path: root/arch/sh/include/asm
2011-11-21sh: Fix cached/uncaced address calculation in 29bit modeNobuhiro Iwamatsu
commit dfd3b596fbbfa48b8e7966ef996d587157554b69 upstream. In the case of 29bit mode, CAC/UNCAC_ADDR does not return a right address. This revises this problem by using P1SEGADDR and P2SEGADDR in 29bit mode. Reported-by: Yutaro Ebihara <ebiharaml@si-linux.co.jp> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Tested-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-03sh: Fix conflicting definitions of ptrace_triggeredPaul Gortmaker
The extra nmi argument is causing this compile fail: CC arch/sh/kernel/ptrace_32.o arch/sh/kernel/ptrace_32.c:66:6: error: conflicting types for 'ptrace_triggered' arch/sh/include/asm/ptrace.h:126:13: note: previous declaration of 'ptrace_triggered' was here make[3]: *** [arch/sh/kernel/ptrace_32.o] Error 1 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-22asm-generic: move archictures to common delay.hJonas Bonn
This patch moves the in-tree architectures that were using the 'generic' delay.h over to using the header file in asm-generic. This is not done using the generic-y mechanism as none of these arch's have started using that mechanism yet. This is a trivial change to make later when the arch begins using generic-y. Note the subtle change to the avr32 and SH architectures where the argument to __const_udelay was previously using the rounded down constant value instead of the rounded up value. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-06-27Fix node_start/end_pfn() definition for mm/page_cgroup.cKAMEZAWA Hiroyuki
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end of nodes. But, it's not defined in linux/mmzone.h but defined in /arch/???/include/mmzone.h which is included only under CONFIG_NEED_MULTIPLE_NODES=y. Then, we see mm/page_cgroup.c: In function 'page_cgroup_init': mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn' mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn' So, fixiing page_cgroup.c is an idea... But node_start_pfn()/node_end_pfn() is a very generic macro and should be implemented in the same manner for all archs. (m32r has different implementation...) This patch removes definitions of node_start/end_pfn() in each archs and defines a unified one in linux/mmzone.h. It's not under CONFIG_NEED_MULTIPLE_NODES, now. A result of macro expansion is here (mm/page_cgroup.c) for !NUMA start_pfn = ((&contig_page_data)->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); for NUMA (x86-64) start_pfn = ((node_data[nid])->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); Changelog: - fixed to avoid using "nid" twice in node_end_pfn() macro. Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-and-tested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-14sh, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so those calls to set_fs(USER_DS) are redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-08sh: Fix up xchg/cmpxchg corruption with gUSA RB.Srinivas KANDAGATLA
gUSA special cases r15 for part of its login/out sequence, meaning that any parameters need to be explicitly prohibited from accidentally being assigned that particular register, and the compiler ultimately needs to use a temporary instead. Certain configurations have begun generating code paths that do indeed get allocated r15, resulting in immediate corruption of the exchanged value. This was observed in (amongst others) exit_mm() code generation where the xchg_u32 call was immediately corrupting a structure address. As this is a general gUSA restriction, the rest of the users likewise need to be updated to ensure sensible constraints. References: https://bugzilla.stlinux.com/show_bug.cgi?id=11229 Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Reviewed-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-31sh: Fix up asm-generic/ptrace.h fallout.Paul Mundt
There was an ordering issue with regards to instruction_pointer() being used in profile_pc() prior to the asm-generic/ptrace.h include, which subsequently provided the instruction_pointer() definition. In the interest of simplicity we simply open-code the regs->pc deref for the profile_pc() definition instead. The FP functions were also broken due to a lack of a common regs->fp, so provide a common GET_FP() that is safe for both architectures in order to fix up the frame pointer helpers too. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-31sh64: asm/pgtable.h needs asm/mmu.hPaul Mundt
Needed to satisfy the __in_29bit_mode() check. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-31sh: asm/tlb.h needs linux/swap.hNobuhiro Iwamatsu
Commit 1e56a56410bb64bce62d44563e35a143fc2d515f introduced the mmu_gather rework for sh, but missed a linux/swap.h include: CC arch/sh/mm/tlb-urb.o In file included from arch/sh/mm/tlb-urb.c:14:0: arch/sh/include/asm/tlb.h: In function '__tlb_remove_page': arch/sh/include/asm/tlb.h:92:2: error: implicit declaration of function 'free_page_and_swap_cache' Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: Fix PM QOS's user mode interface to work with ASCII input PM / Hibernate: Update kerneldoc comments in hibernate.c PM / Hibernate: Remove arch_prepare_suspend() PM / Hibernate: Update some comments in core hibernate code
2011-05-26kgdbts: unify/generalize gdb breakpoint adjustmentMike Frysinger
