Signed-off-by: Yihui Zeng <yzeng56@asu.edu>
Cc: stable@vger.kernel.org
[heiko.carstens@de.ibm.com: keep semantics of how *lenp and *ppos are handled]
[ Upstream commit 062795fcdcb2d22822fb42644b1d76a8ad8439b3 ]
Depending on inlining decisions by the compiler, __get/put_user_fn
might become out of line. Then the compiler is no longer able to tell
that size can only be 1,2,4 or 8 due to the check in __get/put_user
resulting in false positives like
./arch/s390/include/asm/uaccess.h: In function ‘__put_user_fn’:
./arch/s390/include/asm/uaccess.h:113:9: warning: ‘rc’ may be used uninitialized in this function [-Wmaybe-uninitialized]
113 | return rc;
./arch/s390/include/asm/uaccess.h: In function ‘__get_user_fn’:
./arch/s390/include/asm/uaccess.h:143:9: warning: ‘rc’ may be used uninitialized in this function [-Wmaybe-uninitialized]
143 | return rc;
These functions are supposed to be always inlined. Mark it as such.
commit f3122a79a1b0a113d3aea748e0ec26f2cb2889de upstream.
arch_update_cpu_topology is first called from:
kernel_init_freeable->sched_init_smp->sched_init_domains
even before cpus has been registered in:
kernel_init_freeable->do_one_initcall->s390_smp_init
Do not trigger kobject_uevent change events until cpu devices are
actually created. Fixes the following kasan findings:
BUG: KASAN: global-out-of-bounds in kobject_uevent_env+0xb40/0xee0
Read of size 8 at addr 0000000000000020 by task swapper/0/1
BUG: KASAN: global-out-of-bounds in kobject_uevent_env+0xb36/0xee0
Read of size 8 at addr 0000000000000018 by task swapper/0/1
CPU: 0 PID: 1 Comm: swapper/0 Tainted: G B
Hardware name: IBM 3906 M04 704 (LPAR)
Call Trace:
([<0000000143c6db7e>] show_stack+0x14e/0x1a8)
[<0000000145956498>] dump_stack+0x1d0/0x218
[<000000014429fb4c>] print_address_description+0x64/0x380
[<000000014429f630>] __kasan_report+0x138/0x168
[<0000000145960b96>] kobject_uevent_env+0xb36/0xee0
[<0000000143c7c47c>] arch_update_cpu_topology+0x104/0x108
[<0000000143df9e22>] sched_init_domains+0x62/0xe8
[<000000014644c94a>] sched_init_smp+0x3a/0xc0
[<0000000146433a20>] kernel_init_freeable+0x558/0x958
[<000000014599002a>] kernel_init+0x22/0x160
[<00000001459a71d4>] ret_from_fork+0x28/0x30
[<00000001459a71dc>] kernel_thread_starter+0x0/0x10
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
commit a13b03bbb4575b350b46090af4dfd30e735aaed1 upstream.
If the KVM_S390_MEM_OP ioctl is called with an access register >= 16,
then there is certainly a bug in the calling userspace application.
We check for wrong access registers, but only if the vCPU was already
in the access register mode before (i.e. the SIE block has recorded
it). The check is also buried somewhere deep in the calling chain (in
the function ar_translation()), so this is somewhat hard to find.
It's better to always report an error to the userspace in case this
field is set wrong, and it's safer in the KVM code if we block wrong
values here early instead of relying on a check somewhere deep down
the calling chain, so let's add another check to kvm_s390_guest_mem_op()
directly.
We also should check that the "size" is non-zero here (thanks to Janosch
Frank for the hint!). If we do not check the size, we could call vmalloc()
with this 0 value, and this will cause a kernel warning.
Signed-off-by: Thomas Huth <thuth@redhat.com>
Link: https://lkml.kernel.org/r/20190829122517.31042-1-thuth@redhat.com
Reviewed-by: Janosch Frank <frankja@linux.ibm.com>
commit 8769f610fe6d473e5e8e221709c3ac402037da6c upstream.
With THREAD_INFO_IN_TASK (which is selected on s390) task's stack usage
is refcounted and should always be protected by get/put when touching
other task's stack to avoid race conditions with task's destruction code.
