Return errors immediately so the straightline path is the normal,
no-error path. No functional change.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Previously, pci_scan_root_bus() created a root PCI bus, enumerated the
devices on it, and called pci_bus_add_devices(), which made the devices
available for drivers to claim them.
Most callers assigned resources to devices after pci_scan_root_bus()
returns, which may be after drivers have claimed the devices. This is
incorrect; the PCI core should not change device resources while a driver
is managing the device.
Remove pci_bus_add_devices() from pci_scan_root_bus() and do it after any
resource assignment in the callers.
Note that ARM's pci_common_init_dev() already called pci_bus_add_devices()
after pci_scan_root_bus(), so we only need to remove the first call:
pci_common_init_dev
pcibios_init_hw
pci_scan_root_bus
pci_bus_add_devices # first call
pci_bus_assign_resources
pci_bus_add_devices # second call
[bhelgaas: changelog, drop "root_bus" var in alpha common_init_pci(),
return failure earlier in mn10300, add "return" in x86 pcibios_scan_root(),
return early if xtensa platform_pcibios_fixup() fails]
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
CC: Richard Henderson <rth@twiddle.net>
CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
CC: Matt Turner <mattst88@gmail.com>
CC: David Howells <dhowells@redhat.com>
CC: Tony Luck <tony.luck@intel.com>
CC: Michal Simek <monstr@monstr.eu>
CC: Ralf Baechle <ralf@linux-mips.org>
CC: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
CC: Sebastian Ott <sebott@linux.vnet.ibm.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: Chris Metcalf <cmetcalf@ezchip.com>
CC: Chris Zankel <chris@zankel.net>
CC: Max Filippov <jcmvbkbc@gmail.com>
CC: Thomas Gleixner <tglx@linutronix.de>
Pull slave-dma updates from Vinod Koul:
"Some notable changes are:
- new driver for AMBA AXI NBPF by Guennadi
- new driver for sun6i controller by Maxime
- pl330 drivers fixes from Lar's
- sh-dma updates and fixes from Laurent, Geert and Kuninori
- Documentation updates from Geert
- drivers fixes and updates spread over dw, edma, freescale, mpc512x
etc.."
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (72 commits)
dmaengine: sun6i: depends on RESET_CONTROLLER
dma: at_hdmac: fix invalid remaining bytes detection
dmaengine: nbpfaxi: don't build this driver where it cannot be used
dmaengine: nbpf_error_get_channel() can be static
dma: pl08x: Use correct specifier for size_t values
dmaengine: Remove the context argument to the prep_dma_cyclic operation
dmaengine: nbpfaxi: convert to tasklet
dmaengine: nbpfaxi: fix a theoretical race
dmaengine: add a driver for AMBA AXI NBPF DMAC IP cores
dmaengine: add device tree binding documentation for the nbpfaxi driver
dmaengine: edma: Do not register second device when booted with DT
dmaengine: edma: Do not change the error code returned from edma_alloc_slot
dmaengine: rcar-dmac: Add device tree bindings documentation
dmaengine: shdma: Allocate cyclic sg list dynamically
dmaengine: shdma: Make channel filter ignore unrelated devices
dmaengine: sh: Rework Kconfig and Makefile
dmaengine: sun6i: Fix memory leaks
dmaengine: sun6i: Free the interrupt before killing the tasklet
dmaengine: sun6i: Remove switch statement from buswidth convertion routine
dmaengine: of: kconfig: select DMA_ENGINE when DMA_OF is selected
The symbol is an orphan, get rid of it.
Submitted by Richard a few months ago as "[PATCH 21/28] Remove
CPU_SUBTYPE_SH7764".
[pebolle@tiscali.nl: re-added dropped ||]
Signed-off-by: Richard Weinberger <richard@nod.at>
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
dma_declare_coherent_memory() needs both the CPU physical address and the
bus address of the device memory. They are the same on this platform, but
in general we should use pcibios_resource_to_bus() to account for any
address translation done by the PCI host bridge.
This makes no difference on Dreamcast, but is safer if the usage is copied
to future drivers.
CC: Magnus Damm <damm@opensource.se>
CC: linux-sh@vger.kernel.org
We don't need anything arch-specific in pcibios_enable_device(), so drop
the arch implementation and use the default generic one.
CC: Paul Mundt <lethal@linux-sh.org>
We currently enable PCI bridges after scanning a bus and assigning
resources. This is often done in arch code.
This patch changes this so we don't enable a bridge until necessary, i.e.,
until we enable a PCI device behind the bridge. We do this in the generic
pci_enable_device() path, so this also removes the arch-specific code to
enable bridges.