The Blackfin arch, like the x86 arch, needs to adjust the PC manually after a breakpoint is hit as normally this is handled by the remote gdb. However, rather than starting another arch ifdef mess, create a common GDB_ADJUSTS_BREAK_OFFSET define for any arch to opt-in via their kgdb.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Dongdong Deng <dongdong.deng@windriver.com> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26sh: convert to asm-generic ptrace.hMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Cc: Dongdong Deng <dongdong.deng@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25sh: mmu_gather reworkPeter Zijlstra
Fix up the sh mmu_gather code to conform to the new API. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24PM / Hibernate: Remove arch_prepare_suspend()Rafael J. Wysocki
All architectures supporting hibernation define arch_prepare_suspend() as an empty function, so remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-05-23sh: remove warning and warning_symbol from struct stacktrace_opsRichard Weinberger
Both warning and warning_symbol are nowhere used. Let's get rid of them. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23sh: wire up sys_sendmmsg.Paul Mundt
2011-03-24Merge branch 'sh-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Fix build alloc_thread_info_node function sh: Fix ptrace hw_breakpoint handling sh: Fix ptrace fpu state initialisation sh: Re-enable GENERIC_HARDIRQS_NO_DEPRECATED. sh: pmb: Use struct syscore_ops instead of sysdevs sh: Use struct syscore_ops instead of sysdevs sh: Conver to asm-generic/sizes.h. sh: wire up sys_syncfs.
2011-03-24Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-latest
2011-03-23bitops: remove minix bitops from asm/bitops.hAkinobu Mita
minix bit operations are only used by minix filesystem and useless by other modules. Because byte order of inode and block bitmaps is different on each architecture like below: m68k: big-endian 16bit indexed bitmaps h8300, microblaze, s390, sparc, m68knommu: big-endian 32 or 64bit indexed bitmaps m32r, mips, sh, xtensa: big-endian 32 or 64bit indexed bitmaps for big-endian mode little-endian bitmaps for little-endian mode Others: little-endian bitmaps In order to move minix bit operations from asm/bitops.h to architecture independent code in minix filesystem, this provides two config options. CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k. CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu, m32r, mips, sh, xtensa). The architectures which always use little-endian bitmaps do not select these options. Finally, we can remove minix bit operations from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce little-endian bitops for most architecturesAkinobu Mita
Introduce little-endian bit operations to the big-endian architectures which do not have native little-endian bit operations and the little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300, ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa) These architectures can just include generic implementation (asm-generic/bitops/le.h). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: NUMA aware alloc_thread_info_node()Eric Dumazet
Add a node parameter to alloc_thread_info(), and change its name to alloc_thread_info_node() This change is needed to allow NUMA aware kthread_create_on_cpu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22sh: Conver to asm-generic/sizes.h.Paul Mundt
A trivial conversion for the most part. EDOSK7760 is special, but uses a non-power-of-2-aligned size, so just drop the SZ_xx helper and open-code it for the sake of simplicity. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22sh: wire up sys_syncfs.Paul Mundt
2011-03-17sh: Wire up new fhandle and clock_adjtime syscalls.Paul Mundt
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-15Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rtmutex: tester: Remove the remaining BKL leftovers lockdep/timers: Explain in detail the locking problems del_timer_sync() may cause rtmutex: Simplify PI algorithm and make highest prio task get lock rwsem: Remove redundant asmregparm annotation rwsem: Move duplicate function prototypes to linux/rwsem.h rwsem: Unify the duplicate rwsem_is_locked() inlines rwsem: Move duplicate init macros and functions to linux/rwsem.h rwsem: Move duplicate struct rwsem declaration to linux/rwsem.h x86: Cleanup rwsem_count_t typedef rwsem: Cleanup includes locking: Remove deprecated lock initializers cred: Replace deprecated spinlock initialization kthread: Replace deprecated spinlock initialization xtensa: Replace deprecated spinlock initialization um: Replace deprecated spinlock initialization sparc: Replace deprecated spinlock initialization mips: Replace deprecated spinlock initialization cris: Replace deprecated spinlock initialization alpha: Replace deprecated spinlock initialization rtmutex-tester: Remove BKL tests
2011-03-14net: sh_eth: add set_mdio_gate in bb_infoYoshihiro Shimoda
The SH7757's ETHER and GETHER use common MDIO pin. The MDIO pin is selected by specific register. So this patch adds new interface in bb_info, and when the sh_eth driver use the mdio, the register can be changed by the function. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14net: sh_eth: modify the PHY_INTERFACE_MODEYoshihiro Shimoda
The previous code had hardcoded the PHY_INTERFACE_MODE_MII of phy_connect. So some Gigabit PHYs will not behave correctly. The patch adds the phy_interface in sh_eth_plat_data, so we can select the phy interface. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14net: sh_eth: modify the definitions of registerYoshihiro Shimoda