Fixes: d5c352cdd022 ("s390: move thread_info into task_struct")
Cc: stable@vger.kernel.org # v4.10+
Acked-by: Ilya Leoshkevich <iii@linux.ibm.com>
[ Upstream commit b54c64f7adeb241423cd46598f458b5486b0375e ]
In hypfs_fill_super(), if hypfs_create_update_file() fails,
sbi->update_file is left holding an error number. This is passed to
hypfs_kill_super() which doesn't check for this.
Fix this by not setting sbi->update_value until after we've checked for
error.
Fixes: 24bbb1faf3f0 ("[PATCH] s390_hypfs filesystem")
cc: Martin Schwidefsky <schwidefsky@de.ibm.com>
cc: Heiko Carstens <heiko.carstens@de.ibm.com>
cc: linux-s390@vger.kernel.org
[ Upstream commit 9e323d45ba94262620a073a3f9945ca927c07c71 ]
With 'extra run-time crypto self tests' enabled, the selftest
for s390-xts fails with
alg: skcipher: xts-aes-s390 encryption unexpectedly succeeded on
test vector "random: len=0 klen=64"; expected_error=-22,
cfg="random: inplace use_digest nosimd src_divs=[2.61%@+4006,
84.44%@+21, 1.55%@+13, 4.50%@+344, 4.26%@+21, 2.64%@+27]"
This special case with nbytes=0 is not handled correctly and this
fix now makes sure that -EINVAL is returned when there is en/decrypt
called with 0 bytes to en/decrypt.
Signed-off-by: Harald Freudenberger <freude@linux.ibm.com>
[ Upstream commit 91b4db5313a2c793aabc2143efb8ed0cf0fdd097 ]
"p runtime/jit: pass > 32bit index to tail_call" fails when
bpf_jit_enable=1, because the tail call is not executed.
This in turn is because the generated code assumes index is 64-bit,
while it must be 32-bit, and as a result prog array bounds check fails,
while it should pass. Even if bounds check would have passed, the code
that follows uses 64-bit index to compute prog array offset.
Fix by using clrj instead of clgrj for comparing index with array size,
and also by using llgfr for truncating index to 32 bits before using it
Fixes: 6651ee070b31 ("s390/bpf: implement bpf_tail_call() helper")
Reported-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com>
Acked-by: Vasily Gorbik <gor@linux.ibm.com>
Signed-off-by: Ilya Leoshkevich <iii@linux.ibm.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit bb2d267c448f4bc3a3389d97c56391cb779178ae ]
"masking, test in bounds 3" fails on s390, because
BPF_ALU64_IMM(BPF_NEG, BPF_REG_2, 0) ignores the top 32 bits of
BPF_REG_2. The reason is that JIT emits lcgfr instead of lcgr.
The associated comment indicates that the code was intended to
emit lcgr in the first place, it's just that the wrong opcode
was used.
Fix by using the correct opcode.
Fixes: 054623105728 ("s390/bpf: Add s390x eBPF JIT compiler backend")
commit 53936b5bf35e140ae27e4bbf0447a61063f400da upstream.
When the userspace program runs the KVM_S390_INTERRUPT ioctl to inject
an interrupt, we convert them from the legacy struct kvm_s390_interrupt
to the new struct kvm_s390_irq via the s390int_to_s390irq() function.
However, this function does not take care of all types of interrupts
that we can inject into the guest later (see do_inject_vcpu()). Since we
do not clear out the s390irq values before calling s390int_to_s390irq(),
there is a chance that we copy random data from the kernel stack which
could be leaked to the userspace later.
Specifically, the problem exists with the KVM_S390_INT_PFAULT_INIT
interrupt: s390int_to_s390irq() does not handle it, and the function
__inject_pfault_init() later copies irq->u.ext which contains the
random kernel stack data. This data can then be leaked either to
the guest memory in __deliver_pfault_init(), or the userspace might
retrieve it directly with the KVM_S390_GET_IRQ_STATE ioctl.
Fix it by handling that interrupt type in s390int_to_s390irq(), too,
and by making sure that the s390irq struct is properly pre-initialized.
And while we're at it, make sure that s390int_to_s390irq() now
directly returns -EINVAL for unknown interrupt types, so that we
immediately get a proper error code in case we add more interrupt
types to do_inject_vcpu() without updating s390int_to_s390irq()
sometime in the future.