[bhelgaas: changelog]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: vger.kernel.org
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Don't use create_proc_read_entry() as that is deprecated, but rather use
proc_create_data() and seq_file instead.
cc: Paul Mundt <lethal@linux-sh.org>
cc: linux-sh@vger.kernel.org
A function type is typically defined as
typedef ret_type (*func)(args..)
but async_func_ptr is not. Redefine it.
Also rename async_func_ptr to async_func_t for _func_t suffix is more generic.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
This fixes up all of the smaller arches that had __dev* markings for
their platform-specific drivers.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Bob Liu <lliubbo@gmail.com>
Cc: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Myron Stowe <myron.stowe@redhat.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Yong Zhang <yong.zhang0@gmail.com>
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Cc: Jan Glauber <jang@linux.vnet.ibm.com>
Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Remove conditional code based on CONFIG_HOTPLUG being false. It's
always on now in preparation of it going away as an option.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Pull workqueue changes from Tejun Heo:
"This is workqueue updates for v3.7-rc1. A lot of activities this
round including considerable API and behavior cleanups.
* delayed_work combines a timer and a work item. The handling of the
timer part has always been a bit clunky leading to confusing
cancelation API with weird corner-case behaviors. delayed_work is
updated to use new IRQ safe timer and cancelation now works as
expected.
* Another deficiency of delayed_work was lack of the counterpart of
mod_timer() which led to cancel+queue combinations or open-coded
timer+work usages. mod_delayed_work[_on]() are added.
These two delayed_work changes make delayed_work provide interface
and behave like timer which is executed with process context.
* A work item could be executed concurrently on multiple CPUs, which
is rather unintuitive and made flush_work() behavior confusing and
half-broken under certain circumstances. This problem doesn't
exist for non-reentrant workqueues. While non-reentrancy check
isn't free, the overhead is incurred only when a work item bounces
across different CPUs and even in simulated pathological scenario
the overhead isn't too high.
All workqueues are made non-reentrant. This removes the
distinction between flush_[delayed_]work() and
flush_[delayed_]_work_sync(). The former is now as strong as the
latter and the specified work item is guaranteed to have finished
execution of any previous queueing on return.
* In addition to the various bug fixes, Lai redid and simplified CPU
hotplug handling significantly.
* Joonsoo introduced system_highpri_wq and used it during CPU
hotplug.
There are two merge commits - one to pull in IRQ safe timer from
tip/timers/core and the other to pull in CPU hotplug fixes from
wq/for-3.6-fixes as Lai's hotplug restructuring depended on them."
Fixed a number of trivial conflicts, but the more interesting conflicts
were silent ones where the deprecated interfaces had been used by new
code in the merge window, and thus didn't cause any real data conflicts.
Tejun pointed out a few of them, I fixed a couple more.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits)
workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending()
workqueue: use cwq_set_max_active() helper for workqueue_set_max_active()
workqueue: introduce cwq_set_max_active() helper for thaw_workqueues()
workqueue: remove @delayed from cwq_dec_nr_in_flight()
workqueue: fix possible stall on try_to_grab_pending() of a delayed work item
workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback()
workqueue: use __cpuinit instead of __devinit for cpu callbacks
workqueue: rename manager_mutex to assoc_mutex
workqueue: WORKER_REBIND is no longer necessary for idle rebinding
workqueue: WORKER_REBIND is no longer necessary for busy rebinding
workqueue: reimplement idle worker rebinding
workqueue: deprecate __cancel_delayed_work()
workqueue: reimplement cancel_delayed_work() using try_to_grab_pending()
workqueue: use mod_delayed_work() instead of __cancel + queue
workqueue: use irqsafe timer for delayed_work
workqueue: clean up delayed_work initializers and add missing one
workqueue: make deferrable delayed_work initializer names consistent
workqueue: cosmetic whitespace updates for macro definitions
workqueue: deprecate system_nrt[_freezable]_wq
workqueue: deprecate flush[_delayed]_work_sync()
Most architectures implement this in exactly the same way. Instead of
having each architecture duplicate this function, provide a single
implementation in the core and make it a weak symbol so that it can be
overridden on architectures where it is required.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Remove the __init annotations in order to keep pci_fixup_irqs() around
after init (e.g. for hotplug). This requires the same change for the
implementation of pcibios_update_irq() on all architectures. While at
it, all __devinit annotations are removed as well, since they will be
useless now that HOTPLUG is always on.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
flush[_delayed]_work_sync() are now spurious. Mark them deprecated
and convert all users to flush[_delayed]_work().