The previous code cannot handle the ETHER and GETHER both as same time because the definitions of register was hardcoded. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-11futex: Sanitize futex ops argument typesMichel Lespinasse
Change futex_atomic_op_inuser and futex_atomic_cmpxchg_inatomic prototypes to use u32 types for the futex as this is the data type the futex core code uses all over the place. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Darren Hart <darren@dvhart.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110311025058.GD26122@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-11futex: Sanitize cmpxchg_futex_value_locked APIMichel Lespinasse
The cmpxchg_futex_value_locked API was funny in that it returned either the original, user-exposed futex value OR an error code such as -EFAULT. This was confusing at best, and could be a source of livelocks in places that retry the cmpxchg_futex_value_locked after trying to fix the issue by running fault_in_user_writeable(). This change makes the cmpxchg_futex_value_locked API more similar to the get_futex_value_locked one, returning an error code and updating the original value through a reference argument. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile] Acked-by: Tony Luck <tony.luck@intel.com> [ia64] Acked-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Michal Simek <monstr@monstr.eu> [microblaze] Acked-by: David Howells <dhowells@redhat.com> [frv] Cc: Darren Hart <darren@dvhart.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110311024851.GC26122@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-17tty: add TIOCVHANGUP to allow clean tty shutdown of all ttysKay Sievers
This is useful for system management software so that it can kick off things like gettys and everything that's started from a tty, before we reuse it from/for something else or shut it down. Without this ioctl it would have to temporarily become the owner of the tty, then call vhangup() and then give it up again. Cc: Lennart Poettering <lennart@poettering.net> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-15sh: Change __nosave_XXX symbols to longFrancesco Virlinzi
This patch changes the: - __nosave_begin - __nosave_end symbols from 'void' to 'long' as required by the latest Gcc (4.5.2) which raises the compilation error: cc1: warnings being treated as errors arch/sh/kernel/swsusp.c: In function 'pfn_is_nosave': arch/sh/kernel/swsusp.c:24:28: error: taking address of expression of type 'void' arch/sh/kernel/swsusp.c:25:26: error: taking address of expression of type 'void' arch/sh/kernel/swsusp.c:25:26: error: taking address of expression of type 'void' arch/sh/kernel/swsusp.c:25:26: error: taking address of expression of type 'void' Signed-off-by: Francesco Virlinzi <francesco.virlinzi@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-31Merge branch 'tip/rtmutex' of ↵Thomas Gleixner
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into core/locking *git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace tip/rtmutex: rtmutex: Simplify PI algorithm and make highest prio task get lock
2011-01-27rwsem: Move duplicate function prototypes to linux/rwsem.hThomas Gleixner
All architecture specific rwsem headers carry the same function prototypes. Just x86 adds asmregparm, which is an empty define on all other architectures. S390 has a stale rwsem_downgrade_write() prototype. Remove the duplicates and add the prototypes to linux/rwsem.h Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.970840140@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-27rwsem: Unify the duplicate rwsem_is_locked() inlinesThomas Gleixner
Instead of having the same implementation in each architecture, move it to linux/rwsem.h and remove the duplicates. It's unlikely that an arch will ever implement something different, but we can deal with that when it happens. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Matt Turner <mattst88@gmail.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.876773757@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-27rwsem: Move duplicate init macros and functions to linux/rwsem.hThomas Gleixner
The rwsem initializers and related macros and functions are mostly the same. Some of them lack the lockdep initializer, but having it in place does not matter for architectures which do not support lockdep. powerpc, sparc, x86: No functional change sh, s390: Removes the duplicate init_rwsem (inline and #define) alpha, ia64, xtensa: Use the lockdep capable init function in lib/rwsem.c which is just uninlining the init function for the LOCKDEP=n case Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Matt Turner <mattst88@gmail.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.771812729@linutronix.de>
2011-01-27rwsem: Move duplicate struct rwsem declaration to linux/rwsem.hThomas Gleixner
The difference between these declarations is the data type of the count member and the lack of lockdep in some architectures/ long is equivivalent to signed long and the #ifdef guarded dep_map member does not hurt anyone. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Matt Turner <mattst88@gmail.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.679641914@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-27rwsem: Cleanup includesThomas Gleixner
All rwsem implementations include the same headers. Include them from include/linux/rwsem.h Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Matt Turner <mattst88@gmail.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.483520950@linutronix.de>