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Link: https://lore.kernel.org/kvm/20190912115438.25761-1-thuth@redhat.com
commit fa9dd599b4dae841924b022768354cfde9affecb upstream.
Having a pure_initcall() callback just to permanently enable BPF
JITs under CONFIG_BPF_JIT_ALWAYS_ON is unnecessary and could leave
a small race window in future where JIT is still disabled on boot.
Since we know about the setting at compilation time anyway, just
initialize it properly there. Also consolidate all the individual
bpf_jit_enable variables into a single one and move them under one
location. Moreover, don't allow for setting unspecified garbage
values on them.
Acked-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[bwh: Backported to 4.14 as dependency of commit 2e4a30983b0f
"bpf: restrict access to core bpf sysctls":
- Adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 4f18d869ffd056c7858f3d617c71345cf19be008 upstream.
The stfle inline assembly returns the number of double words written
(condition code 0) or the double words it would have written
(condition code 3), if the memory array it got as parameter would have
been large enough.
The current stfle implementation assumes that the array is always
large enough and clears those parts of the array that have not been
written to with a subsequent memset call.
If however the array is not large enough memset will get a negative
length parameter, which means that memset clears memory until it gets
an exception and the kernel crashes.
To fix this simply limit the maximum length. Move also the inline
assembly to an extra function to avoid clobbering of register 0, which
might happen because of the added min_t invocation together with code
instrumentation.
The bug was introduced with commit 14375bc4eb8d ("[S390] cleanup
facility list handling") but was rather harmless, since it would only
write to a rather large array. It became a potential problem with
commit 3ab121ab1866 ("[S390] kernel: Add z/VM LGR detection"). Since
then it writes to an array with only four double words, while some
machines already deliver three double words. As soon as machines have
a facility bit within the fifth double a crash on IPL would happen.
Fixes: 14375bc4eb8d ("[S390] cleanup facility list handling")
Cc: <stable@vger.kernel.org> # v2.6.37+
Reviewed-by: Vasily Gorbik <gor@linux.ibm.com>
[ Upstream commit 19ec166c3f39fe1d3789888a74cc95544ac266d4 ]
kselftests exposed a problem in the s390 handling for memory slots.
Right now we only do proper memory slot handling for creation of new
memory slots. Neither MOVE, nor DELETION are handled properly. Let us
implement those.
[ Upstream commit 01eb42afb45719cb41bb32c278e068073738899d ]
arch/s390/lib/uaccess.c is built without kasan instrumentation. Kasan
checks are performed explicitly in copy_from_user/copy_to_user
functions. But since those functions could be inlined, calls from
files like uaccess.c with instrumentation disabled won't generate
kasan reports. This is currently the case with strncpy_from_user
function which was revealed by newly added kasan test. Avoid inlining of
copy_from_user/copy_to_user when the kernel is built with kasan support
to make sure kasan checks are fully functional.
commit a86cb413f4bf273a9d341a3ab2c2ca44e12eb317 upstream.
KVM_CAP_MAX_VCPU_ID is currently always reporting KVM_MAX_VCPU_ID on all
architectures. However, on s390x, the amount of usable CPUs is determined
during runtime - it is depending on the features of the machine the code
is running on. Since we are using the vcpu_id as an index into the SCA
structures that are defined by the hardware (see e.g. the sca_add_vcpu()
function), it is not only the amount of CPUs that is limited by the hard-
ware, but also the range of IDs that we can use.
Thus KVM_CAP_MAX_VCPU_ID must be determined during runtime on s390x, too.
So the handling of KVM_CAP_MAX_VCPU_ID has to be moved from the common
code into the architecture specific code, and on s390x we have to return
the same value here as for KVM_CAP_MAX_VCPUS.
This problem has been discovered with the kvm_create_max_vcpus selftest.
With this change applied, the selftest now passes on s390x, too.
Reviewed-by: Andrew Jones <drjones@redhat.com>
Message-Id: <20190523164309.13345-9-thuth@redhat.com>
The backport of commit 0336e04a6520 ("s390/speculation: Support
'mitigations=' cmdline option") introduces a build error. Fix it up.
Fixes: 91788fcb21d0 ("s390/speculation: Support 'mitigations=' cmdline option")
commit 0336e04a6520bdaefdb0769d2a70084fa52e81ed upstream
Configure s390 runtime CPU speculation bug mitigations in accordance
with the 'mitigations=' cmdline option. This affects Spectre v1 and
Spectre v2.