If you're cc'd and wondering what's going on: Now all workqueues are
non-reentrant and the regular flushes guarantee that the work item is
not pending or running on any CPU on return, so there's no reason to
use the sync flushes at all and they're going away.
This patch doesn't make any functional difference.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: linux-wireless@vger.kernel.org
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Avi Kivity <avi@redhat.com>
When calling request_irq with IRQF_SHARED, the dev cookie must be set
(i.e. non-NULL), otherwise the code rejects it immediately with -EINVAL.
So restore the logic here where we'd pass a pointer to the name as a
dummy unique val.
Otherwise, booting up on my LANDISK system would fail with:
DMAC Address Error0 request_irq fail
This was introduced in commit 7f47c7189b3e8f19a589f77a3ad169d7b691b582.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Pull PCI changes from Bjorn Helgaas:
"Host bridge hotplug:
- Add MMCONFIG support for hot-added host bridges (Jiang Liu)
Device hotplug:
- Move fixups from __init to __devinit (Sebastian Andrzej Siewior)
- Call FINAL fixups for hot-added devices, too (Myron Stowe)
- Factor out generic code for P2P bridge hot-add (Yinghai Lu)
- Remove all functions in a slot, not just those with _EJx (Amos
Kong)
Dynamic resource management:
- Track bus number allocation (struct resource tree per domain)
(Yinghai Lu)
- Make P2P bridge 1K I/O windows work with resource reassignment
(Bjorn Helgaas, Yinghai Lu)
- Disable decoding while updating 64-bit BARs (Bjorn Helgaas)
Power management:
- Add PCIe runtime D3cold support (Huang Ying)
Virtualization:
- Add VFIO infrastructure (ACS, DMA source ID quirks) (Alex
Williamson)
- Add quirks for devices with broken INTx masking (Jan Kiszka)
Miscellaneous:
- Fix some PCI Express capability version issues (Myron Stowe)
- Factor out some arch code with a weak, generic, pcibios_setup()
(Myron Stowe)"
* tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (122 commits)
PCI: hotplug: ensure a consistent return value in error case
PCI: fix undefined reference to 'pci_fixup_final_inited'
PCI: build resource code for M68K architecture
PCI: pciehp: remove unused pciehp_get_max_lnk_width(), pciehp_get_cur_lnk_width()
PCI: reorder __pci_assign_resource() (no change)
PCI: fix truncation of resource size to 32 bits
PCI: acpiphp: merge acpiphp_debug and debug
PCI: acpiphp: remove unused res_lock
sparc/PCI: replace pci_cfg_fake_ranges() with pci_read_bridge_bases()
PCI: call final fixups hot-added devices
PCI: move final fixups from __init to __devinit
x86/PCI: move final fixups from __init to __devinit
MIPS/PCI: move final fixups from __init to __devinit
PCI: support sizing P2P bridge I/O windows with 1K granularity
PCI: reimplement P2P bridge 1K I/O windows (Intel P64H2)
PCI: disable MEM decoding while updating 64-bit MEM BARs
PCI: leave MEM and IO decoding disabled during 64-bit BAR sizing, too
PCI: never discard enable/suspend/resume_early/resume fixups
PCI: release temporary reference in __nv_msi_ht_cap_quirk()
PCI: restructure 'pci_do_fixups()'
* pci/myron-pcibios_setup:
xtensa/PCI: factor out pcibios_setup()
x86/PCI: adjust section annotations for pcibios_setup()
unicore32/PCI: adjust section annotations for pcibios_setup()
tile/PCI: factor out pcibios_setup()
sparc/PCI: factor out pcibios_setup()
sh/PCI: adjust section annotations for pcibios_setup()
sh/PCI: factor out pcibios_setup()
powerpc/PCI: factor out pcibios_setup()
parisc/PCI: factor out pcibios_setup()
MIPS/PCI: adjust section annotations for pcibios_setup()
MIPS/PCI: factor out pcibios_setup()
microblaze/PCI: factor out pcibios_setup()
ia64/PCI: factor out pcibios_setup()
cris/PCI: factor out pcibios_setup()
alpha/PCI: factor out pcibios_setup()
PCI: pull pcibios_setup() up into core
Make pcibios_setup() consistently use the "__init" section annotation.
Signed-off-by: Myron Stowe <myron.stowe@redhat.com>
The PCI core provides a generic pcibios_setup() routine. Drop this
architecture-specific version in favor of that.
