[ Upstream commit b615e3c74621e06cd97f86373ca90d43d6d998aa ]
Cc: stable@vger.kernel.org
[ Upstream commit c2f18fa4cbb3ad92e033a24efa27583978ce9600 ]
* should zero on any failure
* __get_user() should use __copy_from_user(), not copy_from_user()
The latest version of modinfo fails to compile score architecture
targets with the following error.
FATAL: The relocation at __ex_table+0x634 references
section "__ex_table" which is not executable, IOW
the kernel will fault if it ever tries to
jump to it. Something is seriously wrong
and should be fixed.
The probem is caused by a bad label in an __ex_table entry.
Acked-by: Lennox Wu <lennox.wu@gmail.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
LKP has triggered a compiler warning after my recent patch "mm: account
pmd page tables to the process":
mm/mmap.c: In function 'exit_mmap':
>> mm/mmap.c:2857:2: warning: right shift count >= width of type [enabled by default]
The code:
> 2857 WARN_ON(mm_nr_pmds(mm) >
2858 round_up(FIRST_USER_ADDRESS, PUD_SIZE) >> PUD_SHIFT);
In this, on tile, we have FIRST_USER_ADDRESS defined as 0. round_up() has
the same type -- int. PUD_SHIFT.
I think the best way to fix it is to define FIRST_USER_ADDRESS as unsigned
long. On every arch for consistency.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
We've replaced remap_file_pages(2) implementation with emulation.
Nobody creates non-linear mapping anymore.
This patch also increase number of bits availble for swap offset.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
As there are now no remaining users of arch_fast_hash(), lets kill
it entirely.
This basically reverts commit 71ae8aac3e19 ("lib: introduce arch
optimized hash library") and follow-up work, that is f.e., commit
237217546d44 ("lib: hash: follow-up fixups for arch hash"),
commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for
asm-generic/hash.h") and last but not least commit 6a02652df511
("perf tools: Fix include for non x86 architectures").
Cc: Francesco Fusco <fusco@ntop.org>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Pull timer fixes from Ingo Molnar:
"Main changes:
- Fix the deadlock reported by Dave Jones et al
- Clean up and fix nohz_full interaction with arch abilities
- nohz init code consolidation/cleanup"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
nohz: nohz full depends on irq work self IPI support
nohz: Consolidate nohz full init code
arm64: Tell irq work about self IPI support
arm: Tell irq work about self IPI support
x86: Tell irq work about self IPI support
irq_work: Force raised irq work to run on irq work interrupt
irq_work: Introduce arch_irq_work_has_interrupt()
nohz: Move nohz full init call to tick init
The symbol is an orphan, get rid of it.
Cc: Paul Bolle <pebolle@tiscali.nl>
[Guenter Roeck: Merge with 3.17-rc3; update headline]
The related error (with allmodconfig under score):
CC [M] drivers/staging/speakup/speakup_acntpc.o
In file included from drivers/staging/speakup/speakup_acntpc.c:33:0:
drivers/staging/speakup/serialio.h:7:24: fatal error: asm/serial.h: No such file or directory
#include <asm/serial.h>
compilation terminated.
make[3]: *** [drivers/staging/speakup/speakup_acntpc.o] Error 1
make[2]: *** [drivers/staging/speakup] Error 2
make[1]: *** [drivers/staging] Error 2
make: *** [drivers] Error 2
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
This patch removes the use of the IRQF_DISABLED flag
from arch/score/kernel/time.c
It's a NOOP since 2.6.35 and it will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
MODPOST 1365 modules
ERROR: "flush_icache_range" [drivers/misc/lkdtm.ko] undefined!
'csum_partial_copy_from_user' and 'flush_dcache_page' are also needed by
outside modules, so need export them in the related files.
ERROR: "csum_partial_copy_from_user" [net/rxrpc/af-rxrpc.ko] undefined!