The default behavior is unchanged.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Tested-by: Jiri Kosina <jkosina@suse.cz> (on x86)
Reviewed-by: Jiri Kosina <jkosina@suse.cz>
Cc: "H . Peter Anvin" <hpa@zytor.com>
Cc: Jiri Kosina <jikos@kernel.org>
Cc: Waiman Long <longman@redhat.com>
Cc: Jon Masters <jcm@redhat.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-s390@vger.kernel.org
Cc: Tyler Hicks <tyhicks@canonical.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Steven Price <steven.price@arm.com>
Cc: Phil Auld <pauld@redhat.com>
Link: https://lkml.kernel.org/r/e4a161805458a5ec88812aac0307ae3908a030fc.1555085500.git.jpoimboe@redhat.com
[ Upstream commit cd479eccd2e057116d504852814402a1e68ead80 ]
For a 64-bit process the randomization of the program break is quite
large with 1GB. That is as big as the randomization of the anonymous
mapping base, for a test case started with '/lib/ld64.so.1 <exec>'
it can happen that the heap is placed after the stack. To avoid
this limit the program break randomization to 32MB for 64-bit and
keep 8MB for 31-bit.
Reported-by: Stefan Liebler <stli@linux.ibm.com>
Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
commit 86a86804e4f18fc3880541b3d5a07f4df0fe29cb upstream.
The fix to make WARN work in the early boot code created a problem
on older machines without EDAT-1. The setup_lowcore_dat_on function
uses the pointer from lowcore_ptr[0] to set the DAT bit in the new
PSWs. That does not work if the kernel page table is set up with
4K pages as the prefix address maps to absolute zero.
To make this work the PSWs need to be changed with via address 0 in
form of the S390_lowcore definition.
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Cornelia Huck <cohuck@redhat.com>
Fixes: 94f85ed3e2f8 ("s390/setup: fix early warning messages")
commit 152482580a1b0accb60676063a1ac57b2d12daf6 upstream.
kvm_arch_memslots_updated() is at this point in time an x86-specific
hook for handling MMIO generation wraparound. x86 stashes 19 bits of
the memslots generation number in its MMIO sptes in order to avoid
full page fault walks for repeat faults on emulated MMIO addresses.
Because only 19 bits are used, wrapping the MMIO generation number is
possible, if unlikely. kvm_arch_memslots_updated() alerts x86 that
the generation has changed so that it can invalidate all MMIO sptes in
case the effective MMIO generation has wrapped so as to avoid using a
stale spte, e.g. a (very) old spte that was created with generation==0.
Given that the purpose of kvm_arch_memslots_updated() is to prevent
consuming stale entries, it needs to be called before the new generation
is propagated to memslots. Invalidating the MMIO sptes after updating
memslots means that there is a window where a vCPU could dereference
the new memslots generation, e.g. 0, and incorrectly reuse an old MMIO
spte that was created with (pre-wrap) generation==0.
Fixes: e59dbe09f8e6 ("KVM: Introduce kvm_arch_memslots_updated()")
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
commit 8727638426b0aea59d7f904ad8ddf483f9234f88 upstream.
The setup_lowcore() function creates a new prefix page for the boot CPU.
The PSW mask for the system_call, external interrupt, i/o interrupt and
the program check handler have the DAT bit set in this new prefix page.
At the time setup_lowcore is called the system still runs without virtual
address translation, the paging_init() function creates the kernel page
table and loads the CR13 with the kernel ASCE.
Any code between setup_lowcore() and the end of paging_init() that has
a BUG or WARN statement will create a program check that can not be
handled correctly as there is no kernel page table yet.
To allow early WARN statements initially setup the lowcore with DAT off
and set the DAT bit only after paging_init() has completed.
[ Upstream commit be534791011100d204602e2e0496e9e6ce8edf63 ]
There exist very few ap messages which need to have the 'special' flag
enabled. This flag tells the firmware layer to do some pre- and maybe
postprocessing. However, it may happen that this special flag is
enabled but the firmware is unable to deal with this kind of message
and thus returns with reply code 0x41. For example older firmware may
not know the newest messages triggered by the zcrypt device driver and
thus react with reject and the named reply code. Unfortunately this
reply code is not known to the zcrypt error routines and thus default
behavior is to switch the ap queue offline.
