path: root/arch/sh/boards
2008-05-23sh: use sm501 8250 mfd support on r2d boardsMagnus Damm
Make use of recently added sm501 8250 uart support, commit 61711f8fd8180e458cfb6846bcf4fc636a95f3db makes the mfd code handle 8250 uarts so there is no longer need to do it from the r2d board code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-09sh: update smc91x platform data for se7206.Paul Mundt
Follows the se7722 change. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: update smc91x platform data for se7722Magnus Damm
Select smc91x bus width using platform data for se7722 now when the smc91x header file is in place. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: update smc91x platform data for MigoRMagnus Damm
Select smc91x bus width and irg flags using platform data for MigoR now when the smc91x header file is in place. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: r7780rp: Kill off unneded ifdefs for irq setup.Paul Mundt
2008-05-08sh: rts7751r2d: Kill off unneeded ifdefs.Paul Mundt
2008-05-08sh: remove the broken SH_MPC1211 supportAdrian Bunk
SH_MPC1211 has been marked as BROKEN for some time. Unless someone is working on reviving it now, I'd therefore suggest this patch to remove it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-29i2c: Convert most new-style drivers to use module aliasingJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. Update most new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. I've left the video drivers apart (except for SoC camera drivers) as they're a bit more diffcult to deal with, they'll have their own patch later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Jochen Friedrich <jochen@scram.de>
2008-04-18sh: Add migor_ts support to MigoRMagnus Damm
Add support for the migor_ts touch panel to the MigoR board. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Add rs5c732b RTC support to MigoRMagnus Damm
Add support for the rs5c372b RTC chip to MigoR. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Add I2C support to MigoRMagnus Damm
Enable the sh7722 I2C controller on the MigoR board. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: MigoR NAND flash support using gen_flashMagnus Damm
Add NAND flash support to the MigoR board by giving board specific data to the gen_nand platform driver. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: MigoR NOR flash support using physmap-flashMagnus Damm
Add NOR flash support to the MigoR board by giving board specific data to the physmap-flash platform driver. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: r7780rp: Hook up the I2C and SMBus platform devices.Paul Mundt
2008-04-18sh: Use phyical addresses for MigoR smc91x resourcesMagnus Damm
Use physical addresses and change resource name of MigoR ethernet chip. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Add MigoR header fileMagnus Damm
This patch adds a MigoR specific header file. We may want to use a cpu specific header file instead, but this will do for now. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Add support for Solution Engine SH7721 boardYoshihiro Shimoda
Add support for Solution Engine SH7721 board(MS7721RP01). Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Hook up remaining IRQ sources for R7780MP FPGA.Masayuki Hosokawa
Signed-off-by: Masayuki Hosokawa <hosokawa@ace-jp.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: SuperH KEYSC keypad data for Solution Engine 7722Magnus Damm
Add KEYSC platform data for the Solution Engine 7722 board. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: SuperH KEYSC keypad data for MigoRMagnus Damm
Add KEYSC platform data for the sh7722 MigoR board. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-03-06sh: Fix up SH7710 VoIP-GW build.Paul Mundt
The only board-specific bits that existed here were for setting up the IRQs, which are now handled by the SH7710 CPU support code instead. As there's nothing else to do for setup, kill off the board support code and have the defconfig use the generic machvec instead. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-03-06sh: hp6xx: Fix up hp6xx_apm build failure.Paul Mundt
2008-03-06sh: hp6xx: Correct APM output.Kristoffer Ericson
This patch fixes the old non-verbose hp6xx apm code and enables some very basic apm output. We now get percentage (battery) output and basic time estimate. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-03-06sh: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-14sh: Kill off bogus SH_SDK7780_STANDALONE symbol.Paul Mundt
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-14sh: trapped io support for highlander V2Magnus Damm
This patch converts the highlander CF device from good old machvec readb/writeb to the new shiny trapped io. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-14sh: trapped io support for r2d V2Magnus Damm
This patch converts the CF device on r2d boards from machvec readb/writeb to trapped io. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-14sh: migor board supportMagnus Damm
This patch adds basic support for the Migo-R board. Only simple stuff provided by the cpu specific sh7722 code is in place now, like serial console port, timers and usb gadget. There is also partial support for the smc91c111 ethernet controller - unfortunately some driver header file also needs patching (not included here) to make the driver get IRQ sense information from the platform data. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-06Rename: linux/pata_platform.h to linux/ata_platform.hJeff Garzik