ERROR: "flush_dcache_page" [net/sunrpc/sunrpc.ko] undefined!
The nohz full code needs irq work to trigger its own interrupt so that
the subsystem can work even when the tick is stopped.
Lets introduce arch_irq_work_has_interrupt() that archs can override to
tell about their support for this ability.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc
Pull arch signal handling cleanup from Richard Weinberger:
"This patch series moves all remaining archs to the get_signal(),
signal_setup_done() and sigsp() functions.
Currently these archs use open coded variants of the said functions.
Further, unused parameters get removed from get_signal_to_deliver(),
tracehook_signal_handler() and signal_delivered().
At the end of the day we save around 500 lines of code."
* 'signal-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (43 commits)
powerpc: Use sigsp()
openrisc: Use sigsp()
mn10300: Use sigsp()
mips: Use sigsp()
microblaze: Use sigsp()
metag: Use sigsp()
m68k: Use sigsp()
m32r: Use sigsp()
hexagon: Use sigsp()
frv: Use sigsp()
cris: Use sigsp()
c6x: Use sigsp()
blackfin: Use sigsp()
avr32: Use sigsp()
arm64: Use sigsp()
arc: Use sigsp()
sas_ss_flags: Remove nested ternary if
Rip out get_signal_to_deliver()
Clean up signal_delivered()
tracehook_signal_handler: Remove sig, info, ka and regs
There's no need to have an architecture version of scatterlist.h if the
only thing the file does is include asm-generic/scatterlist.h. Switch to
the asm-generic versions directly.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Cc: Chen Liqin <liqin.linux@gmail.com>,
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
'COUNTER' and other same kind macros are too common to use, and easy to
get conflict with other modules.
At present, they are not used, so it is OK to simply remove them. And
the related warning (allmodconfig with score):
CC [M] drivers/md/raid1.o
In file included from drivers/md/raid1.c:42:0:
drivers/md/bitmap.h:93:0: warning: "COUNTER" redefined
#define COUNTER(x) (((bitmap_counter_t) x) & COUNTER_MAX)
In file included from ./arch/score/include/asm/ptrace.h:4:0,
from include/linux/sched.h:31,
from include/linux/blkdev.h:4,
from drivers/md/raid1.c:36:
./arch/score/include/uapi/asm/ptrace.h:13:0: note: this is the location of the previous definition
#define COUNTER 38
Signed-off-by: David Rientjes <rientjes@google.com>
Use the more generic functions get_signal() signal_setup_done()
for signal delivery.
The arch_mutex_cpu_relax() function, introduced by 34b133f, is
hacky and ugly. It was added a few years ago to address the fact
that common cpu_relax() calls include yielding on s390, and thus
impact the optimistic spinning functionality of mutexes. Nowadays
we use this function well beyond mutexes: rwsem, qrwlock, mcs and
lockref. Since the macro that defines the call is in the mutex header,
any users must include mutex.h and the naming is misleading as well.
This patch (i) renames the call to cpu_relax_lowlatency ("relax, but
only if you can do it with very low latency") and (ii) defines it in
each arch's asm/processor.h local header, just like for regular cpu_relax
functions. On all archs, except s390, cpu_relax_lowlatency is simply cpu_relax,
and thus we can take it out of mutex.h. While this can seem redundant,
I believe it is a good choice as it allows us to move out arch specific
logic from generic locking primitives and enables future(?) archs to
transparently define it, similarly to System Z.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Bharat Bhushan <r65777@freescale.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Cc: Dominik Dingel <dingel@linux.vnet.ibm.com>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Joseph Myers <joseph@codesourcery.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: Qiaowei Ren <qiaowei.ren@intel.com>
Cc: Rafael Wysocki <rafael.j.wysocki@intel.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: Stratos Karafotis <stratosk@semaphore.gr>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Vasily Kulikov <segoon@openwall.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: adi-buildroot-devel@lists.sourceforge.net
Cc: linux390@de.ibm.com
Cc: linux-alpha@vger.kernel.org
Cc: linux-am33-list@redhat.com
Cc: linux-c6x-dev@linux-c6x.org
Cc: linux-cris-kernel@axis.com
Cc: linux-hexagon@vger.kernel.org
Cc: linux-ia64@vger.kernel.org
Cc: linux@lists.openrisc.net
Cc: linux-m32r-ja@ml.linux-m32r.org
Cc: linux-m32r@ml.linux-m32r.org
Cc: linux-m68k@lists.linux-m68k.org
Cc: linux-metag@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-parisc@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-s390@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-xtensa@linux-xtensa.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/1404079773.2619.4.camel@buesod1.americas.hpqcorp.net
score fully relies on asm-generic/barrier.h, so it can use its default
implementation.
