path: root/arch/sh/boards
2011-06-16sh: ecovec: Add renesas_usbhs supportKuninori Morimoto
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-24sh: add MMCIF runtime PM support on ecovecGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Simon Horman <horms@verge.net.au> Cc: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-24sh: switch ap325rxa to dynamically manage the platform cameraGuennadi Liakhovetski
Use soc_camera_platform helper functions to dynamically manage the camera device. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-04-18sh: fix SD / MMC configuration dependencies on ecovecGuennadi Liakhovetski
Update CONFIG_MMC_TMIO to the new CONFIG_MMC_SDHI symbol and fix MMCIF to also function in modular builds for ecovec. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Simon Horman <horms@verge.net.au> Cc: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-04-07Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6 * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: efifb: Add override for 11" Macbook Air 3,1 efifb: Support overriding fields FW tells us with the DMI data. fb: Reduce priority of resource conflict message savagefb: Remove obsolete else clause in savage_setup_i2c_bus savagefb: Set up I2C based on chip family instead of card id savagefb: Replace magic register address with define drivers/video/bfin-lq035q1-fb.c: introduce missing kfree video: s3c-fb: fix checkpatch errors and warning efifb: support AMD Radeon HD 6490 s3fb: fix Virge/GX2 fbcon: Remove unused 'display *p' variable from fb_flashcursor() fbdev: sh_mobile_lcdcfb: fix module lock acquisition fbdev: sh_mobile_lcdcfb: add blanking support viafb: initialize margins correct viafb: refresh rate bug collection sh: mach-ap325rxa: move backlight control code sh: mach-ecovec24: support for main lcd backlight
2011-04-07Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: select ARCH_NO_SYSDEV_OPS. sh: fix build error in board-sh7757lcr.c sh: landisk: Remove whitespace sh: landisk: Remove mv_nr_irqs sh: sh-sci: Fix double initialization by serial_console_setup serial: sh-sci: prevent setup of uninitialized serial console dma: shdma: add checking the DMAOR_AE in sh_dmae_err
2011-03-31sh: fix build error in board-sh7757lcr.cYoshihiro Shimoda
Fix the problem that the sh_mobile_sdhi.h changed the directory from "linux/mfd/" to "linux/mmc/". Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-31Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-latest
2011-03-31sh: landisk: Remove whitespaceNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-31sh: landisk: Remove mv_nr_irqsNobuhiro Iwamatsu
2011-03-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (26 commits) mmc: SDHI should depend on SUPERH || ARCH_SHMOBILE mmc: tmio_mmc: Move some defines into a shared header mmc: tmio: support aggressive clock gating mmc: tmio: fix power-mode interpretation mmc: tmio: remove work-around for unmasked SDIO interrupts sh: fix SDHI IO address-range ARM: mach-shmobile: fix SDHI IO address-range mmc: tmio: only access registers above 0xff, if available mfd: remove now redundant sh_mobile_sdhi.h header sh: convert boards to use linux/mmc/sh_mobile_sdhi.h ARM: mach-shmobile: convert boards to use linux/mmc/sh_mobile_sdhi.h mmc: tmio: convert the SDHI MMC driver from MFD to a platform driver sh: ecovec: use the CONFIG_MMC_TMIO symbols instead of MFD mmc: tmio: split core functionality, DMA and MFD glue mmc: tmio: use PIO for short transfers mmc: tmio-mmc: Improve DMA stability on sh-mobile mmc: fix mmc_app_send_scr() for dma transfer mmc: sdhci-esdhc: enable esdhc on imx53 mmc: sdhci-esdhc: use writel/readl as general APIs mmc: sdhci: add the abort CMDTYPE bits definition ...
2011-03-29sh: Convert to new function namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29sh: Use the proper accessor functionsThomas Gleixner
2011-03-29Merge branch 'common/fbdev' of ↵Paul Mundt
master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6
2011-03-25sh: fix SDHI IO address-rangeGuennadi Liakhovetski
SDHI registers occupy only a 0x100 byte large window, not 0x200 byte. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-25sh: convert boards to use linux/mmc/sh_mobile_sdhi.hGuennadi Liakhovetski
2011-03-25sh: ecovec: use the CONFIG_MMC_TMIO symbols instead of MFDGuennadi Liakhovetski
The CONFIG_MFD_SH_MOBILE_SDHI Kconfig symbol is going to disappear soon, switch ecovec to using CONFIG_MMC_TMIO(_MODULE). Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-22sh: Conver to asm-generic/sizes.h.Paul Mundt
A trivial conversion for the most part. EDOSK7760 is special, but uses a non-power-of-2-aligned size, so just drop the SZ_xx helper and open-code it for the sake of simplicity. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (308 commits) ALSA: sound/pci/asihpi: check adapter index in hpi_ioctl ALSA: aloop - Fix possible IRQ lock inversion ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail() ALSA: ctxfi - use list_move() instead of list_del()/list_add() combination ALSA: firewire - msleep needs delay.h ALSA: firewire-lib, firewire-speakers: handle packet queueing errors ALSA: firewire-lib: allocate DMA buffer separately ALSA: firewire-lib: use no-info SYT for packets without SYT sample ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver ALSA: hda - Remove an unused variable in patch_realtek.c ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecs ALSA: hda - fix digital mic selection in mixer on 92HD8X codecs ALSA: hda - Move default input-src selection to init part ALSA: hda - Initialize special cases for input src in init phase ALSA: ctxfi - Clear input settings before initialization ALSA: ctxfi - Fix SPDIF status retrieval ALSA: ctxfi - Fix incorrect SPDIF status bit mask ALSA: ctxfi - Fix microphone boost codes/comments ALSA: atiixp - Fix wrong time-out checks during ac-link reset ALSA: intel8x0m: append 'm' to "r_intel8x0" ...