This patch now makes the ap error routine aware of the reply code and
so userspace is informed about the bad processing result but the queue
is not switched to offline state any more.
commit 60f1bf29c0b2519989927cae640cd1f50f59dc7f upstream.
When calling smp_call_ipl_cpu() from the IPL CPU, we will try to read
from pcpu_devices->lowcore. However, due to prefixing, that will result
in reading from absolute address 0 on that CPU. We have to go via the
actual lowcore instead.
This means that right now, we will read lc->nodat_stack == 0 and
therfore work on a very wrong stack.
This BUG essentially broke rebooting under QEMU TCG (which will report
a low address protection exception). And checking under KVM, it is
also broken under KVM. With 1 VCPU it can be easily triggered.
:/# echo 1 > /proc/sys/kernel/sysrq
:/# echo b > /proc/sysrq-trigger
[ 28.476745] sysrq: SysRq : Resetting
[ 28.476793] Kernel stack overflow.
[ 28.476817] CPU: 0 PID: 424 Comm: sh Not tainted 5.0.0-rc1+ #13
[ 28.476820] Hardware name: IBM 2964 NE1 716 (KVM/Linux)
[ 28.476826] Krnl PSW : 0400c00180000000 0000000000115c0c (pcpu_delegate+0x12c/0x140)
[ 28.476861] R:0 T:1 IO:0 EX:0 Key:0 M:0 W:0 P:0 AS:3 CC:0 PM:0 RI:0 EA:3
[ 28.476863] Krnl GPRS: ffffffffffffffff 0000000000000000 000000000010dff8 0000000000000000
[ 28.476864] 0000000000000000 0000000000000000 0000000000ab7090 000003e0006efbf0
[ 28.476864] 000000000010dff8 0000000000000000 0000000000000000 0000000000000000
[ 28.476865] 000000007fffc000 0000000000730408 000003e0006efc58 0000000000000000
[ 28.476887] Krnl Code: 0000000000115bfe: 4170f000 la %r7,0(%r15)
[ 28.476887] 0000000000115c02: 41f0a000 la %r15,0(%r10)
[ 28.476887] #0000000000115c06: e370f0980024 stg %r7,152(%r15)
[ 28.476887] >0000000000115c0c: c0e5fffff86e brasl %r14,114ce8
[ 28.476887] 0000000000115c12: 41f07000 la %r15,0(%r7)
[ 28.476887] 0000000000115c16: a7f4ffa8 brc 15,115b66
[ 28.476887] 0000000000115c1a: 0707 bcr 0,%r7
[ 28.476887] 0000000000115c1c: 0707 bcr 0,%r7
[ 28.476901] Call Trace:
[ 28.476902] Last Breaking-Event-Address:
[ 28.476920] [<0000000000a01c4a>] arch_call_rest_init+0x22/0x80
[ 28.476927] Kernel panic - not syncing: Corrupt kernel stack, can't continue.
[ 28.476930] CPU: 0 PID: 424 Comm: sh Not tainted 5.0.0-rc1+ #13
[ 28.476932] Hardware name: IBM 2964 NE1 716 (KVM/Linux)
[ 28.476932] Call Trace:
Fixes: 2f859d0dad81 ("s390/smp: reduce size of struct pcpu")
Cc: stable@vger.kernel.org # 4.0+
Reported-by: Cornelia Huck <cohuck@redhat.com>
Signed-off-by: David Hildenbrand <david@redhat.com>
commit b7cb707c373094ce4008d4a6ac9b6b366ec52da5 upstream.
smp_rescan_cpus() is called without the device_hotplug_lock, which can lead
to a dedlock when a new CPU is found and immediately set online by a udev
rule.
This was observed on an older kernel version, where the cpu_hotplug_begin()
loop was still present, and it resulted in hanging chcpu and systemd-udev
processes. This specific deadlock will not show on current kernels. However,
there may be other possible deadlocks, and since smp_rescan_cpus() can still
trigger a CPU hotplug operation, the device_hotplug_lock should be held.