Link: http://lkml.kernel.org/n/tip-4mv9svf28lnotjpfuza8urh8@git.kernel.org
This removes the CPU_SCORE7 Kconfig parameter, which is no longer used
anywhere in the source code and Makefiles.
Many architectures have a stub cputime.h that only include the default
cputime.h
Lets remove the useless headers, we only need to mention that we want
the default headers on the Kbuild files.
Cc: Archs <linux-arch@vger.kernel.org>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
This patch allows each architecture to add its specific assembly optimized
arch_mcs_spin_lock_contended and arch_mcs_spinlock_uncontended for
MCS lock and unlock functions.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Scott J Norton <scott.norton@hp.com>
Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Cc: AswinChandramouleeswaran <aswin@hp.com>
Cc: George Spelvin <linux@horizon.com>
Cc: Rik vanRiel <riel@redhat.com>
Cc: MichelLespinasse <walken@google.com>
Cc: Peter Hurley <peter@hurleysoftware.com>
Cc: Alex Shi <alex.shi@linaro.org>
Cc: "Figo.zhang" <figo1802@gmail.com>
Cc: "Paul E.McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Davidlohr Bueso <davidlohr.bueso@hp.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: Matthew R Wilcox <matthew.r.wilcox@intel.com>
Link: http://lkml.kernel.org/r/1390347382.3138.67.camel@schen9-DESK
alphabetical order
We perform a clean up of the Kbuid files in each architecture.
We order the files in each Kbuild in alphabetical order
by running the below script.
for i in arch/*/include/asm/Kbuild
do
cat $i | gawk '/^generic-y/ {
i = 3;
do {
for (; i <= NF; i++) {
if ($i == "\\") {
getline;
i = 1;
continue;
if ($i != "")
hdr[$i] = $i;
break;
} while (1);
next;
print $0;
END {
n = asort(hdr);
for (i = 1; i <= n; i++)
print "generic-y += " hdr[i];
}' > ${i}.sorted;
mv ${i}.sorted $i;
done
[ Fixed build bug. ]
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- a new jpeg codec driver for Samsung Exynos (jpeg-hw-exynos4)
- a new dvb frontend for ds2103 chipset (m88ds2103)
- a new sensor driver for Samsung S5K5BAF UXGA (s5k5baf)
- new drivers for R-Car VSP1
- a new radio driver: radio-raremono
- a new tuner driver for ts2022 chipset (m88ts2022)
- the analog part of em28xx is now a separate module that only
load/runs if the device is not a pure digital TV device
- added a staging driver for bcm2048 radio devices
- the omap 2 video driver (omap24xx) was moved to staging. This driver
is for an old hardware and uses a deprecated Kernel internal API. If
nobody cares enough to fix it, it would be removed on a couple Kernel
releases
- the sn9c102 driver was moved to staging. This driver was replaced by
gspca, and disabled on some distros, as almost all devices are known
to work properly with gspca. It should be removed from kernel on a
couple Kernel releases
- lots of driver fixes, improvements and cleanups
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (421 commits)
[media] media: v4l2-dev: fix video device index assignment
[media] rc-core: reuse device numbers
[media] em28xx-cards: properly initialize the device bitmap
[media] Staging: media: Fix line length exceeding 80 characters in as102_drv.c
[media] Staging: media: Fix line length exceeding 80 characters in as102_fe.c
[media] Staging: media: Fix quoted string split across line in as102_fe.c
[media] media: st-rc: Add reset support
[media] m2m-deinterlace: fix allocated struct type
[media] radio-usb-si4713: fix sparse non static symbol warnings
[media] em28xx-audio: remove needless check before usb_free_coherent()
[media] au0828: Fix sparse non static symbol warning
Revert "[media] go7007-usb: only use go->dev after allocated"