2008-01-28sh: add spi header and r2d platform data V3Magnus Damm
This patch adds the header file asm/spi.h and board specific code for the r2d board. The header file contains a structure that should be used to point out a single spi bus. The board specific code for r2d is updated with such a structure for the new spi_sh_sci driver. The structure contains a chip select callback plus information about the R9701 rtc chip which is attached to the spi bus. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: update r7780rp interrupt codeMagnus Damm
This patch updates the board specific irq code for r7780rp. The new code is very similar to the other highlander implementations, with the exception that the r7780rp handles pci interrupts using IRL. To simplify the pci code and use the same interrupt numbers as r7780mp and r7785rp we hook in to the cpu specific pci vectors. The pci interrupts and the push switch all work well with and without this patch. CF and AX88796 are not ok though and the source of the problem is unknown at this point. The AX88796 does for not detect it's proper mac address (IPL gets it right) and the kernel hangs on CF access. As a workaround this patch removes the CF and the AX88796 from the platform datain case of r7780rp. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: use declared coherent memory for dreamcast pci ethernet adapterMagnus Damm
This patch makes the dreamcast use the recently added declared coherent memory functions to point out the memory window suitable for dma. Apart from cleaning up, this gives the dreamcast a proper memory allocator for pci dma memory. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: Add support for SDK7780 board.Nicholas Beck
Add support for Renesas Technology Europe SDK7780 board. Signed-off-by: Nicholas Beck <nbeck@mpc-data.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: Kill off dead HS771RVoIP board support.Paul Mundt
2008-01-28sh: r7785rp: Fix up DECLARE_INTC_DESC() arg mismatch.Paul Mundt
2008-01-28sh: r7785rp: Hook up the rest of the HL7785 FPGA IRQ vectors.Paul Mundt
2008-01-28sh: r2d - enable sm501 usb host functionMagnus Damm
This patch tells the sm501 mfd driver to build platform data for the sm501 usb host driver. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: remove voyagergxMagnus Damm
This patch removes redundant irq handling code together with unused consistent alloc code. R2D uart setup code is changed to use sm501-regs.h and unused header files are removed. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: r2d - add lcd planel timings to sm501 platform dataMagnus Damm
This patch adds timings to drive a Sharp LQ104V1DG21 lcd panel that can be hooked up to R2D-1 or R2D-PLUS. The sm501fb driver should leave the pins FPEN and VBIASEN alone, and this patch instructs the driver to do so by not setting flags flags for these pins. This patch works best together with the patch posted to the linux-fbdev-devel list "sm501fb: control panel pin usage with platform data flags", but this patch can be merged independently. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: intc - remove default interrupt priority tablesMagnus Damm
This patch removes interrupt priority tables from the intc code. Optimal priority assignment varies with embedded application anyway, so keeping the interrupt priority tables together with cpu-specific code doesn't make sense. The function intc_set_priority() should be used instead to set the desired interrupt priority level. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: arch/sh/: Spelling fixes.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: comment tidying for sh64->sh migration.Paul Mundt
2008-01-28sh: Move mach-cayman in with the rest of the boards.Paul Mundt
2007-11-23sh: fix R2D-1 CF supportMagnus Damm
This patch fixes CF support for R2D-1 boards. Both R2D-1 and R2D-PLUS are equipped with CF IRQs, but the R2D-1 FPGA version seem to deliver IRQ spikes with certain CF cards during libata probing. This patch enables polling for R2D-1 as a workaround for this broken FGPA logic. R2D-1 CF support was recently introduced by commit: 43f4b8c7578b928892b6f01d374346ae14e5eb70. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-11-08sh: Kill off broken snapgear ds1302 code.Paul Mundt
This will force the snapgear boards to use the on-chip SH RTC instead, until the rtc-ds1302 driver is merged. The current code is broken and hasn't built in some time, so just kill it off and get the board working again. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-11-07sh: Fix heartbeart on Solution Engine seriesNobuhiro Iwamatsu
Access size to LED is not added on Solution Engine series. LED doesn't work. Fixed this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-11-07sh: hs7751rvoip: Kill off dead IPR IRQ mappings.Paul Mundt
This is dead code, and doesn't build anyways. Kill it off. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-11-07sh: hs7751rvoip: irq.c needs linux/interrupt.h.Paul Mundt
2007-11-07sh: Kill off duplicate includes.Paul Mundt
Caught by the surprisingly not-entirely-useless 'includecheck'. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