Tested-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
sh_clk_mstp32_register is deprecated. This convert to sh_clk_mstp_register.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
* topic/sebastian-devinit-fixups:
scripts/modpost: check for bad references in .pci.fixups area
sh/PCI: move fixup hooks from __init to __devinit
powerpc/PCI: move fixup hooks from __init to __devinit
frv/PCI: move fixup hooks from __init to __devinit
arm/PCI: move fixup hooks from __init to __devinit
alpha/PCI: move fixup hooks from __init to __devinit
x86/PCI: move fixup hooks from __init to __devinit
The fixups are executed once the pci-device is found which is during
boot process so __init seems fine as long as the platform does not
support hotplug.
However it is possible to remove the PCI bus at run time and have it
rediscovered again via "echo 1 > /sys/bus/pci/rescan" and this will call
the fixups again.
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Replace the struct pci_bus secondary/subordinate members with the
struct resource busn_res. Later we'll build a resource tree of these
bus numbers.
Attempt to "tidy" up some of the multi IRQ handling and base + IRQ
management. This should keep it limping along without too much hassle,
and no new parts should ever be enabling or using this API anyways.
It doesn't get any closer to lipstick on a pig as this.
We don't support the ISA DMA API, so this is only ever misused. The
dma-sh case inadvertently broke the dreamcast case by testing the wrong
variable for the total number of channels, so this fixes that up too.
This converts over the legacy PCI IRQs to evt2irq() backed hwirq lookups.
This fixes up an attribute mismatch that was introduced in the
sysdev->struct device migration.
If in big-endian mode, switch the PCI bus, too.
Tested on both litte-endian and big-endian sh7785lcr.
Signed-off-by: Thomas Schwinge <thomas@codesourcery.com>
Cc: linux-sh@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux into sh-latest
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
Pull PCI changes (including maintainer change) from Jesse Barnes:
"This pull has some good cleanups from Bjorn and Yinghai, as well as
some more code from Yinghai to better handle resource re-allocation
when enabled.
There's also a new initcall_debug feature from Arjan which will print
out quirk timing information to help identify slow quirks for fixing
or refinement (Yinghai sent in a few patches to do just that once the
new debug code landed).
Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas.
He's been a core PCI and Linux contributor for some time now, and has
kindly volunteered to take over. I just don't feel I have the time
for PCI review and work that it deserves lately (I've taken on some
other projects), and haven't been as responsive lately as I'd like, so
I approached Bjorn asking if he'd like to manage things. He's going
to give it a try, and I'm confident he'll do at least as well as I
have in keeping the tree managed, patches flowing, and keeping things
stable."
Fix up some fairly trivial conflicts due to other cleanups (mips device
resource fixup cleanups clashing with list handling cleanup, ppc iseries
removal clashing with pci_probe_only cleanup etc)
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits)
PCI: Bjorn gets PCI hotplug too
PCI: hand PCI maintenance over to Bjorn Helgaas
unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h
sparc/PCI: convert devtree and arch-probed bus addresses to resource
powerpc/PCI: allow reallocation on PA Semi
powerpc/PCI: convert devtree bus addresses to resource
powerpc/PCI: compute I/O space bus-to-resource offset consistently
arm/PCI: don't export pci_flags
PCI: fix bridge I/O window bus-to-resource conversion
x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()'
PCI / PCIe: Introduce command line option to disable ARI
PCI: make acpihp use __pci_remove_bus_device instead
PCI: export __pci_remove_bus_device
PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge
PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device
PCI: print out PCI device info along with duration
PCI: Move "pci reassigndev resource alignment" out of quirks.c
PCI: Use class for quirk for usb host controller fixup
PCI: Use class for quirk for ti816x class fixup
PCI: Use class for quirk for intel e100 interrupt fixup
free_irq are compatible
Convert calls to free_irq so that the second argument is the same as the
last argument of the corresponding call to request_irq. Without this
property, free_irq does nothing.
In the case of dmabrg.c the change is merely cosmetic - changing 0 to NULL.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
SuperH fixes for 3.3-rc5
* tag 'sh-for-linus' of git://github.com/pmundt/linux-sh:
sh: Fix sh2a build error for CONFIG_CACHE_WRITETHROUGH
sh: modify a resource of sh_eth_giga1_resources in board-sh7757lcr
arch/sh: remove references to cpu_*_map.
sh: Fix typo in pci-sh7780.c
sh: add platform_device for SPI1 in setup-sh7757
sh: modify resource for SPI0 in setup-sh7757
sh: se7724: fix compile breakage
sh: clkfwk: bugfix: use clk_reparent() for div6 clocks
sh: clock-sh7724: fixup sh_fsi clock settings
sh: sh7757lcr: update to the new MMCIF DMA configuration
sh: fix the sh_mmcif_plat_data in board-sh7757lcr
video: pvr2fb: Fix up spurious section mismatch warnings.
sh: Defer to asm-generic/device.h.