2011-03-17sh: modify platform_device for sh_eth driverYoshihiro Shimoda
A new parameter is added to sh_eth_plat_data. And the sh_eth driver needs additional memory resource if a module has TSU. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-17sh: add GETHER's platform_device in board-sh7757lcrYoshihiro Shimoda
This patch also modifies for ETHER's platform_device. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-16Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-03-11sh: add platform_device of tmio_mmc and sh_mmcif to sh7757lcrYoshihiro Shimoda
2011-03-11sh: add spi_board_info in sh7757lcrYoshihiro Shimoda
2011-03-10sh: mach-ap325rxa: move backlight control codeAlexandre Courbot
Move the backlight control code into the appropriate hooks for the LCDC driver. Signed-off-by: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-10sh: mach-ecovec24: support for main lcd backlightAlexandre Courbot
Add support for the main LCD backlight that is controlled through the PTR1 GPIO. Signed-off-by: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-26ASoC: sh: fsi: modify selection method of I2S/PCM/SPDIF formatKuninori Morimoto
Current format selection of FSI-codecs depended on platform information for FSI, and chip default settings for codecs. It is not understandable/formal method. This patch modify FSI and FSI-codecs to use snd_soc_dai_set_fmt. But FSI can use I2S/PCM and SPDIF format today. It can be selected to I2S/PCM by snd_soc_dai_set_fmt, but can not select SPDIF. So, this patch change FSI platform information to have DAI/SPDIF mode. If platform selects DAI mode (default), FSI-codecs can select I2S/PCM by snd_soc_dai_set_fmt, and if it is SPDIF mode, FSI become SPDIF format. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-21ASoC: sh: fsi: Add snd_soc_dai_set_fmt supportKuninori Morimoto
This patch add snd_soc_dai_ops :: set_fmt to FSI driver and select master/slave clock mode by snd_soc_dai_set_fmt on fsi-xxx.c instead of platform infomation code. This patch remove fsi_is_master function which is no longer needed. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-18sh: fix MSIOF0 SPI on ecovec: it conflicts with VOUGuennadi Liakhovetski
MSIOF0 and VOU share pins on sh7724, make MSIOF0 available again, as long as VOU is not configured. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-13Merge branch 'sh-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (31 commits) sh: Add support for AP-SH4AD-0A board. sh: Add support for AP-SH4A-3A board. sh: Add a new mach type for alpha project boards. serial: sh-sci: build fixes. sh: sh7372 SH4AL-DSP probe support sh: sh7366 Enable SDIO IRQs sh: sh7343 Enable SDIO IRQs sh: mach-ecovec24: enable runtime PM for SDHI sh: sh7723 / ap325rxa enable SDIO IRQs sh: sh7722 Enable SDIO IRQs sh: sh7724 Enable SDIO IRQs sh: Fix up legacy PTEA space attribute mapping. sh: Stub out legacy PCC pgprot encoding for X2 TLBs. sh: constify prefetch pointers. sh: Add a machvec callback for early memblock reservations. sh: update sh7757lcr_defconfig sh: add PVR probing for SH7757 3rd cut sh: Use device_initcall() instead of __initcall() sh: intc - convert board specific landisk code sh: Move init_landisk_IRQ to header file ...
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits) ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO ALSA: oxygen: fix Xonar DG input ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low ALSA: hda - Fix missing EAPD for Acer 4930G ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs. ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser ALSA: hda - Don't refer ELD when unplugged ASoC: tpa6130a2: Fix compiler warning ASoC: tlv320dac33: Add DAPM selection for LOM invert ASoC: DMIC codec: Adding a generic DMIC codec ALSA: snd-usb-us122l: Fix missing NULL checks ALSA: snd-usb-us122l: Fix MIDI output ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync() ASoC: Fix section mismatch in wm8995.c ALSA: oxygen: add S/PDIF source selection for Claro cards ALSA: oxygen: fix CD/MIDI for X-Meridian (2G) ASoC: fix migor audio build ALSA: include delay.h for msleep in Xonar DG support ...
