path: root/arch/sh/boards/board-shmin.c
2010-01-26sh: Mass ctrl_in/outX to __raw_read/writeX conversion.Paul Mundt
The old ctrl in/out routines are non-portable and unsuitable for cross-platform use. While drivers/sh has already been sanitized, there is still quite a lot of code that is not. This converts the arch/sh/ bits over, which permits us to flag the routines as deprecated whilst still building with -Werror for the architecture code, and to ensure that future users are not added. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-12-22sh: board-shmin: Convert shmin to use __set_io_port_base().Paul Mundt
Drop the special mv_ioport_map() implementation, as this can simply use __set_io_port_base() directly. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-10-20sh: Migrate common board headers to mach-common/.Paul Mundt
2008-07-30sh: Move out individual boards without mach groups.Paul Mundt