Correct spelling "erorr" to "error" in
arch/sh/drivers/pci/pci-sh7780.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Tell the PCI core about host bridge address translation so it can take
care of bus-to-resource conversion for us.
commit 43db595e8b5d78ce5ad2feab719814a76e3ad2e5
(sh: switch to GENERIC_PCI_IOMAP)
failed to take into account the PCI channels's
io_map_base for mapping IO BARs.
This also caused a new warning on sh.
Fix this, without re-introducing code duplication,
by setting NO_GENERIC_PCI_IOPORT_MAP
and supplying a sh-specific __pci_ioport_map.
Reported-by: Kevin Cernekee <cernekee@gmail.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits)
x86/PCI: Expand the x86_msi_ops to have a restore MSIs.
PCI: Increase resource array mask bit size in pcim_iomap_regions()
PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES
PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT)
PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB
x86/PCI: amd: factor out MMCONFIG discovery
PCI: Enable ATS at the device state restore
PCI: msi: fix imbalanced refcount of msi irq sysfs objects
PCI: kconfig: English typo in pci/pcie/Kconfig
PCI/PM/Runtime: make PCI traces quieter
PCI: remove pci_create_bus()
xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources
x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus()
x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented()
x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan
sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources
sparc/PCI: convert to pci_create_root_bus()
sh/PCI: convert to pci_scan_root_bus() for correct root bus resources
powerpc/PCI: convert to pci_create_root_bus()
powerpc/PCI: split PHB part out of pcibios_map_io_space()
Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due
to the same patches being applied in other branches.
lib: use generic pci_iomap on all architectures
Many architectures don't want to pull in iomap.c,
so they ended up duplicating pci_iomap from that file.
That function isn't trivial, and we are going to modify it
https://lkml.org/lkml/2011/11/14/183
so the duplication hurts.
This reduces the scope of the problem significantly,
by moving pci_iomap to a separate file and
referencing that from all architectures.
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
alpha: drop pci_iomap/pci_iounmap from pci-noop.c
mn10300: switch to GENERIC_PCI_IOMAP
mn10300: add missing __iomap markers
frv: switch to GENERIC_PCI_IOMAP
tile: switch to GENERIC_PCI_IOMAP
tile: don't panic on iomap
sparc: switch to GENERIC_PCI_IOMAP
powerpc: switch to GENERIC_PCI_IOMAP
parisc: switch to GENERIC_PCI_IOMAP
mips: switch to GENERIC_PCI_IOMAP
microblaze: switch to GENERIC_PCI_IOMAP
arm: switch to GENERIC_PCI_IOMAP
alpha: switch to GENERIC_PCI_IOMAP
lib: add GENERIC_PCI_IOMAP
lib: move GENERIC_IOMAP to lib/Kconfig
Fix up trivial conflicts due to changes nearby in arch/{m68k,score}/Kconfig
Convert from pci_scan_bus() to pci_scan_root_bus() and remove root bus
resource fixups. This fixes the problem of "early" and "header" quirks
seeing incorrect root bus resources.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This patch removes sh's architecture-specific 'pcibios_set_master()'
routine and lets the default PCI core based implementation handle PCI
device 'latency timer' setup.
The 'latency timer' of PCI devices, both Type 0 and Type 1,
is setup in architecture-specific code [see: 'pcibios_set_master()'].
There are two approaches being taken by all the architectures - check
if the 'latency timer' is currently set between 16 and 255 and if not
bring it within bounds, or, do nothing (and then there is the
gratuitously different PA-RISC implementation).
There is nothing architecture-specific about PCI's 'latency timer' so
this patch pulls its setup functionality up into the PCI core by
creating a generic 'pcibios_set_master()' function using the '__weak'
attribute which can be used by all architectures as a default which,
if necessary, can then be over-ridden by architecture-specific code.
After all sysdev classes are ported to regular driver core entities, the
sysdev implementation will be entirely removed from the kernel.
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
sh copied pci_iomap from generic code, probably to avoid
pulling the rest of iomap.c in. Since that's in
a separate file now, we can reuse the common implementation.
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
To fix:
arch/sh/drivers/dma/dma-sysfs.c:45:8: error: 'S_IRUGO' undeclared here (not in a function)
arch/sh/drivers/dma/dma-sysfs.c:75:8: error: 'S_IWUSR' undeclared here (not in a function)
make[4]: *** [arch/sh/drivers/dma/dma-sysfs.o] Error 1
drivers/sh/intc/core.c:449: error: 'S_IRUGO' undeclared here (not in a function)
make[5]: *** [drivers/sh/intc/core.o] Error 1