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-13set_rtc_mmss: show warning message only onceStephen Hemminger
Occasionally the system gets into a state where the CMOS clock has gotten slightly ahead of current time and the periodic update of RTC fails. The message is a nuisance and repeats spamming the log. See: http://www.ntp.org/ntpfaq/NTP-s-trbl-spec.htm#Q-LINUX-SET-RTC-MMSS Rather than just removing the message, make it show only once and reduce severity since it indicates a normal and non urgent condition. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'sh/alphaproject' into sh-latestPaul Mundt
2011-01-13sh: Add support for AP-SH4AD-0A board.Paul Mundt
This adds preliminary support for the alpha project AP-SH4AD-0A reference platform (SH7786 based). Additional platform information available at: http://www.apnet.co.jp/product/superh/ap-sh4ad-0a.html Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-13sh: Add support for AP-SH4A-3A board.Paul Mundt
This adds preliminary support for the alpha project AP-SH4A-3A reference platform (SH7785 based). Additional paltform information available at: http://www.apnet.co.jp/product/superh/ap-sh4a-3a.html Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-13sh: Add a new mach type for alpha project boards.Paul Mundt
2011-01-13Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-01-12Merge branch 'sh/sdio' into sh-latestPaul Mundt
2011-01-12sh: mach-ecovec24: enable runtime PM for SDHIArnd Hannemann
This patch enables runtime PM for SDHI on ecovec. Tested with a b43 based SDIO card. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-12sh: sh7723 / ap325rxa enable SDIO IRQsArnd Hannemann
This patch enables the interrupt generation for SDIO IRQs of the sdhi controllers of the SoC. To make sure SDIO IRQs are used announce the MMC_CAP_SDIO_IRQ capability on ap325rxa. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-12sh: sh7722 Enable SDIO IRQsArnd Hannemann
This patch enables the interrupt generation for SDIO IRQs of the sdhi controllers of the SoC. To make sure SDIO IRQs are used, announce the MMC_CAP_SDIO_IRQ capability on migor. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-12sh: sh7724 Enable SDIO IRQsArnd Hannemann
This patch enables the interrupt generation for SDIO IRQs of the sdhi controllers of the SoC. To make sure interrupt are handled announce the MMC_CAP_SDIO_IRQ capability on ecovec, kfr2r09 and se7724. Tested with a b43-based SDIO wireless card on ecovec. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-11sh: Use device_initcall() instead of __initcall()Nobuhiro Iwamatsu
2011-01-11sh: intc - convert board specific landisk codeNobuhiro Iwamatsu
This converts the board specific interrupt code for landisk to make use of intc (use register_intc_controller). Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigarui.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-11sh: Move init_landisk_IRQ to header fileNobuhiro Iwamatsu
2011-01-07sh: mach-sdk7786: Fix up fallout from clkdev consolidation.Paul Mundt
CC arch/sh/boards/mach-sdk7786/setup.o arch/sh/boards/mach-sdk7786/setup.c:179: error: variable 'sdk7786_pcie_cl' has initializer but incomplete type arch/sh/boards/mach-sdk7786/setup.c:180: error: unknown field 'con_id' specified in initializer arch/sh/boards/mach-sdk7786/setup.c:180: warning: excess elements in struct initializer arch/sh/boards/mach-sdk7786/setup.c:180: warning: (near initialization for 'sdk7786_pcie_cl') arch/sh/boards/mach-sdk7786/setup.c:181: error: unknown field 'clk' specified in initializer arch/sh/boards/mach-sdk7786/setup.c:181: warning: excess elements in struct initializer arch/sh/boards/mach-sdk7786/setup.c:181: warning: (near initialization for 'sdk7786_pcie_cl') arch/sh/boards/mach-sdk7786/setup.c: In function 'sdk7786_clk_init': arch/sh/boards/mach-sdk7786/setup.c:211: error: implicit declaration of function 'clkdev_add' which is a fanciful way of saying that the struct definition moved from asm/clkdev.h to linux/clkdev.h. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-06Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (416 commits) ARM: DMA: add support for DMA debugging ARM: PL011: add DMA burst threshold support for ST variants ARM: PL011: Add support for transmit DMA ARM: PL011: Ensure IRQs are disabled in UART interrupt handler ARM: PL011: Separate hardware FIFO size from TTY FIFO size ARM: PL011: Allow better handling of vendor data ARM: PL011: Ensure error flags are clear at startup ARM: PL011: include revision number in boot-time port printk ARM: vexpress: add sched_clock() for Versatile Express ARM i.MX53: Make MX53 EVK bootable ARM i.MX53: Some bug fix about MX53 MSL code ARM: 6607/1: sa1100: Update platform device registration ARM: 6606/1: sa1100: Fix platform device registration ARM i.MX51: rename IPU irqs ARM i.MX51: Add ipu clock support ARM: imx/mx27_3ds: Add PMIC support ARM: DMA: Replace page_to_dma()/dma_to_page() with pfn_to_dma()/dma_to_pfn() mx51: fix usb clock support MX51: Add support for usb host 2 arch/arm/plat-mxc/ehci.c: fix errors/typos ...
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