[media] em28xx-audio: provide an error code when URB submit fails
[media] em28xx: fix check for audio only usb interfaces when changing the usb alternate setting
[media] em28xx: fix usb alternate setting for analog and digital video endpoints > 0
[media] em28xx: make 'em28xx_ctrl_ops' static
em28xx-alsa: Fix error patch for init/fini
[media] em28xx-audio: flush work at .fini
[media] drxk: remove the option to load firmware asynchronously
[media] em28xx: adjust period size at runtime
Pull networking updates from David Miller:
1) BPF debugger and asm tool by Daniel Borkmann.
2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann.
3) Correct reciprocal_divide and update users, from Hannes Frederic
Sowa and Daniel Borkmann.
4) Currently we only have a "set" operation for the hw timestamp socket
ioctl, add a "get" operation to match. From Ben Hutchings.
5) Add better trace events for debugging driver datapath problems, also
from Ben Hutchings.
6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we
have a small send and a previous packet is already in the qdisc or
device queue, defer until TX completion or we get more data.
7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko.
8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel
Borkmann.
9) Share IP header compression code between Bluetooth and IEEE802154
layers, from Jukka Rissanen.
10) Fix ipv6 router reachability probing, from Jiri Benc.
11) Allow packets to be captured on macvtap devices, from Vlad Yasevich.
12) Support tunneling in GRO layer, from Jerry Chu.
13) Allow bonding to be configured fully using netlink, from Scott
Feldman.
14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can
already get the TCI. From Atzm Watanabe.
15) New "Heavy Hitter" qdisc, from Terry Lam.
16) Significantly improve the IPSEC support in pktgen, from Fan Du.
17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom
Herbert.
18) Add Proportional Integral Enhanced packet scheduler, from Vijay
Subramanian.
19) Allow openvswitch to mmap'd netlink, from Thomas Graf.
20) Key TCP metrics blobs also by source address, not just destination
address. From Christoph Paasch.
21) Support 10G in generic phylib. From Andy Fleming.
22) Try to short-circuit GRO flow compares using device provided RX
hash, if provided. From Tom Herbert.
The wireless and netfilter folks have been busy little bees too.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits)
net/cxgb4: Fix referencing freed adapter
ipv6: reallocate addrconf router for ipv6 address when lo device up
fib_frontend: fix possible NULL pointer dereference
rtnetlink: remove IFLA_BOND_SLAVE definition
rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info
qlcnic: update version to 5.3.55
qlcnic: Enhance logic to calculate msix vectors.
qlcnic: Refactor interrupt coalescing code for all adapters.
qlcnic: Update poll controller code path
qlcnic: Interrupt code cleanup
qlcnic: Enhance Tx timeout debugging.
qlcnic: Use bool for rx_mac_learn.
bonding: fix u64 division
rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC
sfc: Use the correct maximum TX DMA ring size for SFC9100
Add Shradha Shah as the sfc driver maintainer.
net/vxlan: Share RX skb de-marking and checksum checks with ovs
tulip: cleanup by using ARRAY_SIZE()
ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called
net/cxgb4: Don't retrieve stats during recovery
Commit 5fbbf8a1a934 ("Score: The commit is for compiling successfully.")
re-introduced "select HAVE_GENERIC_HARDIRQS" in v3.12-rc4, which had
just been removed in v3.12-rc1 by 0244ad004a5 ("Remove GENERIC_HARDIRQ
config option").