For reference, this was the deadlock with the old cpu_hotplug_begin() loop:
chcpu (rescan) systemd-udevd
echo 1 > /sys/../rescan
-> smp_rescan_cpus()
-> (*) get_online_cpus()
(increases refcount)
-> smp_add_present_cpu()
(new CPU found)
-> register_cpu()
-> device_add()
-> udev "add" event triggered -----------> udev rule sets CPU online
-> echo 1 > /sys/.../online
-> lock_device_hotplug_sysfs()
(this is missing in rescan path)
-> device_online()
-> (**) device_lock(new CPU dev)
-> cpu_up()
-> cpu_hotplug_begin()
(loops until refcount == 0)
-> deadlock with (*)
-> bus_probe_device()
-> device_attach()
-> device_lock(new CPU dev)
-> deadlock with (**)
Fix this by taking the device_hotplug_lock in the CPU rescan path.
commit 03aa047ef2db4985e444af6ee1c1dd084ad9fb4c upstream.
Right now the early machine detection code check stsi 3.2.2 for "KVM"
and set MACHINE_IS_VM if this is different. As the console detection
uses diagnose 8 if MACHINE_IS_VM returns true this will crash Linux
early for any non z/VM system that sets a different value than KVM.
So instead of assuming z/VM, do not set any of MACHINE_IS_LPAR,
MACHINE_IS_VM, or MACHINE_IS_KVM.
CC: stable@vger.kernel.org
commit 98dfd32620e970eb576ebce5ea39d905cb005e72 upstream.
When triggered by pci hotplug (PEC 0x306) clp_get_state is called
with spinlocks held resulting in the following warning:
zpci: n/a: Event 0x306 reconfigured PCI function 0x0
BUG: sleeping function called from invalid context at mm/page_alloc.c:4324
in_atomic(): 1, irqs_disabled(): 0, pid: 98, name: kmcheck
2 locks held by kmcheck/98:
Change the allocation to use GFP_ATOMIC.
Cc: stable@vger.kernel.org # 4.13+
Signed-off-by: Sebastian Ott <sebott@linux.ibm.com>
[ Upstream commit 613a41b0d16e617f46776a93b975a1eeea96417c ]
On s390 command perf top fails
[root@s35lp76 perf] # ./perf top -F100000 --stdio
Error:
cycles: PMU Hardware doesn't support sampling/overflow-interrupts.
Try 'perf stat'
Using event -e rb0000 works as designed. Event rb0000 is the event
number of the sampling facility for basic sampling.
During system start up the following PMUs are installed in the kernel's
PMU list (from head to tail):
cpum_cf --> s390 PMU counter facility device driver
cpum_sf --> s390 PMU sampling facility device driver
uprobe
kprobe
tracepoint
task_clock
cpu_clock
Perf top executes following functions and calls perf_event_open(2) system
call with different parameters many times:
cmd_top
--> __cmd_top
--> perf_evlist__add_default
--> __perf_evlist__add_default
--> perf_evlist__new_cycles (creates event type:0 (HW)
config 0 (CPU_CYCLES)
--> perf_event_attr__set_max_precise_ip
Uses perf_event_open(2) to detect correct
precise_ip level. Fails 3 times on s390 which is ok.
Then functions cmd_top
--> __cmd_top
--> perf_top__start_counters
-->perf_evlist__config
--> perf_can_comm_exec
--> perf_probe_api
This functions test support for the following events:
"cycles:u", "instructions:u", "cpu-clock:u" using
--> perf_do_probe_api
--> perf_event_open_cloexec
Test the close on exec flag support with
perf_event_open(2).
perf_do_probe_api returns true if the event is
supported.
The function returns true because event cpu-clock is
supported by the PMU cpu_clock.
This is achieved by many calls to perf_event_open(2).
Function perf_top__start_counters now calls perf_evsel__open() for every
event, which is the default event cpu_cycles (config:0) and type HARDWARE
(type:0) which a predfined frequence of 4000.
Given the above order of the PMU list, the PMU cpum_cf gets called first
and returns 0, which indicates support for this sampling. The event is
fully allocated in the function perf_event_open (file kernel/event/core.c
near line 10521 and the following check fails:
event = perf_event_alloc(&attr, cpu, task, group_leader, NULL,
NULL, NULL, cgroup_fd);
if (IS_ERR(event)) {
err = PTR_ERR(event);
goto err_cred;
if (is_sampling_event(event)) {
if (event->pmu->capabilities & PERF_PMU_CAP_NO_INTERRUPT) {
err = -EOPNOTSUPP;
goto err_alloc;
The check for the interrupt capabilities fails and the system call
perf_event_open() returns -EOPNOTSUPP (-95).
