path: root/arch/sh/boards/shmin
2007-09-21sh: intc - remove redundant irq code for shminMagnus Damm
This patch removes redundant interrupt code for the shmin board which is using a sh770x processor and 4 IRQ lines as individual interrupts (IRQ-mode). Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-06-15sh: rework ipr codeMagnus Damm
This patch reworks the ipr code by grouping the offset array together with the ipr_data structure in a new data structure called ipr_desc. This new structure also contains the name of the controller in struct irq_chip. The idea behind putting struct irq_chip in there is that we can use offsetof() to locate the base addresses in the irq_chip callbacks. This strategy has much in common with the recently merged intc2 code. One logic change has been made - the original ipr code enabled the interrupts by default but with this patch they are all disabled by default. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-06-08sh: Kill off machvec aliases.Paul Mundt
We now throw all of the machvecs in to .machvec.init and either select one on the command line, or copy out the first (and usually only) one to sh_mv. The rest are freed as usual. This gets rid of all of the silly sh_mv aliasing and makes the selection explicit rather than link-order dependent. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-02-13sh: Fixup SHMIN INTC register definitions.Nobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <hemamu@t-base.ne.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-02-13sh: shmin updates.Takashi YOSHII
This fixes up shmin (and SH7706/SH7708) IPR support for some of the recent API changes. Signed-off-by: Takashi YOSHII <takasi-y@ops.dti.ne.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-10-19sh: Cleanup board header directories.Paul Mundt
Now with the ide.h mess sorted out, most of these boards don't need their own directory. Move the headers out, and update the driver paths. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-27sh: machvec rework.Paul Mundt
Some more machvec overhauling and setup code cleanup. Kill off get_system_type() and platform_setup(), we can do these both through the machvec. While we're add it, kill off more useless mach.c's and drop some legacy cruft from setup.c. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-27sh: SHMIN board support.Takashi YOSHII
This adds support for the SHMIN SH7706 board. Signed-off-by: Takashi YOSHII <takasi-y@ops.dti.ne.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