Checkin:
93ea02bb8435 arch: Clean up asm/barrier.h implementations using asm-generic/barrier.h
... unfortunately left some Kbuild files out of order, which caused
unnecessary merge conflicts, in particular with checkin:
e3fec2f74f7f lib: Add missing arch generic-y entries for asm-generic/hash.h
Put them back in order to make the upcoming merges cleaner.
Link: http://lkml.kernel.org/r/20140114164420.d296fbcc4be3a5f126c86069@canb.auug.org.au
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
We're going to be adding a few new barrier primitives, and in order to
avoid endless duplication make more agressive use of
asm-generic/barrier.h.
Change the asm-generic/barrier.h such that it allows partial barrier
definitions and fills out the rest with defaults.
There are a few architectures (m32r, m68k) that could probably
do away with their barrier.h file entirely but are kept for now due to
their unconventional nop() implementation.
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Michael Ellerman <michael@ellerman.id.au>
Cc: Victor Kaplansky <VICTORK@il.ibm.com>
Link: http://lkml.kernel.org/r/20131213150640.846368594@infradead.org
Stop that, stop that! You're not going to do a song while I'm here.
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Pull irq cleanups from Ingo Molnar:
"This is a multi-arch cleanup series from Thomas Gleixner, which we
kept to near the end of the merge window, to not interfere with
architecture updates.
This series (motivated by the -rt kernel) unifies more aspects of IRQ
handling and generalizes PREEMPT_ACTIVE"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
preempt: Make PREEMPT_ACTIVE generic
sparc: Use preempt_schedule_irq
ia64: Use preempt_schedule_irq
m32r: Use preempt_schedule_irq
hardirq: Make hardirq bits generic
m68k: Simplify low level interrupt handling code
genirq: Prevent spurious detection for unconditionally polled interrupts
Cc: Chen Liqin <liqin.chen@sunplusct.com>
No point in having this bit defined by architecture.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20130917183629.090698799@linutronix.de
Merge Linux v3.12-rc4 to fix a conflict and also to refresh the tree
before applying more scheduler patches.
arch/avr32/include/asm/Kbuild
Signed-off-by: Lennox Wu <lennox.wu@gmail.com>
The modifications include:
1. Kconfig of Score: we don't support ioremap
2. Missed headfile including
3. There are some errors in other people's commit not checked by us, we fix it now
3.1 arch/score/kernel/entry.S: wrong instructions
3.2 arch/score/kernel/process.c : just some typos
In order to prepare to per-arch implementations of preempt_count move
the required bits into an asm-generic header and use this for all
archs.
Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org
After the last architecture switched to generic hard irqs the config
options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code
for !CONFIG_GENERIC_HARDIRQS can be removed.
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
user-triggered faults.
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: azurIt <azurit@pobox.sk>
The memcg code can trap tasks in the context of the failing allocation
until an OOM situation is resolved. They can hold all kinds of locks
(fs, mm) at this point, which makes it prone to deadlocking.
This series converts memcg OOM handling into a two step process that is
started in the charge context, but any waiting is done after the fault
stack is fully unwound.
Patches 1-4 prepare architecture handlers to support the new memcg
requirements, but in doing so they also remove old cruft and unify
out-of-memory behavior across architectures.
Patch 5 disables the memcg OOM handling for syscalls, readahead, kernel
faults, because they can gracefully unwind the stack with -ENOMEM. OOM
handling is restricted to user triggered faults that have no other
option.
Patch 6 reworks memcg's hierarchical OOM locking to make it a little
more obvious wth is going on in there: reduce locked regions, rename
locking functions, reorder and document.