Add a check to return -ENODEV when sampling is requested in PMU cpum_cf.
This allows common kernel code in the perf_event_open() system call to
test the next PMU in above list.
Fixes: 97b1198fece0 (" "s390, perf: Use common PMU interrupt disabled code")
commit 1843abd03250115af6cec0892683e70cf2297c25 upstream.
Userspace could have munmapped the area before doing unmapping from
the gmap. This would leave us with a valid vmaddr, but an invalid vma
from which we would try to zap memory.
Let's check before using the vma.
Fixes: 1e133ab296f3 ("s390/mm: split arch/s390/mm/pgtable.c")
Signed-off-by: Janosch Frank <frankja@linux.ibm.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Message-Id: <20180816082432.78828-1-frankja@linux.ibm.com>
[ Upstream commit 0bb2ae1b26e1fb7543ec7474cdd374ac4b88c4da ]
The function perf_init_event() creates a new event and
assignes it to a PMU. This a done in a loop over all existing
PMUs. For each listed PMU the event init function is called
and if this function does return any other error than -ENOENT,
the loop is terminated the creation of the event fails.
If the event is invalid, return -ENOENT to try other PMUs.
[ Upstream commit a541f0ebcc08ed8bc0cc492eec9a86cb280a9f24 ]
Fixes:
ERROR: "__node_distance" [drivers/nvme/host/nvme-core.ko] undefined!
make[1]: *** [scripts/Makefile.modpost:92: __modpost] Error 1
make: *** [Makefile:1275: modules] Error 2
+ exit 1
Signed-off-by: Justin M. Forbes <jforbes@fedoraproject.org>
[ Upstream commit b44b136a3773d8a9c7853f8df716bd1483613cbb ]
According to Documentation/kbuild/makefiles.txt all build targets using
if_changed should use FORCE as well. Add missing FORCE to make sure
vdso targets are rebuild properly when not just immediate prerequisites
have changed but also when build command differs.
Reviewed-by: Philipp Rudo <prudo@linux.ibm.com>
[ Upstream commit b5130dc2224d1881f24224c0590c6d97f2168d6a ]
When running as a level 3 guest with no host provided sthyi support
sclp_ocf_cpc_name_copy() will only return zeroes. Zeroes are not a
valid group name, so let's not indicate that the group name field is
valid.
Also the group name is not dependent on stsi, let's not return based
on stsi before setting it.
Fixes: 95ca2cb57985 ("KVM: s390: Add sthyi emulation")
[ Upstream commit 6b2ddf33baec23dace85bd647e3fc4ac070963e8 ]
arch/s390/mm/extmem.c: In function '__segment_load':
arch/s390/mm/extmem.c:436:2: warning: 'strncat' specified bound 7 equals
source length [-Wstringop-overflow=]
strncat(seg->res_name, " (DCSS)", 7);
What gcc complains about here is the misuse of strncat function, which
in this case does not limit a number of bytes taken from "src", so it is
in the end the same as strcat(seg->res_name, " (DCSS)");
Keeping in mind that a res_name is 15 bytes, strncat in this case
would overflow the buffer and write 0 into alignment byte between the
fields in the struct. To avoid that increasing res_name size to 16,
and reusing strlcat.
[ Upstream commit 9f35b818a2f90fb6cb291aa0c9f835d4f0974a9a ]
Get rid of this compile warning for !PROC_FS:
CC arch/s390/kernel/sysinfo.o
arch/s390/kernel/sysinfo.c:275:12: warning: 'sysinfo_show' defined but not used [-Wunused-function]
static int sysinfo_show(struct seq_file *m, void *v)
[ Upstream commit 5bedf8aa03c28cb8dc98bdd32a41b66d8f7d3eaa ]
Since proc_dointvec does not perform value range control,
proc_dointvec_minmax should be used to limit value range, which is
clearly intended here, as the internal representation of the value:
unsigned int alloc_pgste:1;
In fact it currently works, since we have
mm->context.alloc_pgste = page_table_allocate_pgste || ...
... since commit 23fefe119ceb5 ("s390/kvm: avoid global config of vm.alloc_pgste=1")
Before that it was
mm->context.alloc_pgste = page_table_allocate_pgste;
which was broken. That was introduced with commit 0b46e0a3ec0d7 ("s390/kvm:
remove delayed reallocation of page tables for KVM").
Fixes: 0b46e0a3ec0d7 ("s390/kvm: remove delayed reallocation of page tables for KVM")
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit b81126e01a8c6048249955feea46c8217ebefa91 upstream.
The return code of cpacf_kmc() is less than the number of
bytes to process in case of an error, not greater.
The crypt routines for the other cipher modes already have
this correctly.
Cc: stable@vger.kernel.org # v4.11+
Fixes: 279378430768 ("s390/crypt: Add protected key AES module")
Signed-off-by: Ingo Franzki <ifranzki@linux.ibm.com>
Acked-by: Harald Freudenberger <freude@linux.ibm.com>
commit 204c97245612b6c255edf4e21e24d417c4a0c008 upstream.
Copy the key mask to the right offset inside the shadow CRYCB
Fixes: bbeaa58b3 ("KVM: s390: vsie: support aes dea wrapping keys")
Signed-off-by: Pierre Morel <pmorel@linux.ibm.com>
Cc: stable@vger.kernel.org # v4.8+
Message-Id: <1535019956-23539-2-git-send-email-pmorel@linux.ibm.com>
commit 5eda25b10297684c1f46a14199ec00210f3c346e upstream.
The memove, memset, memcpy, __memset16, __memset32 and __memset64
function have an additional indirect return branch in form of a
"bzr" instruction. These need to use expolines as well.
Cc: <stable@vger.kernel.org> # v4.17+
Fixes: 97489e0663 ("s390/lib: use expoline for indirect branches")
[ Upstream commit 2d2e7075b87181ed0c675e4936e20bdadba02e1f ]
The vmcoreinfo of a crashed system is potentially fragmented. Thus the
crash kernel has an intermediate step where the vmcoreinfo is copied into a
temporary, continuous buffer in the crash kernel memory. This temporary
buffer is never freed. Free it now to prevent the memleak.
While at it replace all occurrences of "VMCOREINFO" by its corresponding
macro to prevent potential renaming issues.
Signed-off-by: Philipp Rudo <prudo@linux.ibm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
commit 866f3576a72b2233a76dffb80290f8086dc49e17 upstream.
During interrupt setup we allocate interrupt vectors, walk the list of msi
descriptors, and fill in the message data. Requesting more interrupts than
supported on s390 can lead to an out of bounds access.
When we restrict the number of interrupts we should also stop walking the
msi list after all supported interrupts are handled.
commit fb7d7518b0d65955f91c7b875c36eae7694c69bd upstream.
The numa_init_early initcall sets the node_to_cpumask_map[0] to the
full cpu_possible_mask. Unfortunately this early_initcall is too late,
the NUMA setup for numa=emu is done even earlier. The order of calls
is numa_setup() -> emu_update_cpu_topology(), then the early_initcalls(),
followed by sched_init_domains().
Starting with git commit 051f3ca02e46432c0965e8948f00c07d8a2f09c0
"sched/topology: Introduce NUMA identity node sched domain"
the incorrect node_to_cpumask_map[0] really screws up the domain
setup and the kernel panics with the follow oops:
Cc: <stable@vger.kernel.org> # v4.15+
commit 64e03ff72623b8c2ea89ca3cb660094e019ed4ae upstream.
When allocating a new AOB fails, handle_outbound() is still capable of
transmitting the selected buffer (just without async completion).
But if a previous transfer on this queue slot used async completion, its
sbal_state flags field is still set to QDIO_OUTBUF_STATE_FLAG_PENDING.
So when the upper layer driver sees this stale flag, it expects an async
completion that never happens.
Fix this by unconditionally clearing the flags field.
Fixes: 104ea556ee7f ("qdio: support asynchronous delivery of storage blocks")
Cc: <stable@vger.kernel.org> #v3.2+
Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com>
commit 26f843848bae973817b3587780ce6b7b0200d3e4 upstream.
For machines without the exrl instruction the BFP jit generates
code that uses an "br %r1" instruction located in the lowcore page.
Unfortunately there is a cut & paste error that puts an additional
"larl %r1,.+14" instruction in the code that clobbers the branch
target address in %r1. Remove the larl instruction.
Fixes: de5cb6eb51 ("s390: use expoline thunks in the BPF JIT")