Patch 7 implements the two-part OOM handling such that tasks are never
trapped with the full charge stack in an OOM situation.
This patch:
Back before smart OOM killing, when faulting tasks were killed directly on
allocation failures, the arch-specific fault handlers needed special
protection for the init process.
Now that all fault handlers call into the generic OOM killer (see commit
609838cfed97: "mm: invoke oom-killer from remaining unconverted page
fault handlers"), which already provides init protection, the
arch-specific leftovers can be removed.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc bits]
All architectures include "kernel/Kconfig.freezer" except three left, so
let them include it too, or 'allmodconfig' will report error.
The related errors: (with allmodconfig for openrisc):
CC kernel/cgroup_freezer.o
kernel/cgroup_freezer.c: In function 'freezer_css_online':
kernel/cgroup_freezer.c:133:15: error: 'system_freezing_cnt' undeclared (first use in this function)
kernel/cgroup_freezer.c:133:15: note: each undeclared identifier is reported only once for each function it appears in
kernel/cgroup_freezer.c: In function 'freezer_css_offline':
kernel/cgroup_freezer.c:157:15: error: 'system_freezing_cnt' undeclared (first use in this function)
kernel/cgroup_freezer.c: In function 'freezer_attach':
kernel/cgroup_freezer.c:200:4: error: implicit declaration of function 'freeze_task'
kernel/cgroup_freezer.c: In function 'freezer_apply_state':
kernel/cgroup_freezer.c:371:16: error: 'system_freezing_cnt' undeclared (first use in this function)
Signed-off-by: Chen Gang <gang.chen@asianux.com>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
are flagged as __cpuinit -- so if we remove the __cpuinit from
arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
content into no-ops as early as possible, since that will get rid
of these warnings. In any case, they are temporary and harmless.
This removes all the arch/score uses of the __cpuinit macros from
all C files. Currently score does not have any __CPUINIT used in
assembly files.
[1] https://lkml.org/lkml/2013/5/20/589
A few remaining architectures directly kill the page faulting task in an
out of memory situation. This is usually not a good idea since that
task might not even use a significant amount of memory and so may not be
the optimal victim to resolve the situation.
Since 2.6.29's 1c0fe6e ("mm: invoke oom-killer from page fault") there
is a hook that architecture page fault handlers are supposed to call to
invoke the OOM killer and let it pick the right task to kill. Convert
the remaining architectures over to this hook.
To have the previous behavior of simply taking out the faulting task the
vm.oom_kill_allocating_task sysctl can be set to 1.
Acked-by: David Rientjes <rientjes@google.com>
Merge first patch-bomb from Andrew Morton:
- various misc bits
- I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been
distracted. There has been quite a bit of activity.
- About half the MM queue
- Some backlight bits
- Various lib/ updates
- checkpatch updates
- zillions more little rtc patches
- ptrace
- signals
- exec
- procfs
- rapidio
- nbd
- aoe
- pps
- memstick
- tools/testing/selftests updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits)
tools/testing/selftests: don't assume the x bit is set on scripts
selftests: add .gitignore for kcmp
selftests: fix clean target in kcmp Makefile
selftests: add .gitignore for vm
selftests: add hugetlbfstest
self-test: fix make clean
selftests: exit 1 on failure
kernel/resource.c: remove the unneeded assignment in function __find_resource
aio: fix wrong comment in aio_complete()
drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode
drivers/memstick/host/r592.c: convert to module_pci_driver
drivers/memstick/host/jmb38x_ms: convert to module_pci_driver
pps-gpio: add device-tree binding and support
drivers/pps/clients/pps-gpio.c: convert to module_platform_driver
drivers/pps/clients/pps-gpio.c: convert to devm_* helpers
drivers/parport/share.c: use kzalloc
Documentation/accounting/getdelays.c: avoid strncpy in accounting tool
aoe: update internal version number to v83
aoe: update copyright date
aoe: perform I/O completions in parallel
